龙人旗下深圳市龙芯世纪科技有限公司
  • EMI滤波器和信号调节
  • 发布时间:2013/3/18 10:19:42   修改时间:2013/3/18 10:19:42 浏览次数:2103
  • RF前端用IPD
    RF前端用IPD
    型号 概述
    BAL-2593D5U 50 / 50+j50 Balun transformer for 2.45 GHz ISM band
    BAL-2690D3U 50 / 30+j25 Balun transformer for 2.45 GHz ISM band
    CPL-WB-00C2 Wide band directional coupler with ISO port
    CPL-WB-00D3 Wide band directional coupler with ISO port
    CPL-WB-01C2 Wide band directional coupler with ISO port
    CPL-WB-01D3 Wide-band directional coupler with ISO port
    CPL-WB-02D3 Wide-band, directional coupler with integrated 50 ohm loaded isolated port
    DCPL-WB-00C2 Wide-band, dual-path directional coupler with ISO port
    DCPL-WB-00D3 Wide band dual path directional coupler with ISO port
    DCPL-WB-02D3 Wide-band, dual-path directional coupler with integrated 50 ohm loaded isolated port
    DIP1524-01D3 GPS/GLONASS and 2.4 GHz diplexer
    DIP2450-01D3 2 G / 5 G WLAN diplexer
    EMI滤波和ESD保护器件
    EMI滤波和ESD保护器件
    型号 概述
    ECMF02-2AMX6 Common-mode filter and ESD protection for USB 2.0 and MIPI/MDDI interfaces
    ECMF02-2BF3 Dual line IPAD?, common mode filter with ESD protection for high speed serial interface
    ECMF04-4AMX12 Common-mode filter and ESD protection for MIPI D-PHY and MDDI interfaces
    ECMF06-6AM16 Common mode filter with ESD protection for MIPI D-PHY and MDDI interface
    EMIF01-10005 2-line EMI filter and ESD protection
    EMIF01-1003M3 Single-line EMI filter and ESD protection
    EMIF01-SMIC01F2 Single-line EMI filter and ESD protection for microphones
    EMIF01-TV01F3 Single-line EMI filter and ESD protection for TV analog outputs
    EMIF01-TV02F3 Single-line EMI filter and ESD protection for TV analog outputs
    EMIF02-1003M6 2-line EMI filter and ESD protection
    EMIF02-AV01F3 2-line EMI filter and ESD protection for audio and video interfaces
    EMIF02-MIC02F2 2-line EMI filter and ESD protection for microphones
    EMIF02-MIC02F3 2-line EMI filter and ESD protection for microphones
    EMIF02-MIC03F2 2-line EMI filter and ESD protection for microphones
    EMIF02-MIC03M6 2-line EMI filter and ESD protection for microphones
    EMIF02-MIC06F3 2-line EMI filter and ESD protection for microphones
    EMIF02-MIC07F3 EMI filter and ESD protection for microphones
    EMIF02-SPK01C2 2-line EMI filter and ESD protection for speakers
    EMIF02-SPK01F2 2-line EMI filter and ESD protection for speakers
    EMIF02-SPK01M6 2-line EMI filter and ESD protection for speakers
    EMIF02-SPK02F2 2-line IPAD? EMIF filter and ESD protection
    EMIF02-USB01F2 2-line EMI filter and ESD protection with R pull-up for USB interfaces
    EMIF02-USB03F2 2-line EMI filter and ESD protection with R pull-up for USB interfaces
    EMIF02-USB04F3 3-line EMI filter and ESD protection for USB interfaces
    EMIF02-USB05F2 2-line EMI filter and ESD protection with R pull-up, for USB interfaces
    EMIF03-SIM01F2 3-line EMI filter and ESD protection for SIM card interfaces
    EMIF03-SIM02C2 3-line EMI filter and ESD protection for SIM card interfaces
    EMIF03-SIM02F2 3-line EMI filter and ESD protection for SIM card interfaces
    EMIF03-SIM02F3 3-line EMI filter and ESD protection for SIM card interfaces
    EMIF03-SIM02M8 3-line EMI filter and ESD protection for SIM card interfaces
    EMIF03-SIM03F3 3-line EMI filter and ESD protection for SIM card interfaces
    EMIF03-SIM04F3 3-line EMI filter and ESD protection for SIM card interfaces
    EMIF04-1005M8 4-line low capacitance EMI filter and ESD protection
    EMIF04-1502M8 4-line low capacitance EMI filter and ESD protection
    EMIF04-EAR02M8 2-line EMI filter for earphones + 2-line EMI filter for microphones
    EMIF04-VID01F2 4-line EMI filter and ESD protection
    EMIF06-10006C2 6-line EMI filter and ESD protection
    EMIF06-10006F2 6-line EMI filter and ESD protection
    EMIF06-1002F2 6-line EMI filter and ESD protection
    EMIF06-1005M12 6-line low capacitance EMI filter and ESD protection
    EMIF06-1005N12 6-line low capacitance EMI filter and ESD protection
    EMIF06-1502M12 6-line low capacitance EMI filter and ESD protection
    EMIF06-AUD01F2 6-line EMI filter and ESD protection for audio interfaces
    EMIF06-HMC01F2 6-line EMI filter and ESD protection for mini and micro SD card interfaces
    EMIF06-MSD02N16 6-line EMI filter and ESD protection for T-Flash and micro SD card interfaces
    EMIF06-MSD03F3 6-line low capacitance IPAD? for micro-SD card with EMI filtering and ESD protection
    EMIF06-MSD04F3 6-line EMI filter and ESD protection for mini and micro SD card interfaces
    EMIF06-SD02F3 6-line EMI filter and ESD protection for mini and micro SD card interfaces
    EMIF06-SD03F3 6-line EMI filter and ESD protection for mini and micro SD card interfaces
    EMIF06-VID01C2 6-line EMI filter and ESD protection for display interfaces
    EMIF06-VID01F2 6-line EMI filter and ESD protection for display interfaces
    EMIF06-mSD01F2 6-line EMI filter and ESD protection for mini and micro SD card interfaces
    EMIF06-mSD02C3 6-line EMI filter and ESD protection for mini and micro SD card interfaces
    EMIF07-LCD02F3 7-line EMI filter ans ESD protection for display interfaces
    EMIF07-LCD03F3 7-line EMI filter and ESD protection for display interfaces
    EMIF08-1005M16 8-line low capacitance EMI filter and ESD protection
    EMIF08-1502M16 8-line low capacitance EMI filter and ESD protection
    EMIF08-LCD04M16 8-line L-C EMI filter and ESD protection for display interfaces
    EMIF08-VID01F2 8-line EMI filter and ESD protection for display interfaces
    EMIF09-SD01F3 9-line EMI filter and ESD protection for mini and micro SD card interfaces
    EMIF10-1K010F2 10-line EMI filter and ESD protection for keypads
    EMIF10-COM01C2 10-line EMI filter and ESD protection for display interfaces
    EMIF10-COM01F2 10-line EMI filter and ESD protection for display interfaces
    EMIF10-LCD01C2 10-line EMI filter and ESD protection for for display interfaces
    EMIF10-LCD02F3 10-line EMI filter and ESD protection for display interfaces
    EMIF10-LCD03F3 10-line EMI filter and ESD protection for display interfaces
    HDMI05-CL01F3 5-line signal conditioning and ESD protection for HDMI interfaces
    HDMI05-CL02F3 5-line signal conditioning and ESD protection for HDMI interfaces
    HDMI2C1-5DIJ Signal conditioning and ESD protection for HDMI control line interfaces
    KBMF 2-line EMI filter and ESD protection with Termination and R pull-up for keyboards
    ST1284 17-line EMI filter and ESD protection with Termination and R pull-up for ST1284 interfaces
    USBDF 2-line EMI filter and ESD protection with R pull-up, for USB interfaces
    USBUF 2-line EMI filter and ESD protection with R pull-up, for USB interfaces
    USBUF01P6 2-line EMI fiter and ESD protection with R pull-up for USB interfaces
    Antenna Tuners
    Antenna Tuners
    型号 概述
    STHVDAC-303 High voltage BST capacitance controller
    STHVDAC-304M High voltage BST capacitance controller
    STPTIC BST tunable integrated RF capacitor
    STRAFT-P98L15 Antenna tuner for cellular application
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
