龙人旗下深圳市龙芯世纪科技有限公司
  • 音频芯片评估板
  • 发布时间:2013/3/18 10:22:56   修改时间:2013/3/18 10:23:25 浏览次数:6345
  • 音频芯片评估板
    音频芯片评估板
    型号 概述
    ANT1-M24LR-A 45 mm x 75 mm antenna reference board for M24LR64-R
    ANT1-M24LR16E 45 mm x 75 mm antenna reference board for M24LR16E-R
    ANT2-M24LR-A 20 mm x 40 mm antenna reference board for M24LR64-R
    ANT2-M24LR16E 20 mm x 40 mm antenna reference board for M24LR16E-R
    ANT3-M24LR-A SMD-inductor based antenna reference board for M24LR64-R
    ANT4-M24LR-A Multi-bank reference antenna board for M24LR64-R
    ANT5-M24LR-A Multi-bank reference antenna board for M24LR64-R
    ANT7-M24LR16E 15 mm x 15 mm double layer antenna reference board for the M24LR16E-R Dual Interface EEPROM
    DATALOG-M24LR-A M24LR64-R datalogger reference board
    DEMO-CR95HF-A Demonstration board for CR95HF
    DEMOKIT-M24LR-A Demonstration kit for M24LRxx-R
    DEMOTS488 Evaluation board for the TS488 stereo headphone driver
    DEMOTS489 Evaluation board for the TS489 stereo headphone driver
    DEMOTS4909 -
    DEMOTS4995 Evaluation board for the TS4995 stereo speaker driver
    DEVKIT-M24LR-A Development kit for M24LRxx-R
    EVALSP1340CPU SPEAr1340 CPU evaluation board
    EVALSP320SCPU SPEAr320S CPU evaluation board
    EVALSP320SHMI SPEAr320S HMI evaluation board
    EVALSP320SPLC SPEAr320S evaluation kit for PLC applications, including CPU board
    EVALSPEAr300 SPEAr300 evaluation board
    EVALSPEAr310 SPEAr310 evaluation board
    EVALSPEAr320CPU SPEAr320 CPU evaluation board
    EVALSPEAr320HMI SPEAr320 evaluation board for HMI applications
    EVALSPEAr320PLC SPEAr320 evaluation board for PLC applications
    EVALSPEAr600 SPEAr600 evaluation board
    FLEX-M24LR04E 45 mm x 75 mm flexible antenna reference board for M24LR04E-R Dual Interface EEPROM
    M24LR-DISCOVERY Discovery kit for M24LR04E Dual Interface EEPROM with energy harvesting
    PLUG-CR95HF-B Development board for CR95HF
    ROBOT-M24LR16E-A Demonstration board for M24LR16E-R
    ST622XC-KIT Starter kit with preprogrammed device to demonstrate ST622X capabilities.
    SPC560B64A100S Daughter/adapter board for SPC560 series devices in QFP100 package
    SPC560BADPT144S Daughter/adapter board for SPC560 series 512KB/1.5MB devices in QFP144 package
    SPC560BADPT176S Daughter/adapter board for SPC560 series 512KB/1.5MB devices in QFP176 package
    SPC560PADPT100S Daughter/adapter board for SPC560 series 512KB/1MB devices in QFP100 package
    SPC560PADPT144S Daughter/adapter board for SPC560 series 512KB/1MB devices in QFP144 package
    SPC563M64AVB176 Vertical base board for SPC563M (Monaco) series devices in QFP176
    SPC563M64CAL144 Calibration system for SPC563M (Monaco) series 1M5 devices in QFP144
    SPC563M64CAL176 Calibration system for SPC563M (Monaco) series 1M5 for QFP176
    SPC563MADPT144S Daughter/adapter board for SPC563 series devices in QFP144 package
    SPC563MADPT176S Daughter/adapter board for SPC563 series devices in QFP144 package
    SPC564A70CAL176 Calibration system for SPC564A series devices (Andorra 2) MB devices
    SPC564A80CAL176 Calibration system for SPC564A (Andorra) series 4 MB devices in QFP176
    SPC564AADPT324S Daughter/adapter board for SPC564 series devices in BGA324 package
    SPC56ELADPT144S Daughter/adapter board for SPC56EL series devices in LQFP144 package
    SPC56XXMB Evaluation motherboard for SPC56 series microcontrollers
    ST7-D/RAIS ST7 MCU daughter board for use with Raisonance REva starter kits
    ST7-SK/RAIS Raisonance REva starter kit for STM7 MCUs, includes RLink
    ST7232X-EVAL Evaluation board for ST72F321/521 with ICC connector for programming capability.
    ST7DALI-EVAL Demonstration board for ST7 DALI (Digital Addressable Lighting Interface) with 1 master board, 2 slave boards, ST7DALI slave sof
    ST7MC-KIT/BLDC Motor control evaluation and development kit for the ST7MC. Includes firmware, GUI, ST7MC samples, a 12VDC-240VAC 1000W inverter
    ST7MDT10-TEB Target emulation board to adapt any ST7-EMU3 series emulator to emulate a specific ST7 or ST7 sub-family. Includes all package s
    ST7MDT20-TEB/DVP Target emulation board to adapt any ST7-DVP3 series emulator to emulate a specific ST7 or ST7 sub-family. Package specific conne
    ST7MDT20J-TEB Target emulation board to adapt any ST7-EMU3 series emulator to emulate a specific ST7 or ST7 sub-family. Includes all package s
    ST7MDT20M-TEB Target emulation board to adapt any ST7-EMU3 series emulator to emulate a specific ST7 or ST7 sub-family. Includes all package s
    STEVAL-CCA003V1 Low voltage audio power stereo amplifier based on TS4984IQT
    STEVAL-CCA005V1 Evaluation board for the TSH173 triple video buffer with filter
    STEVAL-CCA007V1 Demonstration board for the TS2012 filter-free stereo 2x2.8W class D audio power amplifier
    STEVAL-CCA009V1 High performance stereo headphone driver based on TS4601
    STEVAL-CCA010V1 Demonstration board for video buffer plus filter with SAG correction based on the TSH122
    STEVAL-CCA011V1 Filter-free stereo 2x2.5 W Class-D audio power amplifier demonstration board based on the TS2012FC
    STEVAL-CCA012V1 3 W filter-free class-D audio amplifier demonstration board with 6-12 dB fixed gain select based on the TS2007
    STEVAL-CCA014V1 Triple video buffer with filter for HD demonstration board based on the TSH345
    STEVAL-CCA015V1 Triple video buffer with filter for HD demonstration board based on the TSH346
    STEVAL-CCA016V1 Filter-free stereo 2.8 W Class-D audio power amplifier demo board with selectable 3D sound effects based on the TS4999
    STEVAL-CCA018V1 Single-supply stereo digital audio line driver based on the TS4657
    STEVAL-CCA019V1 2 W stereo audio power amplifier based on the TS4982
    STEVAL-CCA021V1 USB audio demonstration board based on the STM32F103RE and TS4657
    STEVAL-CCA022V1 Demonstration board for single op-amps in SC70 or SOT-23 packages
    STEVAL-CCA023V1 Demonstration board for low noise microphone preamplifier with 2 V bias based on the TS472
    STEVAL-CCA025V1 Class G capless headphone amplifier based on TS4621E
    STEVAL-CCA027V1 50 W+50 W dual BTL class-D audio amplifier demonstration board based on TDA7492
    STEVAL-CCA028V1 10 W + 10 W class-D audio amplifier demonstration board based on the TDA7491P
    STEVAL-CCA029V1 5 W + 5 W class-D audio amplifier demonstration board based on the TDA7491LP
    STEVAL-CCA030V1 STA350BW Sound Terminal? 2.1-channel high-efficiency digital audio system board
    STEVAL-CCA035V1 APWLink USB interface board based on the STA120D
    STEVAL-CCA037V1 Amplifier based on the TS4990IQT
    STEVAL-CCA038V1 Low-voltage audio power amplifier based on the TS4871IQT
    STEVAL-CCA042V1 20 W + 20 W dual BTL class-D audio amplifier demonstration board based on the TDA7491HV
    STEVAL-CCA043V1 25 Watt mono BTL class-D audio amplifier demonstration board based on the TDA7491MV
    STEVAL-CCA048V1 STA333ML Sound Terminal? 2-channel microless high efficiency digital audio system board
    STEVAL-CCA049V1 STA335ML Sound Terminal? 2-channel microless high efficiency digital audio system board
    STEVAL-ICB002V1 Capacitive touch daughterboard based on the STMPE821
    STEVAL-ICB003V1 Smart touchpanel interface based on the STMPE1208S, STLED316S and STM8S
    STEVAL-ICB004V1 Advanced resistive touchscreen controller demonstration board based on the STMPE811
    STEVAL-ICB007V1 Capacitive touch demonstration board based on STMPE321
    STEVAL-ICB008V1 Touch-sensing software library demonstration board based on the STM8S
    STEVAL-ICB010V1 AirNavigationPad based on the STM8T143, STM32F103
    STEVAL-MKI004V1 MEMS 3-axis - ±2g/±6g digital output low voltage linear accelerometer evaluation board based on LIS3LV02DQ
    STEVAL-MKI005V1 MEMS 3-axis ±2g/±6g digital output low voltage linear accelerometer evaluation board based on the LIS3LV02DL
    STEVAL-MKI006V1 MEMS 3-axis - ±2g/±8g digital output low power linear accelerometer evaluation board based on LIS302DL
    STEVAL-MKI009V1 LIS3LV02DL adapter board designed to be plugged into a standard DIL 20 socket
    STEVAL-MKI013V1 Standard DIL 24 socket-compatible adapter board for testing the LIS302DL
    STEVAL-MKI014V1 MEMS 3-axis ±2g/±6g analog-output demonstration board based on the LIS344ALH
    STEVAL-MKI015V1 Adapter board for the LIS344ALH
    STEVAL-MKI019V1 MEMS 3-Axis ±2g analog output demonstration board based on LIS302SG
    STEVAL-MKI021V1 MEMS 3-axis ±2g analog output demonstration board based on the nano accelerometer LIS331AL
    STEVAL-MKI022V1 MEMS 3-axis ±2g /±4g /±8g smart digital output evaluation board based on nano accelerometer LIS331DLH
    STEVAL-MKI024V1 MEMS 3-axis ±2g /±8g smart digital output demonstration board based on the "nano" accelerometer LIS331DL
    STEVAL-MKI029V1 Inclination analysis demonstration board based on the STM8S207R6 MCU and LIS331DLH MEMS
    STEVAL-MKI031V1 Multi sensor application (MuSA) board platform
    STEVAL-MKI032V1 Interconnection board for connecting STM32xxx and MEMS demonstration boards
    STEVAL-MKI042V1 LPR503AL adapter board for standard DIL24 socket
    STEVAL-MKI043V1 LPR510AL adapter board for standard DIL24 socket
    STEVAL-MKI044V1 LPR530AL adapter board designed to be plugged into a standard DIL24 socket
    STEVAL-MKI064V1 LSM303DLH adapter demonstration board for a standard DIL24 socket
    STEVAL-MKI071V1 MEMS demonstration board based on the LY330ALH analog output single-axis gyroscope
    STEVAL-MKI072V1 MEMS demonstration board based on LY3100ALH (analog output single-axis gyroscope)
    STEVAL-MKI073V1 MEMS demonstration board based on the LY3200ALH analog output single-axis gyroscope
    STEVAL-MKI074V1 LY330ALH adapter board for standard DIL 24 socket
    STEVAL-MKI075V1 LY3100ALH adapter board designed for a standard DIL24 socket
    STEVAL-MKI076V1 LY3200ALH adapter board for standard DIL 24 socket
    STEVAL-MKI077V1 MEMS: demonstration board based on the LPR4150AL (analog output two axis gyroscope)
    STEVAL-MKI078V1 MEMS demonstration board based on the LPR450AL analog output dual-axis gyroscope
    STEVAL-MKI079V1 MEMS demonstration board based on the LPR430AL (analog output two-axis gyroscope)
    STEVAL-MKI080V1 MEMS demonstration board based on LPR410AL (analog output two axis gyroscope)
    STEVAL-MKI081V1 MEMS demonstration board based on LPR403AL (analog output two-axis gyroscope)
    STEVAL-MKI082V1 LPY4150AL adapter board for standard DIL 24 socket
    STEVAL-MKI083V1 LPY450AL adapter board for standard DIL 24 socket
    STEVAL-MKI084V1 LPY430AL adapter board designed to be plugged into a standard DIL24 socket
    STEVAL-MKI085V1 LPY410AL adapter board for standard DIL 24 socket
    STEVAL-MKI086V1 LPY403AL adapter board for standard DIL 24 socket
    STEVAL-MKI087V1 LIS331DL adapter board for standard DIL 24 socket
    STEVAL-MKI088V1 LIS33DE adapter board for standard DIL 24 socket
    STEVAL-MKI089V1 LIS331DLH adapter board for standard DIL 24 socket
    STEVAL-MKI090V1 LIS331DLF adapter board for standard DIL 24 socket
    STEVAL-MKI091V1 LIS331DLM adapter board for standard DIL 24 socket
    STEVAL-MKI092V1 LIS331HH adapter board for standard DIL 24 socket
    STEVAL-MKI095V1 LPR4150AL adapter board for standard DIL 24 socket
    STEVAL-MKI096V1 LPR450AL adapter board for standard DIL 24 socket
    STEVAL-MKI097V1 LPR430AL adapter board designed to be plugged into a standard DIL24 socket
    STEVAL-MKI098V1 LPR410AL adapter demonstration board for a standard DIL24 socket
    STEVAL-MKI099V1 LPR403AL adapter board for standard DIL 24 socket
    STEVAL-MKI100V1 MEMS demonstration board based on LPY4150AL (dual-axis pitch and yaw ±1500 dps analog gyroscope)
    STEVAL-MKI101V1 MEMS demonstration board based on LPY450AL (dual-axis pitch and yaw ±500 dps analog gyroscope)
    STEVAL-MKI102V1 MEMS demonstration board based on the LPY430AL (dual-axis pitch and yaw ±300 dps analog gyroscope)
    STEVAL-MKI103V1 MEMS demonstration board based on the LPY410AL (dual-axis pitch and yaw ±100 dps analog gyroscope)
    STEVAL-MKI104V1 MEMS demonstration board based on LPY403AL (dual-axis pitch and yaw ±30 dps analog gyroscope)
    STEVAL-MKI105V1 LIS3DH adapter board for standard DIL 24 socket
    STEVAL-MKI106V1 LSM303DLHC adapter board designed to be plugged into a standard DIL24 socket
    STEVAL-MKI107V1 L3G4200D adapter board for a standard DIL 24 socket
    STEVAL-MKI107V2 L3GD20 adapter board for a standard DIL 24 socket
    STEVAL-MKI108V1 L3G4200D and LSM303DLHC 9 axis module for a standard DIL24 socket
    STEVAL-MKI108V2 L3GD20 and LSM303DLHC 9 axis module for a standard DIL24 socket
    STEVAL-MKI109V2 eMotion: ST MEMS adapters motherboard based on STM32. Compatible with all ST MEMS adapters based on STM32F103
    STEVAL-MKI110V1 AIS328DQ adapter board for standard DIL24 socket
    STEVAL-MKI113V1 LSM303DLM adapter board for standard DIL24 socket
    STEVAL-MKI114V1 Magnetic field probe kit based on the LSM303DLHC
    STEVAL-MKI115V1 Bluetooth extension demonstration board for STEVAL-MKI109V1
    STEVAL-MKI116V1 MEMS microphone demonstration board based on the MP34DB01 and STM32
    STEVAL-MKI117V1 MEMS microphone demonstration board based on the MP34DT01 and STM32
    STEVAL-MKI117V2 MEMS microphone demonstration board based on the MP45DT02 and STM32
    STEVAL-MKI119V1 eMotion Win8: STEVAL-MKI109V2 + STEVAL-MKI108V2
    STEVAL-MKI120V1 LPS331AP adapter board for standard DIL24 socket
    STEVAL-MKI122V1 LSM330DLC adapter board for standard DIL24 socket
    STEVAL-MKI123V1 LSM330D adapter board for standard DIL24 socket
    STEVAL-MKI124V1 L3GD20, LSM303DLHC and LPS331AP 10-axis module designed to be plugged into a standard DIL 24 socket
    STEVAL-MKI126V1 STSmartVoice demonstration board
    STEVAL-MKI126V3 STSmartVoice demonstration board
    STEVAL-MKI127V1 Ultra stable 3-axis gyro based on the L3GD20
    STEVAL-TDR001V1 4 W / 380 - 512 MHz reference design using PD84001 + PD54003L-E + LPF
    STEVAL-TDR003V1 5 W / 135 - 175 MHz reference design using PD84001 + PD54008L-E + LPF
    STEVAL-TDR004V1 400 W / 1.6 - 54 MHz reference design using 2x SD2933
    STEVAL-TDR005V1 450 W / 1.8-54 MHz reference design based on 2xSD2943
    STEVAL-TDR006V1 4 W / 400 - 470 MHz reference design using PD84001 + PD84008L-E + LPF
    STEVAL-TDR007V1 200 W / 1030 MHz IFF Mode-S reference design using PD57002-E, PD57018-E and 2x PD57060-E
    STEVAL-TDR009V1 650 W / 88 - 108 MHz reference design using 2x SD2932
    STEVAL-TDR010V1 700 W / 88 - 108 MHz reference design using 2x SD2942
    STEVAL-TDR011V1 50 W / 400 - 470 MHz reference design using PD85006L-E + 2x PD85035S-E + LPF
    STEVAL-TDR013V1 2 W / 860 - 960 MHz evaluation board based on PD84002
    STEVAL-TDR014V1 8W / 400 - 500 MHz evaluation board based on PD55008-E
    STEVAL-TDR015V1 8 W / 400 - 470 MHz evaluation board based on PD54008L-E
    STEVAL-TDR016V1 30 W, 155 - 165 MHz evaluation board based on PD55015-E
    STEVAL-TDR017V1 1 W / 860 - 960 MHz evaluation board based on PD84001
    STEVAL-TDR019V1 4 W / 860 - 960 MHz evaluation board based on PD85004
    STEVAL-TDR020V1 4 W, 740 - 950 MHz evaluation board based on PD84006L-E
    STEVAL-TDR021V1 5 W, 740 - 950 MHz evaluation board based on PD84008L-E
    STEVAL-TDR022V1 10 W, 340 - 520 MHz evaluation board based on PD85025-E
    STEVAL-TDR023V1 20 W, 460 - 540 MHz evaluation board based on PD55025-E
    STEVAL-TDR025V1 1 W, 380 - 520 MHz evaluation board based on PD84001
    STEVAL-TDR027V1 6 W / 380 - 512 MHz evaluation board based on the PD84008L-E
    STEVAL-TDR028V1 350 W - 48 V demoboard using 1x STAC2942B for FM broadcast application (VHF amplifier 87.5 - 108 MHz)
    STEVAL-TDR029V1 700 W - 48 V demoboard using 2x STAC2942B for FM broadcast application (VHF amplifier 87.5 - 108 MHz)
    STM32-COMSTICK Low-cost evaluation and development kit from Hitex for STM32 (256KB flash) Connectivity Line MCUs
    STM32-D/RAIS STM32 MCU daughter board for use with Raisonance REva starter kits
    STM32-PRIMER Complete Primer ready to use from Raisonance for easy evaluation and development with STM32 MCUs
    STM32-SK/HIT Hitex starter kit for STM32 (128KB Flash) Performance and Access Line MCUs; includes PerformanceStick and extension I/O board; Hitex starter kit for STM32 (512KB Flash) Performance and Access Line MCUs; includes PerfStick-2 and LCD extension board
    STM32-SK/RAIS Raisonance REva starter kit for STM32 MCUs, includes RLink
    STM320518-EVAL Evaluation board for STM32 F0 series - with STM32F051 MCU
    STM320518-SK/IAR IAR starter kit for STM32 F0 series microcontrollers (STM32F051R8 MCU)
    STM32100B-EVAL Evaluation board for STM32F100 (128KB Flash) MCUs - embeds ST-LINK
    STM32100B-MCKIT Motor control starter kit for STM32F100 (128KB Flash) Value Line MCUs
    STM32100E-EVAL Evaluation board for STM32F100 (512KB Flash) Value Line MCUs
    STM3210B-EVAL Evaluation board for STM32F (128KB Flash) MCUs; it is replaced by STM3210E-EVAL
    STM3210B-MCKIT Motor control starter kit for STM32 (128KB flash) Performance and Access Line microcontrollers
    STM3210B-PFSTICK Hitex Performance Stick for STM32 (128KB Flash) Performance and Access Line MCUs
    STM3210C-EVAL Evaluation board for STM32 (256KB Flash) Connectivity Line MCUs
    STM3210C-SK/IAR IAR starter kit for STM32 (256KB flash) Connectivity Line MCUs, embeds J-Link
    STM3210C-SK/KEI Keil starter kit for STM32 (256KB flash) Connectivity Line MCUs, includes ULINK-ME
    STM3210E-EVAL Evaluation board for STM32 F1 series - with STM32F103 MCU
    STM3210E-SK/IAR IAR starter kit for STM32 (512KB Flash) Performance and Access Line MCUs, embeds J-Link
    STM3210E-SK/KEI Keil starter kit for STM32 (128KB Flash) Performance and Access Line MCUs, includes ULINK-ME
    STM3220G-EVAL Evaluation board for STM32 F-2 series
    STM3220G-SK/IAR IAR starter kit for STM32 F2 series 32-bit MCUs
    STM3220G-SK/KEI Keil starter kit for ST ARM core-based microcontrollers
    STM3221G-EVAL Evaluation board for STM32F21x MCUs
    STM32303C-EVAL Evaluation board for STM32 F3 series - with STM32F303 MCU
    STM32373C-EVAL Evaluation board for STM32 F3 series - with STM32F373 MCU
    STM3240G-EVAL Evaluation board for STM32 F4 series - with STM32F407 MCU
    STM3240G-SK/IAR IAR starter kit for STM32F4 series 32-bit microcontrollers
    STM3240G-SK/KEI Keil starter kit for ST ARM core-based microcontrollers
    STM3241G-EVAL Evaluation board for STM32 F4 series - with STM32F417 MCU
    STM32F0DISCOVERY Discovery kit for STM32 F0 series - with STM32F051 MCU
    STM32F3DISCOVERY Discovery kit for STM32 F3 series - with STM32F303 MCU
    STM32F4-NETMF Microsoft .NET Micro Framework platform for STM32 F4 series
    STM32F4DISCOVERY Discovery kit for STM32 F4 series - with STM32F407 MCU
    STM32L-DISCOVERY Discovery kit for the STM32L EnergyLite 32-bit MCUs
    STM32L152-EVAL Evaluation board for STM32L1 series - with STM32L152VB MCU
    STM32L152-SK/IAR IAR starter kit for STM32L EnergyLite 32-bit MCUs
    STM32L152D-EVAL Evaluation board for STM32L1 series - with STM32L152ZD MCU
    STM32VLDISCOVERY Discovery kit for the Value line STM32F100
    STM32W-EXT Extension boards for evaluation kit for STM32 Wireless devices
    STM32W-RFCKIT STM32W Low-cost RF control kit
    STM32W-SK Evaluation kit for STM32 Wireless devices
    STM8-D/RAIS STM8 MCU daughter board for use with Raisonance REva starter kits
    STM8-SK/RAIS Raisonance REva starter kit for STM8S MCUs, includes RLink
    STM8/128-EV/TS STM8S evaluation board with Touch Sensing solution evaluation
    STM8/128-EVAL Evaluation board for STM8S (128KB Flash) MCUs; with CAN, I2C, SPI and IrDA i/f
    STM8/128-MCKIT Motor control starter kit for STM8S (128KB flash) microcontrollers
    STM8A/128-EVAL Evaluation board for STM8A (128KB Flash) MCUs
    STM8L-DISCOVERY Discovery kit for the STM8L EnergyLite 8-bit MCUs
    STM8L-PRIMER Complete EvoPrimer ready to use from Raisonance for easy evaluation and development with STM8L MCUs
    STM8L101-EVAL Evaluation board for STM8L101 MCUs
    STM8L1526-EVAL Evaluation board for STM8L15x/16x (32KB flash) ErnergyLite 8-bit MCUs
    STM8L1528-EVAL Evaluation board for STM8L15x/16x (64KB flash) ErnergyLite 8-bit MCUs
    STM8L15LPBOARD Low Power demonstration board for STM8L15x (32KB flash) MCUs
    STM8S-DISCOVERY Discovery kit for the STM8S general-purpose 8-bit MCUs
    STM8SVLDISCOVERY STM8S Value line Discovery
    STM8T-MOD Module with STM8T141AM device
    STM8T141-EVAL STM8T141-EVAL evaluation kit
    STM8T143-EVAL Evaluation board for STM8T143 Touch sensing devices
    STMPRIMER EvoPrimer components to build your own EvoPrimer for easy evaluation and development with STM32 and STM8 MCUs
    STMT-BOX Evaluation platform for STMTouch
    STMT/8L-EV1 Touch sensing Library for STM8L - Evaluation board
    STR7-D/RAIS Daughter board for REva starter kit with STR730F device.; Daughter board for REva starter kit with STR750F device.
    STR7-SK/IAR IAR KickStart starter kit with STR711 evaluation board, USB-JTAG in-circuit debugger/programmer and 32-KB code-size limited ver; IAR KickStart starter kit with STR712 evaluation board, USB-JTAG in-circuit debugger/programmer and 32-KB code-size limited ver; IAR KickStart starter kit with STR731F evaluation board, USB-JTAG debugger and 32KB code-size limited version of IAR EWARM softw; IAR KickStart starter kit with evaluation board, STR7 microcontroller, USB-JTAG in-circuit debugger/programmer and 32-KB code-si
    STR7-SK/KEIL Keil starter kit with STR750F evaluation board, USB-JTAG debugger and evaluation version of RealView Microcontroller Development
    STR7-SK/RAIS Raisonance REva starter kit for STR71x with RLink in-circuit debugger/programmer (USB host interface), REva mother board, 2 daug; Raisonance REva starter kit for STR730 with RLink in-circuit debugger/programmer (USB host interface), REva mother board, STR730; Raisonance REva starter kit for STR75x with RLink in-circuit debugger/programmer (USB host interface), REva mother board, daught
    STR710-EVAL STR710 evaluation board with CAN, USB and RS232 interfaces, LCD, I2C EEPROM, 4MBytes EMI Flash and 4MBytes EMI SRAM
    STR750-EVAL STR750F evaluation board with 2x16 LCD, LEDs, UART and CAN interfaces.
    STR9-COMSTICK Low-cost evaluation and development tool package for STR9 includes STR9 evaluation hardware for Ethernet, USB and CAN connectivi
    STR9-D/RAIS Daughter board for REva starter kit with STR912F device.
    STR910-EVAL STR910F evaluation board with LCD, LEDs, UART, CAN, USB, Ethernet, Motor control connector, audio circuit (record and playback)
    STR91X-SK/HIT Hitex starter kit with STR912F evaluation board, USB-JTAG in-circuit debugger/programmer and 16KB code-size limited version of H
    STR91X-SK/IAR IAR KickStart starter kit with STR912F evaluation board, USB-JTAG debugger and 32KB code-size limited version of IAR EWARM softw
    STR91X-SK/KEI Keil starter kit with STR912F evaluation board, USB-JTAG debugger and evaluation version of RealView Microcontroller Development
    STR91X-SK/RAI Low-cost Raisonance REva starter kit for STR91xF with RLink in-circuit debugger/programmer (USB host interface), REva mother boa
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
