龙人旗下深圳市龙芯世纪科技有限公司
  • 逻辑、信号开关
  • 发布时间:2013/3/18 10:29:57   修改时间:2013/3/18 10:30:15 浏览次数:1979
  • 逻辑 Xpander
    逻辑 Xpander
    型号 概述
    STMPE1600 Low power
    STMPE1601 8x8 keypad, PWM
    STMPE1801 8x10 keypad, low power, low EMI, high ESD
    STMPE2401 8x12 keypad, PWM, wheel
    STMPE2403 8x12 keypad, PWM, wheel
    STMPE801 Wake-up feature on I/O
    开关 (NEATSwitch)
    开关 (NEATSwitch)
    型号 概述
    ST3DV520 High bandwidth analog switch with 16-to-8 bit MUX/DEMUX
    ST3DV520A High bandwidth switch with 20- to 10-bit MUX/DEMUX
    ST3DV520E MUX/DEMUX for 4 differential channel LVDS and DDC
    ST890 1.2 A current limited high side power switch with thermal shutdown
    STA1102R 3 Gbps, 2 differential-pair channel eSATA signal re-driver
    STDVE001A Adaptive single 3.4Gbps TMDS/HDMI signal equalizer
    STDVE003A Adaptive 3.4 Gbps 3:1 TMDS/HDMI signal equalizer
    STDVE103A Adaptive 3.4Gbps 3:1 TMDS/HDMI signal equalizer
    STG3155 Low Voltage 0.5 Ohm Max Single SPDT Switch with Break-Before-Make Feat.
    STG3157 Low Voltage Low On Resistance SPDT Switch with Break-Before-Make Feat.
    STG3220 Low Voltage High Bandwidth Dual SPDT Switch
    STG3482 Low Voltage Dual SP4T Switch with Break-Before-Make Feat.
    STG3682 Low Voltage High Bandwidth Dual SPDT Switch
    STG3684A Low Voltage 0.5 Ohm Max Dual SPDT Switch with Break-Before-Make Feat
    STG3692 Low Voltage High Bandwidth Quad SPDT
    STG3693 Low Voltage High Bandwidth Quad SPDT Switch
    STG3696E Low voltage dual SPDT switch for USB/audio signal switching
    STG3699 Low voltage 0.5 Ω max, quad SPDT switch with break-before-make feature
    STG3699A Low voltage 0.5 Ω max, quad SPDT switch with break-before-make feature
    STG3699B Low voltage 0.5 Ω max, quad SPDT switch with break-before-make feature
    STG3820 Low voltage high bandwidth quad DPDT switch
    STG3856 Low voltage 1.0Ω max dual SP3T switch with break-before-make feature
    STG4158 Low voltage 0.6 Ω typ single SPDT switch with break-before-make feature and 15 kV ESD protection
    STG4159 Low Voltage 0.3 Ohm Max Single SPDT Switch with Break-Before-Make Feature and 10kV Contact ESD Protection
    STG4160 Low voltage 0.5 Ohm single SPDT switch with break-before-make feature and 15 kV ESD protection
    STG4260 Low voltage 0.5 Ω dual SPDT switch with break-before-make feature and 15 kV ESD protection
    STG5123 Low voltage 1 Ω single SPDT switch with break-before-make feature
    STG5223 Low voltage 0.5 Ω dual SPDT switch with break-before-make
    STG5678 Low voltage dual SPDT switch with negative rail capability
    STG5682 Low voltage dual SPDT switch with negative rail capability
    STG719 Low voltage 4 Ohm SPDT switch
    STHDMI002A High bandwidth 2-to-1 HDMI switch with single enable, HPD and DDC lines switching
    STHV748 5-level, ±90 V, 2 A high speed pulser with four independent channels
    STMAV335 Low ON resistance triple, SP3T, wide-bandwidth video switch
    STMAV340 Low on resistance quad, SPDT, wide-bandwidth video switch
    STMPS2141 Enhanced single channel power switches
    STMPS2151 Enhanced single channel power switches
    STMPS2161 Enhanced single channel power switches
    STMPS2171 Enhanced single channel power switches
    STMPS2242 Enhanced dual channel power switches
    STMPS2252 Enhanced dual channel power switches
    STMPS2262 Enhanced dual channel power switches
    STMPS2272 Enhanced dual channel power switches
    STMUX1000L GIGABIT LAN ANALOG SWITCH 16-BIT TO 8-BIT MULTIPLEXER
    STMUX1800E 16-bit to 8-bit MUX/DEMUX for gigabit Ethernet LAN switch with LED switch and enhanced ESD protection
    STMUX1800L Gigabit LAN switch 16-bit to 8-bit multiplexer with enhanced ESD
    STMUX3040 Octal SPDT high bandwidth signal switch
    STMUX7000 7-channel MUX/DEMUX for analog video signal
    单/双栅
    单/双栅
    型号 概述
    74AUP1G04 Inverter gate
    74AUP1G125 Tristate buffer
    74AUP1G32 OR gate
    74H1G66 Single Bilateral Switch
    74LX1G00 Single 2-Input NAND Gate
    74LX1G04 Single Inverter
    74LX1G07 Single Buffer (Open Drain)
    74LX1G08 Single 2-Input AND Gate
    74LX1G132 Single 2-Input Schmitt NAND Gate
    74LX1G14 Single Schmitt Inverter
    74LX1G32 Low Voltage Single 2-Input OR Gate
    74LX1G70 Single Buffer
    74LX1G86 Single Exclusive OR Gate
    74LX1GU04 Single Inverter
    74LX3G07 Triple buffer (open drain)
    74V1G00 Single 2-Input NAND Gate
    74V1G02 Single 2-Input NOR Gate
    74V1G04 Single Inverter
    74V1G05 Single Inverter (open Drain)
    74V1G07 Single Buffer (Open Drain)
    74V1G08 Single 2-Input AND Gate
    74V1G125 Single Bus Buffer (3-State)
    74V1G126 Single Bus Buffer (3-State)
    74V1G14 Single Schmitt Inverter
    74V1G32 Single 2-Input OR Gate
    74V1G66 Single Bilateral Switch
    74V1G70 Single Buffer
    74V1G77 Single D-Type Latch
    74V1G79 Single Positive Edge Triggered D-Type Flip-Flop
    74V1G86 Single Exclusive OR Gate
    74V1GU04 Single Inverter (Single Stage)
    74V1T00 Single 2-Input NAND Gate
    74V1T02 Single 2-Input NOR Gate
    74V1T04 Single Inverter
    74V1T07 Single Buffer (Open Drain)
    74V1T08 Single 2-Input AND Gate
    74V1T125 Single Bus Buffer (3-State)
    74V1T126 Single Bus Buffer (3-State)
    74V1T14 Single Schmitt Inverter
    74V1T32 Single 2-Input OR Gate
    74V1T66 Single Bilateral Switch
    74V1T86 Single Exclusive OR Gate
    74V2G66 Dual Bilateral Switch
    电平转换器
    电平转换器
    型号 概述
    74VCX1632245 16-BIT DUAL SUPPLY BUS TRANSCEIVER LEVEL TRANSLATOR WITH A SIDE SERIES RESISTOR
    ST16C32245 14-bit dual supply bus transceiver level translator, A side series resistor 2-bit I2C lines
    ST1G3234 1-bit dual supply bus buffer level translator with A-side series resistor
    ST1G3234B 1-bit dual supply level translators with A-side series resistor
    ST1G3236 1-bit dual supply bus transceiver level translator with A-side series resistor
    ST2129 2-bit dual supply level translator without direction control pin
    ST2129B 2-bit dual supply level translator without direction control pin
    ST2149 4-bit dual supply level translator without direction control pin
    ST2149B 4-bit dual supply level translator without direction control pin
    ST2189 8-bit dual supply level translator without direction control pin
    ST2329 2-bit dual supply level translator without direction control pin
    ST2329A 2-bit level translator for I2C/SPI
    ST2329B 2-bit dual supply level translator without direction control pin, open drain output
    ST2329I 2-bit level translator for I2C/SPI with 10KOhm pull-up
    ST2349 4-bit dual supply level translator without direction control pin
    ST2349A 4-bit dual supply level translator without direction control pin
    ST2378E 8-Bit Level Translator with 15kV ESD Protection
    ST2G3236 2-bit dual supply bus transceiver level translator with a side series resistor
    ST4G3234 4-Bit Dual Supply Bus Buffer Level Translator with a side series resistor
    ST6G3238BE Dual Supply Level Translator for SD/ MINISD/ T-FLASH With ±8KV contact Discharge ESD Protection
    ST6G3244ME Level translator for SD, SDIO, mini SD, micro SD cards with internal I/O supply and 15kV ESD protection
    STHDLS101 2.7 Gbps DisplayPort/PCIe to HDMI/DVI signal converter
    STHDLS101A Enhanced 2.7 Gbps DisplayPort/PCIe to HDMI/DVI signal converter with configurable HPD output
    STHDLS101T 2.7 Gbps DisplayPort/PCIe to HDMI/DVI signal converter with configurable HPD output
    LED驱动器,前板控制器
    LED驱动器,前板控制器
    型号 概述
    STFPC311 Front panel controller/driver with standby
    STFPC320 Front panel controller/driver with standby power management and real-time clock
    STLED316S Serial-interfaced 6-digit LED controller with keyscan
    STLED325 I2C interfaced LED controller with standby and RTC
    STM86312 1/4 to 1/11-duty VFD controller/driver
    STP04CM05 4-bit constant current power-LED sink driver
    STP08CP05 Low-voltage, low current power 8-bit shift register
    STP08DP05 Low-voltage 8-bit constant current LED sink with full outputs error detection
    STP1612PW05 16-channel LED driver with 16-bit PWM, 8-bit gain and full LED error detection
    STP16CP05 Low-voltage 16-bit constant current LED sink driver
    STP16CPC05 Low voltage 16 - bit constant current LED sink driver
    STP16CPC26 Low voltage 16-bit constant current LED sink driver
    STP16CPP05 Low-voltage 16-bit constant current LED sink driver
    STP16CPPS05 Low voltage 16-bit constant current LED sink driver with auto power-saving
    STP16CPS05 Low-voltage 16-bit constant current LED sink driver with auto-power saving
    STP16DP05 Low-voltage 16-bit constant current LED sink driver with outputs error detection
    STP16DPP05 Low voltage 16-bit constant current LED sink driver with output error detection
    STP16DPPS05 Low-voltage 16-bit constant current LED sink driver with outputs error detection and auto-power saving
    STP16DPS05 Low voltage 16-bit constant current LED sink driver with outputs error detection
    STP24DP05 24-bit constant current LED sink driver with output error detection
    STP4CMP Low voltage 4-channel constant current LED driver with charge pump
    STPIC6C595 Power logic 8-bit shift register
    STPIC6D595 Power logic 8-bit shift register
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
