龙人旗下深圳市龙芯世纪科技有限公司
  • ST 5V逻辑 3.3V逻辑
  • 发布时间:2013/3/18 10:30:56   修改时间:2013/3/18 10:31:50 浏览次数:2673
  • 5V逻辑
    5V逻辑
    型号 概述
    74VHC00 Quad 2 Input NAND Gate
    74VHC02 Quad 2 Input NOR Gate
    74VHC04 Hex Inverter
    74VHC05 HEX Inverter (Open Drain)
    74VHC08 Quad 2 Input AND Gate
    74VHC125 Quad Bus Buffer (3-State)
    74VHC132 Quad 2 input Schmitt NAND Gate
    74VHC138 3 to 8 Line Decoder (Inverting)
    74VHC14 Hex Schmitt Inverter
    74VHC157 Quad 2 Channel multiplexer
    74VHC174 Hex D Type Flip Flop with Clear
    74VHC238 3 to 8 Line Decoder
    74VHC244 Octal Bus Buffer with 3-state Outputs (Not inverted)
    74VHC245 Octal Bus Transceiver (3-state)
    74VHC27 Triple 3 Input NOR Gate
    74VHC273 Octal D Type Flip Flop with Clear
    74VHC32 Quad 2 Input OR Gate
    74VHC373 Octal D Type Latch with 3-state Outputs Non Inverting
    74VHC374 Octal D Type Flip Flop with 3-state Outputs Non Inverting
    74VHC541 Octal Bus Buffer with 3-state Outputs (Not inverted)
    74VHC573 Octal D Type Latch with 3-state Outputs Non Inverting
    74VHC574 Octal D Type Flip Flop with 3-state Outputs Non Inverting
    74VHC594 8 Bit Shift Register with Output Register
    74VHC74 Dual D Type Flip-Flop With preset & Clear
    74VHC86 Quad Exclusive OR Gate
    74VHCT00A Quad 2 Input NAND Gate
    74VHCT04A Hex Inverter
    74VHCT08A Quad 2 Input AND Gate
    74VHCT125A Quad Bus Buffer (3-State)
    74VHCT138A 3 to 8 Line Decoder (Inverting)
    74VHCT238A 3 to 8 Line Decoder
    74VHCT244A Octal Bus Buffer with 3-state Outputs (Not inverted)
    74VHCT245A Octal Bus Transceiver (3-state)
    74VHCT273A Octal D Type Flip Flop with Clear
    74VHCT32A Quad 2 Input OR Gate
    74VHCT541A Octal Bus Buffer with 3-state Outputs (Not inverted)
    74VHCT574A Octal D Type Flip Flop with 3-state Outputs Non Inverting
    74VHCU04 Hex Inverter (Single Stage)
    HCF4001 Quad 2-Input NOR Gate
    HCF4007U Dual Complementary Pair Plus Inverter
    HCF4010 Hex Buffer/Converters non Inverting
    HCF40103 Presettable 8-Bit Binary Down Counter
    HCF40106 Hex Schmitt Trigger
    HCF4011 Quad 2-Input NAND Gate
    HCF4013 Dual D Flip-Flop
    HCF4014 8-Stage Static Syncr. Shift Register
    HCF4016 Quad Bilateral Switch
    HCF4017 Decade Counter/Divider
    HCF4019 Quad AND/OR Select Gate
    HCF4020 14-Stage Binary/Ripple Counter
    HCF4021 8-Stage Static Shift Register
    HCF4024 7-Stage Binary/Ripple Counter
    HCF4025 Triple 3-Input NOR Gate
    HCF4030 Quad Exclusive OR Gate
    HCF4040 12-Stage Binary/Ripple Counter
    HCF4042 Quad Clocked D Latch
    HCF4047 Monostable/Astable Multivibrator
    HCF4049U Hex Inverting Buffer/Converter
    HCF4050 Hex Non Inverting Buffer/Converter
    HCF4051 Single 8-Channel Analog Multiplexer/Demultiplexer
    HCF4052 Different 4 Channel Analog Multiplexer/Demultiplexer
    HCF4053 Triple 2-Channel Analog Multiplexer/Demultiplexer
    HCF4056 BCD to 7-Segment Decoder/Driver
    HCF4060 14-Stage Counter/Driver AND Oscillator
    HCF4066 Quad Bilateral Switch
    HCF4067 Single 16-Channel Analog Multiplexer/Demultiplexer
    HCF4069U Hex Inverter
    HCF4070 Quad Ex-OR Gate
    HCF4077 Quad ex-NOR Gate
    HCF4081 Quad 2-Input AND Gate
    HCF4093 Quad 2-Input NAND Schmitt Trigger
    HCF4094 8-Stage Shift-AND-Store Bus Register
    HCF4097 Different. 8-Channel Analog Multiplexer/Demultiplexer
    HCF4098 Dual Monostable Multivibrator
    HCF4099 8-Bit Addressable Latch
    HCF4538 Dual Precision Monostable Multivibrator
    HCF4541 Programmable Timer
    HCF4555 Dual 1-Of-4 Decoder/Demultiplexer (Out. High)
    HCF4556 Dual 1-of-4 Decoder/Demultiplexer (Out. Low)
    M22100 4x4 Crosspoint Switch With Control Memory
    M74HC00 Quad 2-Input NAND Gate
    M74HC02 Quad 2-Input NOR Gate
    M74HC03 Quad 2-Input NAND (Open Drain)
    M74HC04 Hex Inverter
    M74HC08 Quad 2-Input AND Gate
    M74HC10 Triple 3-Input NAND Gate
    M74HC107 Dual J-K Flip-Flop With Clear
    M74HC109 Dual J-K Flip-Flop With Preset & Clear
    M74HC123 Dual Retrigg. Monostable Multivibrator with Clear
    M74HC125 Quad Bus Buffer (3-State)
    M74HC126 Quad Bus Buffer (3-State)
    M74HC132 Quad 2-Input Schmitt NAND Gate
    M74HC133 13-Input NAND Gate
    M74HC138 3 to 8 Line Decoder (Inv.)
    M74HC139 Dual 2 to 4 Line Decoder/Demultiplexer
    M74HC14 Hex Schmitt Inverter
    M74HC148 8 to 3 Line Priority Encoder
    M74HC151 8-Channel Multiplexer
    M74HC153 Dual 4-Channel Multiplexer
    M74HC157 Quad 2-Channel Multiplexer
    M74HC160 Synchronous Decade Counter With Async. Clear
    M74HC161 Synchronous Binary Counter With Async. Clear
    M74HC163 Synchronous Binary Counter With Sync. Clear
    M74HC164 8-Bit SIPO shift register
    M74HC165 8 Bit PISO Shift Register
    M74HC174 Hex D-Type Flip-Flop With Clear
    M74HC175 Quad D-Type Flip-Flop With Clear
    M74HC191 4 Bit Synchronous Binary Up/Down Counter
    M74HC20 Dual 4-Input NAND Gate
    M74HC221 Dual Monostable Multivibrator
    M74HC238 3 to 8 Line Decoder
    M74HC240 Octal Bus Buffer (3-State/Inv.)
    M74HC241 Octal Bus Buffer (3-State)
    M74HC244 Octal Bus Buffer (3-State)
    M74HC245 Octal Bus Transceiver (3-state)
    M74HC251 8-Channel Multiplexer (3-State)
    M74HC253 Dual 4-Channel Multiplexer (3-State)
    M74HC257 Quad 2-Channel Multiplexer (3-State)
    M74HC259 8 Bit Addressable Latch
    M74HC266 Quad Exclusive Nor Gate With Open Drain
    M74HC27 Triple 3-Input NOR Gate
    M74HC273 Octal D-Type Flip-Flop with Clear
    M74HC280 9 Bit Parity Generator
    M74HC283 4 Bit Binary Full Adder
    M74HC299 8 Bit PIPO Shift Register (3-State)
    M74HC32 Quad 2-Input OR Gate
    M74HC365 Hex Bus Buffer (3-State)
    M74HC367 Hex Bus Buffer (3-State)
    M74HC368 Hex Bus Buffer (3-State/Inv.)
    M74HC373 Octal D-Type Latch (3-State)
    M74HC374 Octal D-Type Flip-Flop (3-State)
    M74HC377 Octal D-Type Flip-Flop
    M74HC390 Dual Decade Counter
    M74HC393 Dual Binary Counter
    M74HC4016 Quad Bilateral Switch
    M74HC4017 Decade Counter/Divider
    M74HC4020 14-Stage Binary Counter
    M74HC4024 7-Stage Binary Counter
    M74HC4040 12-Stage Binary Counter
    M74HC4049 Hex Buffer/Converter (Inv.)
    M74HC4050 Hex Buffer/Converter
    M74HC4051 Single 8-Channel Analog Multiplexer/Demultiplexer
    M74HC4052 Dual 4-Channel Analog Multiplexer/Demultiplexer
    M74HC4053 Triple 2-Channel Analog Multiplexer/Demultiplexer
    M74HC4060 14-Stage Binary Counter/Oscillator
    M74HC4066 Quad Bilateral Switch
    M74HC4075 Triple 3-Input OR Gate
    M74HC4078 8-Input NOR/OR Gate
    M74HC4094 8 Bit SIPO Shift Register Latch (3-State)
    M74HC4316 Quad Bilateral Switch
    M74HC4518 Dual Decade Counter
    M74HC4520 Dual 4 Bit Binary Counter
    M74HC4538 Dual Monostable Multivibrator
    M74HC4543 BCD to 7-Segment L/D/D (LCD)
    M74HC4851 Single 8 Channel Analog Mux/Demux With Injection Current Protection
    M74HC4852 DUAL 4 Channel Analog Mux/Demux With Injection Current Protection
    M74HC51 Dual 2-Wide 2-Input AND-OR Inv. Gate
    M74HC533 Octal D-Type Latch (3-State/Inv.)
    M74HC534 Octal D-Type Flip-Flop (3-State/Inv.)
    M74HC540 Octal Bus Buffer (3-State/Inv.)
    M74HC541 Octal Bus Buffer (3-State)
    M74HC563 Octal D-Type Latch (3-State/Inv.)
    M74HC564 Octal D-Type Flip-Flop (3-State/Inv.)
    M74HC573 Octal D-Type Latch (3-State)
    M74HC574 Octal D-Type Flip-Flop (3-State)
    M74HC590 8 Bit Binary Counter Register (3-State)
    M74HC592 8 Bit Binary Counter Register
    M74HC595 8 Bit Shift Register Output Latch (3-State)
    M74HC597 8 Bit Latch Shift Register
    M74HC688 8 Bit Equality Comparator
    M74HC7266 Quad Exclusive NOR Gate
    M74HC73 Dual J-K Flip-Flop With Clear
    M74HC74 Dual D-Type Flip-Flop With Preset & Clear
    M74HC86 Quad Exclusive OR Gate
    M74HCT00 Quad 2-Input NAND Gate
    M74HCT04 Hex Inverter
    M74HCT08 Quad 2-Input AND Gate
    M74HCT132 Quad 2-Input Schmitt NAND Gate
    M74HCT138 3 to 8 Line Decoder (Inv.)
    M74HCT14 Hex Schmitt Inverter
    M74HCT157 Quad 2-Channel Multiplexer
    M74HCT244 Octal Bus Buffer (3-State)
    M74HCT245 Octal Bus Transceiver (3-state)
    M74HCT273 Octal D-Type Flip-Flop with Clear
    M74HCT32 Quad 2-Input OR Gate
    M74HCT367 Hex Bus Buffer (3-State)
    M74HCT373 Octal D-Type Latch (3-State)
    M74HCT374 Octal D-Type Flip-Flop (3-State)
    M74HCT4051 SINGLE 8 CHANNEL ANALOG MULTIPLEXER/DEMULTIPLEXER
    M74HCT4053 Triple 2-Channel Analog Multiplexer/Demultiplexer
    M74HCT540 Octal Bus Buffer (3-State/Inv.)
    M74HCT541 Octal Bus Buffer (3-State)
    M74HCT573 Octal D-Type Latch (3-State)
    M74HCT574 Octal D-Type Flip-Flop (3-State)
    M74HCT640 Octal Bus Transceiver (3-State/Inv.)
    M74HCT652 Octal Bus Transceiver Register (3-State)
    M74HCT7007 Hex Buffer
    M74HCT74 Dual D-Type Flip-Flop With Preset & Clear
    M74HCU04 Hex Inverter (Single Stage)
    3.3V逻辑
    3.3V逻辑
    型号 概述
    74LCX00 Low voltage CMOS QUAD 2-Input NAND gate with 5V tolerant inputs
    74LCX02 Low voltage CMOS QUAD 2-Input NOR gate with 5V tolerant inputs
    74LCX04 Low voltage CMOS HEX inverter with 5V tolerant inputs
    74LCX07 Hex Buffer (open drain) with 5V Tolerant Input
    74LCX08 Low voltage CMOS QUAD 2-input AND gate with 5V tolerant inputs
    74LCX125 Low voltage CMOS quad bus buffer (3-State) with 5V tolerant inputs and outputs
    74LCX138 Low voltage CMOS 3 to 8 line decoder (Inverter) with 5V tolerant inputs
    74LCX139 Low voltage CMOS Dual 2 to 4 decoder / demultiplexer
    74LCX14 Low voltage CMOS HEX SCHMITT inverter with 5V tolerant inputs
    74LCX157 Low voltage CMOS Quad 2 channel multiplexer with 5V tolerant inputs
    74LCX16245 16-Bit Bus Transceiver (3-State) with 5V Tolerant Input & Output
    74LCX244 Octal Bus Buffer (3-State) with 5V Tolerant Input & Output
    74LCX245 Octal Bus Transceiver (3-State) with 5V Tolerant Input & Output
    74LCX257 Quad 2-Channel Multiplexer with 5V Tolerant Input & Output (3-State)
    74LCX32 Quad 2-Input OR Gate with 5V Tolerant Input
    74LCX373 Octal D-Type Latch Non-Inverting (3-State) with 5V Tolerant Input & Output
    74LCX374 Octal D-Type Flip-Flop Non-Inverting (3-State) with 5V Tolerant Input & Output
    74LCX541 Octal Bus Buffer (3-State Non-Inverting) with 5V Tolerant Input & Output
    74LCX573 Octal D-Type Latch Non-Inverting (3-State) with 5V Tolerant Input & Output
    74LCX574 Octal D-Type Flip-Flop Non-Inverting (3-State) with 5V Tolerant Input & Output
    74LCX74 Dual D-Type Flip-Flop with Preset & Clear With 5V Tolerant Input
    74LCX86 Quad Exclusive OR Gate with 5V Tolerant Input
    74LVC00A Low Voltage CMOS Quad 2-Input NAND Gate Advenced Performance
    74LVC04A Low Voltage CMOS Hex Inverter Advenced Performance
    74LVC08A Low Voltage CMOS Quad 2-Input AND Gate Advenced Performance
    74LVC125A Low Voltage CMOS Quad Bus Buffer (3-State) Advenced Performance
    74LVC14A Low Voltage CMOS Hex Schmitt Inverter Advenced Performance
    74LVC161284 Low Voltage CMOS Octal D-Type Latch Advenced Performance
    74LVC244A Low Voltage CMOS Octal Bus Buffer (3-State) Advenced Performance
    74LVC245A Low Voltage CMOS Octal Bus Transceiver (3-State) Advenced Performance
    74LVC32A Low Voltage CMOS Quad 2-Input OR Gate Advenced Performance
    74LVC373A Low Voltage CMOS Octal D-Type Latch Advenced Performance
    74LVC374A Low Voltage CMOS Octal D-Type Flip-Flop Advenced Performance
    74LVC573A Low Voltage CMOS Octal D-Type Latch Advenced Performance
    74LVX00 Low Voltage CMos Quad 2-Input Nand Gate
    74LVX02 Low Voltage CMos Quad 2-Input Nor Gate
    74LVX04 Low Voltage CMos Hex Inverter
    74LVX05 Low Voltage CMos Hex Inverter (Open Drain)
    74LVX08 Low Voltage CMos Quad 2-Input And Gate
    74LVX125 Low Voltage CMos Quad Bus Buffer (3-State) 5V Tolerant Inputs
    74LVX126 Low Voltage Quad Bus Buffer (3-state)
    74LVX132 Low Voltage CMos Quad 2-Input Schmitt NAND Gate 5V Tolerant Inputs
    74LVX138 Low Voltage CMos 3 To 8 Line Decoder (Inv.) with Clear with 5V Tolerant Inputs
    74LVX14 Low Voltage CMos Hex Schmitt Inverter
    74LVX157 Low Voltage CMos Quad 2 Channel Multiplexer with 5V Tolerant Inputs
    74LVX174 Low Voltage CMos 3 To 8 Line Decoder (Inv.) with Clear with 5V Tolerant Inputs
    74LVX20 Low voltage CMOS dual 4-input NAND gate with 5 V tolerant inputs
    74LVX238 Low Voltage 3 to 8 Line Decoder
    74LVX244 Low Voltage CMos Octal Bus Buffer with 3-State Outputs (Non Inverted)
    74LVX245 Low Voltage CMos Octal Bus Transceiver (3-State)
    74LVX257 Low Voltage CMos Octal Bus Transceiver (3-State)
    74LVX27 Low Voltage CMos Octal Bus Transceiver (3-State)
    74LVX273 Low Voltage CMos Octal D-Type Flip Flop with Clear with 5V Tolerant Inputs
    74LVX32 Low Voltage CMos Quad 2-Input Or Gate
    74LVX3245 Low Voltage CMos 8-Bit Dual Supply Translating Transceiver with 3-State Outputs
    74LVX373 Low Voltage Octal D-Type Latch 3-State non inverting
    74LVX374 Low Voltage Octal D-Type Flip-Flop 3-State non inverting
    74LVX4245 Low Voltage CMos 8-Bit Dual Supply Translating Transceiver with 3-State Outputs
    74LVX541 Low Voltage Octal Bus Buffer with 3-state Outputs (Not inverted)
    74LVX573 Low Voltage Octal D-Type Latch 3-State non inverting
    74LVX574 Low Voltage Octal D-Type Flip-Flop 3-State non inverting
    74LVX594 Low Voltage Cmos 8-Bit Shift Register with Output Register
    74LVX74 Low Voltage CMos Dual D-Type Flip-Flop with preset and Clear (5V tolerant inputs)
    74LVX86 Low Voltage CMos Quad Exclusive Or Gate
    74LVXC4245 Low Voltage CMos 8-Bit Dual Supply Configurable Voltage Iterface Transceiver with 3-State Outputs
    74LVXU04 Low Voltage CMos Hex Inverter (Single Stage)
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
