龙人旗下深圳市龙芯世纪科技有限公司
  • ST 存储器EEPROM NVRAM RFID & RF 存储器
  • 发布时间:2013/3/18 10:35:25   修改时间:2013/3/18 10:35:25 浏览次数:2766
  • 双接口EEPROM
    双接口EEPROM
    型号 概述
    CR95HF 13.56 MHz multi-protocol contactless transceiver IC with SPI and UART serial access
    M24LR04E-R 4-Kbit Dual Interface EEPROM with password protection, energy harvesting and RF status functions
    M24LR16E-R 16-Kbit Dual Interface EEPROM with password protection, energy harvesting and RF status functions
    M24LR64-R 64-Kbit dual interface EEPROM with password protection
    M24LR64E-R 64-Kbit Dual Interface EEPROM with password protection, energy harvesting and RF status functions
    EEPROM,串行
    EEPROM,串行
    型号 概述
    M24128-125 Automotive 128 Kbit serial I2C bus EEPROM
    M24128-BF 128 Kbit Serial I2C Bus EEPROM
    M24128-BR 128 Kbit Serial I2C Bus EEPROM
    M24128-BW 128 Kbit Serial I2C Bus EEPROM
    M24128-DF 128-Kbit serial I2C bus EEPROM
    M24256-125 Automotive 256 Kbit serial I2C bus EEPROM
    M24256-A125 Automotive 256 Kbit serial I2C bus EEPROM
    M24256-BF 256 Kbit serial I2C bus EEPROM
    M24256-BR 256 Kbit serial I2C bus EEPROM
    M24256-BW 256 Kbit serial I2C bus EEPROM
    M24256-DF 256 Kbit serial I2C bus EEPROM
    M24256-DR 256 Kbit serial I2C bus EEPROM
    M24512-125 Automotive 512 Kbit serial I2C bus EEPROM
    M24512-A125 Automotive 512 Kbit serial I2C bus EEPROM
    M24512-DF 512Kit Serial I2C bus EEPROM with three Chip Enable Lines
    M24512-DR 512 Kbit serial I2C bus EEPROM
    M24512-R 512 Kbit serial I2C bus EEPROM
    M24512-W 512 Kbit serial I2C bus EEPROM
    M24C01-R 1 Kbit serial I2C bus EEPROM
    M24C01-W 1 Kbit serial I2C bus EEPROM
    M24C02-125 Automotive 2 Kbit serial I2C bus EEPROM
    M24C02-R 2 Kbit serial I2C bus EEPROM
    M24C02-W 2 Kbit serial I2C bus EEPROM
    M24C04-125 Automotive 4 Kbit serial I2C bus EEPROM
    M24C04-F 4 Kbit serial I2C bus EEPROM
    M24C04-R 4 Kbit serial I2C bus EEPROM
    M24C04-W 4 Kbit serial I2C bus EEPROM
    M24C08-125 Automotive 8 Kbit serial I2C bus EEPROM
    M24C08-F 8 Kbit serial I2C bus EEPROM
    M24C08-R 8 Kbit serial I2C bus EEPROM
    M24C08-W 8 Kbit serial I2C bus EEPROM
    M24C16-125 Automotive 16 Kbit serial I2C bus EEPROM
    M24C16-F 16 Kbit serial I2C bus EEPRO
    M24C16-R 16 Kbit serial I2C bus EEPRO
    M24C16-W 16 Kbit serial I2C bus EEPRO
    M24C32-125 Automotive 32 Kbit serial I2C bus EEPROM
    M24C32-A125 Automotive 32 Kbit serial I2C bus EEPROM
    M24C32-DF 32 Kbit serial I2C bus EEPROM
    M24C32-F 32 Kbit serial I2C bus EEPROM
    M24C32-R 32 Kbit serial I2C bus EEPROM
    M24C32-W 32 Kbit serial I2C bus EEPROM
    M24C32-X 32 Kbit Serial I2C bus EEPROM
    M24C64-125 Automotive 64 Kbit serial I2C bus EEPROM
    M24C64-A125 Automotive 64 Kbit serial I2C bus EEPROM
    M24C64-DF 64 Kbit Serial I2C bus EEPROM
    M24C64-F 64 Kbit Serial I2C bus EEPROM
    M24C64-R 64 Kbit Serial I2C bus EEPROM
    M24C64-W 64 Kbit Serial I2C bus EEPROM
    M24M01-DF 1-Mbit serial I2C bus EEPROM
    M24M01-R 1 Mbit serial I2C bus EEPROM
    M24M02-DR 2 Mbit serial I2C bus EEPROM
    M34E02-F EEPROM, Serial, SPD for DRAM Modules
    M34F04 4 Kbit Serial I2C EEPROM With Hardware Write Control on Top Half of Memory
    M35B32 32 Kbit, 256-byte page, fast program EEPROM memory accessed by SPI bus interface
    M93C46-125 Automotive 1 Kbit MICROWIRE serial access EEPROM
    M93C46-W 1 Kbit (8-bit or 16-bit wide) MICROWIRE serial access EEPROM
    M93C56-125 Automotive 2 Kbit MICROWIRE serial access EEPROM
    M93C56-R 2 Kbit (8-bit or 16-bit wide) MICROWIRE serial access EEPROM
    M93C56-W 2 Kbit (8-bit or 16-bit wide) MICROWIRE serial access EEPROM
    M93C66-125 Automotive 4 Kbit MICROWIRE serial access EEPROM
    M93C66-R 4 Kbit (8-bit or 16-bit wide) MICROWIRE serial access EEPROM
    M93C66-W 4 Kbit (8-bit or 16-bit wide) MICROWIRE serial access EEPROM
    M93C76-125 Automotive 8 Kbit MICROWIRE serial access EEPROM
    M93C76-R 8 Kbit (8-bit or 16-bit wide) MICROWIRE serial access EEPROM
    M93C76-W 8 Kbit (8-bit or 16-bit wide) MICROWIRE serial access EEPROM
    M93C86-125 Automotive 16 Kbit MICROWIRE serial access EEPROM
    M93C86-W 16 Kbit (8-bit or 16-bit wide) MICROWIRE serial access EEPROM
    M93S46-W Automotive 1 Kbit MICROWIRE serial access EEPROM with block protection
    M93S56-125 Automotive 2 Kbit MICROWIRE serial access EEPROM with Block Protection
    M93S56-W 2 Kbit (16-bit wide) MICROWIRE serial access EEPROM with block protection
    M93S66-W 4 Kbit (16-bit wide) MICROWIRE serial access EEPROM with block protection
    M95010-125 Automotive 1 Kbit serial SPI bus EEPROM
    M95010-R 1Kbit Serial SPI Bus EEPROM With High Speed Clock
    M95010-W 1 Kbit SPI bus EEPROM with high-speed clock
    M95020-125 Automotive 2 Kbit serial SPI bus EEPROM
    M95020-R 2 Kbit SPI bus EEPROM with high-speed clock
    M95020-W 2 Kbit SPI bus EEPROM with high-speed clock
    M95040-125 Automotive 4 Kbit serial SPI bus EEPROM
    M95040-R 4 Kbit SPI bus EEPROM with high-speed clock
    M95040-W 4 Kbit SPI bus EEPROM with high-speed clock
    M95080-125 Automotive 8 Kbit serial SPI bus EEPROM
    M95080-R 8 Kbit SPI bus EEPROM with high-speed clock
    M95080-W 8 Kbit SPI bus EEPROM with high-speed clock
    M95128-125 Automotive 128 Kbit SPI bus EEPROM
    M95128-A125 Automotive 128 Kbit SPI bus EEPROM with high speed clock
    M95128-A145 Automotive 128 Kbit SPI bus EEPROM with high speed clock
    M95128-R 128 Kbit SPI bus EEPROM with high-speed clock
    M95128-W 128 Kbit SPI bus EEPROM with high-speed clock
    M95160-125 Automotive 16 Kbit serial SPI bus EEPROM
    M95160-145 Automotive 16 Kbit SPI bus EEPROM
    M95160-F 16 Kbit SPI bus EEPROM with high-speed clock
    M95160-R 16 Kbit SPI bus EEPROM with high-speed clock
    M95160-W 16 Kbit SPI bus EEPROM with high-speed clock
    M95256-125 Automotive 256 Kbit SPI bus EEPROM
    M95256-A125 Automotive 256 Kbit SPI bus EEPROM with high speed clock
    M95256-A145 Automotive 256 Kbit SPI bus EEPROM with high speed clock
    M95256-DF 256-Kbit serial SPI bus EEPROM with high speed clock
    M95256-DR 256 Kbit SPI bus EEPROM with high-speed clock
    M95256-R 256 Kbit SPI bus EEPROM with high-speed clock
    M95256-W 256 Kbit SPI bus EEPROM with high-speed clock
    M95320-125 Automotive 32 Kbit serial SPI bus EEPROM
    M95320-A125 Automotive 32 Kbit SPI bus EEPROM with high speed clock
    M95320-A145 Automotive 32 Kbit SPI bus EEPROM with high speed clock
    M95320-DR 32 Kbit SPI bus EEPROM with high-speed clock
    M95320-R 32 Kbit SPI bus EEPROM with high-speed clock
    M95320-W 32 Kbit SPI bus EEPROM with high-speed clock
    M95512-125 Automotive 512 Kbit SPI bus EEPROM
    M95512-A125 Automotive 512 Kbit SPI bus EEPROM with high speed clock
    M95512-A145 Automotive 512 Kbit SPI bus EEPROM with high speed clock
    M95512-DF 512Kbit Serial Bus EEPROM
    M95512-DR 512Kbit Serial Bus EEPROM
    M95512-R 512 Kbit SPI bus EEPROM with high-speed clock
    M95512-W 512 Kbit SPI bus EEPROM with high-speed clock
    M95640-125 Automotive 64 Kbit serial SPI bus EEPROM
    M95640-A125 Automotive 64 Kbit SPI bus EEPROM with high speed clock
    M95640-A145 Automotive 64 Kbit SPI bus EEPROM with high speed clock
    M95640-DR 64 Kbit SPI bus EEPROM with high-speed clock
    M95640-R 64 Kbit SPI bus EEPROM with high-speed clock
    M95640-W 64 Kbit SPI bus EEPROM with high-speed clock
    M95M01-125 Automotive 1024 Kbit serial SPI bus EEPROM
    M95M01-A125 Automotive 1024 Kbit SPI bus EEPROM with high speed clock
    M95M01-A145 Automotive 1024 Kbit SPI bus EEPROM with high speed clock
    M95M01-R 1 Mbit SPI bus EEPROM with high-speed clock
    M95M02-DR 2 Mbit serial SPI bus EEPROM
    NVRAM
    NVRAM
    型号 概述
    M48Z02 ZEROPOWER SRAM
    M48Z08 ZEROPOWER SRAM
    M48Z12 ZEROPOWER SRAM
    M48Z18 ZEROPOWER SRAM
    M48Z2M1V ZEROPOWER SRAM
    M48Z35 ZEROPOWER SRAM
    M48Z35Y ZEROPOWER SRAM
    M48Z512AV 4 Mbit (512 Kbit x 8) ZEROPOWER? SRAM
    M48Z58 ZEROPOWER SRAM
    M48Z58Y ZEROPOWER SRAM
    M4Z28-BR00SH ZEROPOWER SNAPHAT (Battery)
    M4Z32-BR00SH ZEROPOWER SNAPHAT (Battery)
    RFID & RF 存储器
    RFID & RF 存储器
    型号 概述
    CR14 13.56 MHz single-protocol contactless transceiver IC with I2C serial access
    CRX14 13.56 MHz single-protocol contactless transceiver IC with I2C serial access
    LRI1K 1024-bit ISO15693 contactless memory with 64-bit UID, AFI, DSFID, anti-collision, kill function
    LRI2K 2048-bit ISO15693 contactless memory with 64-bit UID, AFI, DSFID, anti-collision, kill function
    LRIS2K 2048-bit ISO15693 contactless memory with 64-bit UID, AFI, DSFID, anti-collision, kill function and password protection
    LRIS64K 65536-bit ISO15693 contactless memory with 64-bit UID, AFI, DSFID, anti-collision, kill function and password protection
    SRI2K 2048-bit ISO14443-B contactless memory with 2 binary counters and anti-collision
    SRI4K 4096-bit ISO14443-B contactless memory with 2 binary counters and anti-collision
    SRI512 512-bit ISO14443-B contactless memory with 2 binary counters, 5 OTP blocks and anti-collision
    SRIX4K 4096-bit ISO14443-B contactless memory with 2 binary counters, anti-collision and anti-clone function
    SRT512 512-bit ISO14443-B contactless memory with 2 binary counters, full EEPROM user memory and anti-collision
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
