龙人旗下深圳市龙芯世纪科技有限公司
  • 电压参考 开关稳压器 以太网供电 微处理器电压监控和复位IC
  • 发布时间:2013/3/18 10:55:48   修改时间:2013/3/18 10:58:02 浏览次数:3728
  • 以太网供电
    以太网供电
    型号 概述
    PM8800 Integrated IEEE 802.3af compliant PoE-PD interface and PWM controller with support of external source
    PM8803 High efficiency integrated IEEE 802.3at PoE-PD interface and PWM controller type 2 PSE indicator, plus support for forward active clamp topology
    电源路径管理
    电源路径管理
    型号 概述
    STBP110 Overvoltage protection device
    STBP112 Overvoltage protection device
    STBP120 Overvoltage protection device with thermal shutdown
    STM6600 Smart push-button on/off controller with smart reset and power-on lockout
    STM6601 Smart push-button on/off controller with Smart ResetTM and power-on lockout
    安全监控器
    安全监控器
    型号 概述
    STM1403 3 V FIPS-140 security supervisor with battery switchover
    STM1404 3 V FIPS-140 security supervisor with battery switchover
    开关稳压器
    开关稳压器
    型号 概述
    MC34063AB DC-DC CONVERTER CONTROL CIRCUITS
    MC34063AC DC-DC CONVERTER CONTROL CIRCUITS
    MC34063EB DC-DC CONVERTER CONTROL CIRCUITS
    MC34063EC DC-DC CONVERTER CONTROL CIRCUITS
    ST662AB DC-DC CONVERTER FROM 5V TO 12V, 0.03A FOR FLASH MEMORY PROGRAMMING SUPPLY
    ST662AC DC-DC CONVERTER FROM 5V TO 12V, 0.03A FOR FLASH MEMORY PROGRAMMING SUPPLY
    STBB1-AXX 1 A, high efficiency single inductor dual mode buck-boost DC-DC converter
    STBB1XX 1 A, high efficiency single inductor dual mode buck-boost DC-DC converter
    STBB2 800 mA 3 MHz, high efficiency dual mode buck-boost DC-DC converter
    STOD02 Dual DC-DC converter for powering AMOLED display
    STOD03A Dual DC-DC converter for powering AMOLED display
    STOD03AS Dual DC-DC converter for powering AMOLED displays
    STOD03B 150 mA dual DC-DC converter with LDO for powering AMOLED display
    STOD13A 250 mA dual DC-DC converter for powering AMOLED displays
    STOD13AM 250 mA dual DC-DC converter for powering AMOLED displays
    STOD13AS 250 mA dual DC-DC converter for powering AMOLED display
    STOD14 STOD14 700mA dual DC/DC converter for powering AMOLED display
    STODD01 Monolithic power management for high definition ODD with true shut-down, reset, and programmable step-up voltage
    STODD03 Monolithic 2 channel power management for high definition ODD with integrated power switch
    电压参考
    电压参考
    光电集成电路
    光电集成电路
    型号 概述
    SPV1001 Cool bypass switch for photovoltaic applications
    SPV1001N Cool bypass switch for photovoltaic applications
    SPV1002 Cool bypass switch for photovoltaic applications
    SPV1020 Interleaved DC-DC boost converter with built-in MPPT algorithm
    SPV1040 High efficiency solar battery charger with embedded MPPT
    SPV1012 Cool bypass switch for photovoltaic applications
    SPV1520 Cool bypass switch for photovoltaic applications
    型号 概述
    LM336 2.5V Voltage Reference
    LM4041xx Precision micropower shunt voltage reference
    TL1431 Programmable Voltage Reference
    TL431 Programmable Voltage Reference
    TL432 Programmable voltage reference
    TLVH431 Programmable Shunt Voltage Reference
    TS2431 Programmable Shunt Voltage Reference
    TS3431 1.24V PROGRAMMABLE SHUNT VOLTAGE REFERENCE
    TS4040 2.5V Micropower Shunt Voltage Reference
    TS4041 1.225V Micropower Shunt Voltage Reference
    TS431 Low voltage adjustable shunt reference
    TS432 1.24V Adjustable Shunt Voltage Reference
    TS4431 1.224V open collector shunt voltage reference
    TS4436 Adjustable 0.6V open collector shunt voltage reference
    TS821 1.225V Micropower Shunt Voltage Reference
    TS822 2.5V Micropower Shunt Voltage Reference
    TS824-1.2 High Thermal Stability Micropower Shunt Voltage Reference
    TS824-2.5 High Thermal Stability Micropower Shunt Voltage Reference
    微处理器电压监控和复位IC
    微处理器电压监控和复位IC
    型号 概述
    M40SZ100W ZEROPOWER Supervisor
    STM1001 Active Low, Open Drain
    STM1061 Low power voltage detector
    STM1810 Low Power Reset Circuit
    STM1811 Low Power Reset Circuit
    STM1812 Low Power Reset Circuit
    STM1813 Low Power Reset Circuit
    STM1815 Low Power Reset Circuit
    STM1816 Low Power Reset Circuit
    STM1817 Low Power Reset Circuit
    STM1818 Low Power Reset Circuit
    STM1831 Voltage detector with sense input and external delay capacitor
    STM6315 Open Drain Microprocessor Reset
    STM6321 Reset + Watchdog
    STM6322 Reset + Manual Reset
    STM6503 Dual push-button smart reset
    STM6504 Dual push-button smart reset
    STM6505 Dual push-button smart reset
    STM6510 Microprocessor Supervisors and Reset ICs, Smart Reset ICs
    STM6513 Smart reset
    STM6519 4-pin Smart Reset?
    STM6520 Push-button controlled smart reset
    STM6522
    STM6524 6-pin Smart Reset
    STM6710 Microprocessor Supervisors and Reset ICs, Reset ICs
    STM6717 Dual/Triple Ultra-Low Voltage Supervisors with Push-Button Reset
    STM6718 Dual/triple ultra-low voltage supervisors with push-button reset (with delay option)
    STM6719 Dual/triple ultra-low voltage supervisors with push-button reset (with delay option)
    STM6720 Dual/triple ultra-low voltage supervisors with push-button reset (with delay option)
    STM6777 Dual/triple ultra-low voltage supervisors with push-button reset (with delay option)
    STM6778 Dual/triple ultra-low voltage supervisors with push-button reset (with delay option)
    STM6779 Dual/triple ultra-low voltage supervisors with push-button reset (with delay option)
    STM6780 Dual/triple ultra-low voltage supervisors with push-button reset (with delay option)
    STM6821 Reset + Watchdog
    STM6822 Reset + Watchdog
    STM6823 Reset + Watchdog
    STM6824 Reset + Watchdog
    STM6825 Reset + Manual Reset
    STM6904 Quad, ultralow voltage supervisor with push-button reset
    STM6905 Quintuple, ultralow voltage supervisor with push-button reset
    STM690A 5V Supervisor
    STM690T/S/R 3V Supervisor
    STM692A 5V Supervisor
    STM703 5V Supervisor
    STM704 5V Supervisor
    STM704T/S/R 3V Supervisor
    STM705 5V Supervisor
    STM706 5V Supervisor
    STM706P 3V Supervisor
    STM706T/S/R 3V Supervisor
    STM707 5V Supervisor
    STM708 5V Supervisor
    STM708T/S/R 3V Supervisor
    STM795T/S/R 3V Supervisor
    STM802L/M 5V Supervisor
    STM802T/S/R 3V Supervisor
    STM804T/S/R 3V Supervisor
    STM805L 5V Supervisor
    STM805T/S/R 3V Supervisor
    STM806T/S/R 3V Supervisor
    STM809 Active Low, Push-Pull
    STM810 Active High, Push-Pull
    STM811 Active Low, Push-Pull
    STM812 Active Low, Push-Pull
    STM813L 5V Supervisor
    STM817L/M 5V Supervisor
    STM818L/M 5V Supervisor
    STM819L/M 5V Supervisor
    STWD100 Watchdog
    TS831 Micropower voltage supervisor with reset active low
    TS834 Micropower voltage supervisor with reset active low or high and integrated timer
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
