龙人旗下深圳市龙芯世纪科技有限公司
  • 发光二极管电源 热插拔电源管理 DC-DC转换 电池管理 AC-DC转换
  • 发布时间:2013/3/18 11:01:59   修改时间:2013/3/18 11:02:21 浏览次数:3676
  • 发光二极管
    发光二极管
    型号 概述
    HVLED805 Off-line LED driver with primary-sensing
    HVLED807PF Off-line led driver with primary-sensing and high power factor
    HVLED815PF OFF-LINE LED DRIVER WITH PRIMARY-SENSING
    L5970AD Up to 1 A step down switching regulator
    L5970D Up to 1 A step down switching regulator
    L5972D Up to 1.5 A step down switching regulator
    L5973AD Up to 1.5 A step down switching regulator
    L5973D Up to 2 A step down switching regulator
    L5980 Up to 0.7 A step down switching regulator
    L5981 Up to 1 A step down switching regulator
    L5983 Up to 1.5 A step down switching regulator
    L5985 Up to 2 A step down switching regulator
    L5986 2.5 A step-down switching regulator
    L5987 3 A step-down switching regulator
    L5988D 4 A continuous (more than 5 A pulsed) step-down switching regulator with synchronous rectification
    L5989D 4 A continuous (more than 5 A pulsed) step-down switching regulator with synchronous rectification
    L7980 2 A step-down switching regulator
    L7981 3 A step-down switching regulator
    L7985 2A step-down switching regulator
    L7986 3A step-down switching regulator
    L7986TA 3A step-down switching regulator
    LED2000 3 A monolithic step-down current source with synchronous rectification
    LED7706 LED driver with boost regulator, 6-rows 30 mA, for LCD panels backlight
    LED7707 LED driver with boost regulator, 6-rows 85 mA, for LCD panels backlight
    LED7708 16 channels x 85 mA LED driver with boost controller and 4-wire serial interface
    PM6600 6-rows 30 mA LEDs driver with boost regulator for mobile pc LCD panels backlight
    STCF02 HIGH POWER WHITE LED DRIVER
    STCF03 HIGH POWER WHITE LED DRIVER
    STCF04 High power white LED SuperCap driver with I2C interface
    STCF05 HIGH POWER WHITE LED DRIVER WITH I2C INTERFACE
    STCF06 WHITE LED DRIVER WITH I2C INTERFACE
    STCF07 High buck-boost power white LED driver
    STCS05 0.5A MAX CONSTANT CURRENT LED DRIVER
    STCS05A 0.5 A max constant current LED driver
    STCS1 1.5A MAX CONSTANT CURRENT LED DRIVER
    STCS1A 1.5A MAX CONSTANT CURRENT LED DRIVER
    STCS2 1.5A MAX CONSTANT CURRENT LED DRIVER
    STCS2A 1.5A MAX CONSTANT CURRENT LED DRIVER
    STCS44 4 Channels Current Source for High Power White LEDs
    STLA01 50 mA stand-alone linear LED driver
    STLA02 White LED driver for display backlight
    STLD40D White Led Power Supply For Large Display Backlight
    STLD41 White LED driver for mid-size LCD display backlight
    STLDC08 Step-up controller for LED supply
    STLED25 5 channels step-up white LED driver
    STP04CM05 4-bit constant current power-LED sink driver
    STP08CP05 Low-voltage, low current power 8-bit shift register
    STP08DP05 Low-voltage 8-bit constant current LED sink with full outputs error detection
    STP1612PW05 16-channel LED driver with 16-bit PWM, 8-bit gain and full LED error detection
    STP16CP05 Low-voltage 16-bit constant current LED sink driver
    STP16CPC05 Low voltage 16 - bit constant current LED sink driver
    STP16CPC26 Low voltage 16-bit constant current LED sink driver
    STP16CPP05 Low-voltage 16-bit constant current LED sink driver
    STP16CPPS05 Low voltage 16-bit constant current LED sink driver with auto power-saving
    STP16CPS05 Low-voltage 16-bit constant current LED sink driver with auto-power saving
    STP16DP05 Low-voltage 16-bit constant current LED sink driver with outputs error detection
    STP16DPP05 Low voltage 16-bit constant current LED sink driver with output error detection
    STP16DPPS05 Low-voltage 16-bit constant current LED sink driver with outputs error detection and auto-power saving
    STP16DPS05 Low voltage 16-bit constant current LED sink driver with outputs error detection
    STP24DP05 24-bit constant current LED sink driver with output error detection
    STP4CMP Low voltage 4-channel constant current LED driver with charge pump
    STPIC6C595 Power logic 8-bit shift register
    STPIC6D595 Power logic 8-bit shift register
    热插拔电源管理
    热插拔电源管理
    型号 概述
    STEF05 Electronic fuse for 5 V line
    STEF12 Electronic fuse for 12 V line
    DC-DC转换
    DC-DC转换
    型号 概述
    A5970AD Up to 1 A step down switching regulator for automotive applications
    A5970D Up to 1 A step down switching regulator for automotive applications
    A5972D Up to 1.5 A step down switching regulator for automotive applications
    A5973AD Up to 1.5 A step down switching regulator for automotive applications
    A5973D Up to 2 A step down switching regulator for automotive applications
    A5974AD Up to 2 A step down switching regulator for automotive applications
    A5974D Up to 2.5 A step down switching regulator for automotive applications
    A5975AD Up to 2.5 A step down switching regulator for automotive applications
    A5975D Up to 3 A step down switching regulator for automotive applications
    A6902D Up to 1 A Switch Step Down regulator with Adjustable Current Limit for Automotive Applications
    A7985A 2 A step-down switching regulator for automotive applications
    A7986A 3 A step-down switching regulator for automotive applications
    B5973D Up to 2 A step down switching regulator for automotive applications
    L296 HIGH CURRENT SWITCHING REGULATORS
    L4960 2.5 A Switching Regulator
    L4962 1.5 A Switching Regulator
    L4963 1.5 A SWITCHING REGULATOR
    L4964 High current switching regulator
    L4970A 10 A switching regulator
    L4971 1.5A Switching Regulator
    L4972 2 A SWITCHING REGULATOR
    L4973 3.5 A Switching Regulator
    L4974A 3.5 A switching regulator
    L4975A 5 A switching regulator
    L4976 1 A step down switching regulator
    L4977A 7 A switching regulator
    L4978 2A Step down switching regulator
    L6706 VR11.1 single phase controller with integrated driver
    L6712 2 Phase interleaved DC/DC Controller
    L6713A 2/3 phase controller with embedded drivers for Intel VR10, VR11 and AMD 6 bit CPUs
    L6716 2/3/4 phase controller with embedded drivers for Intel VR11.1
    L6717 High-Efficiency Hybrid AM2r2 Controller with I2C Interface and Embedded Drivers
    L6718 Digitally Controlled Dual PWM with Embedded Drivers for VR12
    L6725 Voltage mode PWM controller with bootstrap anti-discharging system
    L6725A Voltage mode PWM controller with bootstrap anti-discharging system
    L6726A Single phase PWM controller
    L6727 Single phase PWM controller
    L6728AH High frequency single phase PWM controller with Power Good
    L6728D Single phase PWM controller with Power Good
    L6730 Adjustable step-down controller with synchronous rectification
    L6730B Adjustable step-down controller with synchronous rectification
    L6730C Adjustable step-down controller with synchronous rectification
    L6731D Adjustable step-down controller with synchronous rectification dedicated to DDR memory
    L6732 Adjustable step-down controller with synchronous rectification
    L6738 Single Phase PWM Controller with Light-Load Efficiency Optimization
    L6738A Single Phase PWM Controller with Light-Load Efficiency Optimization
    L6740L Hybrid controller (4+1) for AMD SVID and PVID processors
    L6741 High current MOSFET driver
    L6743B High current MOSFET driver
    L6743D High current MOSFET driver
    L6743Q High current MOSFET driver
    L6747A High current MOSFET driver
    L6747C High current MOSFET driver
    L6756 2/3/4 phase buck controller for VR10, VR11.1 and AM2 processor applications
    L6756D 2/3/4 phase buck controller for VR10, VR11.1 and AM2 processor applications
    L6759D 3+1 dual controller for VR12 with PMBus
    L6788A 3-phase controller with embedded drivers for the next GPU generation
    L6902 1A Switching Regulator
    L6910 CPU Power Supply
    L6910G Adjustable step down controller with synchronous rectification
    L6920 1V HIGH EFFICIENCY SYNCRONOUS STEP UP CONVERTER
    L6920DB Synchronous rectifier step up converter
    L6920DC Synchronous rectifier step up converter
    L6925D High Efficiency Syncronous Step-Down Regulator
    L6926 High Efficiency Syncronous Step-Down Regulator
    L6928 High efficiency monolithic synchronous step down regulator
    L6932 High Performance 2A ULDO Linear Regulator
    L6932H1.2 High Performance 2A ULDO Linear Regulator
    L6933H1.2 High Performance 2A ULDO Linear Regulator with Soft Start
    L6935 High performance 3 A ULDO linear regulator
    L6997S Step Down Controller for Low Voltage Operations
    PM6610 2-4 Cells Li-ion, Li-FePO4 Battery Charger with SMBus Interface, N-Channel RBFET & BATFET Mosfet Selector
    PM6611N 2-4 Cells Li-ion, Li-FePO4 Battery Charger with SMBus Interface, N-Channel RBFET & BATFET Mosfet Selector
    PM6612 2-4 cells Li-ion, Li-FePO4 battery charger with SMBus interface, N-channel RBFET and BATFET MOSFET selector
    PM6613N 2-4 cells Li-ion, Li-FePO4 battery charger with SMBus interface, N-channel RBFET and BATFET MOSFET selector
    PM6641 Monolithic VR for Chipset and DDR2/3 Supply for Ultra-Mobile PC (UMPC) Applications
    PM6644 350 mA adjustable step-down regulator
    PM6652 Single-phase multifunctional DC-DC controller for Intel platforms
    PM6670AS Complete DDR 2/3 memory power supply controller
    PM6670S Complete DDR 2/3 memory power supply controller
    PM6675AS High efficiency step down controller with embedded 2A LDO regulator
    PM6675S High efficiency step down controller with embedded 2A LDO regulator
    PM6680 2 adjustable output power controller for notebook PC chipset power
    PM6680A Dual synchronous step down controller with adjustable output voltages plus LDO
    PM6681A Dual synchronous step down controller with adjustable LDO
    PM6685 Dual step-down controller with auxiliary voltages for notebook system power
    PM6686 Dual step-down controller with adjustable voltages, adjustable LDO and auxiliary charge pump controller for notebook
    PM6690 Three phase controller for Intel MVP7 CPU power supply
    PM6691 Single phase controller for Intel MVP7 GPU and CPU power supply
    PM6692 Two phase controller for Intel MVP7 GPU and CPU power supply
    PM8903 3 A step-down monolithic switching regulator
    ST1S03 1.5 A, 1.5 MHz adjustable, step-down switching regulator
    ST1S03A 1.5 A, 1.5 MHz adjustable, step-down switching regulator
    ST1S06A Synchronous rectification, 1.5 A, 1.5 MHz adjustable, step-down switching regulator
    ST1S06XX12 Synchronous rectification with inhibit, 1.5 A, 1.5 MHz fixed, step-down switching regulator
    ST1S06XX33 Synchronous rectification with inhibit, 1.5 A, 1.5 MHz fixed, step-down switching regulator
    ST1S09 Synchronous rectification with inhibit, 2 A, 1.5 MHz adjustable, step-down switching regulator
    ST1S10 Monolithic synchronous step-down regulator
    ST1S12XX Synchronous rectification with inhibit, 0.7 A, 1.7 MHz adjustable, step-down switching regulator
    ST1S12XX12 Synchronous rectification with inhibit, 0.7 A, 1.7 MHz fixed, step-down switching regulator
    ST1S12XX18 Synchronous rectification with inhibit, 0.7 A, 1.7 MHz fixed, step-down switching regulator
    ST1S14 Up to 3 A step down switching regulator
    ST1S15 500 mA, 6 MHz synchronous step-down converter
    ST1S30 3 A, 1.5 MHz PWM step-down switching regulator with synchronous rectification
    ST1S31 3 A DC step-down switching regulator
    ST1S32 4 A DC step-down switching regulator
    ST1S40 3A DC step-down switching regulator
    ST2S06A33 SYNCHRONOUS RETTIFICATION 0.5 A, 1.5 MHZ STEP-DOWN SWITCHING REGULATOR
    ST2S06B SYNCHRONOUS RETTIFICATION 0.5 A, 1.5 MHZ STEP-DOWN SWITCHING REGULATOR
    ST2S08B Dual synchronous rectification, 1.5 A, 1.5 MHz adjustable step-down switching regulator
    ST619LB DC-DC CONVERTER REGULATED 5V CHARGE PUMP
    ST763AC 3.3V STEP DOWN CURRENT MODE PWM DC-DC CONVERTERS
    ST8R00 MICROPOWER STEP UP DC/DC CONVERTER
    STOD1317B 170 mA 13 V, high efficiency boost converter + LDO
    STOD1812 Power supply for PMOLED display panel
    STOD2540 PMOLED display power supply
    TSM108 Step down controller with constant voltage/current
    电池管理
    电池管理
    型号 概述
    EFL700A39 EnFilm? - rechargeable solid state lithium thin film battery
    L6924D Single Cell Li Ion battery Charger
    L6924U Single Cell Li-Ion Battery Charger IC for USB port and AC Adapter
    STBC08 800mA STANDALONE LINEAR Li-Ion Battery charger with therminal regulation
    STBC21 LI+ battery charger with thermal regulation
    STC3100 Battery monitor IC with Coulomb counter/gas gauge
    STC3105 Battery monitor IC with alarm output for gas gauge applications
    STC4054 800mA STANDALONE LINEAR Li-Ion Battery charger with therminal regulation
    STw4102 Dual source USB Li-ion charger with gas gauge
    AC-DC转换
    AC-DC转换
    型号 概述
    ALTAIR04-900 Off-line all-primary-sensing switching regulator
    ALTAIR05T-800 Off-line all-primary-sensing switching regulator
    L4981 L4981A: Fixed Frequency Average Current Mode; L4981B: Line Modulated Frequency Average Current Mode
    L4984 CCM PFC CONTROLLER
    L5991 Current Mode PWM
    L6561 Transition mode power factor corrector
    L6562 Transition mode
    L6562A Transition-mode PFC controller BCD technology
    L6562AT Transition-mode PFC controller
    L6563 Advanced transition-mode PFC controller
    L6563A Advanced transition-mode PFC controller
    L6563H High voltage start-up transition-mode PFC
    L6563S Enhanced transition-mode PFC controller
    L6564 10 pin transition-mode PFC controller
    L6564H High voltage start-up transition-mode PFC
    L6564T 10 pin transition-mode PFC controller for outdoor applications
    L6565 Quasi-resonant Controller
    L6566A Multi-mode controller for SMPS with PFC front-end
    L6566B Multi-mode controller for SMPS
    L6566BH Multi-mode controller for SMPS
    L6591 Current mode PWM controller for Asymmetrical Half Bridge converter topology
    L6598 Resonant Controller
    L6599 High-voltage resonant controller
    L6599A IMPROVED HIGH-VOLTAGE RESONANT CONTROLLER
    L6599AT IMPROVED HIGH-VOLTAGE RESONANT CONTROLLER
    L6615 High/low side load share controller
    L6668 Smart primary controller
    L6699 Enhanced high-voltage resonant controller
    PM8834 4 A dual low side MOSFET driver
    SEA05 Advanced CV/CC secondary controller
    SEA05L Advanced constant voltage and constant current controller with very efficient LED pilot-lamp driver
    SG2525 Voltage Mode PWM
    SG3524 Voltage Mode PWM
    SG3525 Voltage Mode PWM
    SRK2000 SYNCHRONOUS RECTIFIER SMART DRIVER FOR LLC RESONANT CONVERTER
    STSR2P FORWARD SYNCHRONOUS RECTIFIERS SMART DRIVERS
    STSR2PM FORWARD SYNCHRONOUS RECTIFIERS SMART DRIVERS
    STSR3 SYNCHRONOUS RECTIFIERS SMART DRIVERS FOR FLYBACK
    STSR30 SYNCHRONOUS RECTIFIERS SMART DRIVERS FOR ADAPTOR FLYBACK
    TSM101 VOLTAGE AND CURRENT CONTROLLER
    TSM1011 Constant Voltage and Constant Current Controller
    TSM1012 LOW CONSUMPTION VOLTAGE AND CURRENT CONTROLLER FOR BATTERY CHARGERS AND ADAPTORS
    TSM1013 Constant Voltage and Constant Current Controller for Battery Chargers and Adaptors
    TSM1014 Low Consumption Voltage and Current Controller for Battery Chargers and Adaptors
    TSM102 Dual Op-Amp + Dual Comparator + VRef (Bipolar), Adjustable
    TSM103W Dual operational amplifier and voltage reference
    TSM104W Quad Operational Amplifier and Voltage Reference
    TSM1052 Constant voltage and constant current controller for battery chargers and adapters
    TSM106 Dual Operational Amplifier and Voltage Reference
    TSM107 Triple operational amplifier and voltage reference
    TSM109 DUAL COMPARATOR AND VOLTAGE REFERENCE
    TSM111 3.3, 5, 12V triple over voltage and over current protection
    UC2842B Current Mode PWM
    UC2843B Current Mode PWM
    UC2844B Current Mode PWM
    UC2845B Current Mode PWM
    UC3842B Current Mode PWM
    UC3843B Current Mode PWM
    UC3844B Current Mode PWM
    UC3845B Current Mode PWM
    VIPER06 Fixed frequency VIPerTM plus family
    VIPER100-E Fixed frequency off line converter
    VIPER100A-E Fixed frequency off line converter
    VIPER12A-E Fixed frequency off line converter
    VIPER15 VIPerPlus family: quasi-resonant high performance off line high voltage converter
    VIPER16 VIPerPlus family: fixed frequency high performance off line high voltage converter
    VIPER17 VIPerPlus family: fixed frequancy high performance off line high voltage converter
    VIPER20A-E Fixed frequency off line converter
    VIPER22A-E Fixed frequency off line converter
    VIPER22ADIP-E Fixed frequency off line converter
    VIPER22AS-E Low power off-line SMPS primary switcher
    VIPER25 VIPerPlus family: quasi-resonant high performance off line high voltage converter
    VIPER26 VIPerPlus family: fixed frequency high performance off line high voltage converter
    VIPER27 VIPerPlus family: fixed frequency high performance off line high voltage converter
    VIPER28 VIPerPlus family: fixed frequency high performance off line high voltage converter
    VIPER37 VIPerPlus Family: Fixed frequency off line converter
    VIPER50A-E Fixed frequency off line converter
    VIPER53-E Fixed frequency off line converter
    VIPER53E-E Fixed frequency off line converter
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
