龙人旗下深圳市龙芯世纪科技有限公司
  • ADSP-21xx处理器 SigmaDSP音频处理器 MicroConverter模拟微控制器
  • 发布时间:2013/3/18 18:05:37   修改时间:2013/3/18 18:06:20 浏览次数:6511
  • ADSP-21xx处理器
    ADSP-21xx 处理器, 系列处理器是工作频率达160 MHz、功耗电流低到184 μA、代码兼容和引脚兼容的数字信号处理器 (DSP)。21xx系列产品包括适合蜂窝通信应用在Softfone 产品中嵌入的系统芯片(SOC)级集成产品,以及适合电机控制应用的2199x系列产品。21xx系列产品广泛用于从调制解调到工业测试设备多种应用。
    Performance Packaging & Temp Range Memory Peripherals 开发工具
     型号 Clock Speed MHz (Max) External (IO) Supply Voltage Package Temp Range Program RAM Words Data RAM Word (KWords) Ext. Memory Bus (Bits) Timers Host Port SPORT SPI/UART ADC 评估版 Development Software
      (KWords)
    ADSP-21990 160 3.3 176 LQFP, 196 CSP_BGA Industrial 4 4 24 3 Yes 1 Yes 14 bit Dual Ch, 20 MSPS VisualDSP++
    ADSP-21991 160 3.3 176 LQFP, 196 CSP_BGA Industrial 32 8 24 3 Yes 1 Yes 14 bit Dual Ch, 20 MSPS VisualDSP++
    ADSP-21992 160 3.3 176 LQFP, 196 CSP_BGA Industrial 32 16 24 3 Yes 1 Yes 14 bit Dual Ch, 20 MSPS VisualDSP++
    ADSP-2191M 160 3.3 144 LQFP, 144 CSP_BGA Industrial, Commercial 32 32 16 3 Yes 3 Yes 0 VisualDSP++
    ADSP-2196M 160 3.3 144 LQFP, 144 CSP_BGA Industrial, Commercial 8 8 16 3 Yes 3 Yes 0 VisualDSP++
    ADSP-2188N 80 1.8, 2.5, 3.3 144 LQFP, 144 CSP_BGA Industrial, Commercial 48 56 24 1 Yes 2 No 0 ADZS-2189M-EZLITE VisualDSP++
    ADSP-2189N 80 1.8, 2.5, 3.3 144 LQFP, 144 CSP_BGA Industrial, Commercial 32 48 24 1 Yes 2 No 0 ADZS-2189M-EZLITE VisualDSP++
    ADSP-2187N 80 1.8, 2.5, 3.3 144 LQFP, 144 CSP_BGA Industrial, Commercial 32 32 24 1 Yes 2 No 0 ADZS-2189M-EZLITE VisualDSP++
    ADSP-2185N 80 1.8, 2.5, 3.3 144 LQFP, 144 CSP_BGA Industrial, Commercial 16 16 24 1 Yes 2 No 0 ADZS-2189M-EZLITE VisualDSP++
    ADSP-2186N 80 1.8, 2.5, 3.3 144 LQFP, 144 CSP_BGA Industrial, Commercial 8 8 24 1 Yes 2 No 0 ADZS-2189M-EZLITE VisualDSP++
    ADSP-2184N 80 1.8, 2.5, 3.3 144 LQFP, 144 CSP_BGA Industrial, Commercial 4 4 24 1 Yes 2 No 0 ADZS-2189M-EZLITE VisualDSP++
    ADSP-2188M 75 2.75, 3.3 144 LQFP, 144 CSP_BGA Industrial, Commercial 48 56 24 1 Yes 2 No 0 ADZS-2189M-EZLITE VisualDSP++
    ADSP-2189M 75 2.5, 3.3 144 LQFP, 144 CSP_BGA Industrial, Commercial 32 48 24 1 Yes 2 No 0 ADZS-2189M-EZLITE VisualDSP++
    ADSP-2185M 75 2.5, 3.3 144 LQFP, 144 CSP_BGA Industrial, Commercial 16 16 24 1 Yes 2 No 0 ADZS-2189M-EZLITE VisualDSP++
    ADSP-2186M 75 2.5, 3.3 144 LQFP, 144 CSP_BGA Industrial, Commercial 8 8 24 1 Yes 2 No 0 ADZS-2189M-EZLITE VisualDSP++
    SigmaDSP?音频处理器
    SigmaDSPSigmaDSP?数字音频处理器使每个人都可以使用SigmaStudio?图形开发工具进行简单配置的完全可编程音频DSP。包括AD1953在内的第一代SigmaDSP产品集成了三个高性能音频DAC与功能强大的DSP内核。第二代全数字器件AD1940与AD1941具有更多的I/O通道,可提供更强的处理能力。
    最新的SigmaDSP产品ADAU1701与ADAU1702结合了完整的模拟I/O、数字I/O以及独立执行(stand-alone)功能,可在单芯片上提供完整的音频处理系统。ADAU1401的功能与ADAU1701相似,但它专为汽车市场设计,可在更宽的温度范围内工作。
    SigmaStudio是一种完全图形化的可编程工具,允许用户使用熟悉的音频处理模块(如双二阶滤波器、延迟以及动态处理器)产生信号流。这个设计工具可以直接与SigmaDSP硬件进行连接,SigmaStudio工具还可以用作设计参数的实时控制界面,可以轻松的实现系统调整。面向SigmaDSP的第三方算法,如Dolby? ProLogic?II、Audistry?、Waves MaxxBass?以及SRS? TruSurround XT?,已经无缝集成入SigmaStudio环境中。
    Part# Results: 11 Instructions/Cycles Data RAM (k Words) Digital I/O Channels Analog I/O Channels GPIOs Features Product Description Price* (1000 pcs.)
    AD1940 1,536 6 16/16 0/0 - - Multichannel 28-/56-bit audio processor with 4-wire SPI control interface $8.45
    AD1941 1,536 6 16/16 0/0 - - Multichannel 28-/56-bit audio processor with 2-wire I2C control interface $8.45
    ADAU1401A 1,024 2 8/8 - 12 Selfboot from EEPROM, Auxiliary ADCs 28-/56-bit automotive audio processor with 2 ADCs and 4 DACs $5.68
    ADAU1442 3,584 8 24/24 0/0 12 8x2-ch ASRC, Selfboot from EEPROM, S/PDIF Rx, Aux A/Ds Digital audio processor with flexible audio routing matrix, 2 × 8-channel ASRC $9.96
    ADAU1445 3,584 8 24/24 0/0 12 2x8-ch ASRC, Selfboot from EEPROM, S/PDIF Rx, Aux A/Ds Digital audio processor with flexible audio routing matrix, 8 × 2-channel ASRC $9.31
    ADAU1446 3,584 8 24/24 0/0 12 Selfboot from EEPROM, Auxiliary ADCs Digital audio processor with flexible audio routing matrix $8.28
    ADAU1461 1,024 4 8/8 2/2 4 Digital Microphone inputs, headphone amp, Frac PLL Stereo, low power, 96 kHz, 24-bit automotive SigmaDSP audio codec with integrated PLL $4.89
    ADAU1701 1,024 2 8/8 2/4 12 Selfboot from EEPROM, Auxiliary ADCs 28-/56-bit audio processor with 2 ADCs and 4 DACs $4.52
    ADAU1702 512 0.5 8/8 2/4 12 Selfboot from EEPROM, Auxiliary ADCs 28-/56-bit audio processor with 2 ADCs and 4 DACs $3.57
    ADAU1761 1,024 4 8/8 2/2 4 Digital Microphone inputs, headphone amp, Frac PLL Stereo, low power, 96 kHz, 24-bit SigmaDSP audio codec with integrated PLL $3.91
    ADAU1781 512 0.5 8/8 2/2 5 Digital microphone inputs, mono speaker amp, Frac PLL SigmaDSP low-noise stereo audio codec for portable applications $3.20
    Part# Results: 3 Instructions/Cycles # ADC Input Channels # DAC Outputs DAC DNR (dB) DAC THD+N @ 1 kHz (-3dB) ADC THD+N (dB) Digital I/O Channels Digital Output PWM Chs Product Description Price* (1000 pcs.)
    ADAV4322 2,560 4 11 95 85 -90 8/2 - Audio Processor for Advanced TV w/ Sound IF Demod & Stereo Decoder **
    ADAV4601 - 2 6 94 86 -90 - 8 Audio Processor for Advanced TV $6.21
    ADAV4622 2,560 4 8 94 86 -90 - 8 Audio Processor for Advanced TV with Sound IF Demodulator and Stereo Decoder $
    模拟微控制器
    Analog Devices( ADI公司)的MicroConverter?系列精密模拟微控制器融合了多种精密模拟功能,例如:高分辨率模数转换器(ADC)和数模转换器(DAC)、基准电压源和温度传感器以及符合工业标准的微控制器(MCU)和内置闪存。其中ADuC7000系列产品具有ARM7? 32 bit精简指令集计算机(RISC)MCU内核,ADuC800系列产品具有符合工业标准的8052 MCU内核。
    Part#
    Results: 36
    MCU Core MCU Speed (MIPS) Flash (kbytes) SRAM (bytes) GPIO Pins Resolution (Bits) Sample Rate ADC # Channels Other 12 Bit DAC Outputs US Price 1000-4999
    ADuC7126 ARM7 TDMI 40 126KBytes 32KBytes 40 12bit 1MSPS 16 PWM 4 $6.34
    ADuC7124 ARM7 TDMI 40 126KBytes 32KBytes 30 12bit 1MSPS 12 - 2 $5.98
    ADuC7039 ARM7 TDMI 40 64KBytes 4.096KBytes 5 16bit 1KSPS 1 - 0 $4.36
    ADuC7122 ARM7 TDMI 40 126KBytes 8.192KBytes 32 - 1MSPS 13 - 4 $8.7
    ADuC7023 ARM7 TDMI 40 62KBytes 8.192KBytes 20 - 1MSPS 12 PWM 4 $2.99
    ADuC7029 ARM7 TDMI 40 62KBytes 8.152KBytes 22 12bit 1MSPS 7 - 4 $4.66
    ADuC7121 ARM7 TDMI 40 126KBytes 8.192KBytes 32 12bit 1MSPS 9 - 4 $11.13
    ADuC7061 ARM7 TDMI 10 32KBytes 4.096KBytes 8 24bit 8KSPS 10 14 Bit DAC, PWM - $3.4
    ADuC7060 ARM7 TDMI 10 32KBytes 4.096KBytes 14 24bit 8KSPS 10 14 Bit DAC, PWM - $4.4
    ADuC7036 ARM7 TDMI 20 96KBytes 6.144KBytes 9 16bit 8KSPS 2 - - $6.72
    ADuC7034 ARM7 TDMI 20 32KBytes 4.096KBytes 9 16bit 8KSPS 2 - - $6.37
    ADuC7033 ARM7 TDMI 20 96KBytes 6.144KBytes 9 16bit - - - - $6.72
    ADuC7128 ARM7 TDMI 40 126KBytes 8.192KBytes 28 12bit 1MSPS 10 10 Bit DAC, PWM - $7.03
    ADuC7129 ARM7 TDMI 40 126KBytes 8.192KBytes - 12bit 1MSPS 12 - - $7.83
    ADuC7019 ARM7 TDMI 40 62KBytes 8.192KBytes 14 12bit 1MSPS 5 - 3 $6.42
    ADuC7020 ARM7 TDMI 40 62KBytes 8.192KBytes 14 12bit 1MSPS 5 - 4 $6.88
    ADuC7021 ARM7 TDMI 40 62KBytes 8.192KBytes 13 12bit 1MSPS 8 - 2 $4.94
    ADuC7022 ARM7 TDMI 40 62KBytes 8.192KBytes 13 12bit 1MSPS 10 - - $4.03
    ADuC7024 ARM7 TDMI 40 62KBytes 8.192KBytes 30 12bit 1MSPS 10 PWM 2 $5.66
    ADuC7025 ARM7 TDMI 40 62KBytes 8.192KBytes 30 12bit 1MSPS 12 PWM - $5.3
    ADuC7027 ARM7 TDMI 40 62KBytes 8.192KBytes 40 12bit 1MSPS 16 PWM - $6.5
    ADuC7026 ARM7 TDMI 40 62KBytes 8.192KBytes 40 12bit 1MSPS 12 PWM 4 $8.91
    ADuC845 8052 (1-clk) 12 62KBytes 2.304KBytes 34 24bit 1.37KSPS 10 PWM 1 $9.04
    ADuC847 8052 (1-clk) 12 62KBytes 2.304KBytes 34 24bit 1.37KSPS 10 PWM 1 $5.92
    ADuC848 8052 (1-clk) 12 62KBytes 2.304KBytes 34 16bit 1.37KSPS 10 PWM 1 $5.04
    ADuC841 8052 (1-clk) 20 62KBytes 2.304KBytes 34 12bit 400KSPS 8 PWM 2 $6.64
    ADuC842 8052 (1-clk) 16 62KBytes 2.304KBytes 34 12bit 400KSPS 8 PWM 2 $6.64
    ADuC843 8052 (1-clk) 16 62KBytes 2.304KBytes 34 12bit 400KSPS 8 PWM - $5.21
    ADuC831 8052 (12-clk) 1.3 62KBytes 2.304KBytes 34 12bit 247KSPS 8 PWM 2 $8.87
    ADuC832 8052 (12-clk) 1.3 62KBytes 2.304KBytes 34 12bit 247KSPS 8 PWM 2 $8.87
    ADuC834 8052 (12-clk) 1 62KBytes 2.304KBytes 34 24bit 105SPS 4 PWM 1 $12.47
    ADuC836 8052 (12-clk) 1 62KBytes 2.304KBytes 34 16bit 105SPS 4 PWM 1 $9.97
    ADuC814 8052 (12-clk) 1.3 8KBytes 256Bytes 17 12bit 247KSPS 6 - 2 $4.57
    ADuC816 8052 (12-clk) 1.3 8KBytes 256Bytes 34 16bit 105SPS 4 - 1 $5.66
    ADuC824 8052 (12-clk) 1 8KBytes 256Bytes 34 24bit 105SPS 4 - 1 $6.14
    ADuC812 8052 (12-clk) 1.3 8KBytes 256Bytes 34 12bit 200KSPS 8 - 2 $8.65
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
