龙人旗下深圳市龙芯世纪科技有限公司
  • 串行收发器
  • 发布时间:2013/7/17 10:16:19   修改时间:2013/7/17 10:16:19 浏览次数:2237
  • 串行收发器
    多协议
    name 发送器
    数量(Tx)
    接收器
    数量(Rx)
    数据传输
    速率(kbps)
    电源电压
    Vcc(V)
    Typ.
    集成元件
    电路(mA)
    静电放电
    ESD(KV)
    终止 支持协议 说明书
    SP331 4 4 10000 5 2 RS232, V.28, RS485, RS422, V.24 RS232/RS485
    SP332 4 4 10000 5 2 RS232, V.28, RS485, RS422, V.24 RS232/RS485 w/回送
    SP334 3 3 10000 5 2 RS232, V.28, RS485, RS422, V.24 RS232/Appletalk
    SP336 4 4 250/100/10000 3.3 or 5 2 15 n/a RS-232, V.28, RS-485, RS-422, V.24 4Tx/4Rx - RS-232, 2Tx/2Rx - RS-485/RS-422
    SP337 4 4 250/100/10000 3.3 or 5 2 15 n/a RS-232, V.28, RS-485, RS-422, V.24 4Tx/4Rx - RS-232, 2Tx/2Rx - RS-485/RS-422
    SP338 3/1 5/1 256/1M/20M 3.3 or 5 2 15 Complete RS-232, V.28, RS-485, RS-422, V.24
    SP339 3/1 5/1 256/1M/20M 3.3 or 5 2 15 Complete RS-232, V.28, RS-485, RS-422, V.24
    SP3508 8 8 20000 3.3 4 完整 RS232, RS449,EIA530, EIA530A,V.10, V.11, V.28, V.35, V.36,X.21 3V单电源供电,单芯片
    SP503 7 7 5000 5 2 N/A RS232, RS449,EIA530, V.10, V.11, V.28, X.21, RS485 基本、单芯片多协议
    SP504 7 7 10000 5 2 基本 RS232, RS449,EIA530, V.10, V.11, V.28, X.21, RS485, V.35 简化的V.35终端
    SP505A 7 7 10000 5 2 V.35, V.11 RS232, RS449,EIA530, ,V.10, V.11, V.28, V.35, V.36,X.21 完全V.35终端
    SP505B 7 7 16000 5 2 V.35, V.11 RS232, RS449,EIA530, ,V.10, V.11, V.28, V.35, V.36,X.21 完全V.35终端
    SP506 7 7 20000 5 2 V.35, V.11 RS232, RS449,EIA530, ,V.10, V.11, V.28, V.35, V.36,X.21 完全V.35终端
    SP507 7 7 20000 5 2 V.35, V.11 RS232, RS449,EIA530, EIA530A,V.10, V.11, V.28, V.35, V.36,X.21 完全V.35终端
    SP508 8 8 20000 5 15 RS232, RS449,EIA530, EIA530A,V.10, V.11, V.28, V.35, V.36,X.21 单芯片, 15kV
    SP508E 8 8 20000 5 15 RS232, RS449,EIA530, EIA530A,V.10, V.11, V.28, V.35, V.36,X.21 单芯片, 15kV
    SP510 8 8 52000 5 15 Complete RS232, RS449,EIA530, EIA530A,V.10, V.11, V.28, V.35, V.36, X.21 Single Chip, 15kV
    SP510E 8 8 52000 5 15 Complete RS232, RS449,EIA530, EIA530A,V.10, V.11, V.28, V.35, V.36, X.21 Single Chip, 15kV
    SP514 7 7 10000 5 2 Basic RS232, RS449,EIA530, EIA530A,V.10, V.11, V.28, V.35, V.36,X.21 After LTB of May 31, The SP514CF-L does not have a drop-in replacement. However, Sipex will continue to sell the following func
    SP526 4 4 10000 5 15 N/A RS232, RS449, EIA530, EIA530A,V.10, V.11, V.28, V.36, X.21 握手/控制收发器
    RS232
    name 发送器
    数量(Tx)
    接收器
    数量(Rx)
    数据传输
    速率(kbps)
    静电放电
    ESD(KV)
    最低
    电源电压
    Vcc(V)
    最高
    电源电压
    Vcc(V)
    电源电压
    Vcc(V)
    内置
    电荷泵
    外部
    电容器
    数量
    额定
    电容值
    (μF)
    关断 TTL 三态
    SP202E 2 2 120 15 4.5 5.5 5 4 0.1 ?
    SP206 4 3 120 2 4.5 5.5 5 4 0.1
    SP207 5 3 120 2 4.5 5.5 5 4 0.1 ?
    SP207E 5 3 120 15 4.5 5.5 5 4 0.1 ?
    SP208 4 4 120 10 4.5 5.5 5 4 0.1
    SP208E 4 4 120 15 4.5 5.5 5 4 0.1
    SP211 4 5 120 2 4.5 5.5 5 4 0.1 ?
    SP211E 4 5 120 15 4.5 5.5 5 4 0.1 ?
    SP211EH 4 5 460 15 4.5 5.5 5 4 0.1 ?
    SP213E 4 5 120 15 4.5 5.5 5 4 0.1 ?
    SP213EH 4 5 460 15 4.5 5.5 5 4 0.1 ?
    SP2209E 6 10 460 15 10.8 13.2 12 2 0.1
    SP232A 2 2 120 2 4.5 5.5 5 4 0.1 ?
    SP232E 2 2 120 15 4.5 5.5 5 4 0.1
    SP233A 2 2 120 2 4.5 5.5 5 0 ?
    SP233E 2 2 120 15 4.5 5.5 5 0 ?
    SP235B 5 5 20 2 4.5 5.5 5 0 ?
    SP238A 4 4 20 2 4.5 5.5 5 4 1 ?
    SP310A 2 2 120 2 4.5 5.5 5 4 0.1
    SP310E 2 2 120 15 4.5 5.5 5 4 0.1
    SP312A 2 2 120 2 4.5 5.5 5 4 0.1
    SP312E 2 2 120 15 4.5 5.5 5 4 0.1
    SP3203E 3 2 250 15 3 5.5 3.3 4 0.1 ?
    SP3220E 1 1 120 15 3 5.5 3.3 4 0.1 ?
    SP3220EU 1 1 1000 15 3 5.5 3.3 4 0.1 ?
    SP3222E 2 2 120 15 3 5.5 3.3 4 0.1 ?
    SP3222EB 2 2 250 15 3 5.5 3.3 4 0.1 ?
    SP3222EU 2 2 1000 15 3 5.5 3.3 4 0.1 ?
    SP3223E 2 2 120 15 3 5.5 3.3 4 0.1 ?
    SP3223EB 2 2 250 15 3 5.5 3.3 4 0.1 ?
    SP3223EU 2 2 1000 15 3 5.5 3.3 4 0.1 ?
    SP3224E 2 2 250 15 3 5.5 3.3 ? 4 0.1 ? ?
    SP3225E 2 2 250 15 3 5.5 3.3 ? 4 0.1 ? ?
    SP3226E 1 1 1 15 3 5.5 3.3 ? 4 0.1 ? ?
    SP3227E 1 1 1 15 3 5.5 3.3 ? 4 0.1 ? ?
    SP3232E 2 2 120 15 3 5.5 3.3 4 0.1 ?
    SP3232EB 2 2 250 15 3 5.5 3.3 4 0.1
    SP3232EH 2 2 460 15 3 5.5 3.3 4 0.1
    SP3232EU 2 2 1000 15 3 5.5 3.3 4 0.1
    SP3238E 5 3 250 15 3 5.5 3.3 4 0.1 ?
    SP3239E 5 3 250 15 3 5.5 3.3 4 0.1 ?
    SP3243E 3 5 120 15 3 5.5 3.3 4 0.1 ?
    SP3243EB 3 5 250 15 3 5.5 3.3 4 0.1
    SP3243EH 3 5 460 15 3 5.5 3.3 4 0.1
    SP3243EU 3 5 1000 15 3 5.5 3.3 4 0.1
    SP3244E 3 5 250 15 3 5.5 3.3 4 0.1
    SP3245E 3 5 1000 15 3 5.5 3.3 4 0.1
    SP3249E 5 3 250 15 3 5.5 3.3 4 0.1
    SP385E 2 2 120 15 3 5 3.6 4 0.1
    RS422
    name 电源电压
    Vcc(V)
    发送器
    数量(Tx)
    接收器
    数量(Rx)
    双工 数据传输
    速率(kbps)
    静电放电
    ESD(KV)
    典型关断
    集成元件
    电路(μA)
    接收开路
    故障防护
    接收短路
    故障防护
    关断 多点节点
    SP1481E 5 1 1 Half 20000 15 10 ? ? ? 32
    SP1485E 5 1 1 Half 20000 15 ? ? 32
    SP1486E 5 1 1 Half 20000 15 1 ? ? 256
    SP1490E 5 1 1 Full 20000 15 ? 32
    SP1491E 5 1 1 Full 20000 15 10 ? ? 32
    SP26LV431 3.3 4 0 60000 2 2 10
    SP26LV432 3.3 0 4 50000 2 5000 10
    SP3070E 3.3 1 1 250 15 0.05 256
    SP3071E 3.3 1 1 250 15 0.05 256
    SP3072E 3.3 1 1 250 15 0.5 256
    SP3073E 3.3 1 1 500 15 0.5 256
    SP3074E 3.3 1 1 500 15 0.05 256
    SP3075E 3.3 1 1 500 15 0.5 256
    SP3076E 3.3 1 1 16000 15 0.5 256
    SP3077E 3.3 1 1 16000 15 0.05 256
    SP3078E 3.3 1 1 16000 15 0.5 256
    SP3080E 5 1 1 115 15 1 256
    SP3081E 5 1 1 Full 115 15 1 ? ? 256
    SP3082E 5 1 1 Half 115 15 1 ? ? ? 256
    SP3083E 5 1 1 Full 500 15 1 ? ? ? 256
    SP3084E 5 1 1 Full 500 15 ? ? 256
    SP3085E 5 1 1 Half 500 15 1 ? ? ? 256
    SP3086E 5 1 1 Full 20000 15 1 ? ? ? 256
    SP3087E 5 1 1 Full 20000 15 ? ? 256
    SP3088E 5 1 1 Half 20000 15 1 ? ? ? 256
    SP3483 3.3 1 1 Half 250 2 1 ? ? 32
    SP3485 3.3 1 1 10000 2 10 32
    SP3490 3.3 1 1 10000 2 32
    SP3491 3.3 1 1 Full 10000 2 10 ? ? 32
    SP3494 3.3 1 1 2500 2 10 32
    SP3495E 3.3 1 1 Half 32000 15 1 ? 64
    SP3496E 3.3 1 1 Full 32000 15 1 ? ? 64
    SP3497E 3.3 1 1 Full 32000 15 1 ? ? ? 64
    SP4082E 5V 1 1 Half 115kbps 15KV 400 ? 256
    SP481E 5 1 1 10000 15 1 32
    SP483 5 1 1 250 2 1 32
    SP483E 5 1 1 Half 250 15 1 ? ? 32
    SP485 5 1 1 5000 2 32
    SP485E 5 1 1 10000 15 32
    SP485R 5 1 1 Half 1000 2 0.5 ? 400
    SP486 5 4 0 Quad 10000 2 32
    SP487 5 4 0 4线 10000 2 32
    SP490 5 1 1 5000 2 32
    SP490E 5 1 1 Full 10000 15 ? 32
    SP491 5 1 1 5000 2 32
    SP491E 5 1 1 10000 15 ? 32
    XR5486E 5 1 1 Full 52000 15 1 ? 256
    XR5487E 5 1 1 Full 52000 15 1 ? 256
    XR5488E 5 1 1 Half 52000 15 1 ? 256
    RS485
    name 电源电压
    Vcc(V)
    发送器
    数量(Tx)
    接收器
    数量(Rx)
    双工 数据传输
    速率(kbps)
    静电放电
    ESD(KV)
    典型关断
    集成元件
    电路(μA)
    接收开路
    故障防护
    接收短路
    故障防护
    关断 多点节点
    SP1481E 5 1 1 20000 15 10 32
    SP1485E 5 1 1 20000 15 32
    SP1490E 5 1 1 20000 15 32
    SP1491E 5 1 1 20000 15 10 32
    SP3070E 3.3 1 1 Full 250 15 0.05 ? ? ? 256
    SP3071E 3.3 1 1 Full 250 15 0.05 ? ? 256
    SP3072E 3.3 1 1 Half 250 15 0.5 ? ? ? 256
    SP3073E 3.3 1 1 Full 500 15 0.5 ? ? ? 256
    SP3074E 3.3 1 1 Full 500 15 0.05 ? ? 256
    SP3075E 3.3 1 1 Half 500 15 0.5 ? ? ? 256
    SP3076E 3.3 1 1 Full 16000 15 0.5 ? ? ? 256
    SP3077E 3.3 1 1 Full 16000 15 0.05 ? ? 256
    SP3078E 3.3 1 1 Half 16000 15 0.5 ? ? ? 256
    SP3080E 5 1 1 Full 115 15 1 256
    SP3081E 5 1 1 Full 115 15 ? ? 256
    SP3084E 5 1 1 Full 500 15 1 ? ? 256
    SP3483 3.3 1 1 250 2 1 32
    SP3491 3.3 1 1 10000 2 10 32
    SP3495E 3.3 1 1 32000 15 1 64
    SP3496E 3.3 1 1 32000 15 1 64
    SP3497E 3.3 1 1 32000 15 1 64
    SP483E 5 1 1 250 15 1 32
    SP485R 5 1 1 1000 2 0.5 400
    SP486 5 4 0 4线 10000 2 32
    SP490E 5 1 1 10000 15 ? 32
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
