龙人旗下深圳市龙芯世纪科技有限公司
  • 硅振荡器
  • 发布时间:2013/7/25 9:00:53   修改时间:2013/7/25 9:00:53 浏览次数:1557
  • 硅振荡器
    硅振荡器是工作频率范围为 1kHz 至 170MHz 的固态时钟。凌力尔特公司的每款硅振荡器的频率均可通过引脚搭接、电阻器连接或串行接口 (SPI 或 I2C) 来设置。
    硅振荡器非常适合诸如 PGA、ASIC、微处理器、UART 等一般用途。硅振荡器还是理想开关稳压器时钟的完美选择,可提供同步并降低 EMI (利用扩频技术)。
    硅振荡器
    Product Number of Outputs  Program Method  Frequency Range  Frequency Accuracy  (%) Isupply  (mA) Timing Jitter  (%) Comments  Packages
    LTC1799 1 Resistor 1kHz - 33MHz 1.5 1 0.06 High Frequency SOT-23
    LTC6900 1 Resistor 1kHz - 20MHz 1.5 0.5 0.1 Low Power SOT-23
    LTC6902 1 Resistor 5kHz - 20MHz 1.5 0.5 0.1 Multiphase Oscillator with Spread Spectrum Frequency Modulation MSOP-10
    LTC6903 1 Serial SPI 1kHz - 68MHz 1.1 3 0.4 SPI Interface MSOP-8
    LTC6904 1 Serial I2C 1kHz - 68MHz 1.1 3 0.4 I2C Interface MSOP-8
    LTC6905 1 Resistor 17MHz to 170MHz 0.5 3 0.8 17MHz to 170MHz Resistor Set SOT-23 Oscillator SOT-23
    LTC6905-XXX 1 Fixed Frequency 100MHz, 50MHz or 25MHz (fixed) 0.5 8 0.8 Contact factory for other fixed frequencies SOT-23
    LTC6905-XXX 1 Fixed Frequency 133MHz, 66.7MHz or 33.3MHz (fixed) 0.5 10 0.8 Contact factory for other fixed frequencies SOT-23
    LTC6905-XXX 1 Fixed Frequency 80MHz, 40MHz or 20MHz (fixed) 0.5 7 0.8 Contact factory for other fixed frequencies SOT-23
    LTC6905-XXX 1 Fixed Frequency 96MHz, 48MHz or 24MHz (fixed) 0.5 8 0.8 Contact factory for other fixed frequencies SOT-23
    LTC6906 1 Resistor 10kHz - 1MHz 0.25 0.012 0.03 Lowest power, 12uA supply current SOT-23
    LTC6907 1 Resistor 40kHz - 4MHz 0.25 0.04 0.12 Micropower, 40kHz to 4MHz Resistor Set Oscillator in SOT-23 SOT-23
    LTC6908 2 Resistor 50kHz to 10MHz 1.5 0.4 0.1 Resistor Set Oscillator with Spread Spectrum Modulation SOT-23, DFN-6
    LTC6909 8 Resistor 12.5kHz to 6.67MHz 0.5 0.37 0.2 1 to 8 Output, Multiphase Silicon Oscillator with Spread Spectrum Modulation MS-16
    LTC6930 1 Fixed Frequency 32kHz, 65kHz, 131kHz, 262kHz, 524kHz, 1.048MHz, 2.097MHz, 4.194MHz (fixed) 0.09 0.08 0.15 32.768kHz to 8.192MHz Precision 碌Power Oscillators DFN-8, MS-8
    LTC6930 1 Fixed Frequency 39kHz, 78kHz, 312kHz, 625kHz, 1.25MHz, 2.5MHz, 5MHz (fixed) 0.09 0.08 0.15 32.768kHz to 8.192MHz Precision 碌Power Oscillators DFN-8, MS-8
    LTC6930 1 Fixed Frequency 57kHz, 115kHz, 230kHz, 460kHz, 921kHz, 1.84MHz, 3.68MHz, 7.37MHz (fixed) 0.09 0.08 0.15 32.768kHz to 8.192MHz Precision 碌Power Oscillators DFN-8, MS-8
    LTC6930 1 Fixed Frequency 62.5kHz, 125kHz, 250kHz, 500kHz, 1MHz, 2MHz, 4MHz, 8MHz (fixed) 0.09 0.08 0.15 32.768kHz to 8.192MHz Precision 碌Power Oscillators DFN-8, MS-8
    LTC6930 1 Fixed Frequency 64kHz, 128kHz, 256kHz, 512kHz, 1.024MHz, 2.048MHz, 4.096MHz, 8.192MHz (fixed) 0.09 0.08 0.15 32.768kHz to 8.192MHz Precision 碌Power Oscillators DFN-8, MS-8
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
