龙人旗下深圳市龙芯世纪科技有限公司
  • 差分放大器
  • 发布时间:2013/7/25 9:14:27   修改时间:2013/7/25 9:14:27 浏览次数:1520
  • 凌力尔特公司迅速壮大的差分放大器产品线具有精密薄膜电阻器、集成滤波器、简单的输出共模调节、高负载电容输出驱动电路和轨至轨输出。 (46)
    Product Channels  (#) GBW  (MHz) SR  (V/us) Is  (mA) Enoise Density  (nV/rtHz) Rail-to-Rail Out  (yes/no) Comments  Packages
    LT1993-10 1 700 1100 100 1.7 no Low Distortion ADC Driver, Av="10" QFN-16
    LT1993-2 1 800 1100 100 3.5 no Low Distortion ADC Driver, Av="2" QFN-16
    LT1993-4 1 900 1100 100 2.15 no Low Distortion ADC Driver, Av="4" QFN-16
    LT1994 1 70 65 13.3 3 yes Low Noise, Low Distortion, Diff. In/Out MS-8, DFN-8
    LT6350 1 33 48 4.5 1.9 yes Low Noise Single-Ended to Differential Converter / ADC Driver DFN-8, MS-8
    LT6402-12 1 300 400 30 2.7 no Low Distortion, Low Noise Diff ADC Driver QFN-16
    LT6402-20 1 300 1000 30 1.85 no Low Distortion & Noise Diff. ADC Driver QFN-16
    LT6402-6 1 300 400 30 3.8 no Low Distortion, Low Noise Diff ADC Driver QFN-16
    LT6411 2 650 3300 16 8 no Configurable as Dual Single-Ended or Single Differential Amp QFN-16
    LT6600-10 1 10 35 14 no Low Noise Diff Amp w/ 10MHz LP Filter SO-8, DFN-12
    LT6600-15 1 15 42 19 no Low Noise Diff Amp w/ 15MHz LP Filter SO-8
    LT6600-2.5 1 2.5 26 23 no Low Noise Diff Amp w/ 2.5MHz LP Filter SO-8, DFN-12
    LT6600-20 1 20 42 15 no Low Noise Diff Amp w/ 20MHz LP Filter SO-8
    LT6600-5 1 5 28 16 no Low Noise Diff Amp w/ 5MHz LP Filter SO-8
    LT6604-10 2 10 35 no Dual Very Low Noise, Differential Amplifier and 10MHz Lowpass Filter QFN-34
    LT6604-15 2 15 35 no Dual Very Low Noise, Differential Amplifier and 15MHz Lowpass Filter QFN-34
    LT6604-2.5 2 2.5 26 no Dual Very Low Noise, Differential Ampli铿乪r and 2.5MHz Lowpass Filter QFN-34
    LT6604-5 2 5 26 no Dual Very Low Noise, Differential Ampli铿乪r and 2.5MHz Lowpass Filter QFN-34
    LTC1992 1 4 0.75 0.65 18 yes Fully Differential In/Out, Adjustable Gain MS-8
    LTC1992 1 4 0.75 0.65 18 yes Fully Differential In/Out, Fixed Gain of 1 MS-8
    LTC1992 1 4 0.75 0.65 18 yes Fully Differential In/Out, Fixed Gain of 10 MS-8
    LTC1992 1 4 0.75 0.65 18 yes Fully Differential In/Out, Fixed Gain of 2 MS-8
    LTC1992 1 4 0.75 0.65 18 yes Fully Differential In/Out, Fixed Gain of 5 MS-8
    LTC6400-14 1 1860 4800 85 2.5 no 1.9GHz Low Noise, Low Distortion Differential ADC Driver for 300MHz IF QFN-16
    LTC6400-20 1 1800 4500 90 1.1 no 1.8GHz Low Noise, Low Distortion Differential ADC Driver for 300MHz IF QFN-16
    LTC6400-26 1 1900 6670 85 1.5 no 1.9GHz Low Noise, Low Distortion Differential ADC Driver for DC-300MHz QFN-16
    LTC6400-8 1 2200 3810 85 1 no 2.2GHz Low Noise, Low Distortion Differential ADC Driver for DC-300MHz QFN-16
    LTC6401-14 1 2000 3600 45 1.1 no 2GHz Low Noise, Low Distortion Differential ADC Driver for DC-140MHz QFN-16
    LTC6401-20 1 1300 4500 50 0.91 no 1.3GHz Low Noise, Low Distortion Differential ADC Driver for 140MHz IF QFN-16
    LTC6401-26 1 1600 3300 45 1.5 no 1.6GHz Low Noise, Low Distortion Differential ADC Driver for DC-140MHz QFN-16
    LTC6401-8 1 2200 3400 45 1 no 2.2GHz Low Noise, Low Distortion Differential ADC Driver for DC-140MHz QFN-16
    LTC6403-1 1 200 200 10.8 2.8 yes 200MHz, Low Noise, Low Power Fully Differential Input/Output Ampli铿乪r/Driver QFN-16
    LTC6404 1 600 450 27.2 1.5 yes 600MHz, Low Noise, AC Precision Fully Differential Input/Output Ampli铿乪r/Driver QFN-16
    LTC6404 1 900 700 29.7 1.5 yes 900MHz, Low Noise, AC Precision Fully Differential Input/Output Ampli铿乪r/Driver, designed for closed-loop gains greater than or equal to 2V/V QFN-16
    LTC6404 1 1700 1200 30 1.5 yes 1700MHz, Low Noise, AC Precision Fully Differential Input/Output Ampli铿乪r/Driver, designed for closed-loop gains greater than or equal to 4V/V QFN-16
    LTC6405 1 2700 690 18 1.6 no 2.7GHz, 5V, Low Noise, Rail-to-Rail Input Differential Amplifier/Driver QFN-16, MS-8
    LTC6406 1 3000 630 18 1.6 no 3GHz, Low Noise, Rail-to-Rail Input Differential Amplifier/Driver QFN-16, MS-8
    LTC6409 1 10000 3300 52 1.1 no 10GHz GBW, 1.1nV/rtHz Differential Amplifier/ADC Driver QFN-10
    LTC6410-6 1 1400 1500 104 no Low Distortion, Low Noise Differential IF Amplier with Congurable Input Impedance QFN-16
    LTC6412 1 800 110 no Continuous Analog Gain Control,  Differential In/Out QFN-24
    LTC6416 1 2000 42 1.8 no Differential In/Out; Programmable Output Limiter DFN-10
    LTC6417 1 1600 10000 123 1.5 no 50惟 Load Driver; Differential In/Out; Programmable Output Limiter QFN-20
    LTC6420-20 2 3000 4500 80 2.2 no Dual Matched 1.8GHz Differential Ampli铿乪rs/ADC Drivers QFN-20
    LTC6421-20 2 1300 4500 40 2.2 yes Dual Matched 1.3GHz Differential Ampli铿乪rs/ADC Drivers QFN-20
    LTC6601-1 1 28 32.9 yes Low Noise, 0.5% Tolerance, 5MHz to 28MHz, Pin Configurable Filter/ADC Driver QFN-20
    LTC6601-2 1 28 32 yes Low Power, Low Distortion, 5MHz to 27MHz, Pin Configurable Filter/ADC Driver QFN-20
    LTC6602 2 0.9 65 no Dual Matched, High Frequency Bandpass/Lowpass Filters QFN-16
    LTC6603 2 2.5 88 no Dual Adjustable Lowpass Filter QFN-24
    LTC6605-10 2 10 33.1 2.1 yes Dual Matched 10MHz Filter with Low Noise, Low Distortion Differential Amplifier DFN-22
    LTC6605-14 2 14 33.1 2.1 yes Dual Matched 14MHz Filter with Low Noise, Low Distortion Differential Amplifier DFN-22
    LTC6605-7 2 7 33.1 2.1 yes Dual Matched 7MHz Filter with Low Noise, Low Distortion Differential Amplifier DFN-22
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
