龙人旗下深圳市龙芯世纪科技有限公司
  • IF 放大器 / ADC 驱动器
  • 发布时间:2013/7/25 9:15:28   修改时间:2013/7/25 9:16:35 浏览次数:2234
  • 为满足无线基站和电缆基础设施设备的性能而设计了门类宽泛的高线性度上变频和下变频有源混频器、直接转换 I-Q 解调器、数字可编程增益 ADC 驱动器/放大器和调制器。
    Product Channels  (#) +/-1dB BW  (MHz) Gain Range  OIP3  (dB) Noise Figure  (dB) Isupply  (mA) Comments  Packages
    LT1993-10 1 DC to 100 20dB 40 12.7 100 Low Distortion ADC Driver, Av="10" QFN-16
    LT1993-2 1 DC to 100 6dB 38 12.3 100 Low Distortion ADC Driver, Av="2" QFN-16
    LT1993-4 1 DC to 100 12dB 40 14.5 100 Low Distortion ADC Driver, Av="4" QFN-16
    LT1994 1 DC to 70 Resistor Set 13.3 Low Noise, Low Distortion, Diff. In/Out MS-8, DFN-8
    LT6350 1 2 4.5 Low Noise Single-Ended to Differential Converter / ADC Driver DFN-8, MS-8
    LT6402-12 1 DC to 100 12dB 47.5 15.4 30 Low Distortion, Low Noise Diff ADC Driver QFN-16
    LT6402-20 1 DC to 100 20dB 51 12.4 30 Low Distortion & Noise Diff. ADC Driver QFN-16
    LT6402-6 1 DC to 100 6dB 53 18.6 30 Low Distortion, Low Noise Diff ADC Driver QFN-16
    LTC6360 1 Resistor Set 13.6 Very Low Noise Single-Ended SAR ADC Driver with True Zero Output DFN-8, MS-8
    LTC6362 1 Resistor Set 0.9 Precision, Low Power Rail-to-Rail Input/Output Differential Op Amp/SAR ADC Driver MS-8
    LTC6400-14 1 DC to 300 14dB 59.1 7.5 85 1.9GHz Low Noise, Low Distortion Differential ADC Driver for 300MHz IF QFN-16
    LTC6400-20 1 DC to 300 20dB 51 6.2 90 1.8GHz Low Noise, Low Distortion Differential ADC Driver for 300MHz IF QFN-16
    LTC6400-26 1 DC to 300 26dB 51 6.8 85 1.9GHz Low Noise, Low Distortion Differential ADC Driver for DC-300MHz QFN-16
    LTC6400-8 1 DC to 300 8dB 53.4 7.6 85 2.2GHz Low Noise, Low Distortion Differential ADC Driver for DC-300MHz QFN-16
    LTC6401-14 1 DC to 200 5V/V 51.5 7.3 45 2GHz Low Noise, Low Distortion Differential ADC Driver for DC-140MHz QFN-16
    LTC6401-20 1 DC to 300 20dB 50.5 6.1 50 1.3GHz Low Noise, Low Distortion Differential ADC Driver for 140MHz IF QFN-16
    LTC6401-26 1 DC to 200 26dB 46.5 6.8 45 1.6GHz Low Noise, Low Distortion Differential ADC Driver for DC-140MHz QFN-16
    LTC6401-8 1 DC to 200 8dB 50.7 12.1 45 2.2GHz Low Noise, Low Distortion Differential ADC Driver for DC-140MHz QFN-16
    LTC6403-1 1 DC to 10-100 Resistor Set 48 10.8 10.8 200MHz, Low Noise, Low Power Fully Differential Input/Output Ampli铿乪r/Driver QFN-16
    LTC6404 1 Resistor Set 50 13.4 27.2 600MHz, Low Noise, AC Precision Fully Differential Input/Output Ampli铿乪r/Driver QFN-16
    LTC6404 1 Resistor Set 53 10 29.7 900MHz, Low Noise, AC Precision Fully Differential Input/Output Ampli铿乪r/Driver, designed for closed-loop gains greater than or equal to 2V/V QFN-16
    LTC6404 1 Resistor Set 54 8 30 1700MHz, Low Noise, AC Precision Fully Differential Input/Output Ampli铿乪r/Driver, designed for closed-loop gains greater than or equal to 4V/V QFN-16
    LTC6405 1 DC to >110 Resistor Set 35.5 14.4 18 2.7GHz, 5V, Low Noise, Rail-to-Rail Input Differential Amplifier/Driver QFN-16, MS-8
    LTC6406 1 DC to >150 Resistor Set 36.5 14.1 18 3GHz, Low Noise, Rail-to-Rail Input Differential Amplifier/Driver QFN-16, MS-8
    LTC6409 1 DC to >400 Resistor Set 59 6.9 52 10GHz GBW, 1.1nV/rtHz Differential Amplifier/ADC Driver QFN-10
    LTC6410-6 1 DC to 400 6dB 36 8 104 Low Distortion, Low Noise Differential IF Amplier with Congurable Input Impedance QFN-16
    LTC6420-20 2 DC to 200 20dB 46 6.2 80 Dual Matched 1.8GHz Differential Ampli铿乪rs/ADC Drivers QFN-20
    LTC6421-20 2 DC to 200 20dB 42 6.2 40 Dual Matched 1.3GHz Differential Ampli铿乪rs/ADC Drivers QFN-20
    LTC6430-15 1 20 to 1600 15.2dB 50 3 160 QFN-24
    LTC6431-15 1 20 to 1600 15dB 47 3.33 85.1 50ohm Gain Block IF Amplifier QFN-24
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
