龙人旗下深圳市龙芯世纪科技有限公司
  • 信号链路 μModule
  • 发布时间:2013/7/25 9:19:33   修改时间:2013/7/25 9:19:33 浏览次数:1530
  • 信号链路 μModule
    信号链路 μModule
    Product Bits  (bits) Channels  (#) Speed  (Msps) SINAD  (dB) Power  (mW) I/O  Supply Voltage Range  Packages
    LTM9001-A_-B 16-Bit, 130Msps Fixed Gain Differential Amplifier Band Pass, 162.5MHz center, 50MHz BW CMOS/LVDS, Parallel 1650 3.3V 16-Bit IF/Baseband Receiver Subsystem 11.25mm x 11.25mm x 2.32mm LGA
    LTM9001-A_-B 16-Bit, 130Msps Fixed Gain Differential Amplifier Band Pass , 70MHz center, 25MHz BW CMOS/LVDS, Parallel 1650 3.3V 16-Bit IF/Baseband Receiver Subsystem 11.25mm x 11.25mm x 2.32mm LGA
    LTM9001-A_-B 16-Bit, 160Msps Fixed Gain Differential Amplifier Low Pass, DC-300MHz CMOS/LVDS, Parallel 1914 3.3V 16-Bit IF/Baseband Receiver Subsystem 11.25mm x 11.25mm x 2.32mm LGA
    LTM9001-GA 16-Bit, 25Msps Fixed Gain Differential Amplifier 10MHz Low Pass CMOS, Parallel 550 3.3V 16-Bit IF/Baseband Receiver Subsystem 11.25mm x 11.25mm x 2.32mm LGA
    LTM9002-AA 14-Bit, 125Msps Fixed Gain Differential Amplifier Low Pass, DC-170MHz CMOS, Parallel 1329 3V 14-Bit Dual-Channel IF/Baseband Receiver Subsystem 15mm x 11.25mm x 2.32mm LGA
    LTM9002-LA 12-Bit, 65Msps Fixed Gain Differential Amplifier Low Pass, DC-25MHz CMOS, Parallel 690 3V 12-Bit Dual-Channel IF/Baseband Receiver Subsystem 15mm x 11.25mm x 2.32mm LGA
    LTM9003-AA 12-Bit, 250Msps Fixed Gain Differential Amplifier Band Pass , 184MHz center, 125MHz BW LVDS, Parallel 1472 2.5V (ADC), 3.3V (Amp), 3.3V (Mixer) 12-Bit Digital Pre-Distortion Receiver Subsystem 15mm x 11.25mm x 2.32mm LGA
    LTM9003-AB 12-Bit, 250Msps Fixed Gain Differential Amplifier Band Pass , 184MHz center, 125MHz BW LVDS, Parallel 1591 2.5V (ADC), 3.3V (Amp), 5V (Mixer) 12-Bit Digital Pre-Distortion Receiver Subsystem 15mm x 11.25mm x 2.32mm LGA
    LTM9004 14-Bit, 125Msps Fixed Gain Differential Amplifier Low Pass, DC-1.92MHz CMOS, Parallel 1830 5V, 3.0V 14-Bit, Direct Conversion Receiver 22mm x 15mm x 2.82mm LGA
    LTM9004 14-Bit, 125Msps Fixed Gain Differential Amplifier Low Pass, DC-4.42MHz CMOS, Parallel 1830 5V, 3.0V 14-Bit, Direct Conversion Receiver 22mm x 15mm x 2.82mm LGA
    LTM9004 14-Bit, 125Msps Fixed Gain Differential Amplifier Low Pass, DC-9.42MHz CMOS, Parallel 1830 5V, 3.0V 14-Bit, Direct Conversion Receiver 22mm x 15mm x 2.82mm LGA
    LTM9004 14-Bit, 125Msps Fixed Gain Differential Amplifier Low Pass, DC-20MHz CMOS, Parallel 1830 5V, 3.0V 14-Bit, Direct Conversion Receiver 22mm x 15mm x 2.82mm LGA
    LTM9009-14 14-Bit, 80Msps - - Serial LVDS 752 1.8V 14-Bit, 80Msps Low Power Octal ADCs 11.25mm x 9mm x 2.72mm BGA
    LTM9010-14 14-Bit, 105Msps - - Serial LVDS 904 1.8V 14-Bit, 105Msps Low Power Octal ADCs 11.25mm x 9mm x 2.72mm BGA
    LTM9011-14 14-Bit, 125Msps - - Serial LVDS 1120 1.8V 14-Bit, 125Msps Low Power Octal ADCs 11.25mm x 9mm x 2.72mm BGA
    LTM9012 14-Bit, 125Msps Fixed Gain Differential Amplifier Lowpass, DC-90MHz Serial LVDS 1270 1.8V, 3.3V Quad 14-Bit, 125Msps ADC with Integrated
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
