Product |
Number of Outputs |
Vin Min (V) |
Vin Max (V) |
Output Current (A) |
Topology |
Synchronous (yes/no) |
Features |
Packages |
LTM4600 |
1 |
4.5 |
20 |
10 |
Buck |
yes |
PolyPhase, Soft Start |
15mm x 15mm x 2.8mm LGA |
LTM4600HV |
1 |
4.5 |
28 |
10 |
Buck |
yes |
LTM4601 |
1 |
4.5 |
20 |
12 |
Buck |
yes |
Tracking, Margining, External Synchronization, PolyPhase, PLL, Differential Remote Sense, Soft Start, Power Good |
LTM4601 |
1 |
4.5 |
20 |
24 |
Buck |
yes |
LTM4601 |
1 |
4.5 |
20 |
12 |
Buck |
yes |
Tracking, Margining, External Synchronization, PolyPhase, PLL, Soft Start, Power Good |
LTM4601A |
1 |
4.5 |
20 |
12 |
Buck |
yes |
15mm x 15mm x 2.8mm LGA, 15mm x 15mm x 3.42mm BGA |
LTM4601AHV |
1 |
4.5 |
28 |
12 |
Buck |
yes |
LTM4601HV |
1 |
4.5 |
28 |
12 |
Buck |
yes |
LTM4602 |
1 |
4.5 |
20 |
6 |
Buck |
yes |
Soft Start, PolyPhase |
LTM4602HV |
1 |
4.5 |
28 |
6 |
Buck |
yes |
LTM4603 |
1 |
4.5 |
20 |
6 |
Buck |
yes |
Tracking, Margining, PolyPhase, External Synchronization, PLL, Differential Remote Sense, Soft Start, Power Good |
LTM4603HV |
1 |
4.5 |
28 |
6 |
Buck |
yes |
LTM4604A |
1 |
2.375 |
5.5 |
4 |
Buck |
yes |
Tracking, Soft Start, Power Good, PolyPhase |
15mm x 9mm x 2.3mm LGA |
LTM4605 |
1 |
4.5 |
20 |
5 |
Buck-Boost |
yes |
Power Good, External Synchronization, PLL, PolyPhase, Output Disconnect |
LTM4606 |
1 |
4.5 |
28 |
6 |
Buck |
yes |
Low EMI, External Synchronization, PLL, Power Good, Soft Start, PolyPhase |
LTM4607 |
1 |
4.5 |
36 |
5 |
Buck-Boost |
yes |
LTM4608A |
1 |
2.7 |
5.5 |
8 |
Buck |
yes |
PolyPhase, Tracking, Margining, External Synchronization, Spread Spectrum, Burst Mode, Power Good |
15mm x 9mm x 2.8mm LGA |
LTM4609 |
1 |
4.5 |
36 |
4 |
Buck-Boost |
yes |
External Synchronization, Power Good, PolyPhase, Output Disconnect |
15mm x 15mm x 2.8mm LGA, 15mm 脳 15mm 脳 3.42mm BGA |
LTM4611 |
1 |
1.5 |
5.5 |
15 |
Buck |
yes |
Differential Remote Sense, PolyPhase, External Synchronization, Burst Mode, Tracking, Soft Start, Power Good |
15mm x 15mm x 4.32mm LGA |
LTM4612 |
1 |
5 |
36 |
5 |
Buck |
yes |
LTM4613 |
1 |
5 |
36 |
8 |
Buck |
yes |
Low EMI, Tracking, Margining, Resistor Set Frequency, External Synchronization, PLL, Power Good, PolyPhase, Soft Start |
LTM4614 |
2 |
2.375 |
5.5 |
4 |
Buck |
yes |
LTM4615 |
3 |
2.375 |
5.5 |
4 |
Buck, LDO |
yes |
Tracking, PolyPhase, LDO, Power Good, Soft Start |
LTM4616 |
2 |
2.7 |
5.5 |
8 |
Buck |
yes |
Tracking, Margining, Power Good, External Synchronization, Spread Spectrum, PolyPhase, Burst Mode |
LTM4616 |
1 |
2.7 |
5.5 |
16 |
Buck |
yes |
LTM4618 |
1 |
4.5 |
26.5 |
6 |
Buck |
yes |
External Synchronization, Tracking, Burst Mode, Power Good, PolyPhase |
9mm x 15mm x 4.32mm LGA |
LTM4619 |
2 |
4.5 |
26.5 |
4 |
Buck |
yes |
PolyPhase, Tracking, Power Good, Burst Mode, External Synchronization |
LTM4620 |
2 |
4.5 |
16 |
13 |
Buck |
yes |
Burst Mode, Tracking, PolyPhase, Differential Remote Sense, Resistor Set Frequency, External Synchronization, Power Good, Soft Start |
15mm 脳 15mm 脳 4.41mm LGA |
LTM4620A |
2 |
4.5 |
16 |
13 |
Buck |
yes |
LTM4627 |
1 |
4.5 |
20 |
15 |
Buck |
yes |
Differential Remote Sense, Tracking, External Synchronization, PolyPhase, Burst Mode, Tracking |
15mm x 15mm x 4.32mm LGA, 15mm x 15mm x 4.92mm BGA |
LTM4627 |
1 |
4.5 |
20 |
30 |
Buck |
yes |
LTM4628 |
2 |
4.5 |
26.5 |
8 |
Buck |
yes |
Differential Remote Sense, Resistor Set Frequency, PolyPhase, External Synchronization, Burst Mode, Tracking, Soft Start |
15mm x 15mm x 4.32mm LGA, 15mm 脳 15mm 脳 4.92mm BGA |
LTM4628 |
1 |
4.5 |
26.5 |
16 |
Buck |
yes |
LTM4641 |
1 |
4.5 |
38 |
10 |
Buck |
yes |
Advanced Input and Load Protection, Temperature Monitor, Differential Remote Sense, Tracking, Soft Start, Power Good |
15mm 脳 15mm 脳 5.01mm BGA |
LTM8001 |
6 |
6 |
36 |
5 |
Buck |
no |
Output Current Limit, Soft Start, Sequencing, Resistor Set Frequency, External Synchronization |
LTM8008 |
6 |
3 |
72 |
0.5 |
Sepic, LDO |
no |
Resistor Set Frequency, External Synchronization, Soft Start, LDO |
LTM8020 |
1 |
4 |
36 |
0.2 |
Buck |
no |
Low EMI |
6mm x 6mm x 2.32 mm LGA |
LTM8021 |
1 |
3 |
36 |
0.5 |
Buck |
no |
Low EMI, Soft Start |
11.25mm x 6.25mm x 2.82mm LGA |
LTM8022 |
1 |
3.6 |
36 |
1 |
Buck |
no |
Resistor Set Frequency, External Synchronization, Soft Start, Power Good, PolyPhase |
11.25mm x 9mm x 2.82mm LGA |
LTM8023 |
1 |
3.6 |
36 |
2 |
Buck |
no |
11.25mm x 9mm x 2.82mm LGA, 9mm 脳 11.25mm 脳 3.42mm BGA |
LTM8025 |
1 |
3.6 |
36 |
3 |
Buck |
no |
Resistor Set Frequency, External Synchronization, Soft Start, PolyPhase |
15mm x 9mm x 4.32mm LGA |
LTM8026 |
1 |
6 |
36 |
5 |
Buck |
no |
Resistor Set Frequency, External Synchronization, Constant Voltage Constant Current, Soft Start |
11.25mm x 15mm x 2.82mm LGA |
LTM8027 |
1 |
4.5 |
60 |
4 |
Buck |
yes |
Resistor Set Frequency, External Synchronization, Soft Start |
LTM8029 |
1 |
4.5 |
36 |
0.6 |
Buck |
no |
Burst Mode, Resistor Set Frequency, Power Good |
11.25mm x 6.25mm x 3.42mm BGA |
LTM8031 |
1 |
3.6 |
36 |
1 |
Buck |
no |
Resistor Set Frequency, External Synchronization, Low EMI, Burst Mode, PolyPhase, Soft Start, Power Good |
9mm x 15mm x 2.82mm LGA |
LTM8032 |
1 |
3.6 |
36 |
2 |
Buck |
no |
Low EMI, Soft Start, Resistor Set Frequency, External Synchronization, PolyPhase |
9mm x 15mm x 2.82mm LGA, 9mm 脳 15mm 脳 3.42mm BGA |
LTM8033 |
1 |
3.6 |
36 |
3 |
Buck |
no |
Resistor Set Frequency, External Synchronization, Soft Start, Low EMI, PolyPhase |
11.25mm x 15mm x 4.32mm LGA |
LTM8045 |
1 |
2.8 |
18 |
Sepic, Inverting |
no |
11.25mm 脳 6.25mm 脳 4.92mm BGA |
LTM8047 |
1 |
3.1 |
32 |
0.44 |
Buck |
no |
Isolated Module, Soft Start |
11.25mm x 9mm x 4.92mm BGA |
LTM8048 |
2 |
3.1 |
32 |
0.44 |
Buck, LDO |
no |
Isolated Module, LDO |
LTM8052 |
1 |
6 |
36 |
5 |
Buck |
no |
Resistor Set Frequency, External Synchronization, Soft Start, Constant Voltage Constant Current |
LTM8061 |
1 |
4.95 |
32 |
2 |
Buck |
no |
Constant Voltage Constant Current, Programmable Input Current Limit, Reverse Input Protection |
LTM8062 |
1 |
4.95 |
32 |
2 |
Buck |
no |
Constant Voltage Constant Current, Max Peak Power Tracking Control Loop, Reverse Input Protection |
LTM8062 |
1 |
4.95 |
32 |
2 |
Buck |
no |
