龙人旗下深圳市龙芯世纪科技有限公司
  • 电流源
  • 发布时间:2013/7/25 9:23:32   修改时间:2013/7/25 9:23:32 浏览次数:1766
  • 电流源
    恒定电流源可采用诸多标准模拟构件来设计,包括运算放大器、LED 驱动器和电池充电器。凌力尔特还提供了一个专用恒定电流源系列,该系列提供了使用和设计的简易性、电压、电流和热保护功能、以及内置电流限制
    电流源
    Product Vin Min  (V) Vin Max  (V) Output Current Range  Isupply  (mA) Features  Comments  Extended Temp  Packages
    LM334S 0.8 30 1uA to 10mA 0.28 Reverse Current Protection Constant Current Source and Temperature Sensor C TO-92, SO-8
    LT3080 1.2 36 0 to 1000mA 0.3 Current Limiting, Thermal Protection Adjustable 1.1A Single Resistor Low Dropout Regulator E, I MS-8, DFN-8, TO-220, SOT-223
    LT3080-1 1.2 36 0 to 2200mA 0.3 Current Limiting, Thermal Protection Parallelable 1.1A Adjustable Single Resistor Low Dropout Regulator E, I MS-8, DFN-8
    LT3080-1 1.2 36 0 to 3300mA 0.3 Current Limiting, Thermal Protection Parallelable 1.1A Adjustable Single Resistor Low Dropout Regulator E, I MS-8, DFN-8
    LT3085 1.2 36 0 to 500mA 0.3 Current Limiting, Thermal Protection Adjustable 500mA Single Resistor Low Dropout Regulator E, I, MP DFN-6, MS-8
    LT3092 1.2 40 0.5mA to 200mA 0.3 Reverse Voltage Protection, Reverse Current Protection, Current Limiting, Thermal Protection 200mA Two-Terminal Programmable Current Source E, I, MP SOT-23, DFN-8, SOT-223
    LTM8040 4 36 35mA to 1000mA 2.6 Programmable Output Current, Constant Current Constant Voltage 36V, 1A 碌Module LED Driver E, I 15mm x 9mm x 4.32mm LGA
    LTM8042 3 30 35mA to 1000mA 4.2 Constant Current Constant Voltage, True Color PWM Dimming, Soft Start uModule Multi-Topology  1A CC/CV LED Driver or Current Source E, I 9mm x 15mm x 2.82mm LGA
    LTM8042 3 30 35mA to 350mA 4.2 Constant Current Constant Voltage, True Color PWM Dimming, Soft Start uModule Multi-Topology  350mA CC/CV LED Driver or Current Source E, I 9mm x 15mm x 2.82mm LGA
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
