龙人旗下深圳市龙芯世纪科技有限公司
  • 电池管理
  • 发布时间:2013/7/25 9:26:56   修改时间:2013/7/25 9:26:56 浏览次数:2350
  • 电池管理
    凌力尔特公司制造了门类齐全的高性能电池充电器产品线,适用于任何可再充电化学电池(包括锂离子电池、铅酸电池和镍电池)。这些电池充电器 IC 既有采用线性拓扑结构,也有采用开关拓扑结构,而且在操作中是完全独立的。我们的 IC 提供了诸多电池安全和管理的标准功能,包括片上电池预查验、热调节、NTC 接口以及采用 SMBus 或 I2C 接口的双智能型电池系统管理。
    电池管理
    Product Vin Min  (V) Vin Max  (V) Max Charge Current  (A) Type of Charger  Battery Chemistry  Number of Cells  Comments  Packages
    LT1505 11 26 4 Switching Li-Ion, Li-Polymer, NiCd, NiMH, Lead Acid 1 to 4 (Li), 1 to 12 (Ni) Synchronous switching controller for high current, high efficiency SSOP-28
    LT1510 7 29 1 Switching Li-Ion, Li-Polymer, NiCd, NiMH, Lead Acid 1 to 4 (Li), 1 to 12 (Ni) 500kHz integrated switching frequency for small solution SO-8, SSOP-16, SO-16
    LT1511 7 29 3 Switching Li-Ion, Li-Polymer, NiCd, NiMH, Lead Acid 1 to 4 (Li), 1 to 12 (Ni) Integrated switching charger with 4A internal switch SO-24
    LT1512 2.4 29 0.75 Switching, Buck-Boost Li-Ion, Li-Polymer, NiCd, NiMH, Lead Acid 1 to 4 (Li), 1 to 12 (Ni) Input supply voltage can be above or below battery voltage SO-8
    LT1513 2.4 29 2 Switching, Buck-Boost Li-Ion, Li-Polymer, NiCd, NiMH, Lead Acid 1 to 4 (Li), 1 to 12 (Ni) Input supply voltage can be above or below battery voltage DD, T7
    LT1513 2.4 29 2 Switching, Buck-Boost Li-Ion, Li-Polymer, NiCd, NiMH, Lead Acid 1 to 4 (Li), 1 to 18 (Ni) Input supply voltage can be above or below battery voltage DD, T7
    LT1571 6.2 27 1.5 Switching Li-Ion, Li-Polymer 1, 2, Adj Integrated switching charger with C/10 detection/indicator SSOP-16, SSOP-28
    LT1769 7 29 2 Switching Li-Ion, Li-Polymer, NiCd, NiMH, Lead Acid 1 to 4 (Li), 1 to 12 (Ni) Integrated switching charger in thermally enhanced exposed PAD 20-lead small shrink outline package TSSOP-20, SSOP-28
    LT3650-4.X 4.75 32 2 Switching Li-Ion, Li-Polymer 1 High Voltage 2 Amp Monolithic 1-Cell Li-Ion Battery Charger DFN-12, MS-12
    LT3650-8.X 4.75 32 2 Switching Li-Ion, Li-Polymer 2 High Voltage 2 Amp Monolithic 2-Cell Li-Ion Battery Charger DFN-12, MS-12
    LT3651-4.1 4.8 32 4 Switching Li-Ion, Li-Polymer 1 Monolithic 4A High Voltage Li-Ion Battery Charger QFN-36
    LT3651-8.2 9 32 4 Switching Li-Ion, Li-Polymer 2 Monolithic 4A High Voltage 2-Cell Li-Ion Battery Charger QFN-36
    LT3652 4.95 32 2 Switching Li-Ion, Li-Polymer, LiFePO4, NiCd, NiMH, Lead Acid 1-3 Li-Ion/Li-Poly, 1-4 LiFePO4, NiMH/NiCd up to 14.4V, SLA up to 14.4 Power Tracking 2A Battery Charger for Solar Power DFN-12, MS-12
    LT3652HV 4.95 34 2 Switching Li-Ion, Li-Polymer, LiFePO4, NiCd, NiMH, Lead Acid 1-4 Li-Ion/Li-Poly, 1-5 LiFePO4, SLA up to 18V Power Tracking 2A Battery Charger DFN-12, MS-12
    LT3761 4.5 60 20 Switching Li-Ion, Li-Polymer, NiCd, NiMH, Lead Acid Set by external charger IC 60Vin LED Controller with Internal PWM Generator MS-16
    LT3796 6 100 20 Switching Li-Ion, Li-Polymer, NiCd, NiMH, Lead Acid Set by externals 100V Constant-Current and Constant-Voltage Controller with Dual Current Sense TSSOP-28
    LTC1729 Termination Controller Li-Ion, Li-Polymer, LiFePO4, NiCd, NiMH, Lead Acid Operates with all LTC switching chargers. built-in 3-hour time-out termination. C/10 detection with status indicator MS-8, SO-8
    LTC1730 4.5 12 1.3 Pulse Li-Ion, Li-Polymer 1 Minimum heat dissipation. Selectable 4.1V/4.2V. current limit protection. for use current limited wall adapter SSOP-16, SO-8
    LTC1731-4.2 4.5 12 2 Linear Li-Ion, Li-Polymer 1 Linear charger with AC adapter detection MS-8, SO-8
    LTC1731-8.4 4.5 12 2 Linear Li-Ion, Li-Polymer 2 Linear charger with AC adapter detection MS-8, SO-8
    LTC1732-4 4.5 12 2 Linear Li-Ion, Li-Polymer 1 Complete stand-alone linear charger; needs no firmware MS-10
    LTC1732-4.2 4.5 12 2 Linear Li-Ion, Li-Polymer 1 Complete, stand-alone linear charger. needs no firmware MS-10
    LTC1732-8.4 4.5 12 2 Linear Li-Ion, Li-Polymer 2 Complete, stand-alone linear charger. needs no firmware MS-10
    LTC1733 4.5 6.5 1.5 Linear Li-Ion, Li-Polymer 1 Thermal regulation for no overheating. integrated MOSFET, RSENSE, Diode. Stand-alone. Thermistor interface MS-10
    LTC1734 4.55 8 0.7 Linear Li-Ion, Li-Polymer 1 SOT-23 linear charger; only three components for complete solution ThinSOT
    LTC1734L 4.55 8 0.18 Linear Li-Ion, Li-Polymer 1 Precision ultralow charge current linear charger ThinSOT
    LTC1759 6.7 26 8 Switching, SMBus Li-Ion, Li-Polymer, NiCd, NiMH, Lead Acid 1 to 4 (Li), 1 to 17 (Ni) SMBus Charger with integrated SMBus AcceleratorTM SSOP-36
    LTC1760 6 28 4 Switching, SMBus Li-Ion, Li-Polymer, NiCd, NiMH 2 to 6 (Li) Dual battery selector and charger. crisis management. SMBus v. 1.1, Level 2 charger. Operates with or without host microcontroller TSSOP-48
    LTC1960 6 28 4 Switching, SPI Li-Ion, Li-Polymer, NiCd, NiMH, Lead Acid 1 to 18 (Ni), 2 to 6 (Li) Dual battery selector and charger. fast charge. crisis management SSOP-36, QFN-38
    LTC1980 4.1 12 2 Switching, Buck-Boost Li-Ion, Li-Polymer, NiCd, NiMH, Lead Acid 1, 2 Combination battery charger and system DC/DC converter SSOP-24
    LTC2941 2.7 5.5 Coulomb Counter Li-Ion, Li-Polymer 1 Battery Gas Gauge with I2C Interface DFN-6
    LTC2941-1 2.7 5.5 Coulomb Counter Li-Ion, Li-Polymer 1 1A I2C Battery Gas Gauge with Internal Sense Resistor DFN-6
    LTC2942 2.7 5.5 Coulomb Counter Li-Ion, Li-Polymer 1 Battery Gas Gauge with Temperature, Voltage Measurement DFN-6
    LTC2942-1 2.7 5.5 Coulomb Counter Li-Ion, Li-Polymer 1 1A Battery Gas Gauge with Internal Sense Resistor and Temperature/Voltage Measurement DFN-6
    LTC3101 1.8 5.5 - Alkaline - Wide Vin, Multi-Output DC/DC Converter and PowerPath Controller QFN-24
    LTC3300-1 Li-Ion, LiFePO4 > 1000V of stacked Li-Ion cells High Efficiency Bidirectional Multicell Battery Balancer QFN-48, LQFP-48
    LTC3455 4.3 5.5 1 Linear Li-Ion, Li-Polymer 1 Dual DC/DC Converter with USB Power Manager and Li-Ion Battery Charger QFN-24
    LTC3456 1.8 5.5 - Alkaline, NiCd, NiMH - 2-Cell, Multi-Output DC/DC Converter with USB Power Manager QFN-24
    LTC3550 4.3 8 0.95 Linear Li-Ion, Li-Polymer 1 Dual Input USB/AC Adapter Li-Ion Battery Charger with 600mA Buck Converter DFN-16
    LTC3550-1 4.3 8 0.95 Linear Li-Ion, Li-Polymer 1 Dual Input USB/AC Adapter Li-Ion Battery Charger with 600mA Buck Converter DFN-16
    LTC3552 2.5 5.5 0.95 Linear Li-Ion, Li-Polymer 1 Standalone Linear Li-Ion Battery Charger and Dual Synchronous Buck Converter DFN-16
    LTC3552-1 2.5 5.5 0.95 Linear Li-Ion, Li-Polymer 1 Standalone Linear Li-Ion Battery Charger and Dual Synchronous Buck Converter DFN-16
    LTC3553 4.35 5.5 0.5 Linear Li-Ion, Li-Polymer 1 Micropower USB Power Manager With Li-Ion Charger, LDO and Buck Regulator QFN-20
    LTC3553-2 4.35 5.5 0.5 Linear Li-Ion, Li-Polymer 1 Micropower USB Power Manager With Li-Ion Charger, Always-On LDO and Buck Regulator with Power Good QFN-20
    LTC3554 2.7 5.5 0.4 Linear Li-Ion, Li-Polymer 1 Micropower USB Power Manager With Li-Ion Charger and Two Step-Down Regulators QFN-20
    LTC3554 2.7 5.5 0.4 Linear Li-Ion, Li-Polymer 1 Micropower USB Power Manager With Li-Ion Charger and Two Step-Down Regulators, Extended Hard Reset Time QFN-20
    LTC3555 2.7 5.5 1.5 Linear Li-Ion, Li-Polymer 1 High Efficiency USB Power Manager + Triple Step-Down DC/DC QFN-28
    LTC3556 4.35 5.5 1.5 Linear Li-Ion, Li-Polymer 1 High Ef铿乧iency USB Power Manager with Dual Buck and Buck-Boost DC/DCs QFN-28
    LTC3557 2.7 5.5 1.5 Linear Li-Ion, Li-Polymer 1 USB Power Manager with Li-Ion Charger and Three Step Down Regulators QFN-28
    LTC3558 4.3 5.5 0.95 Linear Li-Ion, Li-Polymer 1 Linear USB Battery Charger with Buck and Buck-Boost Regulators QFN-20
    LTC3559 3 5.5 0.95 Linear Li-Ion, Li-Polymer 1 Linear USB Battery Charger with Dual Buck Regulators QFN-16
    LTC3566 4.35 5.5 1.5 Linear Li-Ion, Li-Polymer 1 High Ef铿乧iency USB Power Manager Plus 1A Buck-Boost Converter QFN-24
    LTC3567 4.35 5.5 1.5 Linear Li-Ion, Li-Polymer 1 High Ef铿乧iency USB Power Manager Plus 1A Buck-Boost Converter with I2C Control QFN-24
    LTC3576 4.35 5.5 1.5 Linear Li-Ion, Li-Polymer 1 Switching Power Manager with USB On-The-Go + Triple Step-Down DC/DC QFN-38
    LTC3577 4.35 5.5 1.5 Linear Li-Ion, Li-Polymer 1 Highly Integrated 6-Channel Portable PMIC QFN-44
    LTC3577-3_-4 4.35 5.5 1.5 Linear Li-Ion, Li-Polymer 1 Highly Integrated Portable Product PMIC QFN-44
    LTC3586 4.35 5.5 1.5 Linear Li-Ion, Li-Polymer 1 High Efficiency USB Power Manager with Boost, Buck-Boost and Dual Bucks, Fault Pin Bi-Directional with Latch, 300mV Boost Overvoltage Hysteresis QFN-38
    LTC3586-2 4.35 5.5 1.5 Linear Li-Ion, Li-Polymer 1 High Efficiency USB Power Manager with Boost, Buck-Boost and Dual Bucks, Fault Pin Output Only, No Latch, 100mV Boost Overvoltage Hysteresis QFN-38
    LTC3677-3 4.35 5.5 1.5 Linear Li-Ion, Li-Polymer 1 Highly Integrated Portable Product PMIC QFN-44
    LTC4000 3 60 20 Switching Li-Ion, Li-Polymer, LiFePO4, NiCd, NiMH, Lead Acid Set by external charger IC High Voltage High Current Controller for Battery Charging and Power Management QFN-28, SSOP-28
    LTC4000-1 3 60 20 Switching Li-Ion, Li-Polymer, LiFePO4, NiCd, NiMH, Lead Acid Set by external charger IC High Voltage High Current Controller for Battery Charging with Maximum Power Point Control QFN-28, SSOP-28
    LTC4001 4 5.5 2 Switching Li-Ion, Li-Polymer 1 2A Synchronous Buck Li-Ion Charger QFN-16
    LTC4001-1 4 5.5 2 Switching Li-Ion, Li-Polymer 1 2A Synchronous Buck Li-Ion Charger QFN-16
    LTC4002 4.7 24 3 Switching Li-Ion, Li-Polymer 1 Charges 1-cell Li-Ion battery from high Vin DFN-10, SO-8
    LTC4002 8.9 24 3 Switching Li-Ion, Li-Polymer 2 Charges 2-cell Li-Ion battery from high Vin DFN-10, SO-8
    LTC4006 6 28 4 Switching Li-Ion, Li-Polymer 2 to 4 Small IC, standalone SSOP-16
    LTC4007 6 28 4 Switching Li-Ion, Li-Polymer 3, 4 Full featrued, standalone SSOP-24
    LTC4007-1 6 28 4 Switching Li-Ion, Li-Polymer 3, 4 4A, High Efficiency, Li-Ion Battery Charger QFN-24
    LTC4008 6 28 4 Switching Li-Ion, Li-Polymer, NiCd, NiMH, LiFePO4, Lead Acid 1 to 6 (Li), 4 to 18 (Ni) Very small design, low profile inductors SSOP-20
    LTC4009 6 28 8 Switching Li-Ion, Li-Polymer, NiCd, NiMH, LiFePO4, Lead Acid 1 to 6 (Li), 2 to 18 (Ni) High Efficiency, Multi-Chemistry Battery Charger QFN-20
    LTC4009 6 28 8 Switching Li-Ion, Li-Polymer 1 to 4 (Li) High Efficiency, Multi-Chemistry Battery Charger QFN-20
    LTC4010 4.5 34 4 Switching NiCd, NiMH 1 to 16 Nickel Battery Charger Controller TSSOP-16
    LTC4011 4.5 34 4 Switching NiCd, NiMH 1 to 16 Nickel Battery Charger Controller with PowerPath Control TSSOP-20
    LTC4012 6 28 12 Switching Li-Ion, Li-Polymer, LiFePO4, NiCd, NiMH, Lead Acid 1 to 6 (Li), 2 to 18 (Ni) High Efficiency, Multi-Chemistry Battery Charger with PowerPath Control QFN-20
    LTC4012 6 28 12 Switching Li-Ion, Li-Polymer 1 to 4 (Li) High Efficiency, Multi-Chemistry Battery Charger with PowerPath Control QFN-20
    LTC4012-3 6 28 12 Switching Li-Ion, Li-Polymer, LiFePO4, NiCd, NiMH, Lead Acid 1 to 6 (Li), 4 to 18 (Ni) High Efficiency, Multi-Chemistry Battery Charger with PowerPath Control QFN-20
    LTC4050 4.5 12 2 Linear Li-Ion, Li-Polymer 1 LTC1732 + thermistor interface MS-10
    LTC4052-4.2 4.5 10 1.3 Pulse Li-Ion, Li-Polymer 1 Minimum heat dissipation. current limit for safety. standalone MS-10
    LTC4053-4.2 4.25 6.5 1.25 Linear Li-Ion, Li-Polymer 1 USB compatible. complete and standalone. thermal regulation prevents overheating MS-10, DFN-10
    LTC4054-4.2 4.25 6.5 0.8 Linear Li-Ion, Li-Polymer 1 Fully integrated, standalone, thermal regulation ThinSOT
    LTC4054L-4.2 4.25 6.5 0.15 Linear Li-Ion, Li-Polymer 1 Precision ultralow charge current linear charger. standalone ThinSOT
    LTC4054X-4.2 4.25 6.5 0.8 Linear Li-Ion, Li-Polymer 1 High trickle charge current ThinSOT
    LTC4055 4.3 5.5 1.25 Linear Li-Ion, Li-Polymer 1 USB Power Manager with Low-Loss 200mohm Ideal Diode and Li-Ion Battery Charger QFN-16
    LTC4056-4.2 4.5 6.5 0.7 Linear Li-Ion, Li-Polymer 1 No charging interruption due to input voltage fluctuation ThinSOT
    LTC4057-4.2 4.25 6.5 0.8 Linear Li-Ion, Li-Polymer 1 LTC4054 with external charge termination control ThinSOT
    LTC4058-4.2 4.25 6.5 0.95 Linear Li-Ion, Li-Polymer 1 Complete, standalone linear charger in DFN package with Trickle Charge DFN-8
    LTC4058-4.2 4.25 6.5 0.95 Linear Li-Ion, Li-Polymer 1 Complete, standalone linear charger in DFN package, No Trickle Charge DFN-8
    LTC4059 3.75 8 0.9 Linear Li-Ion, Li-Polymer, NiCd, NiMH 1 Constant-Current Source Mode for Charging Nickel Batteries (LTC4059 Only) DFN-6
    LTC4059 3.75 8 0.9 Linear Li-Ion, Li-Polymer, NiCd, NiMH 1 ACPR Pin Indicates Presence of Input Supply (LTC4059A Only) DFN-6
    LTC4060 4.5 10 2 Linear NiCd, NiMH, Lead Acid 1 to 4 Standalone Linear NiMH/NiCd Fast Battery Charger DFN-16, TSSOP-16
    LTC4061 4.3 8 1 Linear Li-Ion, Li-Polymer 1 Standalone Linear Li-Ion Battery Charger with Thermistor Input DFN-10
    LTC4061-4.4 4.5 8 1 Linear Li-Ion, Li-Polymer 1 Standalone Linear Li-Ion Battery Charger with Thermistor Input DFN-10
    LTC4062 4.3 8 1 Linear Li-Ion, Li-Polymer 1 On board micropower comparator for battery monitoring DFN-10
    LTC4063 4.3 8 1 Linear Li-Ion, Li-Polymer 1 Standalone Linear Li-Ion Charger with Micropower Low Dropout Linear Regulator DFN-10
    LTC4064 4.25 6.5 1 Linear Li-Ion, Li-Polymer 1 For battery backup. 4.0V float voltage MS-10
    LTC4065 3.75 5.5 0.75 Linear Li-Ion, Li-Polymer 1 Standalone 750mA Li-Ion Battery Charger in 2 x 2 DFN DFN-6
    LTC4065-4.4 3.75 5.5 0.75 Linear Li-Ion, Li-Polymer 1 Standalone 750mA Li-Ion Battery Charger in 2x2 DFN DFN-6
    LTC4065L 3.75 5.5 0.25 Linear Li-Ion, Li-Polymer 1 Standalone 250mA Li-Ion Battery Charger in 2 脳 2 DFN DFN-6
    LTC4066 4.35 5.5 1.5 Linear Li-Ion, Li-Polymer 1 USB Power Manager with Low-Loss 50mohm Ideal Diode and Li-Ion Battery Charger QFN-24
    LTC4067 4.35 5.5 1.25 Linear Li-Ion, Li-Polymer 1 USB Power Manager with OVP and Li-Ion/Polymer Charger DFN-12
    LTC4068-4.2 4.25 6.5 0.95 Linear Li-Ion, Li-Polymer 1 Adjustable charge termination current DFN-8
    LTC4069 3.75 5.5 0.75 Linear Li-Ion, Li-Polymer 1 Standalone 750mA Li-Ion Battery Charger in 2 脳 2 DFN with NTC Thermistor Input DFN-6
    LTC4069-4.4 3.75 5.5 0.75 Linear Li-Ion, Li-Polymer 1 Standalone 750mA Li-Ion Battery Charger in 2x2 DFN with NTC Thermistor Input DFN-6
    LTC4070 0.05 Shunt Li-Ion, Li-Polymer 1 Li-Ion/Polymer Shunt Battery Charger System DFN-8, MSOP-8E
    LTC4071 0.05 Shunt Li-Ion, Li-Polymer 1 Li-Ion/Polymer Shunt Battery Charger System with Low Battery Disconnect DFN-8, MSOP-8
    LTC4075 4.3 8 0.95 Linear Li-Ion, Li-Polymer 1 Dual Input USB/AC Adapter Standalone Li-Ion Battery Chargers DFN-10
    LTC4075HVX 4.3 22 0.95 Linear Li-Ion, Li-Polymer 1 High Voltage Dual Input Li-Ion/Polymer Battery Charger DFN-10
    LTC4075X 4.3 8 0.95 Linear Li-Ion, Li-Polymer 1 Dual Input USB/AC Adapter Standalone Li-Ion Battery Chargers with No Trickle Charge DFN-10
    LTC4076 4.3 8 1 Linear Li-Ion, Li-Polymer 1 Dual Input Standalone Battery Charger DFN-10
    LTC4077 4.3 8 1 Linear Li-Ion, Li-Polymer 1 Dual Input Standalone Battery Charger DFN-10
    LTC4078 4.3 22 0.95 Linear Li-Ion, Li-Polymer 1 Dual Input Li-Ion Battery Charger with Overvoltage Protection DFN-10
    LTC4080 3.75 5.5 0.5 Linear Li-Ion, Li-Polymer 1 500mA Standalone Li-Ion Charger with Integrated 300mA Synchronous Buck in 3mm x 3mm DFN DFN-10, MS-10
    LTC4080X 3.75 5.5 0.5 Linear Li-Ion, Li-Polymer 1 500mA Standalone Li-Ion Charger with Integrated 300mA Synchronous Buck in 3mm 脳 3mm DFN DFN-10, MS-10
    LTC4081 3.75 5.5 0.5 Linear Li-Ion, Li-Polymer 1 500mA Li-Ion Charger with NTC Input and 300mA Synchronous Buck DFN-10
    LTC4085 4.35 5.5 1.2 Linear Li-Ion, Li-Polymer 1 USB Power Manager with Ideal Diode Controller and Li-Ion Charger with 4.2V Float Voltage, 29% Vvntc, Undervoltage Current Limit DFN-14
    LTC4085-1 4.35 5.5 1.5 Linear Li-Ion, Li-Polymer 1 USB Power Manager with Ideal Diode Controller and 4.1V Li-Ion Charger, 32.6% Vvntc, Undervoltage Current Limit DFN-14
    LTC4085-3 4.35 5.5 1.2 Linear Li-Ion, Li-Polymer 1 USB Power Manager with Ideal Diode Controller and 3.95V Li-Ion Charger, 32.6% Vvntc, No Undervoltage Current Limit DFN-14
    LTC4088 4.25 5.5 1.5 Switching Li-Ion, Li-Polymer 1 High Efficiency Battery Charger/USB Power Manager DFN-14
    LTC4088-1_-2 4.25 5.5 1.5 Switching Li-Ion, Li-Polymer 1 High Efficiency Battery Charger/USB Power Manager with Regulated Output Voltage DFN-14
    LTC4089 6 36 1.2 Linear Li-Ion, Li-Polymer 1 USB Power Manager with High Voltage Switching Charger DFN-22
    LTC4089-1 6 36 1.2 Linear Li-Ion, Li-Polymer 1 USB Power Manager with High Voltage Switching Charger DFN-22
    LTC4089-3 6 36 1.2 Linear Li-Ion, Li-Polymer 1 USB Power Manager with High Voltage Switching Charger DFN-22
    LTC4089 6 36 1.2 Linear Li-Ion, Li-Polymer 1 USB Power Manager with High Voltage Switching Charger, Fixed 5V Output DFN-22
    LTC4090 6 38 1.5 Linear Li-Ion, Li-Polymer 1 USB Power Manager + Triple Sync Buck DFN-22
    LTC4095 4.3 5.5 0.95 Linear Li-Ion, Li-Polymer 1 Standalone USB Li-Ion/Polymer Battery Charger in 2mm x 2mm DFN DFN-6
    LTC4096 4.25 5.5 1.2 Linear Li-Ion, Li-Polymer 1 Dual Input Standalone Li-Ion Battery Chargers DFN-10
    LTC4097 4.25 5.5 1.2 Linear Li-Ion, Li-Polymer 1 USB/Wall Adapter Standalone Li-Ion/Polymer Battery Charger DFN-12
    LTC4098 4.35 5.5 1.5 Switching Li-Ion, Li-Polymer 1 USB Compatible Switching Power Manager/Li-Ion Charger with Overvoltage Protection QFN-20
    LTC4098-3.6 4.35 5.5 1.5 Switching LiFePO4 1 USB Compatible Switching Power Manager/LiFePO4 Charger with Overvoltage Protection QFN-20
    LTC4099 4.35 5.5 1.5 Switching, I2C Li-Ion, Li-Polymer 1 I2C Controlled USB Power Manager/Charger with Overvoltage Protection QFN-20
    LTC4100 6 28 4 Switching, SMBus Li-Ion, Li-Polymer, NiCd, NiMH 2 to 6 (Li) SMBus v. 1.1, Level 2 charger. Operates with or without host microcontroller SSOP-24
    LTC4101 6 28 4 Switching, SMBus Li-Ion, Li-Polymer, NiCd, NiMH 1 (Li) Smart Battery Charger Controller SSOP-24
    LTC4110 4.5 19 3 Switching Li-Ion, Li-Polymer, Lead Acid, NiMH, NiCd 1-4 Li, up to 10 Ni, up to 6 SLA Battery Backup System Manager QFN-38
    LTC4150 2.7 8.5 Gas Gauge Li-Ion, Li-Polymer, Lead Acid, NiMH, NiCd 1 Coulomb Counter/Battery Gas Gauge MS-10
    LTC4155 4.35 5.5 3.5 Switching, I2C Li-Ion, Li-Polymer 1 Dual Input Power Manager / 3.5A Li-Ion Battery Charger with I2C Control and USB OTG QFN-28
    LTC4156 4.35 5.5 3.5 Switching LiFePO4 1 Dual-Input Power Manager / 3.5A LiFePO4 Battery Charger with I2C Control and USB OTG QFN-28
    LTC4160 4.35 5.5 1.2 Linear Li-Ion, Li-Polymer 1 Switching Power Manager with USB On-The-Go And Overvoltage Protection QFN-20
    LTC6801 60 Battery Stack Monitor Li-Ion > 1000V of stacked Li-Ion cells Independent Multicell Battery Stack Fault Monitor SSOP-36
    LTC6802-1 60 Battery Stack Monitor Li-Ion > 1000V of stacked Li-Ion cells Multicell Battery Stack Monitor, Daisy Chainable SPI Interface SSOP-44
    LTC6802-2 60 Battery Stack Monitor Li-Ion > 1000V of stacked Li-Ion cells Multicell Battery Stack Monitor, Individually Addressable SPI Interface SSOP-44
    LTC6803-1_-3 60 Battery Stack Monitor Li-Ion, Supercapacitors, Multi-Chemistry > 1000V of stacked Li-Ion cells Multicell Battery Stack Monitor, Serial interface allows daisy chain, -1 Version connects bottom of stack to V- SSOP-44
    LTC6803-2_-4 60 Battery Stack Monitor Li-Ion, Supercapacitors, Multi-Chemistry > 1000V of stacked Li-Ion cells Multicell Battery Stack Monitor, Individually addressable serial communciations, -2 Connects bottom of stack to V- SSOP-44
    LTC6803-1_-3 60 Battery Stack Monitor Li-Ion, Supercapacitors, Multi-Chemistry > 1000V of stacked Li-Ion cells Multicell Battery Stack Monitor, Serial interface allows daisy chain, -3 Separates bottom of stack from V- SSOP-44
    LTC6803-2_-4 60 Battery Stack Monitor Li-Ion, Supercapacitors, Multi-Chemistry > 1000V of stacked Li-Ion cells Multicell Battery Stack Monitor, Individually addressable serial communciations, -4 Separates bottom of stack from V- SSOP-44
    LTM8061 4.95 32 2 Switching Li-Ion, Li-Polymer 1, 2 32V, 2A uModule Li Ion Constant-Current/Constant Voltage Battery Charger 9mm x 15mm x 4.32mm LGA
    LTM8062 4.95 32 2 Switching Li-Ion, Li-Polymer, LiFePO4, Lead Acid 1-4 Li-Ion/Li-Poly, 1-5 LiFePO4, SLA up to 14.4V 32VIN, 2A 渭Module Power Tracking Battery Charger 9mm x 15mm x 4.32mm LGA
    LTM8062 4.95 32 2 Switching Li-Ion, Li-Polymer, LiFePO4, Lead Acid 1-4 Li-Ion/Li-Poly, 1-5 LiFePO4, SLA up to 18.8V 32VIN, 2A 渭Module Power Tracking Battery Charger 9mm x 15mm x 4.32mm LGA
    型号 Packages
    LT1505 SSOP-28
    LT1510 SO-8, SSOP-16, SO-16
    LT1511 SO-24
    LT1512 SO-8
    LT1513 DD, T7
    LT1513 DD, T7
    LT1571 SSOP-16, SSOP-28
    LT1769 TSSOP-20, SSOP-28
    LT3650-4.X DFN-12, MS-12
    LT3650-8.X DFN-12, MS-12
    LT3651-4.1 QFN-36
    LT3651-4.1 QFN-36
    LT3651-8.2 QFN-36
    LT3651-8.2 QFN-36
    LT3652 DFN-12, MS-12
    LT3652HV DFN-12, MS-12
    LT3761 MS-16
    LT3796 TSSOP-28
    LTC1729 MS-8, SO-8
    LTC1730 SSOP-16, SO-8
    LTC1731-4.2 MS-8, SO-8
    LTC1731-8.4 MS-8, SO-8
    LTC1732-4 MS-10
    LTC1732-4.2 MS-10
    LTC1732-8.4 MS-10
    LTC1733 MS-10
    LTC1734 ThinSOT
    LTC1734 ThinSOT
    LTC1734L ThinSOT
    LTC1759 SSOP-36
    LTC1760 TSSOP-48
    LTC1960 SSOP-36, QFN-38
    LTC1980 SSOP-24
    LTC2941 DFN-6
    LTC2941-1 DFN-6
    LTC2942 DFN-6
    LTC2942-1 DFN-6
    LTC3101 QFN-24
    LTC3300-1 QFN-48, LQFP-48
    LTC3455 QFN-24
    LTC3456 QFN-24
    LTC3550 DFN-16
    LTC3550-1 DFN-16
    LTC3552 DFN-16
    LTC3552-1 DFN-16
    LTC3553 QFN-20
    LTC3553-2 QFN-20
    LTC3554 QFN-20
    LTC3554 QFN-20
    LTC3554 QFN-20
    LTC3555 QFN-28
    LTC3556 QFN-28
    LTC3557 QFN-28
    LTC3558 QFN-20
    LTC3559 QFN-16
    LTC3566 QFN-24
    LTC3567 QFN-24
    LTC3576 QFN-38
    LTC3577 QFN-44
    LTC3577 QFN-44
    LTC3577-3_-4 QFN-44
    LTC3577-3_-4 QFN-44
    LTC3586 QFN-38
    LTC3586 QFN-38
    LTC3586-2 QFN-38
    LTC3586-2 QFN-38
    LTC3677-3 QFN-44
    LTC4000 QFN-28, SSOP-28
    LTC4000-1 QFN-28, SSOP-28
    LTC4001 QFN-16
    LTC4001-1 QFN-16
    LTC4002 DFN-10, SO-8
    LTC4006 SSOP-16
    LTC4007 SSOP-24
    LTC4007-1 QFN-24
    LTC4008 SSOP-20
    LTC4009 QFN-20
    LTC4009 QFN-20
    LTC4009 QFN-20
    LTC4010 TSSOP-16
    LTC4011 TSSOP-20
    LTC4012 QFN-20
    LTC4012 QFN-20
    LTC4012 QFN-20
    LTC4012-3 QFN-20
    LTC4050 MS-10
    LTC4052-4.2 MS-10
    LTC4053-4.2 MS-10, DFN-10
    LTC4054-4.2 ThinSOT
    LTC4054L-4.2 ThinSOT
    LTC4054X-4.2 ThinSOT
    LTC4055 QFN-16
    LTC4056-4.2 ThinSOT
    LTC4057-4.2 ThinSOT
    LTC4058-4.2 DFN-8
    LTC4058-4.2 DFN-8
    LTC4059 DFN-6
    LTC4059 DFN-6
    LTC4060 DFN-16, TSSOP-16
    LTC4061 DFN-10
    LTC4061-4.4 DFN-10
    LTC4062 DFN-10
    LTC4063 DFN-10
    LTC4064 MS-10
    LTC4065 DFN-6
    LTC4065-4.4 DFN-6
    LTC4065L DFN-6
    LTC4066 QFN-24
    LTC4067 DFN-12
    LTC4068-4.2 DFN-8
    LTC4069 DFN-6
    LTC4069-4.4 DFN-6
    LTC4070 DFN-8, MSOP-8E
    LTC4071 DFN-8, MSOP-8
    LTC4075 DFN-10
    LTC4075HVX DFN-10
    LTC4075X DFN-10
    LTC4076 DFN-10
    LTC4077 DFN-10
    LTC4078 DFN-10
    LTC4080 DFN-10, MS-10
    LTC4080X DFN-10, MS-10
    LTC4081 DFN-10
    LTC4085 DFN-14
    LTC4085-1 DFN-14
    LTC4085-3 DFN-14
    LTC4085-3 DFN-14
    LTC4088 DFN-14
    LTC4088-1_-2 DFN-14
    LTC4089 DFN-22
    LTC4089-1 DFN-22
    LTC4089 DFN-22
    LTC4090 DFN-22
    LTC4095 DFN-6
    LTC4096 DFN-10
    LTC4097 DFN-12
    LTC4098 QFN-20
    LTC4098 QFN-20
    LTC4098-3.6 QFN-20
    LTC4099 QFN-20
    LTC4100 SSOP-24
    LTC4101 SSOP-24
    LTC4110 QFN-38
    LTC4150 MS-10
    LTC4155 QFN-28
    LTC4156 QFN-28
    LTC4160 QFN-20
    LTC4160 QFN-20
    LTC6801 SSOP-36
    LTC6802-1 SSOP-44
    LTC6802-2 SSOP-44
    LTC6803-1_-3 SSOP-44
    LTC6803-2_-4 SSOP-44
    LTM8061 9mm x 15mm x 4.32mm LGA
    LTM8062 9mm x 15mm x 4.32mm LGA
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
