龙人旗下深圳市龙芯世纪科技有限公司
  • 电压基准
  • 发布时间:2013/7/25 9:50:11   修改时间:2013/7/25 9:50:11 浏览次数:2073
  • 电压基准
    凌力尔特提供了品种繁多的串联和并联高精度电压基准产品线。并联电压基准的工作方式在功能上等同于齐纳二极管。串联电压基准的操作方式在功能上则与三端稳压器等效。凌力尔特的许多电压基准都是专为在串联或并联模式中运作而设计的。我们所有的产品均提供了卓越的初始准确度、以及随时间和温度变化的低漂移特性。凌力尔特的 “基准 +” 器件把高精度电压基准与比较器或放大器组合在一起。
    电压基准
    Product Bits  (bits) Channels  (#) Speed  (Msps) SINAD  (dB) Power  (mW) I/O  Supply Voltage Range  Packages
    LT1004 1.235 Shunt 0.3 20 Shunt 8 0°C to 70°C SO-8
    LT1004 2.5 Shunt 0.8 20 Shunt 12 0°C to 70°C SO-8
    LT1004 1.235 Shunt 0.3 20 Shunt 8 0°C to 70°C TO-92
    LT1004 2.5 Shunt 0.8 20 Shunt 12 0°C to 70°C TO-92
    LT1004 1.235 Shunt 0.8 20 Shunt 8 -40°C to 85°C SO-8
    LT1004 2.5 Shunt 0.8 20 Shunt 12 -40°C to 85°C SO-8
    LT1004 1.235 Shunt 0.3 20 Shunt 8 -40°C to 85°C TO-92
    LT1004 2.5 Shunt 0.8 20 Shunt 12 -40°C to 85°C TO-92
    LT1009 2.5 Shunt 0.2 15 Shunt 400 0°C to 70°C MS-8
    LT1009 2.5 Shunt 0.2 15 Shunt 400 0°C to 70°C TO-92
    LT1009 2.5 Shunt 0.4 35 Shunt 400 -40°C to 85°C SO-8
    LT1009 2.5 Shunt 0.2 35 Shunt 400 -40°C to 85°C TO-92
    LT1009 2.5 Shunt 0.4 15 Shunt 400 0°C to 70°C SO-8
    LT1019 10 Series 0.05 3 1.1 650 0°C to 70°C DIP-8
    LT1019 2.5 Series 0.05 3 1.1 650 0°C to 70°C DIP-8
    LT1019 4.5 Series 0.05 3 1.1 650 0°C to 70°C DIP-8
    LT1019 5 Series 0.05 3 1.1 650 0°C to 70°C DIP-8
    LT1019 2.5 Series 0.05 3 1.1 650 0°C to 70°C SO-8
    LT1019 5 Series 0.05 3 1.1 650 0°C to 70°C SO-8
    LT1019 2.5 Series 0.05 3 1.1 650 -40°C to 85°C SO-8
    LT1019 5 Series 0.05 3 1.1 650 -40°C to 85°C SO-8
    LT1019 10 Series 0.2 5 1.1 650 0°C to 70°C DIP-8
    LT1019 2.5 Series 0.2 5 1.1 650 0°C to 70°C DIP-8
    LT1019 4.5 Series 0.2 5 1.1 650 0°C to 70°C DIP-8
    LT1019 5 Series 0.2 5 1.1 650 0°C to 70°C DIP-8
    LT1019 10 Series 0.2 5 1.1 650 0°C to 70°C SO-8
    LT1019 2.5 Series 0.2 5 1.1 650 0°C to 70°C SO-8
    LT1019 4.5 Series 0.2 5 1.1 650 0°C to 70°C SO-8
    LT1019 5 Series 0.2 5 1.1 650 0°C to 70°C SO-8
    LT1019 10 Series 0.2 5 1.1 650 -40°C to 85°C DIP-8
    LT1019 2.5 Series 0.2 5 1.1 650 -40°C to 85°C DIP-8
    LT1019 4.5 Series 0.2 5 1.1 650 -40°C to 85°C DIP-8
    LT1019 5 Series 0.2 5 1.1 650 -40°C to 85°C DIP-8
    LT1019 2.5 Series 0.2 5 1.1 650 -40°C to 85°C SO-8
    LT1019 5 Series 0.2 5 1.1 650 -40°C to 85°C SO-8
    LT1021 5 Series 1 2 2.2 800 0°C to 70°C TO-5
    LT1021 10 Series 0.5 2 1.5 800 0°C to 70°C DIP-8
    LT1021 5 Series 1 2 2.2 800 0°C to 70°C DIP-8
    LT1021 7 Series 0.71 2 1.5 800 0°C to 70°C DIP-8
    LT1021 10 Series 1 2 2.2 800 -55°C to 125°C TO-5
    LT1021 5 Series 1 2 2.2 800 -55°C to 125°C TO-5
    LT1021 5 Series 0.05 3 2.2 800 0°C to 70°C TO-5
    LT1021 10 Series 0.05 5 2.2 800 0°C to 70°C DIP-8
    LT1021 5 Series 0.05 3 2.2 800 0°C to 70°C DIP-8
    LT1021 10 Series 0.05 5 2.2 800 -40°C to 85°C DIP-8
    LT1021 5 Series 0.05 3 2.2 800 -40°C to 85°C DIP-8
    LT1021 5 Series 0.05 3 2.2 800 -55°C to 125°C TO-5
    LT1021 10 Series 0.5 5 2.2 800 0°C to 70°C DIP-8
    LT1021 5 Series 1 3 2.2 800 0°C to 70°C DIP-8
    LT1021 7 Series 0.71 3 1.5 800 0°C to 70°C DIP-8
    LT1021 10 Series 0.5 5 1.5 800 0°C to 70°C SO-8
    LT1021 5 Series 1 3 2.2 800 0°C to 70°C SO-8
    LT1021 7 Series 0.71 3 1.5 800 0°C to 70°C SO-8
    LT1021 5 Series 1 3 2.2 800 -40°C to 85°C DIP-8
    LT1027 5 Series 0.05 1 3 2200 0°C to 70°C DIP-8
    LT1027 5 Series 0.05 2 3 2200 0°C to 70°C DIP-8
    LT1027 5 Series 0.05 2 3 2200 0°C to 70°C SO-8
    LT1027 5 Series 0.1 3 3 2200 0°C to 70°C DIP-8
    LT1027 5 Series 0.1 3 3 2200 0°C to 70°C SO-8
    LT1029 5 Shunt 0.2 8 Shunt 700 0°C to 70°C TO-92
    LT1029 5 Shunt 1 12 Shunt 700 0°C to 70°C TO-92
    LT1031 10 Series 0.05 3 1 1200 0°C to 70°C TO-39
    LT1031 10 Series 0.05 3 1 1200 -55°C to 125°C TO-39
    LT1031 10 Series 0.1 6 1 1200 0°C to 70°C TO-39
    LT1031 10 Series 0.2 10 1 1200 0°C to 70°C TO-39
    LT1031 10 Series 0.2 10 1 1200 -55°C to 125°C TO-39
    LT1034 1.225 Shunt 1.2 10 Shunt 10 0°C to 70°C TO-92
    LT1034 2.5 Shunt 1.6 10 Shunt 15 0°C to 70°C TO-92
    LT1034 1.225 Shunt 1.2 10 Shunt 10 -40°C to 85°C TO-92
    LT1034 2.5 Shunt 1.6 10 Shunt 15 -40°C to 85°C TO-92
    LT1034 1.225 Shunt 1.2 20 Shunt 10 0°C to 70°C SO-8
    LT1034 2.5 Shunt 1.6 20 Shunt 15 0°C to 70°C SO-8
    LT1034 1.225 Shunt 1.2 20 Shunt 10 0°C to 70°C TO-92
    LT1034 2.5 Shunt 1.6 20 Shunt 15 0°C to 70°C TO-92
    LT1034 1.225 Shunt 1.2 20 Shunt 10 -40°C to 85°C SO-8
    LT1034 2.5 Shunt 1.6 20 Shunt 15 -40°C to 85°C SO-8
    LT1034 1.225 Shunt 1.2 20 Shunt 10 -40°C to 85°C TO-92
    LT1034 2.5 Shunt 1.6 20 Shunt 15 -40°C to 85°C TO-92
    LT1236 10 Series 0.05 2 1 800 0°C to 70°C DIP-8
    LT1236 5 Series 0.05 2 1 800 0°C to 70°C DIP-8
    LT1236 10 Series 0.05 2 1 800 0°C to 70°C SO-8
    LT1236 5 Series 0.05 2 1 800 0°C to 70°C SO-8
    LT1236LS8 5 Series 0.05 2 1 800 -40°C to 85°C LS-8
    LT1236 10 Series 0.05 2 1 800 -40°C to 85°C DIP-8
    LT1236 10 Series 0.05 2 1 800 -40°C to 85°C SO-8
    LT1236 5 Series 0.05 2 1 800 -40°C to 85°C SO-8
    LT1236 10 Series 0.1 5 1 800 0°C to 70°C DIP-8
    LT1236 5 Series 0.1 5 1 800 0°C to 70°C DIP-8
    LT1236 10 Series 0.1 5 1 800 0°C to 70°C SO-8
    LT1236 5 Series 0.1 5 1 800 0°C to 70°C SO-8
    LT1236LS8 5 Series 0.1 5 1 800 -40°C to 85°C LS-8
    LT1236 10 Series 0.1 5 1 800 -40°C to 85°C DIP-8
    LT1236 5 Series 0.1 5 1 800 -40°C to 85°C DIP-8
    LT1236 10 Series 0.1 5 1 800 -40°C to 85°C SO-8
    LT1236 5 Series 0.1 5 1 800 -40°C to 85°C SO-8
    LT1236 10 Series 0.1 10 1 800 0°C to 70°C DIP-8
    LT1236 5 Series 0.1 10 1 800 0°C to 70°C DIP-8
    LT1236 10 Series 0.1 10 1 800 0°C to 70°C SO-8
    LT1236 5 Series 0.1 10 1 800 0°C to 70°C SO-8
    LT1236 10 Series 0.1 10 1 800 -40°C to 85°C DIP-8
    LT1236 5 Series 0.1 10 1 800 -40°C to 85°C DIP-8
    LT1236 10 Series 0.1 10 1 800 -40°C to 85°C SO-8
    LT1236 5 Series 0.1 10 1 800 -40°C to 85°C SO-8
    LT1389 1.25 Shunt 0.05 4 Shunt 0.6 0°C to 70°C SO-8
    LT1389 2.5 Shunt 0.05 8 Shunt 0.6 0°C to 70°C SO-8
    LT1389 4.096 Shunt 0.075 12 Shunt 0.6 0°C to 70°C SO-8
    LT1389 5 Shunt 0.075 12 Shunt 0.6 0°C to 70°C SO-8
    LT1431 5 Shunt 0.4 30 Shunt 600 0°C to 70°C DIP-8
    LT1431 5 Shunt 0.4 30 Shunt 600 0°C to 70°C SO-8
    LT1431 5 Shunt 0.4 30 Shunt 600 0°C to 70°C TO-92
    LT1431 5 Shunt 0.4 50 Shunt 600 -40°C to 85°C DIP-8
    LT1431 5 Shunt 0.4 50 Shunt 600 -40°C to 85°C SO-8
    LT1431 5 Shunt 0.4 50 Shunt 600 -40°C to 85°C TO-92
    LT1431 5 Shunt 0.4 50 Shunt 600 -55°C to 125°C CERDIP
    LT1431 5 Shunt 0.4 50 Shunt 600 -55°C to 125°C SO-8
    LT1460 10 Series 0.075 5 0.9 190 0°C to 70°C DIP-8
    LT1460 2.5 Series 0.075 5 0.9 100 0°C to 70°C DIP-8
    LT1460 5 Series 0.075 5 0.9 125 0°C to 70°C DIP-8
    LT1460 10 Series 0.075 5 0.9 190 0°C to 70°C SO-8
    LT1460 2.5 Series 0.075 5 0.9 100 0°C to 70°C SO-8
    LT1460 5 Series 0.075 5 0.9 125 0°C to 70°C SO-8
    LT1460 10 Series 0.1 5 0.9 190 -40°C to 85°C DIP-8
    LT1460 2.5 Series 0.1 5 0.9 100 -40°C to 85°C DIP-8
    LT1460 5 Series 0.1 5 0.9 125 -40°C to 85°C DIP-8
    LT1460 10 Series 0.1 5 0.9 190 -40°C to 85°C SO-8
    LT1460 2.5 Series 0.1 5 0.9 100 -40°C to 85°C SO-8
    LT1460 5 Series 0.1 5 0.9 125 -40°C to 85°C SO-8
    LT1460 10 Series 0.1 7 0.9 190 0°C to 70°C MS-8
    LT1460 2.5 Series 0.1 7 0.9 100 0°C to 70°C MS-8
    LT1460 5 Series 0.1 7 0.9 125 0°C to 70°C MS-8
    LT1460 10 Series 0.1 10 0.9 190 0°C to 70°C DIP-8
    LT1460 2.5 Series 0.1 10 0.9 100 0°C to 70°C DIP-8
    LT1460 5 Series 0.125 10 0.9 125 0°C to 70°C DIP-8
    LT1460 10 Series 0.1 10 0.9 190 0°C to 70°C SO-8
    LT1460 2.5 Series 0.1 10 0.9 100 0°C to 70°C SO-8
    LT1460 5 Series 0.125 10 0.9 125 0°C to 70°C SO-8
    LT1460 10 Series 0.125 10 0.9 190 -40°C to 85°C DIP-8
    LT1460 2.5 Series 0.125 10 0.9 100 -40°C to 85°C DIP-8
    LT1460 5 Series 0.125 10 0.9 125 -40°C to 85°C DIP-8
    LT1460 10 Series 0.125 10 0.9 190 -40°C to 85°C SO-8
    LT1460 2.5 Series 0.125 10 0.9 100 -40°C to 85°C SO-8
    LT1460 5 Series 0.125 10 0.9 125 -40°C to 85°C SO-8
    LT1460 10 Series 0.15 12 0.9 190 0°C to 70°C MS-8
    LT1460 2.5 Series 0.15 12 0.9 100 0°C to 70°C MS-8
    LT1460 5 Series 0.15 12 0.9 125 0°C to 70°C MS-8
    LT1460 10 Series 0.25 12 0.9 190 0°C to 70°C TO-92
    LT1460 2.5 Series 0.25 12 0.9 100 0°C to 70°C TO-92
    LT1460 5 Series 0.25 12 0.9 125 0°C to 70°C TO-92
    LT1460 10 Series 0.25 12 0.9 190 -40°C to 85°C TO-92
    LT1460 2.5 Series 0.25 12 0.9 100 -40°C to 85°C TO-92
    LT1460 5 Series 0.25 12 0.9 125 -40°C to 85°C TO-92
    LT1460 10 Series 0.2 10 0.9 190 0°C to 70°C SOT-23
    LT1460 2.5 Series 0.5 10 0.9 100 0°C to 70°C SOT-23
    LT1460 3 Series 0.2 10 0.9 145 0°C to 70°C SOT-23
    LT1460 3.3 Series 0.2 10 0.9 145 0°C to 70°C SOT-23
    LT1460 5 Series 0.2 10 0.9 125 0°C to 70°C SOT-23
    LT1460 10 Series 0.4 10 0.9 190 0°C to 70°C SOT-23
    LT1460 2.5 Series 0.4 10 0.9 100 0°C to 70°C SOT-23
    LT1460 3 Series 0.4 10 0.9 145 0°C to 70°C SOT-23
    LT1460 3.3 Series 0.4 10 0.9 145 0°C to 70°C SOT-23
    LT1460 5 Series 0.4 10 0.9 125 0°C to 70°C SOT-23
    LT1460 10 Series 0.5 25 0.9 190 0°C to 70°C SOT-23
    LT1460 2.5 Series 0.5 25 0.9 100 0°C to 70°C SOT-23
    LT1460 3 Series 0.5 25 0.9 145 0°C to 70°C SOT-23
    LT1460 3.3 Series 0.5 25 0.9 145 0°C to 70°C SOT-23
    LT1460 5 Series 0.5 25 0.9 125 0°C to 70°C SOT-23
    LT1460 2.5 Series 0.2 25 0.9 100 -40°C to 125°C SO-8
    LT1460 5 Series 0.2 25 0.9 125 -40°C to 125°C SO-8
    LT1461 2.5 Series 0.04 1 0.3 35 0°C to 70°C SO-8
    LT1461 3 Series 0.04 1 0.3 35 0°C to 70°C SO-8
    LT1461 3.3 Series 0.04 1 0.3 35 0°C to 70°C SO-8
    LT1461 4.096 Series 0.04 1 0.3 35 0°C to 70°C SO-8
    LT1461 5 Series 0.04 1 0.3 35 0°C to 70°C SO-8
    LT1461 2.5 Series 0.04 1 0.3 35 -40°C to 85°C SO-8
    LT1461 3 Series 0.04 1 0.3 35 -40°C to 85°C SO-8
    LT1461 3.3 Series 0.04 1 0.3 35 -40°C to 85°C SO-8
    LT1461 4.096 Series 0.04 1 0.3 35 -40°C to 85°C SO-8
    LT1461 5 Series 0.04 1 0.3 35 -40°C to 85°C SO-8
    LT1461 2.5 Series 0.06 3 0.3 35 0°C to 70°C SO-8
    LT1461 3 Series 0.1 3 0.3 35 0°C to 70°C SO-8
    LT1461 3.3 Series 0.1 3 0.3 35 0°C to 70°C SO-8
    LT1461 4.096 Series 0.06 3 0.3 35 0°C to 70°C SO-8
    LT1461 5 Series 0.06 3 0.3 35 0°C to 70°C SO-8
    LT1461 2.5 Series 0.06 3 0.3 35 -40°C to 85°C SO-8
    LT1461 3 Series 0.06 3 0.3 35 -40°C to 85°C SO-8
    LT1461 3.3 Series 0.1 3 0.3 35 -40°C to 85°C SO-8
    LT1461 4.096 Series 0.1 3 0.3 35 -40°C to 85°C SO-8
    LT1461 5 Series 0.06 3 0.3 35 -40°C to 85°C SO-8
    LT1461 2.5 Series 0.1 5 0.3 35 0°C to 70°C SO-8
    LT1461 3 Series 0.1 5 0.3 35 0°C to 70°C SO-8
    LT1461 3.3 Series 0.1 5 0.3 35 0°C to 70°C SO-8
    LT1461 4.096 Series 0.1 5 0.3 35 0°C to 70°C SO-8
    LT1461 5 Series 0.1 5 0.3 35 0°C to 70°C SO-8
    LT1461 2.5 Series 0.1 5 0.3 35 -40°C to 85°C SO-8
    LT1461 3 Series 0.1 5 0.3 35 -40°C to 85°C SO-8
    LT1461 3.3 Series 0.1 5 0.3 35 -40°C to 85°C SO-8
    LT1461 4.096 Series 0.1 5 0.3 35 -40°C to 85°C SO-8
    LT1461 5 Series 0.1 5 0.3 35 -40°C to 85°C SO-8
    LT1461 2.5 Series 0.15 7 0.3 35 -40°C to 125°C SO-8
    LT1461 3 Series 0.2 7 0.3 35 -40°C to 125°C SO-8
    LT1461 3.3 Series 0.2 7 0.3 35 -40°C to 125°C SO-8
    LT1461 4.096 Series 0.2 7 0.3 35 -40°C to 125°C SO-8
    LT1461 5 Series 0.2 7 0.3 35 -40°C to 125°C SO-8
    LT1634 1.25 Shunt 0.05 4 Shunt 7 0°C to 70°C SO-8
    LT1634 2.5 Shunt 0.05 4 Shunt 7 0°C to 70°C SO-8
    LT1634 4.096 Shunt 0.05 4 Shunt 7 0°C to 70°C SO-8
    LT1634 5 Shunt 0.05 4 Shunt 7 0°C to 70°C SO-8
    LT1634 1.25 Shunt 0.05 4 Shunt 7 -40°C to 85°C SO-8
    LT1634 2.5 Shunt 0.05 4 Shunt 7 -40°C to 85°C SO-8
    LT1634 4.096 Shunt 0.05 4 Shunt 7 -40°C to 85°C SO-8
    LT1634 5 Shunt 0.05 4 Shunt 7 -40°C to 85°C SO-8
    LT1634 1.25 Shunt 0.05 10 Shunt 7 0°C to 70°C MS-8
    LT1634 2.5 Shunt 0.05 10 Shunt 7 0°C to 70°C MS-8
    LT1634 1.25 Shunt 0.05 10 Shunt 7 0°C to 70°C SO-8
    LT1634 2.5 Shunt 0.05 10 Shunt 7 0°C to 70°C SO-8
    LT1634 4.096 Shunt 0.05 10 Shunt 7 0°C to 70°C SO-8
    LT1634 5 Shunt 0.05 10 Shunt 7 0°C to 70°C SO-8
    LT1634 1.25 Shunt 0.05 10 Shunt 7 -40°C to 85°C SO-8
    LT1634 2.5 Shunt 0.05 10 Shunt 7 -40°C to 85°C SO-8
    LT1634 4.096 Shunt 0.05 10 Shunt 7 -40°C to 85°C SO-8
    LT1634 5 Shunt 0.05 10 Shunt 7 -40°C to 85°C SO-8
    LT1634 1.25 Shunt 0.2 10 Shunt 7 0°C to 70°C TO-92
    LT1634 2.5 Shunt 0.2 10 Shunt 7 0°C to 70°C TO-92
    LT1634 4.096 Shunt 0.2 10 Shunt 7 0°C to 70°C TO-92
    LT1634 5 Shunt 0.2 10 Shunt 7 0°C to 70°C TO-92
    LT1635 0.2 Shunt 2.5 30 Shunt 130 C,I DIP-8, SO-8
    LT1790 1.25 Series 0.05 5 0.1 35 0°C to 70°C SOT-23
    LT1790 2.048 Series 0.05 5 0.1 35 0°C to 70°C SOT-23
    LT1790 2.5 Series 0.05 5 0.1 35 0°C to 70°C SOT-23
    LT1790 3 Series 0.05 5 0.1 35 0°C to 70°C SOT-23
    LT1790 3.3 Series 0.05 5 0.1 35 0°C to 70°C SOT-23
    LT1790 4.096 Series 0.05 5 0.1 35 0°C to 70°C SOT-23
    LT1790 5 Series 0.05 5 0.1 35 0°C to 70°C SOT-23
    LT1790 1.25 Series 0.05 5 0.1 35 -40°C to 85°C SOT-23
    LT1790 2.048 Series 0.05 5 0.1 35 -40°C to 85°C SOT-23
    LT1790 2.5 Series 0.05 5 0.1 35 -40°C to 85°C SOT-23
    LT1790 3 Series 0.05 5 0.1 35 -40°C to 85°C SOT-23
    LT1790 3.3 Series 0.05 5 0.1 35 -40°C to 85°C SOT-23
    LT1790 4.096 Series 0.05 5 0.1 35 -40°C to 85°C SOT-23
    LT1790 5 Series 0.05 5 0.1 35 -40°C to 85°C SOT-23
    LT1790 1.25 Series 0.1 12 0.1 35 0°C to 70°C SOT-23
    LT1790 2.048 Series 0.1 12 0.1 35 0°C to 70°C SOT-23
    LT1790 2.5 Series 0.1 12 0.1 35 0°C to 70°C SOT-23
    LT1790 3 Series 0.1 12 0.1 35 0°C to 70°C SOT-23
    LT1790 3.3 Series 0.1 12 0.1 35 0°C to 70°C SOT-23
    LT1790 4.096 Series 0.1 12 0.1 35 0°C to 70°C SOT-23
    LT1790 5 Series 0.1 12 0.1 35 0°C to 70°C SOT-23
    LT1790 1.25 Series 0.1 12 0.1 35 -40°C to 85°C SOT-23
    LT1790 2.048 Series 0.1 12 0.1 35 -40°C to 85°C SOT-23
    LT1790 2.5 Series 0.1 12 0.1 35 -40°C to 85°C SOT-23
    LT1790 3 Series 0.1 12 0.1 35 -40°C to 85°C SOT-23
    LT1790 3.3 Series 0.1 12 0.1 35 -40°C to 85°C SOT-23
    LT1790 4.096 Series 0.1 12 0.1 35 -40°C to 85°C SOT-23
    LT1790 5 Series 0.1 12 0.1 35 -40°C to 85°C SOT-23
    LT6650 0.4 Series 0.75 30 0.1 11 0°C to 70°C SOT-23
    LT6650 0.4 Series 1.5 30 0.1 11 -40°C to 125°C SOT-23
    LT6650 0.4 Series 1 30 0.1 11 -40°C to 85°C SOT-23
    LT6654 2.5 Series 0.05 3 0.055 350 -40°C to 125°C LS-8
    LT6654 1.25 Series 0.05 3 0.055 350 -40°C to 125°C SOT-23
    LT6654 2.048 Series 0.05 3 0.055 350 -40°C to 125°C SOT-23
    LT6654 2.5 Series 0.05 3 0.055 350 -40°C to 125°C SOT-23
    LT6654 3 Series 0.05 3 0.055 350 -40°C to 125°C SOT-23
    LT6654 3.3 Series 0.05 3 0.055 350 -40°C to 125°C SOT-23
    LT6654 4.096 Series 0.05 3 0.055 350 -40°C to 125°C SOT-23
    LT6654 5 Series 0.05 3 0.055 350 -40°C to 125°C SOT-23
    LT6654 1.25 Series 0.05 3 0.055 350 -55°C to 125°C SOT-23
    LT6654 2.048 Series 0.05 3 0.055 350 -55°C to 125°C SOT-23
    LT6654 2.5 Series 0.05 3 0.055 350 -55°C to 125°C SOT-23
    LT6654 3 Series 0.05 3 0.055 350 -55°C to 125°C SOT-23
    LT6654 3.3 Series 0.05 3 0.055 350 -55°C to 125°C SOT-23
    LT6654 4.096 Series 0.05 3 0.055 350 -55°C to 125°C SOT-23
    LT6654 5 Series 0.05 3 0.055 350 -55°C to 125°C SOT-23
    LT6654 2.5 Series 0.1 6 0.055 350 -40°C to 125°C LS-8
    LT6654 1.25 Series 0.1 6 0.055 350 -40°C to 125°C SOT-23
    LT6654 2.048 Series 0.1 6 0.055 350 -40°C to 125°C SOT-23
    LT6654 2.5 Series 0.1 6 0.055 350 -40°C to 125°C SOT-23
    LT6654 3 Series 0.1 6 0.055 350 -40°C to 125°C SOT-23
    LT6654 3.3 Series 0.1 6 0.055 350 -40°C to 125°C SOT-23
    LT6654 4.096 Series 0.1 6 0.055 350 -40°C to 125°C SOT-23
    LT6654 5 Series 0.1 6 0.055 350 -40°C to 125°C SOT-23
    LT6654 1.25 Series 0.1 6 0.055 350 -55°C to 125°C SOT-23
    LT6654 2.048 Series 0.1 6 0.055 350 -55°C to 125°C SOT-23
    LT6654 2.5 Series 0.1 6 0.055 350 -55°C to 125°C SOT-23
    LT6654 3 Series 0.1 6 0.055 350 -55°C to 125°C SOT-23
    LT6654 3.3 Series 0.1 6 0.055 350 -55°C to 125°C SOT-23
    LT6654 4.096 Series 0.1 6 0.055 350 -55°C to 125°C SOT-23
    LT6654 5 Series 0.1 6 0.055 350 -55°C to 125°C SOT-23
    LT6656 1.25 Series 0.1 5 0.5 0.85 0°C to 70°C DFN-6
    LT6656 2.048 Series 0.1 5 0.5 0.85 0°C to 70°C DFN-6
    LT6656 2.5 Series 0.1 5 0.5 0.85 0°C to 70°C DFN-6
    LT6656 3 Series 0.1 5 0.5 0.85 0°C to 70°C DFN-6
    LT6656 3.3 Series 0.1 5 0.5 0.85 0°C to 70°C DFN-6
    LT6656 4.096 Series 0.1 5 0.5 0.85 0°C to 70°C DFN-6
    LT6656 5 Series 0.1 5 0.5 0.85 0°C to 70°C DFN-6
    LT6656 1.25 Series 0.05 5 0.5 0.85 0°C to 70°C SOT-23
    LT6656 2.048 Series 0.05 5 0.5 0.85 0°C to 70°C SOT-23
    LT6656 2.5 Series 0.05 5 0.5 0.85 0°C to 70°C SOT-23
    LT6656 3 Series 0.05 5 0.5 0.85 0°C to 70°C SOT-23
    LT6656 3.3 Series 0.05 5 0.5 0.85 0°C to 70°C SOT-23
    LT6656 4.096 Series 0.05 5 0.5 0.85 0°C to 70°C SOT-23
    LT6656 5 Series 0.05 5 0.5 0.85 0°C to 70°C SOT-23
    LT6656 1.25 Series 0.1 5 0.5 0.85 -40°C to 85°C DFN-6
    LT6656 2.048 Series 0.1 5 0.5 0.85 -40°C to 85°C DFN-6
    LT6656 2.5 Series 0.1 5 0.5 0.85 -40°C to 85°C DFN-6
    LT6656 3 Series 0.1 5 0.5 0.85 -40°C to 85°C DFN-6
    LT6656 3.3 Series 0.1 5 0.5 0.85 -40°C to 85°C DFN-6
    LT6656 4.096 Series 0.1 5 0.5 0.85 -40°C to 85°C DFN-6
    LT6656 5 Series 0.1 5 0.5 0.85 -40°C to 85°C DFN-6
    LT6656 1.25 Series 0.05 5 0.5 0.85 -40°C to 85°C SOT-23
    LT6656 2.048 Series 0.05 5 0.5 0.85 -40°C to 85°C SOT-23
    LT6656 2.5 Series 0.05 5 0.5 0.85 -40°C to 85°C SOT-23
    LT6656 3 Series 0.05 5 0.5 0.85 -40°C to 85°C SOT-23
    LT6656 3.3 Series 0.05 5 0.5 0.85 -40°C to 85°C SOT-23
    LT6656 4.096 Series 0.05 5 0.5 0.85 -40°C to 85°C SOT-23
    LT6656 5 Series 0.05 5 0.5 0.85 -40°C to 85°C SOT-23
    LT6656 1.25 Series 0.2 12 0.5 0.85 0°C to 70°C DFN-6
    LT6656 2.048 Series 0.2 12 0.5 0.85 0°C to 70°C DFN-6
    LT6656 2.5 Series 0.2 12 0.5 0.85 0°C to 70°C DFN-6
    LT6656 3 Series 0.2 12 0.5 0.85 0°C to 70°C DFN-6
    LT6656 3.3 Series 0.2 12 0.5 0.85 0°C to 70°C DFN-6
    LT6656 4.096 Series 0.2 12 0.5 0.85 0°C to 70°C DFN-6
    LT6656 5 Series 0.2 12 0.5 0.85 0°C to 70°C DFN-6
    LT6656 1.25 Series 0.1 12 0.5 0.85 0°C to 70°C SOT-23
    LT6656 2.048 Series 0.1 12 0.5 0.85 0°C to 70°C SOT-23
    LT6656 2.5 Series 0.1 12 0.5 0.85 0°C to 70°C SOT-23
    LT6656 3 Series 0.1 12 0.5 0.85 0°C to 70°C SOT-23
    LT6656 3.3 Series 0.1 12 0.5 0.85 0°C to 70°C SOT-23
    LT6656 4.096 Series 0.1 12 0.5 0.85 0°C to 70°C SOT-23
    LT6656 5 Series 0.1 12 0.5 0.85 0°C to 70°C SOT-23
    LT6656 1.25 Series 0.2 12 0.5 0.85 -40°C to 85°C DFN-6
    LT6656 2.048 Series 0.2 12 0.5 0.85 -40°C to 85°C DFN-6
    LT6656 2.5 Series 0.2 12 0.5 0.85 -40°C to 85°C DFN-6
    LT6656 3 Series 0.2 12 0.5 0.85 -40°C to 85°C DFN-6
    LT6656 3.3 Series 0.2 12 0.5 0.85 -40°C to 85°C DFN-6
    LT6656 4.096 Series 0.2 12 0.5 0.85 -40°C to 85°C DFN-6
    LT6656 5 Series 0.2 12 0.5 0.85 -40°C to 85°C DFN-6
    LT6656 1.25 Series 0.1 12 0.5 0.85 -40°C to 85°C SOT-23
    LT6656 2.048 Series 0.1 12 0.5 0.85 -40°C to 85°C SOT-23
    LT6656 2.5 Series 0.1 12 0.5 0.85 -40°C to 85°C SOT-23
    LT6656 3 Series 0.1 12 0.5 0.85 -40°C to 85°C SOT-23
    LT6656 3.3 Series 0.1 12 0.5 0.85 -40°C to 85°C SOT-23
    LT6656 4.096 Series 0.1 12 0.5 0.85 -40°C to 85°C SOT-23
    LT6656 5 Series 0.1 12 0.5 0.85 -40°C to 85°C SOT-23
    LT6660 10 Series 0.2 10 0.9 215 0°C to 70°C DFN-3
    LT6660 2.5 Series 0.2 10 0.9 115 0°C to 70°C DFN-3
    LT6660 3 Series 0.2 10 0.9 145 0°C to 70°C DFN-3
    LT6660 3.3 Series 0.2 10 0.9 145 0°C to 70°C DFN-3
    LT6660 5 Series 0.2 10 0.9 160 0°C to 70°C DFN-3
    LT6660 10 Series 0.4 10 0.9 215 0°C to 70°C DFN-3
    LT6660 2.5 Series 0.4 10 0.9 115 0°C to 70°C DFN-3
    LT6660 3 Series 0.4 10 0.9 145 0°C to 70°C DFN-3
    LT6660 3.3 Series 0.4 10 0.9 145 0°C to 70°C DFN-3
    LT6660 5 Series 0.4 10 0.9 160 0°C to 70°C DFN-3
    LT6660 10 Series 0.5 25 0.9 215 0°C to 70°C DFN-3
    LT6660 2.5 Series 0.5 25 0.9 115 0°C to 70°C DFN-3
    LT6660 3 Series 0.5 25 0.9 145 0°C to 70°C DFN-3
    LT6660 3.3 Series 0.5 25 0.9 145 0°C to 70°C DFN-3
    LT6660 5 Series 0.5 25 0.9 160 0°C to 70°C DFN-3
    LTC1258 2.5 Series 0.21 60 0.1 4 0°C to 70°C MS-8
    LTC1258 3 Series 0.15 60 0.1 4 0°C to 70°C MS-8
    LTC1258 4.096 Series 0.15 60 0.1 4 0°C to 70°C MS-8
    LTC1258 5 Series 0.18 60 0.1 4 0°C to 70°C MS-8
    LTC1258 2.5 Series 0.15 15 0.1 4 0°C to 70°C SO-8
    LTC1258 3 Series 0.15 15 0.1 4 0°C to 70°C SO-8
    LTC1258 4.096 Series 0.15 15 0.1 4 0°C to 70°C SO-8
    LTC1258 5 Series 0.15 15 0.1 4 0°C to 70°C SO-8
    LTC1440 1.182 Shunt 1 55.5 Shunt 2 0°C to 70°C, -40°C to 85°C MS-8, SO-8, DIP-8, DFN-8
    LTC1442 1.182 Shunt 1 55.5 Shunt 3.5 0°C to 70°C, -40°C to 85°C SO-8, DIP-8
    LTC1443 1.182 Shunt 1 44.4 Shunt 5.5 0°C to 70°C, -40°C to 85°C DIP-16, SO-16, DFN-16
    LTC1444 1.221 Shunt 1 44.4 Shunt 5.5 0°C to 70°C, -40°C to 85°C DIP-16, SO-16
    LTC1445 1.221 Shunt 1 44.4 Shunt 5.5 0°C to 70°C, -40°C to 85°C DIP-16, SO-16, DFN-16
    LTC1540 1.182 Shunt 2.2 62.5 Shunt 0.3 C, I MS-8, SO-8, DFN-8
    LTC1541 1.2 Shunt 1.25 62.5 Shunt 5 0°C to 70°C, -40°C to 85°C MS-8, SO-8, DFN-8
    LTC1798 2.5 Series 0.15 15 0.1 4 0°C to 70°C SO-8
    LTC1798 3 Series 0.15 15 0.1 4 0°C to 70°C SO-8
    LTC1798 4.096 Series 0.15 15 0.1 4 0°C to 70°C SO-8
    LTC1798 5 Series 0.15 15 0.1 4 0°C to 70°C SO-8
    LTC1842 1.182 Shunt 1 55.5 Shunt 3.5 0°C to 70°C, -40°C to 85°C SO-8
    LTC1843 1.182 Shunt 1 55.5 Shunt 3.5 0°C to 70°C, -40°C to 85°C SO-8
    LTC1998 1.2 Shunt 0.6 71 Shunt 3.5 0°C to 70°C, -40°C to 85°C SOT-23
    LTC6652 2.5 Series 0.05 2 0.3 350 -40°C to 125°C LS-8
    LTC6652 1.25 Series 0.05 2 0.3 350 -40°C to 125°C MS-8
    LTC6652 2.048 Series 0.05 2 0.3 350 -40°C to 125°C MS-8
    LTC6652 2.5 Series 0.05 2 0.3 350 -40°C to 125°C MS-8
    LTC6652 3 Series 0.05 2 0.3 350 -40°C to 125°C MS-8
    LTC6652 3.3 Series 0.05 2 0.3 350 -40°C to 125°C MS-8
    LTC6652 4.096 Series 0.05 2 0.3 350 -40°C to 125°C MS-8
    LTC6652 5 Series 0.05 2 0.3 350 -40°C to 125°C MS-8
    LTC6652 2.5 Series 0.1 4 0.3 350 -40°C to 125°C LS-8
    LTC6652 1.25 Series 0.1 4 0.3 350 -40°C to 125°C MS-8
    LTC6652 2.048 Series 0.1 4 0.3 350 -40°C to 125°C MS-8
    LTC6652 2.5 Series 0.1 4 0.3 350 -40°C to 125°C MS-8
    LTC6652 3 Series 0.1 4 0.3 350 -40°C to 125°C MS-8
    LTC6652 3.3 Series 0.1 4 0.3 350 -40°C to 125°C MS-8
    LTC6652 4.096 Series 0.1 4 0.3 350 -40°C to 125°C MS-8
    LTC6652 5 Series 0.1 4 0.3 350 -40°C to 125°C MS-8
    LTC6655 2.5 Series 0.025 1 0.5 5000 -40°C to 125°C LS-8
    LTC6655 1.25 Series 0.025 1 0.5 5000 -40°C to 125°C MS-8
    LTC6655 2.048 Series 0.025 1 0.5 5000 -40°C to 125°C MS-8
    LTC6655 2.5 Series 0.025 1 0.5 5000 -40°C to 125°C MS-8
    LTC6655 3 Series 0.025 1 0.5 5000 -40°C to 125°C MS-8
    LTC6655 3.3 Series 0.025 1 0.5 5000 -40°C to 125°C MS-8
    LTC6655 4.096 Series 0.025 1 0.5 5000 -40°C to 125°C MS-8
    LTC6655 5 Series 0.025 1 0.5 5000 -40°C to 125°C MS-8
    LTC6655 2.5 Series 0.05 2.5 0.5 5000 -40°C to 125°C LS-8
    LTC6655 1.25 Series 0.05 2.5 0.5 5000 -40°C to 125°C MS-8
    LTC6655 2.048 Series 0.05 2.5 0.5 5000 -40°C to 125°C MS-8
    LTC6655 2.5 Series 0.05 2.5 0.5 5000 -40°C to 125°C MS-8
    LTC6655 3 Series 0.05 2.5 0.5 5000 -40°C to 125°C MS-8
    LTC6655 3.3 Series 0.05 2.5 0.5 5000 -40°C to 125°C MS-8
    LTC6655 4.096 Series 0.05 2.5 0.5 5000 -40°C to 125°C MS-8
    LTC6655 5 Series 0.05 2.5 0.5 5000 -40°C to 125°C MS-8
    LTZ1000 7.2 Super Zener 4 0.05 N/A 250 -55°C to 125°C TO-5
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
