龙人旗下深圳市龙芯世纪科技有限公司
  • 滤波器
  • 发布时间:2013/7/25 9:51:07   修改时间:2013/7/25 9:51:48 浏览次数:2466
  • 滤波器
    凌力尔特的连续时间和开关电容滤波器产品线提供了简单和灵活的鉴频解决方案。我们特别设计的滤波器产品可适应任何的频率响应 (低通、高通或带通) 及各种频率。
    滤波器
    Product Bits  (bits) Channels  (#) Speed  (Msps) SINAD  (dB) Power  (mW) I/O  Supply Voltage Range  Packages
    LT1567 1 Universal 2 5000 Wideband Buffer and Diff Out Amp, Flexible 2nd Order Filter, Fcuttoff up to 5MHz no MSOP-8
    LT1568 2 Lowpass or Bandpass 4 100 5000 Two 2nd Order Stages, Excellent for Matched Pair 2-pole Butterworths no SSOP-16
    LT6600-10 1 Lowpass 4 10000 Low Noise Diff Amp w/ 10MHz LP Filter no SO-8, DFN-12
    LT6600-15 1 Lowpass 4 15000 Low Noise Diff Amp w/ 15MHz LP Filter no SO-8
    LT6600-2.5 1 Lowpass 4 2500 Low Noise Diff Amp w/ 2.5MHz LP Filter no SO-8, DFN-12
    LT6600-20 1 Lowpass 4 20000 Low Noise Diff Amp w/ 20MHz LP Filter no SO-8
    LT6600-5 1 Lowpass 4 5000 Low Noise Diff Amp w/ 5MHz LP Filter no SO-8
    LT6604-10 2 Lowpass 4 10000 Dual Very Low Noise, Differential Amplifier and 10MHz Lowpass Filter no QFN-34
    LT6604-15 2 Lowpass 4 15000 Dual Very Low Noise, Differential Amplifier and 15MHz Lowpass Filter no QFN-34
    LT6604-2.5 2 Lowpass 4 2500 Dual Very Low Noise, Differential Ampli詮?r and 2.5MHz Lowpass Filter no QFN-34
    LT6604-5 2 Lowpass 4 5000 Dual Very Low Noise, Differential Ampli詮?r and 2.5MHz Lowpass Filter no QFN-34
    LTC1059 1 Universal 2 1 40 Low Noise, Center Frequency Range is 0.1Hz to 40kHz, MF5 Replacement yes DIP-14, SO-14
    LTC1060 2 Universal 4 1 20 Center Frequency Up to 30kHz, Improved MF10 Replacement yes DIP-20, SO-20
    LTC1061 3 Universal 1 35 Center Frequency Up to 35kHz, Low Offset, 90dB SNR yes DIP-20, SO-20
    LTC1062 1 Lowpass 5 1 20 No DC Error, Low Passband Noise, DC to 20kHz yes DIP-8, SOW-16
    LTC1063 1 Lowpass 5 1 50 Internal or External Clock, 1mV DC Offset, Cascadable for Faster Rolloff yes DIP-8, SOW-16
    LTC1064 4 Universal 8 1 140 Low Noise, Quad, Center Frequency Range Up to 140kHz yes DIP-24, SO-24
    LTC1064-1 1 Lowpass 8 1 50 Low Noise,  8th Order Elliptic, Center Frequency Up to 50kHz yes DIP-14, SOW-16
    LTC1064-2 1 Lowpass 8 1 140 Low Noise,  8th Order Butterworth, Center Frequency Up to 95kHz yes DIP-14, SOW-16
    LTC1064-3 1 Lowpass 8 1 100 Low Noise, Bessel Lowpass Filter yes DIP-14, SOW-16
    LTC1064-4 1 Lowpass 8 1 100 Low Noise,  8th Order Elliptic, Center Frequency Up to 100kHz yes DIP-14, SOW-16
    LTC1064-7 1 Lowpass 8 1 100 Low Noise, 8th Order, Constant Group Delay yes DIP-14, SOW-16
    LTC1065 1 Lowpass 1 60 1mV DC Offset, Internal or External Clock, Cascadable for Faster Rolloff yes DIP-8, SOW-16
    LTC1066-1 1 Lowpass 8 1 100 14-Bit DC Gain Linearity, 1.5mV DC Offset, 7uV/?C Tempco yes SOW-18
    LTC1067 2 Universal 4 1 17 Rail-to-Rail, Very Low Noise, Single 3V Supply yes SSOP-16, SO-16
    LTC1068 4 Universal 8 1 50 4 Identical 2nd Order Filters, Low Noise, Center Frequency Error 0.3% yes SSOP-28, DIP-24
    LTC1069-1 1 Lowpass 8 1 12 Low Power, Attenuation: 20dB @1.2x Cuttoff Freq, 52dB@1.4x, 70dB@2x yes DIP-8, SO-8
    LTC1069-6 1 Lowpass 8 1 20 Single 3V Supply, Low Power, Attenuation: 42dB @1.3x Cuttoff Freq, 66dB@2.0x, 70dB@2.1x yes SO-8
    LTC1069-7 1 Lowpass 8 1 200 Linear Phase. Raised Cosine Amplitude Response, Attenuation:  43dB@2x fcuttoff yes SO-8
    LTC1164 4 Universal 8 1 20 Low Noise, Low Power, Wide Dynamic Range Filter yes DIP-24, SO-24
    LTC1164-5 1 Lowpass 8 1 20 Low Power, Pin Selectable Butterworth or Bessel Response yes DIP-14, SOW-16
    LTC1164-6 1 Lowpass 8 1 20 Low Power, Pin Selectable Elliptic or Bessel yes DIP-14, SOW-16
    LTC1164-7 1 Lowpass 8 1 20 Constant Group Delay, Low Power, Steeper Rolloff than Bessel yes DIP-14, SOW-16
    LTC1264 4 Universal 8 1 200 High Speed, 4 Identical Filters, Double-Sampling for Improved Aliasing yes DIP-24, SO-24
    LTC1264-7 1 Lowpass 8 1 200 Constant Group Delay, Max Cuttoff Frequency 200kHz yes DIP-14, SOW-16
    LTC1560-1 1 Lowpass 5 1000 Continuous-Time, Pin Selectable Cuttoff Freq:  500kHz or 1MHz no SO-8
    LTC1562 4 Universal 8 10 150 Continuous-Time, Four 2nd Order Filters, Center Freq Range:  10kHz to 150kHz no SSOP-20, DIP-16
    LTC1562-2 4 Universal 8 20 300 Continuous-Time, Four 2nd Order Filters, Center Freq Range:  20kHz to 300kHz no SSOP-20
    LTC1563 1 Lowpass 4 0.256 256 One Resistor Sets Cutoff Freq:  256Hz to 256kHz, Rail-to-Rail In/Out no SSOP-16
    LTC1564 1 Lowpass 8 10 150 Digitally Prog. Filter & 4-bit PGA no SSOP-16
    LTC1565-31 1 Lowpass 7 650 Continuous-Time, Differential Inputs and Outputs no SO-8
    LTC1566-1 1 Lowpass 7 2300 Continuous Time, Differential Input and Outputs, Low Noise no SO-8
    LTC1569-6 1 Lowpass 10 1 64 Internal or External Clock, Cutoff Freq: Up to 64kHz with 3V Supply , Root Raised Cosine yes SO-8
    LTC1569-7 1 Lowpass 10 1 300 Internal or External Clock, Cuttoff Freq: Up to 300kHz, Root Raised Cosine yes SO-8
    LTC6601-1 1 Lowpass 2 5000 28000 Low Noise, 0.5% Tolerance, 5MHz to 28MHz, Pin Configurable Filter/ADC Driver no QFN-20
    LTC6601-2 1 Lowpass 5000 Low Power, Low Distortion, 5MHz to 27MHz, Pin Configurable Filter/ADC Driver no QFN-20
    LTC6602 2 Lowpass 5 4 900 Dual Matched, High Frequency Bandpass/Lowpass Filters no QFN-16
    LTC6603 1 Lowpass 9 20 Dual Adjustable Lowpass Filter no QFN-24
    LTC6605-10 2 Lowpass 2 10000 Dual Matched 10MHz Filter with Low Noise, Low Distortion Differential Amplifier no DFN-22
    LTC6605-14 2 Lowpass 2 1400 Dual Matched 14MHz Filter with Low Noise, Low Distortion Differential Amplifier no DFN-22
    LTC6605-7 2 Lowpass 2 70000 Dual Matched 7MHz Filter
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
