龙人旗下深圳市龙芯世纪科技有限公司
  • 离线控制器
  • 发布时间:2013/9/9 10:33:57   修改时间:2013/9/9 10:33:57 浏览次数:1878
  • 离线控制器
    电流模式和电压模式控制器
    安森美半导体提供的控制器和稳压器涵盖多种先进拓扑结构,帮助客户开发高能效电源。
    离线控制器Excel 文档格式选型指南
    Product Description Package Type
    NCL30080 Quasi-Resonant Primary Side Current-Mode Controller for LED Lighting TSOP-6
    NCL30081 Step Dimmable Quasi-Resonant Primary Side Current-Mode Controller for LED Lighting TSOP-6
    NCL30082 Dimmable Quasi-Resonant Primary Side Current  Mode Controller for LED Lighting with thermal foldback Micro8?-8
    NCL30083 Step Dimmable Quasi-Resonant Primary Side Current-Mode Controller for LED Lighting with thermal foldback Micro8?-8
    NCP1244 Fixed Frequency Current Mode Controller for Flyback Converters SOIC-8
    NCP1247 Fixed Frequency Current Mode Controller for Flyback Converters SOIC-8
    NCP1255 Current-Mode PWM Controller for Off-line Power Supplies featuring Peak Power Excursion SOIC-8
    NCP1398 High Performance Resonant Mode Controller with integrated high-voltage drivers SOIC-16
    NCP1937 COMBO PFC & QR FLYBACK CONTROLLER SOIC-20, Less Pins 2, 4, & 19
    NCP1254 Current-Mode PWM Controller TSOP-6
    CS51221 Enhanced Voltage Mode PWM Controller for Forward or Flyback SOIC-16
    CS5124 Integrated Current Mode PWM Controller for Forward or Flyback (36 - 75 V Telecom Supply) SOIC-8
    MC33025 Up-to-1 MHz Dual Output (Push-pull or H-Bridge) Voltage-or-Current-Mode PWM Controller PDIP-16
    SOIC-16W
    MC33060A Fixed Frequency,  Single Ended, Voltage Mode PWM Controller SOIC-14
    MC33067 High Performance Resonant Mode Controller PDIP-16
    SOIC-16W
    MC33364 Critical Conduction Mode SMPS Controller SOIC-16
    SOIC-8
    MC34060A Fixed Frequency,  Single Ended, Voltage Mode PWM Controller SOIC-14
    NCL30000 Power Factor Corrected TRIAC Dimmable LED Driver SOIC-8
    NCL30001 High Efficiency Single Stage Power Factor Corrected LED Driver SOIC-16
    NCL30002 Power Factor Corrected Offline Buck LED Driver SOIC-8
    NCL30051 PFC and Resonant Half Bridge Combo Controller for LED Lighting SOIC-16
    NCP1200 Fixed Frequency Flyback Current Mode PWM Controller PDIP-8
    SOIC-8
    NCP1203 Fixed Frequency Flyback Current Mode PWM Controller PDIP-8
    SOIC-8
    NCP1207A Current Mode PWM Controller for Free Running Quasi-Resonant Operation  PDIP-8
    SOIC-8
    NCP1207B Current Mode PWM Controller for Free Running Quasi-Resonant Operation  SOIC-8
    NCP1216 Fixed Frequency Current Mode PWM Controller PDIP-8
    SOIC-8
    NCP1216A Fixed Frequency Current Mode PWM Controller with Duty Cycle  Limited to 50% PDIP-8
    SOIC-8
    NCP1217 Fixed Frequency Current Mode PWM Controller PDIP-8
    SOIC-8
    NCP1217A Fixed Frequency Current Mode PWM Controller with Duty Cycle  Limited to 50% PDIP-8
    SOIC-8
    NCP1218 PWM Controller Featuring Dynamic Self Supply SOIC-8
    NCP1219 PWM Controller Featuring Dynamic Self Supply SOIC-8
    NCP1230 Fixed Frequency Current Mode PWM Controller PDIP-8
    SOIC-8
    NCP1234 Fixed Frequency Current Mode Controller for Flyback Converters SOIC-8
    NCP1236 Fixed Frequency PWM Controller for Flyback Converters SOIC-8
    NCP1237 Fixed Frequency Current Mode PWM Controller SOIC-8
    NCP1238 Fixed Frequency Current Mode PWM Controller SOIC-8
    NCP1246 Fixed Frequency Current Mode Controller for Flyback Converters SOIC-8
    NCP1250 PWM Current-Mode Controller for Off-line Power Supplies TSOP-6
    NCP1251 Current-Mode PWM Controller for Off-line Power Supplies TSOP-6
    NCP1252 Current Mode PWM Controller for Forward and Flyback Applications PDIP-8
    SOIC-8
    NCP1253 Current-Mode PWM Controller for Off-line Power Supplies TSOP-6
    NCP1271 Soft-Skip Current Mode Standby PWM Controller with Adjustable Skip Level and External Latch PDIP-8
    SOIC-8
    NCP1288 Fixed Frequency Current Mode PWM Controller SOIC-8
    NCP1294 PWM Controller for Flyback or Forward Converters TSSOP-16
    NCP1308 Current Mode Controller for Free Running Quasi-Resonant Operation  SOIC-8
    NCP1336 Quasi-Resonant Current Mode Controller w/ HV Start-up SOIC-14 NB, Less Pin 13
    NCP1337 Quasi-Resonant Current Mode Controller Featuring Overpower Compensation PDIP-8
    SOIC-8
    NCP1338 PWM Current Mode Controller for Free Running Quasi Resonant Operation  SOIC-8
    NCP1351 Variable Off-Time Current Mode Controller Featuring Short Circuit Protection SOIC-8
    NCP1377 Current-Mode Controller for Free Running Quasi-Resonant Operation  PDIP-8
    SOIC-8
    NCP1379 Quasi-Resonant Current Mode Controller SOIC-8
    NCP1380 Quasi-Resonant Current Mode Controller SOIC-8
    NCP1392 High Voltage Half-Bridge MOSFET Driver with Inbuilt Oscillator Featuring Brown-out  and Autorecovery Enable Input SOIC-8
    NCP1395 High Performance Resonant Mode Controller SOIC-16
    NCP1396 High Performance Resonant Mode Controller with High and Low Side Drivers SOIC-16
    NCP1397 High Performance Resonant Mode Controller with Integrated High Voltage Drivers SOIC-16
    NCP1562 High Performance Active Clamp/Reset PWM Controller SOIC-16
    TSSOP-16
    NCP1910 High Performance Combo Controller for ATX Power Supplies SOIC-24
    NCP1927 Combination Power Factor Correction Controller and Flyback Controller for Flat Panel TVs SOIC-16
    NCV3843B Current Mode PWM Controller SOIC-14
    SOIC-8
    UC2842B High Performance Current Mode PWM Controller PDIP-8
    SOIC-14
    SOIC-8
    UC2843B High Performance Current Mode PWM Controller PDIP-8
    SOIC-14
    SOIC-8
    UC2844B High Performance Current Mode PWM Controller PDIP-8
    SOIC-14
    SOIC-8
    UC2845B High Performance Current Mode PWM Controller PDIP-8
    SOIC-14
    SOIC-8
    UC3842B High Performance Current Mode PWM Controller PDIP-8
    SOIC-14
    SOIC-8
    UC3843B High Performance Current Mode PWM Controller PDIP-8
    SOIC-14
    SOIC-8
    UC3844B High Performance Current Mode PWM Controller PDIP-8
    SOIC-14
    SOIC-8
    UC3845B High Performance Current Mode PWM Controller PDIP-8
    SOIC-14
    SOIC-8
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
