龙人旗下深圳市龙芯世纪科技有限公司
  • DC-DC电压模式控制器
  • 发布时间:2013/9/9 10:36:52   修改时间:2013/9/9 10:36:52 浏览次数:1413
  • DC-DC电压模式控制器安森美半导体提供电流模式和电压模式DC-DC控制器,用于DC-DC电源转换电路。
    直流-直流(DC-DC)控制器Excel 文档格式选型指南
    Product Description Package Type
    LV5771QA Step-down Voltage Switching Regulator
    NCL30161 Constant-Current Buck Regulator for Driving High Power LEDs DFN-10
    NCV8851-1 Automotive Average Current Mode Controller TSSOP-20
    NCP81044 Low Voltage Synchronous Buck Controller SOIC-8
    NCP81045 Single Synchronous Step Down Controller QFN-16
    NCP81046 Single Phase Buck Controller DFN-10
    ADP3193A Synchronous Buck Controller for Intel VRD/VRM LFCSP-32
    ADP3198 Synchronous Buck Controller LFCSP-40
    ADP3208D 7-Bit, Programmable, Dual-Phase, Mobile, CPU, Synchronous Buck Controller LFCSP-48
    ADP3210 IMVP6.5, 7-Bit Programmable, Multiphase Mobile, CPU Synchronous Buck Controller QFN-40
    ADP3211 IMVP6.5, 7-Bit, Programmable, Single-Phase, Synchronous Buck Controller QFN-32
    ADP3212 7-Bit, Programmable, Dual-Phase, Mobile, CPU, Synchronous Buck Controller QFN-48
    ADP3290 VR11.1 4-Phase Synchronous Buck Controller LFCSP-40
    ADP3293 VR11.1  8-Bit, Programmable 2- to 3-Phase Synchronous Buck Controller LFCSP-40
    ADP4000 6-Phase VR11.1 Controller with Serial Interface LFCSP-48
    ADP4100 6-Phase VR11.1 Controller  LFCSP-48
    CS51021A Enhanced Current Mode PWM Controller for Forward or Flyback (36-72 V Telecom) SOIC-16
    CS51022A Enhanced Current Mode PWM Controller for Forward or Flyback (36-72 V Telecom) SOIC-16
    TSSOP-16
    CS51031 Hysteretic PFET Buck Controller SOIC-8
    CS5124 Integrated Current Mode PWM Controller for Forward or Flyback (36 - 75 V Telecom Supply) SOIC-8
    LV5044V Step-Down DC-DC Converter Controller, 2-Channel SSOP-30
    LV5050NV DC-DC Converter Controller SSOP-20
    LV5052V Step-Down DC-DC Converter Controller, 2-Channel SSOP-30
    LV5061V Step-Down Switching Controller, 1-Channel SSOP-16
    LV5068V Non-Synchronous Rectification Step-Down Switching Regulator, 1-Channel SSOP-16
    LV5069JA Step-down Switching Regulator Controller SSOP-16
    LV5725JA Step-Down DC-DC Converter, 1-Channel SSOP-16
    LV5744V Step-Down Switching Regulator, 2-Channel SSOP-16
    LV5749NV Step-Down Switching Regulator, 1-Channel SSOP-16
    LV5761V Step-Down Switching Regulator, 1-Channel SSOP-16
    LV5762LF Step-Down Switching Regulator QFN16 3x3, 0.5P / VQFN16
    NCL30100 Fixed Off-Time Buck LED Driver Controller TSOP-6
    NCP1034 100 V Synchronous Buck Controller SOIC-16
    NCP1080 Integrated 13 W PoE-PD & DC-DC Converter Controller (IEEE 802.3af) TSSOP-20
    NCP1081 Integrated 40 W High Power PoE-PD & DC-DC Converter Controller (IEEE 802.3at) TSSOP-20
    NCP1082 Integrated 13 W PoE-PD & DC-DC Converter Controller with Auxiliary Supply Support (IEEE 802.3af) TSSOP-20
    NCP1083 Integrated 40 W High Power PoE-PD & DC-DC Converter Controller with Auxiliary Supply Support (IEEE 802.3at) TSSOP-20
    NCP1090 Integrated IEEE 802.3af PoE-PD Interface Controller SOIC-8
    TSSOP-8
    NCP1091 Integrated IEEE 802.3af PoE-PD Interface Controller w/ Programmable UVLO SOIC-8
    TSSOP-8
    NCP1092 Integrated IEEE 802.3af PoE-PD Interface Controller w/ Vaux Support SOIC-8
    TSSOP-8
    NCP1093 IEEE802.3at PoE-PD Interface Controller DFN-10
    NCP1094 IEEE802.3at PoE-PD Interface Controller DFN-10
    NCP1294 PWM Controller for Flyback or Forward Converters TSSOP-16
    NCP1579 Low Voltage Synchronous Buck Controller SOIC-8
    NCP1581 Full Featured Single Phase Synchronous Buck Controller SOIC-14
    NCP1587 Buck Controller SOIC-8
    NCP1587A Buck Controller SOIC-8
    NCP1589A Single Phase Buck Controller DFN-10
    NCP1589D Snychronous Buck Controller DFN-10
    NCP1589L Low Voltage Sync Buck Controller DFN-10
    NCP3011 Synchronous Buck Controller TSSOP-14
    NCP3012 Synchronous PWM Controller TSSOP-14
    NCP3020 Synchronous Buck Controller SOIC-8
    NCP3030 28 V, >1.0 MHz PWM Controller SOIC-8
    NCP4200 Programmable Multi-Phase Synchronous Buck Converter with I2C Interface QFN-40
    NCP4208 VR11.1 Programmable 8-Phase Synchronous Buck Converter with I2C Interface QFN-48
    NCP5212 Single Synchronous Step Down Controller QFN-16
    NCP5212T Single Synchronous Step Down Controller QFN-16
    NCP5217 Single Sync-Rect Step down controller QFN-14
    NCP5222 Dual-Channel / Two-Phase Synchronous Buck Controller QFN-28
    NCP5228 Notebook DDR Controller  QFN-28
    NCP5230 Low Voltage Synchronous Buck Controller  QFN-16
    NCP5269 System Agent Controller with 2-bit VID QFN-20
    NCP5378 1-Phase Synchronous Buck Controller QFN-32
    NCP5380 Single-Phase Synchronous Buck Controller with Integrated Driver QFN-32
    NCP5386 1/2 Phase Controller QFN-32
    NCP5392 2/3/4-Phase VR11.1 Buck Controller QFN-40
    NCP5392P 2/3/4-Phase VR11.1 Buck Controller QFN-40
    NCP5392Q 2/3/4-Phase VR11.1 Buck Controller QFN-40
    NCP5392T 2/3/4-Phase VR11.1 Buck Controller QFN-40
    NCP5393B 2/3/4 Phase Controller for CPU Applications  QFN-48
    NCP5395 2/3/4-Phase Controller with Gate Drivers QFN-48
    NCP5395T 2/3/4-Phase Controller with Gate Drivers QFN-48
    NCP5422A Dual Out-of-Phase Synchronous Buck Controller SOIC-16
    NCP5425 Dual Synchronous Buck Controller TSSOP-20
    NCP6131 IMVP7 1-, 2-, 3-Phase CPU Controller + 1-Phase GPU Controller QFN-52
    NCP6132 IMVP7 1-, 2-, 3-Phase CPU Controller with 2 Integrated Drivers + 1-, 2-Phase GPU Controller with 1 Integrated Driver  QFN-60
    NCP6151 VR12 2-, 3-, 4-Phase CPU Controller + 1-Phase GPU Controller  QFN-52
    NCP6251 2/3/4-Phase Controller QFN-48
    NCV494 PWM Controller (Automotive) SOIC-16
    NCV8852 Automotive Grade Non-Synchronous Buck Controller SOIC-8
    NCV8853 Automotive Grade Non-Synchronous Buck Controller SOIC-8
    NCV8870 Automotive Grade Non-Synchronous Boost Controller SOIC-8
    NCV8871 Automotive Grade Non-Synchronous Boost Controller SOIC-8
    NCV8873 Automotive Grade Non-Synchronous BoostController SOIC-8
    NCV898031 2 MHz Non-Synchronous SEPIC / Boost Controller SOIC-8
    SG3525A PWM Controller PDIP-16
    SOIC-16W
    TL494 PWM Controller (up to 200 kHz) SOIC-16
    TL594 PWM Controller SOIC-16
    TSSOP-16
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
