龙人旗下深圳市龙芯世纪科技有限公司
  • 线性稳压器
  • 发布时间:2013/9/9 10:37:58   修改时间:2013/9/9 10:37:58 浏览次数:1933
  • 线性稳压器
    线性稳压器 – 稳压器 安森美半导体提供低压降(LDO)线性稳压器。
    线性稳压器Excel 文档格式选型指南
    Product Description Package Type
    LV56841PVD Multi-Power Supply IC HZIP-15
    NCP51198 1.5A, DDR Memory Termination Regulator SOIC8-NB EP
    NCP51199 DDR 2Amp Source / Sink VTT Termination Regulator SOIC8-NB EP
    NCP57152 1.5 A Very Low Dropout Fast Transient Response Regulator  D2PAK-5
    DFN-8
    NCP700B 200 mA, Low Noise, Low Dropout Linear Voltage Regulator TSOP-5 / SOT-23-5
    WDFN-6
    NCP703 300 mA, Ultra-Low Quiescent Current, Ultra-Low Noise, Low Dropout Regulator  TSOP-5 / SOT-23-5
    XDFN-6
    NCP707 200mA Very Low Noise, Low Dropout Linear Voltage Regulator XDFN-4
    NCP752 200mA, Ultra-Low Quiescent Current, Ultra-Low Noise, Low Dropout Regulator with Power-Good Flag TSOP-5 / SOT-23-5
    XDFN-6
    NCV4269A 150 mA LDO Linear Voltage Regulator with Reset, Delay, Adjustable Reset and Early Warning SOIC-14
    SOIC-20W
    SOIC-8
    SOIC-8 EP
    NCV47700 5 V to 20 V Adjustable Low Dropout Regulator with Adjustable Current Limit SOIC-8
    SOIC-8 EP
    NCV47701 5 V to 20 V Adjustable Low Dropout Regulator with Adjustable Current Limit SOIC-8
    SOIC-8 EP
    NCV47710 5 V to 20 V Adjustable LDO with Adjustable Current Limit and 3.3 V Logic Compatible Enable Input SOIC-8
    SOIC-8 EP
    NCV47711 5 V to 20 V Adjustable LDO with Adjustable Current Limit and 3.3 V Logic Compatible Enable Input SOIC-8
    SOIC-8 EP
    NCV7462 System Basis Chip with LIN, CAN, Two LDO, and HS/LS Drivers SSOP-36 EP
    NCV8770 5.0 V, 350 mA Low IQ LDO Linear Voltage Regulator with Reset D2PAK-5
    DPAK-5
    NCV8774 350 mA Low IQ LDO Linear Voltage Regulator DPAK-3
    NCP51190 1.5A DDR Memory Termination Regulator DFN-8
    NCP705 500 mA, Ultra-Low Iq, Ultra-Low Noise LDO Voltage Reulator SOT-223 6-Lead
    WDFN-6
    CAT6201 300 mA / 13 V Adjustable CMOS LDO Regulator TDFN-8
    CAT6202 500 mA / 13 V Adjustable CMOS LDO Regulator TDFN-8
    CAT6217 150 mA LDO Regulator TSOT-23-5
    CAT6218 300 mA LDO Regulator TSOT-23-5
    CAT6219 500 mA LDO Regulator TDFN-6
    TSOT-23-5
    WDFN-6
    CAT6220 300 mA Low Dropout Linear Regulator TDFN-6
    TSOT-23-5
    CAT6221 300 mA Dual LDO Regulator TSOT-23-6
    CAT6243 1.0 A Adjustable Output CMOS Linear Voltage Regulator TDFN-8
    WDFN-6
    CS8101 100 mA LDO Linear Voltage Regulator with Reset and Enable SOIC-20W
    SOIC-8
    CS8126 750 mA LDO Linear Voltage Regulator with Delay and Reset D2PAK-7
    CS8182 200 mA LDO Linear Voltage Tracking Regulator with Enable D2PAK-5
    DPAK-5
    SOIC-8
    CS8183 200 mA LDO Linear Voltage Tracking Regulator with Enable SOIC-20W
    CS8361 100 mA and Tracking 250 mA Dual LDO Linear Voltage Regulator with Reset and Enable D2PAK-7
    SOIC-16W
    CS8363 100 mA and Tracking 250 mA Dual LDO Linear Voltage Regulator with Enable and Reset D2PAK-7
    LA59700MC Linear Voltage Regulator, Adjustable Output SOIC-8 N EP / SOP-8L
    LM2931 100 mA Low Dropout Linear Voltage Regulator with 60 V Load Dump Protection D2PAK-3
    D2PAK-5
    DPAK-3
    SOIC-8
    TO-220-3
    TO-220-5
    TO-92
    LM317 1.5 A Adjustable Output, Positive Linear Voltage Regulator D2PAK-3
    TO-220-3
    LM317L 100 mA Adjustable Output, Positive Linear Voltage Regulator SOIC-8
    TO-92
    LM317M 500 mA Adjustable Output, Positive Linear Voltage Regulator DPAK-3
    SOT-223-4 / TO-261-4
    TO-220-3
    LM337 1.5 A Adjustable Output, Negative Linear Voltage Regulator D2PAK-3
    TO-220-3
    LP2950 100 mA Low Power Low Dropout Linear Voltage Regulator DPAK-3
    TO-92
    LP2951 100 mA Fixed or Adjustable, Low Power Low Dropout Linear Voltage Regulator with Error Flag Output Micro8?-8
    PDIP-8
    SOIC-8
    LV56801P Multi-Power Supply System for Car Audio Systems HZIP-15J
    LV5680NPVC 4-Channel Linear Voltage Regulator with 4 High-Side Switches for Automotive Infotainment HZIP-15J
    LV5680P 4-Channel Linear Voltage Regulator with 4 High-Side Switches for Automotive Infotainment HZIP-15J
    LV5681P Multi-Power Supply System IC for Car Audio Systems HZIP-15J
    LV56831P Multi-Power Supply for Car Audio Systems HZIP-15
    LV5683P Multi-Power Supply for Car Audio Systems HSOP-28H
    LV5684PVC 5-Channel Linear Voltage Regulator with 2 High-Side Switches for Automotive Infotainment  HZIP-15J
    LV5684PVD 5-Channel Linear Voltage Regulator with 2 High-Side Switches for Automotive Infotainment  HZIP-15
    LV5686PVC 3-Channel Linear Voltage Regulator with 6 High-Side Switches for Automotive Infotainment HZIP-15
    LV5692P Multi-Power Supply System for Car Audio Systems HZIP-15J
    LV5693P Multi-Power Supply System for Car Audio Systems HZIP-15J
    LV5694P Multi-Power Supply System for Car Audio Systems HZIP-15J
    LV5695P Multi-Power Supply for Car Audio Systems HZIP-15J
    LV5696P Multi-Power Supply System for Car Audio Systems HZIP-15J
    MC33269 800 mA Low Dropout Linear Voltage Regulator DPAK-3
    SOIC-8
    TO-220-3
    MC33275 300 mA Low Dropout Linear Voltage Regulator DFN-8
    DPAK-3
    SOIC-8
    MC33375 300 mA Low Dropout Linear Voltage Regulator with On/Off Control SOIC-8
    MC33761 Low Noise, Low Dropout Linear Voltage Regulator with 1.0 V ON/OFF Control TSOP-5 / SOT-23-5
    MC33762 Dual Low Noise, Low Dropout Linear Voltage Regulator with 1.0 V ON/OFF Control Micro8?-8
    MC34268 2.85 V, 800 mA SCSI-2 Active Terminator, Low Dropout Linear Voltage Regulator SOIC-8
    MC7805 5.0 V, 1.0 A Positive Linear Voltage Regulator D2PAK-3
    DPAK-3
    TO-220-3
    MC7806 6.0 V, 1.0 A Positive Linear Voltage Regulator D2PAK-3
    TO-220-3
    MC7806A 6.0 V, 1.0 A Positive Linear Voltage Regulator TO-220-3
    MC7808 8.0 V, 1.0 A Positive Linear Voltage Regulator D2PAK-3
    DPAK-3
    TO-220-3
    MC7808A 8.0 V, 1.0 A Positive Linear Voltage Regulator D2PAK-3
    TO-220-3
    MC7809 9.0 V, 1.0 A Positive Linear Voltage Regulator D2PAK-3
    TO-220-3
    MC7809A 9.0 V, 1.0 A Positive Linear Voltage Regulator TO-220-3
    MC7812 12.0 V, 1.0 A Positive Linear Voltage Regulator D2PAK-3
    DPAK-3
    TO-220-3
    MC7812A 12.0 V, 1.0 A Positive Linear Voltage Regulator D2PAK-3
    TO-220-3
    MC7815 15.0 V, 1.0 A Positive Linear Voltage Regulator D2PAK-3
    DPAK-3
    TO-220-3
    MC7815A 15.0 V, 1.0 A Positive Linear Voltage Regulator D2PAK-3
    TO-220-3
    MC7818 18.0 V, 1.0 A Positive Linear Voltage Regulator D2PAK-3
    TO-220-3
    MC7818A 18.0 V, 1.0 A Positive Linear Voltage Regulator TO-220-3
    MC7824 24.0 V, 1.0 A Positive Linear Voltage Regulator D2PAK-3
    TO-220-3
    MC7824A 24.0 V, 1.0 A Positive Linear Voltage Regulator TO-220-3
    MC78FC30 Micropower Ultra-Low Quiescent Current Linear Voltage Regulator SOT-89-3
    MC78FC33 Micropower Ultra-Low Quiescent Current Linear Voltage Regulator SOT-89-3
    MC78FC40 Micropower Ultra-Low Quiescent Current Linear Voltage Regulator SOT-89-3
    MC78FC50 Micropower Ultra-Low Quiescent Current Linear Voltage Regulator SOT-89-3
    MC78L05A 5.0 V, 100 mA Positive Linear Voltage Regulator SOIC-8
    TO-92
    MC78L08A 8.0 V, 100 mA Positive Linear Voltage Regulator SOIC-8
    TO-92
    MC78L09A 9.0 V, 100 mA Positive Linear Voltage Regulator SOIC-8
    TO-92
    MC78L12A 12 V, 100 mA Positive Linear Voltage Regulator SOIC-8
    TO-92
    MC78L15A 15 V, 100 mA Positive Linear Voltage Regulator SOIC-8
    TO-92
    MC78L18A 18 V, 100 mA Positive Linear Voltage Regulator TO-92
    MC78L24A 24 V, 100 mA Positive Linear Voltage Regulator TO-92
    MC78LC MicroPower Low Dropout Linear Voltage Regulator SOT-89-3
    TSOP-5 / SOT-23-5
    MC78M05 5.0 V, 500 mA Positive Linear Voltage Regulator DPAK-3
    TO-220-3
    MC78M05A 5.0 V, 500 mA Positive Linear Voltage Regulator DPAK-3
    TO-220-3
    MC78M06 6.0 V, 500 mA Positive Linear Voltage Regulator DPAK-3
    TO-220-3
    MC78M08 8.0 V, 500 mA Positive Linear Voltage Regulator DPAK-3
    TO-220-3
    MC78M09 9.0 V, 500 mA Positive Linear Voltage Regulator DPAK-3
    TO-220-3
    MC78M12 12 V, 500 mA Positive Linear Voltage Regulator DPAK-3
    TO-220-3
    MC78M12A 12 V, 500 mA Positive Linear Voltage Regulator DPAK-3
    TO-220-3
    MC78M15 15 V, 500 mA Positive Linear Voltage Regulator DPAK-3
    TO-220-3
    MC78M15A 15 V, 500 mA Positive Linear Voltage Regulator DPAK-3
    TO-220-3
    MC78M18 18 V, 500 mA Positive Linear Voltage Regulator DPAK-3
    TO-220-3
    MC78M20 20 V, 500 mA Positive Linear Voltage Regulator TO-220-3
    MC78M24 24 V, 500 mA Positive Linear Voltage Regulator TO-220-3
    MC78PC18 150 mA Low Noise, Low Dropout Linear Voltage Regulator SOT-23-5
    MC78PC25 150 mA Low Noise, Low Dropout Linear Voltage Regulator SOT-23-5
    MC78PC28 150 mA Low Noise, Low Dropout Linear Voltage Regulator SOT-23-5
    MC78PC30 150 mA Low Noise, Low Dropout Linear Voltage Regulator SOT-23-5
    MC78PC33 150 mA Low Noise, Low Dropout Linear Voltage Regulator SOT-23-5
    MC78PC50 150 mA Low Noise, Low Dropout Linear Voltage Regulator SOT-23-5
    MC7905 5.0 V, 1.0 A Negative Linear Voltage Regulator D2PAK-3
    TO-220-3
    MC7905.2 5.2 V, 1.0 A Negative Linear Voltage Regulator TO-220-3
    MC7905A 5.0 V, 1.0 A Negative Linear Voltage Regulator D2PAK-3
    TO-220-3
    MC7906 6.0 V, 1.0 A Negative Linear Voltage Regulator D2PAK-3
    TO-220-3
    MC7908 8.0 V, 1.0 A Negative Linear Voltage Regulator D2PAK-3
    TO-220-3
    MC7908A 8.0 V, 1.0 A Negative Linear Voltage Regulator TO-220-3
    MC7912 12 V, 1.0 A Negative Linear Voltage Regulator D2PAK-3
    TO-220-3
    MC7915 15 V, 1.0 A Negative Linear Voltage Regulator D2PAK-3
    TO-220-3
    MC7918 18 V, 1.0 A Negative Linear Voltage Regulator TO-220-3
    MC7924 24 V, 1.0 A Negative Linear Voltage Regulator D2PAK-3
    TO-220-3
    MC79L05 5.0 V, 100 mA Negative Linear Voltage Regulator SOIC-8
    TO-92
    MC79L12 12 V, 100 mA Negative Linear Voltage Regulator SOIC-8
    TO-92
    MC79L15 15 V, 100 mA Negative Linear Voltage Regulator SOIC-8
    TO-92
    MC79L18 18 V, 100 mA Negative Linear Voltage Regulator TO-92
    MC79L24 24 V, 100 mA Negative Linear Voltage Regulator TO-92
    MC79M05 5.0 V, 500 mA Negative Linear Voltage Regulator DPAK-3
    TO-220-3
    MC79M08 8.0 V, 500 mA Negative Linear Voltage Regulator DPAK-3
    TO-220-3
    MC79M12 12 V, 500 mA Negative Linear Voltage Regulator DPAK-3
    TO-220-3
    MC79M15 15 V, 500 mA Negative Linear Voltage Regulator DPAK-3
    TO-220-3
    NCP102 LDO Linear Regulator Controller TSOP-6
    NCP1117 1.0 A Positive Low Dropout Linear Voltage Regulator (Fixed and Adjustable) DPAK-3
    NCP1117LP 1.0 A Positive Low Dropout Linear Voltage Regulator (Fixed and Adjustable) SOT-223-4 / TO-261-4
    NCP2860 300 mA Low Noise, Low Dropout Linear Voltage Regulator Micro8?-8
    NCP3334 500 mA Low Quiescent Current Low Dropout Linear Voltage Regulator (Adjustable Output) SOIC-8
    NCP3335A 500 mA Low Quiescent Current Low Dropout Linear Voltage Regulator (Adjustable and Fixed Outputs) DFN-10
    Micro8?-8
    NCP3337 500 mA LDO with Power Good DFN-10
    NCP4586 150 mA low noise LDO Linear Voltage Regulator SC-82AB-4
    SOT-23-5
    UDFN-4
    NCP4587 150 mA LDO Linear Voltage Regulator with Auto Low Power mode SOT-23-5
    XDFN-6
    NCP4588 200 mA CMOS NO CAP LDO Linear Voltage Regulator SC-88A-5 / SC-70-5 / SOT-323-5
    XDFN-6
    NCP4589 300 mA LDO Linear Voltage Regulator with Auto Low Power mode SC-88A-5 / SC-70-5 / SOT-323-5
    SOT-23-5
    XDFN-6
    NCP4620 150 mA Low Dropout, Wide Voltage Input Linear Voltage Regulator SC-88A-5 / SC-70-5 / SOT-323-5
    SOT-23-5
    NCP4623 150 mA Wide Input Voltage Range Low Dropout Voltage Regulator SOT-23-5
    XDFN-6
    NCP4624 150 mA, Wide Input Range, LDO Linear Voltage Regulator SC-88A-5 / SC-70-5 / SOT-323-5
    SOT-23-5
    UDFN-4
    NCP4625 300 mA, 10 V input, Low Dropout Linear Voltage Regulator SOT-23-5
    NCP4626 300 mA Reverse Current Protected Low Drop Out  Linear Voltage Regulator with Low Power mode SOT-23-5
    XDFN-6
    NCP4629 500 mA, Wide Input Voltage range, Low Dropout Linear Voltage Regulator DPAK-5
    NCP4632 3 A Low Input Voltage LDO DPAK-5
    NCP4640 50 mA, High Voltage Input Linear Voltage Regulator SOT-89-5
    NCP4641 150 mA, Wide Input Range, Low Dropout Linear Voltage regulator SOT-89-5
    NCP4671 400 mA Low Voltage, Dual Rail, Ultra Low Dropout Linear Voltage Regulator SOT-23-5
    XDFN-6
    NCP4672 Dual Low Dropout Linear Voltage Regulator with Vin and Vout Voltage Detector SOIC-8
    NCP4680 150 mA Small Outline LDO Linear Voltage Regulator SC-88A-5 / SC-70-5 / SOT-323-5
    XDFN-4
    NCP4681 150 mA Ultra Low Supply Current LDO Linear Voltage Regulator SC-88A-5 / SC-70-5 / SOT-323-5
    XDFN-4
    NCP4682 150 mA, Ultra Low Supply Current, Low Dropout Linear Voltage Regulator SC-82AB-4
    SOT-23-5
    UDFN-4
    NCP4683 300 mA, Low Dropout Regulator SC-88A-5 / SC-70-5 / SOT-323-5
    UDFN-4
    NCP4684 150 mA Ultra Low Supply Current LDO Voltage Regulator XDFN-4
    NCP4686 400 mA, Low Voltage, Low Dropout Linear Voltage Regulator SOT-23-5
    NCP4687 500 mA, High PSRR, LDO Linear Voltage Regulator SOT-23-5
    SOT-89-5
    NCP4688 150 mA, Low Noise, LDO Linear Voltage Regulator SOT-23-5
    UDFN-4
    NCP500 150 mA CMOS Low Noise Low Dropout Linear Voltage Regulator DFN-6
    TSOP-5 / SOT-23-5
    NCP502 80 mA CMOS Low Quiescent Current Low Dropout Linear Voltage Regulator SC-88A-5 / SC-70-5 / SOT-323-5
    TSOP-5 / SOT-23-5
    NCP508 50 mA Low Noise, Fast Turn On, Low Dropout Linear Voltage Regulator SC-88A-5 / SC-70-5 / SOT-323-5
    WDFN-6
    NCP511 150 mA CMOS Low Quiescent Current Low Dropout Linear Voltage Regulator TSOP-5 / SOT-23-5
    NCP512 80 mA CMOS Low Quiescent Current Low Dropout Linear Voltage Regulator SC-88A-5 / SC-70-5 / SOT-323-5
    NCP51460 20 mA Micropower Precision Voltage Reference SOT-23-3
    NCP5500 500 mA Low Dropout Linear Voltage Regulator DPAK-5
    SOIC-8
    NCP5501 500 mA Low Dropout Linear Voltage Regulator DPAK-3
    NCP5504 Dual Output Low Dropout Linear Voltage Regulator DPAK-5
    NCP551 150 mA CMOS Low Quiescent Current Low Dropout Linear Voltage Regulator TSOP-5 / SOT-23-5
    NCP553 80 mA CMOS Low Quiescent Current NOCAP™ Low Dropout  Linear Voltage Regulator SC-82AB-4
    NCP562 80 mA CMOS Low Quiescent Current Low Dropout Linear Voltage Regulator SC-82AB-4
    NCP563 80 mA CMOS Low Quiescent Current Low Dropout Linear Voltage Regulator SC-82AB-4
    NCP565 1.5 A Low Voltage Fast Transient Response Low Dropout Linear Voltage Regulator D2PAK-3
    D2PAK-5
    DFN-6
    NCP566 1.5 A Low Voltage Fast Transient Response Low Dropout Linear Voltage Regulator SOT-223-4 / TO-261-4
    NCP5661 1.0 A Fast Response Low Dropout Linear Voltage Regulator with Enable DFN-6
    DPAK-5
    NCP5662 2.0 A Fast Response Low Dropout Linear Voltage Regulator with Enable D2PAK-5
    DFN-8
    NCP5663 3.0 A Fast Response Low Dropout Linear Voltage Regulator with Enable D2PAK-5
    NCP571 150 mA Low Current, Low Vout, Low Dropout Linear Voltage Regulator DFN-6
    TSOP-5 / SOT-23-5
    NCP57302 3 A, Very Low-Dropout (VLDO) Fast Transient Response Regulator series D2PAK-5
    NCP582 150 mA Low Noise, Low Dropout Linear Voltage Regulator with Enable SC-82AB-4
    SOT-563
    NCP583 150 mA Low Quiescent Current Low Dropout Linear Voltage Regulator with Enable SC-82AB-4
    SOT-563
    NCP58300 3.0A, Very Low-Dropout (VLDO) Fast Transient Response Regulator series D2PAK-5
    NCP584 200 mA Tri-Mode Low Quiescent Current Low Dropout Linear Voltage Regulator SOT-23-5
    NCP585 300 mA Tri-Mode Low Quiescent Current Low Dropout Linear Voltage Regulator SOT-23-5
    NCP59150 1.5 A Very Low Dropout Fast Transient Response Regulator series D2PAK-5
    DFN-8
    NCP59300 3.0A, Very Low-Dropout Fast Transient Response Regulator series D2PAK-5
    NCP59302 3.0A, Very Low-Dropout Fast Transient Response Regulator series D2PAK-5
    NCP600 High Performance, Low Power, Low Dropout Linear Voltage Regulator with Enable DFN-6
    TSOP-5 / SOT-23-5
    NCP603 300 mA High Performance CMOS Low Dropout Linear Voltage Regulator with Enable and Enhanced ESD Protection TSOP-5 / SOT-23-5
    NCP605 500 mA, Low Ground Current, CMOS Low Dropout Linear Voltage Regulator DFN-6
    NCP612 100 mA CMOS Low Quiescent Current Low Dropout Linear Voltage Regulator SC-88A-5 / SC-70-5 / SOT-323-5
    NCP623 150 mA Ultra Low Noise, Low Dropout Linear Voltage Regulator with ON/OFF Control DFN-6
    NCP630 3.0 A Fast Low Dropout Linear Voltage Regulator D2PAK-5
    NCP662 100 mA CMOS Low Quiescent Current Low Dropout Linear Voltage Regulator SC-82AB-4
    NCP663 100 mA CMOS Low Quiescent Current Low Dropout Linear Voltage Regulator SC-82AB-4
    NCP690 1.0 A Very Low Dropout CMOS Linear Voltage Regulator  DFN-6
    NCP691 1.0 A Very Low Dropout CMOS Linear Voltage Regulator with Enable DFN-6
    NCP692 1.0 A Very Low Dropout CMOS Linear Voltage Regulator with Enable DFN-6
    NCP6924 6 Channel PMIC with 2 DC-DC Converters and 4 LDOs WLCSP-30
    NCP693 1.0 A CMOS Low Dropout Linear Voltage Regulator UDFN-6
    NCP694 1.0 A Very Low Dropout Linear Voltage Regulator SON-6 / HSON-6
    SOT-89-5
    NCP698 150 mA CMOS Low Quiescent and Ground Current Low Dropout Linear Voltage Regulator SC-82AB-4
    NCP699 150 mA CMOS Low Quiescent Current Low Dropout Linear Voltage Regulator with Enable TSOP-5 / SOT-23-5
    NCP702 200 mA, Ultra-Low Quiescent Current, Ultra-Low Noise, Low Dropout Regulator  TSOP-5 / SOT-23-5
    XDFN-6
    NCP729 200 mA Low Noise LDO Linear Voltage Regulator CSP-4
    NCP7800 1 A, Positive Voltage Regulator TO-220-3
    NCV1117 1.0 A Positive Low Dropout Linear Voltage Regulator (Fixed and Adjustable) DPAK-3
    NCV2931 5.0 V, 100 mA Low Dropout Linear Voltage Regulator with 60 V Load Dump Protection D2PAK-3
    DPAK-3
    SOIC-8
    TO-92
    NCV2951 100 mA Low Power, Low Dropout Linear Voltage Regulator SOIC-8
    NCV317 1.5 A Positive Low Dropout Linear Voltage Regulator (Adjustable Output) D2PAK-3
    TO-220-3
    NCV33269 800 mA Low Dropout Linear Voltage Regulator DPAK-3
    SOIC-8
    NCV33275 300 mA Low Dropout Linear Voltage Regulator SOT-223-4 / TO-261-4
    NCV33375 300 mA, 1.8 V, ±1% Low Dropout Linear Voltage Regulator SOIC-8
    NCV4264 100mA LDO Linear Voltage Regulator SOIC-8
    NCV4264-2 100mA LDO Linear Voltage Regulator SOT-223-4 / TO-261-4
    NCV4266 150 mA, LDO Linear Voltage Regulator with Enable SOT-223-4 / TO-261-4
    NCV4274 400 mA LDO Linear Voltage Regulator D2PAK-3
    DPAK-3
    NCV4275A 450 mA LDO Linear Voltage Regulator with Reset and Delay D2PAK-5
    DPAK-5
    NCV4276B 400 mA LDO Linear Voltage Regulator with Enable D2PAK-5
    DPAK-5
    NCV4279A 150 mA LDO Linear Voltage Regulator with Reset, Delay, Adjustable Reset and Early Warning SOIC-14
    SOIC-8
    NCV4290 450 mA LDO Linear Voltage Regulator with Power Good D2PAK-5
    DPAK-5
    NCV4299 150 mA LDO Linear Voltage Regulator with Reset, Delay, Adjustable Reset, Early Warning and Enable SOIC-8
    NCV4299AD 150 mA LDO Linear Voltage Regulator with Reset, Delay, Adjustable Reset, Early Warning and Enable SOIC-14
    NCV4949A 100 mA LDO Linear Voltage Regulator with Reset, Delay Reset and Early Warning SOIC-20W
    SOIC-8
    SOIC-8 EP
    NCV5500 500 mA Low Dropout Linear Voltage Regulator DPAK-5
    SOIC-8
    NCV5501 500 mA Low Dropout Linear Voltage Regulator DPAK-3
    NCV5504 Dual Output Low Dropout Linear Voltage Regulator DPAK-5
    NCV551 150 mA CMOS Low Quiescent Current Low Dropout Linear Voltage Regulator TSOP-5 / SOT-23-5
    NCV553 80 mA CMOS Low Quiescent Current NOCAP™ Linear Voltage Regulator SC-82AB-4
    NCV565 1.5 A Fast Transient Response Low Dropout Linear Voltage Regulator D2PAK-3
    D2PAK-5
    NCV612 100 mA LDO Linear Voltage Regulator with Enable SC-88A-5 / SC-70-5 / SOT-323-5
    NCV662 100 mA CMOS Low Quiescent Current Low Dropout Linear Voltage Regulator with Enable SC-82AB-4
    NCV663 100 mA CMOS Low Quiescent Current Low Dropout Linear Voltage Regulator SC-82AB-4
    NCV7805 5.0 V, 1.0 A Positive Linear Voltage Regulator D2PAK-3
    DPAK-3
    TO-220-3
    NCV7808 8.0 V, 1.0 A Positive Linear Voltage Regulator D2PAK-3
    DPAK-3
    TO-220-3
    NCV7809 9.0 V, 1.0 A Positive Linear Voltage Regulator D2PAK-3
    NCV7812 1.0 A, 12 V, ±4% Tolerance Linear Voltage Regulator D2PAK-3
    TO-220-3
    NCV78L05A 5.0 V, 100 mA Positive Linear Voltage Regulator SOIC-8
    TO-92
    NCV78L08 8 V, 100 mA, ±5% Tolerance Positive Linear Voltage Regulator SOIC-8
    NCV78L12A 12 V, 100 mA Positive Linear Voltage Regulator SOIC-8
    TO-92
    NCV8141 500 mA Linear Voltage Regulator with Enable, Reset, Delay and Watchdog  D2PAK-7
    NCV8184 70 mA LDO Linear Voltage Tracking Regulator with Enable DPAK-5
    SOIC-8
    SOIC-8 EP
    NCV8501 150 mA LDO Linear Voltage Regulator with Reset, Enable, Delay and Early Warning SOIC-16W EP
    SOIC-8
    NCV8502 150 mA LDO Linear Voltage Regulator with Delay, Reset,  Adjustable Reset, and Early Warning SOIC-16W EP
    SOIC-8
    NCV8503 400 mA LDO Linear Voltage Regulator with Delay, Reset, Adjustable Reset, Enable and Early Warning SOIC-16W EP
    NCV8504 400 mA LDO Linear Voltage Regulator with Delay, Reset, Adjustable Reset, Early Warning SOIC-16W EP
    NCV8505 400 mA LDO Linear Voltage Regulator with Reset, Delay Reset, Enable D2PAK-7
    NCV8506 400 mA LDO Linear Voltage Regulator with Reset, Delay Reset D2PAK-7
    NCV8508 250 mA LDO Linear Voltage Regulator  with Watchdog, Wake Up, Reset and Delay Reset SOIC-8 EP
    NCV8508B 250 mA LDO Linear Voltage Regulator  with Watchdog, Wake Up, Reset and Delay Reset D2PAK-7
    SOIC-8 EP
    NCV8509 100 mA and 100 mA Dual LDO Linear Voltage Regulator with Reset, Delay, Sequenced Output and Slew Rate Control SOIC-16W EP
    NCV8518B 250 mA LDO Linear Voltage Regulator with Watchdog, Wake Up, Reset , Delay and Enable SOIC-16W EP
    SOIC-8 EP
    NCV8535 500 mA Low Quiescent Current Low Dropout Linear Voltage Regulator with Enable DFN-10
    NCV8537 500 mA LDO with Power Good DFN-10
    NCV8560 150 mA High Performance Low Dropout Linear Voltage Regulator with Enable DFN-6
    TSOP-5 / SOT-23-5
    NCV8570B 200 mA, Ultra-Low Noise, High PSRR, BiCMOS RF LDO Voltage Regulator DFN-6
    TSOP-5 / SOT-23-5
    NCV8603 300 mA CMOS Low Dropout Linear Voltage Regulator with Enable  TSOP-5 / SOT-23-5
    NCV8605 500 mA, Low IGND, CMOS LDO Regulator DFN-6
    NCV8614B 100 mA, 300 mA and 400 mA Triple LDO Linear Voltage Regulator with Reset and Delay DFN-20
    NCV8660B 150 mA LDO Linear Voltage Regulator with Reset and Delay DPAK-5
    SOIC-8
    NCV8664 150 mA LDO Linear Voltage Regulator DPAK-3
    SOIC-8
    NCV8665 150 mA LDO Linear Voltage Regulator with Reset and Delay  D2PAK-5
    SOIC-8
    NCV8667 150 mA LDO Linear Voltage Regulator with Enable, Reset, Delay and Early Warning SOIC-14
    SOIC-8
    NCV8668 150 mA LDO Linear Voltage Regulator with Window Watchdog, Enable and Reset SOIC-14
    SOIC-8
    SOIC-8 EP
    NCV8669 150 mA LDO Linear Voltage Regulator with Reset, Delay and Early Warning SOIC-14
    NCV8674 350 mA LDO Linear Voltage Regulator D2PAK-3
    NCV8675 350 mA LDO Linear Voltage Regulator with Reset and Delay D2PAK-5
    DPAK-5
    NCV8702 200 mA, Ultra-Low Quiescent Current, Ultra-Low Noise, LDO Linear Voltage Regulator TSOP-5 / SOT-23-5
    XDFN-6
    NCV8703 300 mA, Ultra-Low Quiescent Current, Ultra-Low Noise, Low Dropout Regulator  TSOP-5 / SOT-23-5
    XDFN-6
    NCV8768 Ultra Low Iq 150 mA LDO Linear Voltage Regulator with Window Watchdog, Enable and Reset SOIC-14
    NCV8769 Ultra Low Iq 150 mA LDO Linear Voltage Regulator with Reset and Early Warning SOIC-14
    NCV8772 350 mA LDO Linear Voltage Regulator with Enable, Delay and Reset D2PAK-5
    D2PAK-7
    DPAK-5
    NCV8881 Switcher with watchdog and reset SOIC-16W EP
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
