龙人旗下深圳市龙芯世纪科技有限公司
  • 电压监测器
  • 发布时间:2013/9/9 10:40:26   修改时间:2013/9/9 10:40:26 浏览次数:1589
  • 电压监测器
    复位监视器 – 复位控制器 – 电压检测器
    安森美半导体提供高压和低压检测器和电压监视器。
    电压监测器Excel 文档格式选型指南
    Product Description Package Type
    NCD9830 8-Bit, 8-Channel ADC with I2C serial interface TSSOP-16
    NCP303 Voltage Detector Series with Programmable Delay and Open Drain N-Channel Output TSOP-5 / SOT-23-5
    CAT130044 Voltage Supervisor with Watchdog Timer and Microwire Serial EEPROM SOIC-8
    CAT1232LP Supervisor, 5.0 V MSOP-8
    PDIP-8
    SOIC-8
    CAT1832 Supervisor, 3.3 V MSOP-8
    PDIP-8
    SOIC-8
    CAT705 Voltage Supervisor MSOP-8
    SOIC-8
    CAT706 Voltage Supervisor MSOP-8
    SOIC-8
    CAT803 Voltage Supervisor, Open drain, Act low SC-70-3
    SOT-23-3
    CAT808 Supervisor, Open drain, Act low TSOT-23-5
    CAT809 Supervisor, Push-pull, Act low SC-70-3
    SOT-23-3
    CAT810 Voltage Supervisor, Push-pull, Act high SC-70-3
    SOT-23-3
    CAT811 Voltage Supervisor, Act Low w/PB 4-pin SOT-123-4
    CAT812 Voltage Supervisor, Act Hi w/PB 4-pin SOT-123-4
    CAT813 Voltage Supervisor MSOP-8
    SOIC-8
    CAT823 Voltage Supervisor, Act low, MR and WD SC-88A-5 / SC-70-5
    TSOT-23-5
    CAT824 Voltage Supervisor, Act low, Act hi and WD SC-88A-5 / SC-70-5
    TSOT-23-5
    CAT825 Voltage Supervisor, Act low, Act hi and MR SC-88A-5 / SC-70-5
    TSOT-23-5
    CAT853 Voltage Supervisor, Open drain, Act low SOT-23-3
    CAT863 Voltage Supervisor, Open drain, Act low SOT-23-3
    CAT869 Voltage Supervisor, Push-pull, Act low SOT-23-3
    CAT871 Dual Input Reset Generator ULLGA-6
    CAT8710 High Efficiency Quad-Voltage Supervisor TSOT-23-6
    CAT872 Dual Input Reset Generator ULLGA-6
    CAT8801 200 nA Microprocessor Power Voltage Supervisor SC-70-3
    SOT-23-3
    CAT8836 NanoPower Supervisory Circuits TSOT-23-5
    CAT884 Quad Voltage Supervisor SOIC-8
    CAT885 Voltage Supervisor, 5 channel, MR MSOP-8
    CAX803 3-Pin Microprocessor Power Supply Supervisors SOT-23-3
    CAX809 3-Pin Microprocessor Power Supply Supervisors SOT-23-3
    CAX810 3-Pin Microprocessor Power Supply Supervisors SOT-23-3
    MAX708 MicroPower Voltage Supervisor Micro8?-8
    SOIC-8
    MAX803 Very Low Supply Current 3-Pin Micropocessor Reset Monitor SC-70-3 / SOT-323-3
    MAX809 Very Low Supply Current 3-Pin Micropocessor Reset Monitor with Active Low Complementary Output SC-70-3 / SOT-323-3
    SOT-23-3
    MAX810 Very Low Supply Current 3-Pin Micropocessor Reset Monitor with Active High Complementary Output SC-70-3 / SOT-323-3
    SOT-23-3
    MC33064 4.59 V Undervoltage Sensing Circuit with Active Low Open Collector Output for 5.0 V Systems Micro8?-8
    SOIC-8
    TO-92
    TSOP-5 / SOT-23-5
    MC33161 Universal Voltage Monitor for Overvoltage and Undervoltage Indication Micro8?-8
    SOIC-8
    MC33164 MicroPower Undervoltage Sensing Circuit with Active Low Open Collector Output for 3.0 V Systems Micro8?-8
    SOIC-8
    TO-92
    MC34064 4.59 V Undervoltage Detector with Active Low Open Collector Output for 5.0 V Systems Micro8?-8
    SOIC-8
    TO-92
    TSOP-5 / SOT-23-5
    MC34164 MicroPower Undervoltage Sensing Circuit with Active Low Open Collector Output for 3 V Systems Micro8?-8
    SOIC-8
    TO-92
    TSOP-5 / SOT-23-5
    NCP300 Voltage Detector Series with Complementary Output TSOP-5 / SOT-23-5
    NCP301 Voltage Detector Series with Open Drain N-Channel Output TSOP-5 / SOT-23-5
    NCP302 Voltage Detector Series with Programmable Delay and Complementary Output TSOP-5 / SOT-23-5
    NCP304 Voltage Detector Series with Complementary Output SC-82AB-4
    NCP304A Voltage Detector with Reverse Pin Out SC-82AB-4
    NCP305 Voltage Detector Series with Open Drain N-Channel Output SC-82AB-4
    NCP308 Voltage Supervisor, Ultra Low Quiescent Current, Programmable Delay Time TSOP-6
    WDFN-6
    NCP803 Very Low Supply Current 3-Pin Microprocessor Reset Monitor SOT-23-3
    NCT80 Hardware Monitor with I2C serial interface TSSOP-24
    NCV300 Voltage Detetor Series - Auto Rated TSOP-5 / SOT-23-5
    NCV301 Voltage Detector Series - Auto Rated TSOP-5 / SOT-23-5
    NCV302 Voltage Detector Series with Programmable Delay - Auto Rated TSOP-5 / SOT-23-5
    NCV303 Voltage Detector Series with Programmable Delay - Auto Rated TSOP-5 / SOT-23-5
    NCV33064 4.59 V Undervoltage Sensing Circuit with Active Low Open Collector Output, Qualified for 5.0 V Systems Micro8?-8
    SOIC-8
    TO-92
    NCV33161 Universal Voltage Monitor - Auto Rated Micro8?-8
    SOIC-8
    NCV33164 MicroPower Undervoltage Sensing Circuit with Open Collector Output, Qualified for 3.0 V Systems SOIC-8
    NCV809 Very Low Supply Current 3-Pin uP Reset Monitors - Auto Rated SOT-23-3
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
