龙人旗下深圳市龙芯世纪科技有限公司
  • LED
  • 发布时间:2013/9/9 10:41:46   修改时间:2013/9/9 10:41:56 浏览次数:1752
  • LED
    LED驱动器 – 稳流器
    安森美半导体提供降压、升压、降压-升压及电感升压型LED驱动器及恒流稳流器(CCR)。
    驱动器LEDExcel 文档格式选型指南
    Product Description Package Type
    LV52204MT LED Boost Driver with PWM and 1-Wire Dimming WDFN-6
    LV52204MU LED Boost Driver with PWM and 1-Wire Dimming UDFN-6
    LV52205MU LED Boost Driver with PWM Dimming UDFN-6
    NCL30080 Quasi-Resonant Primary Side Current-Mode Controller for LED Lighting TSOP-6
    NCL30081 Step Dimmable Quasi-Resonant Primary Side Current-Mode Controller for LED Lighting TSOP-6
    NCL30082 Dimmable Quasi-Resonant Primary Side Current  Mode Controller for LED Lighting with thermal foldback Micro8?-8
    NCL30083 Step Dimmable Quasi-Resonant Primary Side Current-Mode Controller for LED Lighting with thermal foldback Micro8?-8
    NCV7430 Automotive LIN RGB LED Driver SOIC-14
    NSI50150AD 50 V, 150 mA +/- 10%, Adjustable Constant Current Regulator & LED Driver, DPAK DPAK-3
    CAT310 LED Driver, 10-Channel SOIC-20W
    CAT32 White LED Driver TSOT-23-6
    CAT3224 LED Driver, Charge Pump, 2-Channel TQFN-16
    CAT3604A 4-Channel Regulated Charge Pump White LED Driver TQFN-16
    CAT3604V LED Driver, Quad Mode, 4-Channel TQFN-16
    CAT3606 LED Driver, Charge Pump, 6-Channel TQFN-16
    CAT3612 LED Driver, Charge Pump, 2-Channel TDFN-12
    CAT3614 LED Driver, Charge Pump, 4-Channel TDFN-12
    CAT3616 LED Driver, Charge Pump, 6-Channel TQFN-16
    CAT3626 LED Driver, Charge Pump, 6-Channel, I<sup>2</sup>C TQFN-16
    CAT3636 LED Driver, Quad-Mode?, 6-Channel TQFN-16
    CAT3637 LED Driver, Quad-Mode?, 6-Channel TQFN-16
    CAT3643 LED Driver, Quad-Mode?, 3-Channel TDFN-12
    TQFN-16
    CAT3644 LED Driver, Quad-Mode?, 4-Channel TQFN-16
    CAT3647 LED Driver, Quad-Mode?, 3-Channel TQFN-16
    CAT3648 LED Driver, Quad-Mode?, 4-Channel TQFN-16
    CAT3649 LED Driver, Quad-Mode?, 6-Channel TQFN-16
    CAT3661 LED Driver, 1 Channel, with Diagnostics TQFN-16
    CAT37 LED Driver, Boost, 4 LED, series TSOT-23-5
    CAT4002A LED Driver, 2-Channel, with 32 Dimming Levels and Rset SC-88-6 / SC-70-6
    TSOT-23-6
    CAT4003B Constant Current Programmable LED Driver with 32 Dimming Levels SC-88-6 / SC-70-6
    TSOP-6
    TSOT-23-6
    CAT4004 LED Driver, 4-Channel TDFN-8
    CAT4004A LED Driver, 4-Channel, with 32 Dimming Levels and Rset UDFN-8
    CAT4004B Constant Current Programmable LED Driver with 32 Dimming Levels UDFN-8
    CAT4008 LED Driver, 8-Channel SOIC-16
    SOIC-16W
    TSSOP-16
    CAT4016 LED Driver, 16-Channel QSOP-24
    SOIC-24W
    TQFN-24
    TSSOP-24
    CAT4026 6-Channel LED Controller with Fault Diagnostics for Large Panel LED Backlighting SOIC-28W
    CAT4101 LED Driver, 1-Channel D2PAK-5
    CAT4103 LED Driver, RGB, 3-Channel SOIC-16
    CAT4104 LED Driver, 4-Channels, 700 mA SOIC-8
    TDFN-8
    CAT4106 LED Driver, Boost, 4-Channel TQFN-16
    TSSOP-16
    CAT4109 LED Driver, RGB, 3-Channel SOIC-16
    CAT4134 LED Driver, Boost, 2-Channel TDFN-12
    CAT4137 LED Driver, Boost, 5 LED, series TSOT-23-5
    CAT4139 LED Driver, Boost, 5 LED, series TSOT-23-5
    CAT4201 LED Driver, Buck, 7 LED SOIC-8
    TSOT-23-5
    CAT4237 LED Driver, Boost, 8 LED, series TSOT-23-5
    CAT4238 LED Driver, Boost, 10 LED, series TSOT-23-5
    CAT4240 LED Driver, Boost, 10 LED, series TSOT-23-5
    CAV4201 350 mA High Efficiency Step Down LED Driver TSOT-23-5
    LV5026MC LED Driver, High Voltage SOIC-10 NB
    LV5029MD LED Driver, 1-Channel SOIC-10 NB
    LV5207LP 7-Channel LED Driver for Cellular Phone VCT-24
    LV5216CS LED Driver IC, 10-channel
    LV5217GP LED Driver, 3-Channel
    LV5232VH LED Driver , 16 - channel HSOP-28
    NCL30000 Power Factor Corrected TRIAC Dimmable LED Driver SOIC-8
    NCL30001 High Efficiency Single Stage Power Factor Corrected LED Driver SOIC-16
    NCL30002 Power Factor Corrected Offline Buck LED Driver SOIC-8
    NCL30051 PFC and Resonant Half Bridge Combo Controller for LED Lighting SOIC-16
    NCL30100 Fixed Off-Time Buck LED Driver Controller TSOP-6
    NCL30105 Flexible Dimmable Buck LED Driver Controller SOIC-8
    NCL30160 40V LED Buck Regulator SOIC-8
    NCP1840 Fully Programmable Multi-Channel LED Driver QFN-20
    NCP3063 1.5 A, Buck Boost Inverting Switching Regulator DFN-8
    SOIC-8
    NCP3065 1.5 A Constant Current Buck Boost Inverting Switching Regulator for HB-LEDs DFN-8
    SOIC-8
    NCP3066 1.5 A Constant Current Buck Boost Inverting Switching Regulator for HB-LEDs with Enable DFN-8
    SOIC-8
    NCP5005 Compact Backlight Boost LED Driver  TSOP-5 / SOT-23-5
    NCP5006 Compact Backlight Boost LED Driver  TSOP-5 / SOT-23-5
    NCP5007 Compact Backlight Boost LED Driver  TSOP-5 / SOT-23-5
    NCP5030 Buck-Boost Converter to Drive a Single LED from 1 Li-Ion or 3 Alkaline Batteries WDFN-12
    NCP5603 High Efficiency Charge Pump Converter/White LED Driver DFN-10
    NCP5612 2-Channel Charge Pump White LED driver with S-Wire Link Control LLGA-12
    NCP5623B Triple Output I<sup>2</sup>C Controlled RGB LED Driver LLGA-12
    NCP5623C Triple Output I<sup>2</sup>C Controlled RGB LED Driver LLGA-12
    NCP5623T 3-Channel (RGB) Linear LED Driver with I<sup>2</sup>C control TSSOP-14
    NCV7462 System Basis Chip with LIN, CAN, Two LDO, and HS/LS Drivers SSOP-36 EP
    NCV7680 Linear Current Regulator and Controller for LED Rear Combination Lamp SOIC-16W EP
    NCV78663 Power Ballast and Dual LED Driver for Automotive Front Lighting SSOP-36 EP
    NLSF595 Tri-Color LED Driver QFN-16
    TSSOP-16
    NSI45015W 45 V, 15 mA  ± 20% Constant Current Regulator & LED Driver SOD-123
    NSI45020 45 V, 20 mA &#177;15% Constant Current Regulator & LED Driver SOD-123
    NSI45020A 45 V, 20 mA ±10% Constant Current Regulator & LED Driver SOD-123
    NSI45020J 45 V, 20 mA  ±15%, 1.5 W package, Adjustable Constant Current Regulator & LED Driver, SOT-223 SOT-223-4 / TO-261-4
    NSI45025 45 V, 25 mA &#177;15% Constant Current Regulator & LED Driver SOD-123
    NSI45025A 45 V, 25 mA &#177;10% Constant Current Regulator & LED Driver SOD-123
    NSI45025AZ 45 V, 25 mA &#177;10% Constant Current Regulator & LED Driver SOT-223-4 / TO-261-4
    NSI45025Z 45 V, 25 mA &#177;15% Constant Current Regulator & LED Driver SOT-223-4 / TO-261-4
    NSI45030 45 V, 30 mA&#177;15% Constant Current Regulator & LED Driver SOD-123
    NSI45030A 45 V, 30 mA &#177;10% Constant Current Regulator & LED Driver SOD-123
    NSI45030AZ 45 V, 30 mA&#177;10% Constant Current Regulator & LED Driver SOT-223-4 / TO-261-4
    NSI45030Z 45 V, 30 mA &#177;15% Constant Current Regulator & LED Driver SOT-223-4 / TO-261-4
    NSI45035J 45 V, 35 mA  ±15%, 1.5 W package, Adjustable Constant Current Regulator & LED Driver, SOT-223 SOT-223-4 / TO-261-4
    NSI45060JD 45 V, 60 mA  ±15%, 2.7 W package, Adjustable Constant Current Regulator & LED Driver, DPAK DPAK-3
    NSI45090JD 45 V, 90 mA  ±15%, 2.7 W package, Adjustable Constant Current Regulator & LED Driver, DPAK DPAK-3
    NSI50010YT1G 50 V, 10 mA&#177;30% Constant Current Regulator & LED Driver SOD-123
    NSI50350AD 50 V, 350 mA ±10% Constant Current Regulator & LED Driver DPAK-3
    NSI50350AS 50 V, 350 mA ±10% Constant Current Regulator & LED Driver SMC-2
    NSIC2020B 120 V, 20 mA ±15% Constant Current Regulator & LED Driver for A/C off-line Applications SMB-2
    NSIC2030B 120 V, 30 mA ±15% Constant Current Regulator & LED Driver for A/C off-line Applications SMB-2
    NSIC2050B 120 V, 50 mA ±15% Constant Current Regulator & LED Driver for A/C off-line Applications SMB-2
    NUD4001 High Current LED Driver SOIC-8
    NUD4011 Constant Current Regulator & LED Driver  SOIC-8
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
