龙人旗下深圳市龙芯世纪科技有限公司
  • MOSFET 保护 MOSFET
  • 发布时间:2013/9/9 10:46:42   修改时间:2013/9/9 10:46:42 浏览次数:2356
  • MOSFET
    MOSFETs
    N沟道、P沟道和互补MOSFET 安森美半导体提供N沟道和P沟道金属氧化物半导体场效应管(MOSFET),用于电源转换和开关电路。
    MOSFET Excel 文档格式选型指南
    Product Description Package Type
    2SK4087LS Power MOSFET 600V 14A  610m Ohm N-ch Single TO-220F-3FS
    2SK4177 Power MOSFET 1500V 2A 13 Ohm Single N-Channel TO-263-2L TO-3PF-3L
    ATP401 Power MOSFET 60V 100A 3.7 mOhm Single N-Channel ATPAK
    BFL4004 Power MOSFET 800V 4.3A 2.5 Ohm N-Channel Single TO-220F-3FS
    BFL4007 Power MOSFET 600V 14A  680 mOhm Single N-Channel TO-220FP
    EFC4612R Power MOSFET 24V 6A 45m Ohm Dual N-Channel EFCP
    EFC6601R Power MOSFET 24V 13A 11.5mΩ Dual N-Channel EFCP
    EFC6602R Power MOSFET 12V 18A 5.9mΩ Dual N-Channel EFCP
    MCH5839 Small Signal MOSFET -20V -1.5A 645mOhm Complementary MCPH5
    NDD01N60 Power MOSFET 600V 1.5A 8.5 Ohm Single N-Channel DPAK DPAK-3
    IPAK-4
    NDD02N40 Power MOSFET 400V 1.7A  5.5 Ohm Single N-Channel DPAK DPAK-3
    IPAK-4
    NDD60N360U1 Power MOSFET 600V 114A 360 mOhm Single N-Channel DPAK DPAK-3
    IPAK-3
    IPAK-4
    NDT01N60 Power MOSFET 600V 0.4A 8.5Ohm Single N-Channel SOT-223 SOT-223-4 / TO-261-4
    NTB6411AN Power MOSFET 100V 72A 14 mohm Single N-Channel D2PAK D2PAK-3
    NTD3055-150 Power MOSFET 60V 9A 150 mOhm Single N-Channel DPAK DPAK-3
    NTD4856N Power MOSFET 25V 89A 4.7 mOhm Single N Channel DPAK DPAK-3
    NTLJS4114N Power MOSFET 30V 7.8A 35 mOhm Single N-Channel WDFN6 WDFN-6
    NTLUS3A18PZC Power MOSFET -20V 8.2A 18 mOhm Single P-Channel UDFN6 UDFN-6
    NTLUS4930N Power MOSFET 30V 6.3A 26.3 mOhm Single N-Channel UDFN6 UDFN-6
    NTMFD4C20N Power MOSFET 30V 12A 7.3 mOhm Single N-Channel SO-8FL SO-8FL Dual / DFN-8
    NTMFS4982NF Power MOSFET 30V 207A 1.3mOhm Single N-Channel SO-8FL with Schottky Diode   SO-8FL / DFN-5
    NTNS3164NZ Small Signal MOSFET 20V 245mA 1.5 Ohm Single N−Channel SOT−883 SOT-883
    NTR3A30PZ Power MOSFET 20V 2.9A 38mOhm Single P-Channel SOT-23 SOT-23-3
    NTR4501 Power MOSFET 20V 3.2A 80 mOhm Single N-Channel SOT-23 SOT-23-3
    NVD5484NL Power MOSFET 60V 54A 17 mOhm Single N-Channel DPAK DPAK-3
    NVD5490NL Power MOSFET 60V 17A 64 mOhm Single N−Channel DPAK Logic Level DPAK-3
    NVMFD5853NL Power MOSFET 40V 34A 10 mOhm Dual N-Channel SO-8FL Logic Level SO-8FL Dual / DFN-8
    NVMFD5873NL Power MOSFET 60V 58A 13 mOhm Dual N−Channel SO-8FL Logic Level SO-8FL Dual / DFN-8
    WPH4003 Power MOSFET 1700V 3A 10.5 Ohm  Single N-Channel TO-3PF-3L TO-3PF-3L
    5LN01S Small Signal MOSFET 50V 100mA 7.8 Ohm Single N-Channel SMCP
    5LP01S Small Signal MOSFET -50V -70mA 23 Ohm Single P-Channel SMCP
    CPH3356 Power MOSFET -20V -2.5A 137mOhm Single P-Channel CPH3 CPH3
    CPH3360 Small Signal MOSFET -30V -1.6A 303 mOhm Single P-Channel CPH3
    CPH6355 Power MOSFET -30V -3A 169mOhm Single P-Channel CPH6
    ECH8672 Power MOSFET -20V -3.5A 85 mOhm Dual P-Channel ECH8
    ECH8675 Power MOSFET -20V -4.5A 46mOhm Dual P-Channel ECH8
    EMH2314 Power MOSFET -12V -5A  37 mOhm P-Channel Dual ECH8
    EMH2411R Power MOSFET 30V 5A 36.5 mOhm Dual N-Channel EMH8
    MCH3375 Small Signal MOSFET -30V -1.6A 295 mOhm Single P-Channel MCPH3
    MCH3474 Power MOSFET 30V 4A 50 mOhm Single N-Channel MCPH3
    MCH3477 Power MOSFET 20V 4.5A 38 mOhm Single N-Channel MCPH3
    MCH3481 Small Signal MOSFET 20V 2A 104 mOhm Single N-Channel MCPH3
    MCH6448 Power MOSFET 20V 8A 22mOhm Single N-Channel MCPH6
    MCH6663 Small Signal MOSFET 30V 1.8A 188 mOhm Complementary MCPH6
    SCH1333 Small Signal MOSFET -20V -2A 130 mOhm Single P-Channel SCH6
    VEC2315 Small Signal MOSFET 60V 2.5A 137 mOhm Dual P-Channel VEC8
    2N7000 Small Signal MOSFET 60V 200mA 5 Ohm Single N-Channel TO-92 TO-92
    2N7002E Small Signal MOSFET 60V 310mA 2.5 Ohm Single N-Channel SOT-23 SOT-23-3
    2N7002K Small Signal MOSFET 60V 380mA 1.6 Ohm Single N-Channel SOT-23 SOT-23-3
    2N7002L Small Signal MOSFET 60V 115mA 7.5 Ohm Single N-Channel SOT-23 SOT-23-3
    2N7002W Small Signal MOSFET 60V 340mA 1.6 Ohm Single N-Channel SC-70 SC-70-3 / SOT-323-3
    2SK3745LS Power MOSFET 1500V 2A 13 Ohm Single N-Channel TO-220FP TO-220F-3FS
    2SK3746 Power MOSFET 1500V  2A 13 Ohm Single N-Channel TO-3PL TO-3P-3L
    2SK3747 Power MOSFET 1500V 2A 13 Ohm Single N-Channel TO-3PF-3L TO-3PF-3L
    2SK3748 Power MOSFET 1500V 4A 7 Ohm Single N-Channel TO-3PBL TO-3PF-3L
    2SK4198FS Power MOSFET 600V 5A 2.34 Ohm max. N-ch Single TO-220F-3FS  TO-220F-3FS
    3LN01C Small Signal MOSFET 30V 150mA 3.7 Ohm Single N-Channel CP
    3LN01M Small Signal MOSFET 30V 150mA  3.7 Ohm Single N-Channel MCP
    3LN01S Small Signal MOSFET 30V 150mA 3.7 Ohm Single N-Channel SMCP
    3LN01SS Small Signal MOSFET 30V 150mA 3.7 Ohm Single N-Channel SSFP
    3LP01C Small Signal MOSFET -30V -100mA 10.4 Ohms Single P-Channel CP
    3LP01M Small Signal MOSFET 30V 100mA 10.4 Ohms Single P-Channel MCP
    3LP01S Small Signal MOSFET 30V 400A 10.4 Ohm Single P-Channel SMCP
    3LP01SS Small Signal MOSFET -30V -0.1A 10.4 Ohm Single P-Channel SSFP
    3SK263 Small Signal MOSFET 15V 30mA XXOhm Dual N-Channel CP4
    5LN01C Small Signal MOSFET 50V 100mA  7.8 Ohm Single N-Channel CP SOT-23, 3 Lead, 1.3x2.9
    5LN01M Small Signal MOSFET 50V 100mA 7.8 Ohm Single N-Channel MCP
    5LN01SP Small Signal MOSFET 50V 100mA 7.8 Ohm Single N-Channel SPA
    5LN01SS Small Signal MOSFET 50V 100mA 7.8 Ohm Single N-Channel SSFP
    5LP01C Small Signal MOSFET -50V -70mA 23 Ohm Single P-Channel CP
    5LP01M Small Signal MOSFET -50V -0.07A 23 Ohm Single P-Channel MCP
    5LP01SS Small Signal MOSFET -50V -70mA 23 Ohm Single P-Channel SSFP
    ATP101 Power MOSFET -30V -25A 30 mOhm Single P-Channel ATPAK
    ATP102 Power MOSFET -30V -40A 18.5 mOhm Single P-Channel, ATPAK
    ATP103 Power MOSFET -30V -55A 13 mOhm Single P-Channel ATPAK
    ATP104 Power MOSFET -30V -75A 8.4mOhm Single P-Channel ATPAK
    ATP106 Power MOSFET -40V -30A 25mOhm Single P-Channel ATPAK
    ATP107 Power MOSFET -40V -50A 17 mOhm Single P-Channel ATPAK
    ATP108 Power MOSFET -40V -70A 10.4 mOhm Single P-Channel ATPAK
    ATP112 Power MOSFET -60V -25A 43 mOhm Single P-Channel ATPAK
    ATP113 Power MOSFET -60V -35A 29.5 mOhm Single P-Channel ATPAK
    ATP114 Power MOSFET -60V  -55A 16 mOhm Single P-Channel ATPAK
    ATP201 Power MOSFET 30V 35A 17 mOhm Single N-Channel ATPAK
    ATP202 Power MOSFET 30V 50A 12 mOhm Single N-Channel ATPAK
    ATP203 Power MOSFET 30V 75A  8.2 mOhm Single N-Channel ATPAK
    ATP204 Power MOSFET 30V 100A  5.6 mOhm Single N-Channel ATPAK
    ATP206 Power MOSFET 40V 40A 16 mOhm Single N-Channel ATPAK
    ATP207 Power MOSFET 40V 65A  9.1 mOhm Single N-Channel ATPAK
    ATP208 Power MOSFET 40V 90A 6.0 mOhm Single N-Channel ATPAK
    ATP212 Power MOSFET 60V 35A  23 mOhm Single N-Channel ATPAK
    ATP213 Power MOSFET 60V 50A 16 mOhm Single N-Channel ATPAK
    ATP214 Power MOSFET 60V 75A 8.1 mOhm Single N-Channel ATPAK
    ATP216 Power MOSFET 50V 35A 23mOhm Single N-Channel ATPAK
    ATP218 Power MOSFET 30V 100A 3.8mOhm Single N-Channel ATPAK
    ATP301 Power MOSFET -100V -28A 75 mOhm Single P-Channel ATPAK
    ATP302 Power MOSFET -60V -70A 13 mOhm Single P-Channel ATPAK
    ATP404 Power MOSFET 60V 95A 7.2 mOhm Single N-Channel ATPAK
    ATP405 Power MOSFET 100V 40A, 33 mOhm Single N-Channel ATPAK
    ATP602 Power MOSFET 600V 5.0A 2.7 Ohm Single N-Channel ATPAK
    ATP613 Power MOSFET 500V 5.5A 2 Ohm Single N-Channel ATPAK
    BBS3002 Power MOSFET 60V 100A  5.8 mΩ Single P-Channel SMP D2PAK / TO-263-2L
    BS107A Small Signal MOSFET 200V 250mA 6 Ohm Single N-Channel TO-92 TO-92
    BS108 Small Signal MOSFET 200V 250mA 10 Ohm Single N-Channel TO-92 Logic Level TO-92
    BS170 Small Signal MOSFET 60V 500mA 5 Ohm Single N-Channel TO-92 TO-92
    BSS123L Small Signal MOSFET 100V 170mA 6 Ohm Single N-Channel SOT-23 SOT-23-3
    BSS138L Small Signal MOSFET 50V 200mA 3.5 Ohm Single N-Channel SOT-23 Logic Level SOT-23-3
    BSS84L Small Signal MOSFET -50V -130mA 10 Ohm Single P-Channel SOT-23 Logic Level SOT-23-3
    CPH3348 Power MOSFET -12V -3A 70 mOhm Single P-Channel CPH3
    CPH3350 Power MOSFET -20V -3A 83 mOhm Single P-Channel CPH3 CPH3
    CPH3351 Power MOSFET -60V -1.8A 250 mOhm Single P-Channel CPH3
    CPH3355 Power MOSFET -30V -2.5A 156mOhm Single P-Channel CPH3
    CPH3448 Power MOSFET 30V 4A 50mOhm Single N-Channel CPH3
    CPH3455 Power MOSFET 35V 3A 104 mOhm Single N-Channel CPH3
    CPH3456 Power MOSFET 20V 3.5A 71mOhm Single N-Channel CPH3
    CPH3457 Power MOSFET 30V 3A 95mOhm Single N-Channel CPH3
    CPH5617 Small Signal MOSFET 30V 150mA 3.7Ohm Dual N Channel CPH5
    CPH5871 Small Signal MOSFET 30V 3.5A 52 mOhm Single N-Channel CPH5 with Schottky Diode
    CPH6337 Power MOSFET -12V -3.5A  70 mOhm Single P-Channel CPH6
    CPH6341 Power MOSFET -30V -5A 59 mOhm Single P-Channel CPH6
    CPH6347 Power MOSFET -20V -6A 39 mOhm Single P-Channel CPH6
    CPH6350 Power MOSFET -30V -6A 43mOhm Single P-Channel CPH6
    CPH6354 Power MOSFET -60V -4A 100 mOhm Single P-Channel CPH6 SC-88 (SC-70 6 Lead), 1.25x2
    CPH6442 Power MOSFET 60V 6.0A 43 mOhm Single N-Channel CPH6
    CPH6443 Power MOSFET 35V 6A 37 mOhm Single N-Channel CPH6
    CPH6445 Power MOSFET 60V 3.5A 117 mOhm Single N-Channel CPH6
    ECH8308 Power MOSFET -12V -10A 12.5 mOhm Single P-Channel ECH8
    ECH8309 Power MOSFET 12V 9.5A 16 mOhm Single P-Channel ECH8
    ECH8310 Power MOSFET -30V -9A 17 mOhm Single P-Channel ECH8
    ECH8315 Power MOSFET -30V -7.5A  25 mOhm Single P-Channel ECH8
    ECH8320 Power MOSFET -20V -9.5A 14.5 mOhm Single P-Channel ECH8
    ECH8410 Power MOSFET 30V 12A 10 mOhm Single N-Channel ECH8
    ECH8419 Power MOSFET 35V 9A 17 mOhm Single N-Channel ECH8
    ECH8420 Power MOSFET 20V 14A 6.8 mOhm Single N-Channel ECH8
    ECH8601M Power MOSFET 24V 8A 23mOhm Dual N-Channel ECH8
    ECH8602M Power MOSFET 30V 6A 30 mOhm Dual N-Channel ECH8
    ECH8649 Power MOSFET 20V 7.5A 17 mOhm Dual N-Channel ECH8
    ECH8651R Power MOSFET 24V 10A 14 mOhm Dual N-Channel ECH8
    ECH8652 Power MOSFET -12V -6.0A, 28 mOhm Dual P-Channel ECH8
    ECH8653 Power MOSFET 20V 7.5A 20mOhm Dual N-Channel ECH8
    ECH8654 Power MOSFET -20V -5.0A 38 mOhm Dual P-Channel ECH8
    ECH8655R Power MOSFET 24V 9.0A 17 mOhm Dual N-Channel ECH8
    ECH8656 Power MOSFET 20V 7.5A 17 mOhm Dual N-Channel ECH8
    ECH8657 Power MOSFET 35V 4.5A  59 mOhm Dual N-Channel ECH8
    ECH8659 Power MOSFET 30V 7A  24 mOhm Dual N-Channel ECH8
    ECH8660 Power MOSFET 30V 4.5A 59 mOhm Complementary ECH8
    ECH8661 Power MOSFET 30V 7A 24 mOhm Complementary ECH8
    ECH8662 Power MOSFET 40V 6.5A 30mOhm Dual N-Channel ECH8
    ECH8663R Power MOSFET 30V 8.0A 20.5 mOhm Dual N-Channel ECH8
    ECH8664R Power MOSFET 30V 7.0A  23.5 mOhm Dual N-Channel ECH8
    ECH8667 Power MOSFET -30V -5.5A 39 mOhm Dual P-Channel ECH8
    ECH8668 Power MOSFET 20V 5A/7.5A 38 mOhm/17mOhm Complementary ECH8
    ECH8671 Power MOSFET -12V -3.5A 77 mOhm Dual P-Channel ECH8
    ECH8673 Power MOSFET 40V 2.5A/3.5A 163mOhm/85 mOhm Complementary ECH8
    ECH8674 Power MOSFET -12V -5A 41 mOhm Dual P-Channel ECH8
    EMH1303 Power MOSFET -12V -7.0A  23mOhm Single P-Channel EMH8
    EMH1307 Power MOSFET 20V 6.5A 26 mOhm Single P-Channel EMH8
    EMH1405 Power MOSFET 30V 8.5A 19mOhm Single N-Channel EMH8
    EMH2308 Power MOSFET -30V -3A 85 mOhm Dual P-Channel ECH8
    EMH2407 Power MOSFET 20V 6.0A 25 mOhm Dual N-Channel EMH8
    EMH2408 Power MOSFET 20V 4A 45 mOhm Dual N-Channel EMH8
    EMH2409 Power MOSFET 30V 4A 59 mOhm Dual N-Channel EMH8
    EMH2412 Power MOSFET 24V 6A 27 mOhm Dual N-Channel EMH8
    EMH2604 Power MOSFET 20V 3A 85 mOhm Complementary EMH8
    EMH2801 Power MOSFET -20V -3A 85mOhm Single P-Channel EMH8 with SBD
    MCH3374 Power MOSFET -12V -3A 70 mOhm Single P-Channel MCPH3
    MCH3376 Small Signal MOSFET 20V 1.5A 241 mOhm Single P-Channel MCPH3
    MCH3377 Power MOSFET -20V -3.0A, 83 mOhm Single P-Channel MCPH3
    MCH3382 Small Signal MOSFET -12V -2A 198 mOhm Single P-Channel MCPH3
    MCH3383 Power MOSFET -12V -3.5A 69 mOhm Single P-Channel MCH3
    MCH3475 Small Signal MOSFET 30V 1.8A 180 mOhm Single N-Channel MCPH3
    MCH3476 Small Signal MOSFET 20V 2A 125 mOhm Single N-Channel MCPH3 SC-70  (SOT-323) 3 LEAD
    MCH3478 Small Signal MOSFET 30V 2A 165 mOhm Single N-Channel MCPH3
    MCH3479 Small Signal MOSFET 20V 3.5A 64 mOhm Single N-Channel MCPH3
    MCH3484 Power MOSFET 20V 4.5A 40 mOhm Single N-Channel MCPH3 SC-70-3
    MCH6320 Power MOSFET -12V -3.5A 70 mOhm Single P-Channel MCPH6
    MCH6321 Power MOSFET -20V -4A 83mOhm Single P-Channel MCPH6
    MCH6331 Power MOSFET -30V -3.5A 98 mOhm Single P-Channel MCPH6
    MCH6336 Power MOSFET -12V -5A 43 mOhm Single P-Channel MCPH6
    MCH6337 Power MOSFET -20V -4.5A 49 mOhm Single P-Channel MCPH6
    MCH6341 Power MOSFET -30V -5.0A 59 mOhm Single P-Channel MCPH6
    MCH6342 Power MOSFET -30V -4.5A 73 mOhm Single P-Channel MCPH6
    MCH6344 Small Signal MOSFET -30V -2A 150 mOhm Single P-Channel MCPH6
    MCH6421 Power MOSFET 20V 5.5A, 38 mOhm Single N-Channel MCPH6
    MCH6431 Power MOSFET 30V 5A 55 mOhm Single N-Channel MCPH6
    MCH6436 Power MOSFET 30V 6A 34mOhm Single N-Channel MCPH6
    MCH6437 Power MOSFET 20V 7A 24mOhm Single N-Channel MCPH6
    MCH6444 Small Signal MOSFET 35V 2.5A 98 mOhm Single N-Channel MCPH6
    MCH6445 Power MOSFET 60V 4A 78 mOhm Single N-Channel MCPH6
    MCH6601 Small Signal MOSFET -30V -200mA 10.4 Ohm Dual P-Channel MCPH6
    MCH6602 Small Signal MOSFET 30V 350mA 3.7 Ohm Dual N-Channel MCPH6
    MCH6603 Small Signal MOSFET -50V -140mA 23 Ohm Dual P-Channel MCPH6
    MCH6604 Small Signal MOSFET 50V 250mA 7.8 Ohm Dual N-Channel MCPH6
    MCH6613 Small Signal MOSFET -30V -200m 10.4Ohm Complementary MCPH6
    MCH6660 Small Signal MOSFET 20V 2A 136 mOhm Complementary MCPH6
    MCH6662 Small Signal MOSFET 20V 2A 160 mOhm Dual N-Channel MCPH6
    MGSF1N02L Small Signal MOSFET 20V 750mA 90 mOhm Single N-Channel SOT-23 SOT-23-3
    MGSF1N03L Small Signal MOSFET 30V 1.6A 100 mOhm Single N-Channel SOT-23 SOT-23-3
    MGSF2N02EL Power MOSFET 20V 2.8A 85 mOhm Single N-Channel SOT-23 Logic Level SOT-23-3
    MMBF0201NL Small Signal MOSFET 20V 300mA 1 Ohm Single N-Channel SOT-23 Logic Level SOT-23-3
    MMBF170L Small Signal MOSFET 60V 500mA 5 Ohm Single N-Channel SOT-23 Logic Level SOT-23-3
    MMBF2201N Small Signal MOSFET 20V 300mA 1 Ohm Single N-Channel SC-70 SC-70-3 / SOT-323-3
    MMDF1N05E Power MOSFET 50V 2A 300 mOhm Dual N-Channel SO-8 SOIC-8
    MMFT960 Small Signal MOSFET 60V 300mA 1.7 Ohm Single N-Channel SOT-223 SOT-223-4 / TO-261-4
    MMSF3P02HD Power MOSFET 20V 5.6A 75 mOhm Single P-Channel SO-8 SOIC-8
    MTB2P50E Power MOSFET 500V 2A 6 Ohm Single P-Channel D2PAK D2PAK-3
    MTB30P06V Power MOSFET 60V 30A 80 mOhm Single P-Channel D2PAK D2PAK-3
    MTB50P03HDL Power MOSFET 30V 50A 25 mOhm Single P-Channel D2PAK Logic Level D2PAK-3
    MTD5P06V Power MOSFET 60V 5A 450 mOhm Single P-Channel DPAK DPAK-3
    MTD6N15 Power MOSFET 150V 6A 300 mOhm Single N-Channel DPAK DPAK-3
    MTD6N20E Power MOSFET 200V 6A 700 mOhm Single N-Channel DPAK DPAK-3
    MTP2P50E Power MOSFET 500V 2A 6 Ohm Single P-Channel TO-220 TO-220-3
    MTP50P03HDL Power MOSFET 30V 50A 25 mOhm Single P-Channel TO-220 Logic Level TO-220-3
    NDD02N60Z Power MOSFET 600V 2.2A 4.8 Ohm Single N-Channel DPAK/IPAK DPAK-3
    IPAK-4
    NDD03N50Z Power MOSFET 500V 2.6A 3.3 Ohm Single N-Channel DPAK/IPAK DPAK-3
    IPAK-4
    NDD03N60Z Power MOSFET 600V 2.6A 3.6 Ohm Single N-Channel DPAK/IPAK DPAK-3
    IPAK-4
    NDD03N80Z Power MOSFET 800V 2.9A 4.5Ohm Single N-Channel DPAK/IPAK DPAK-3
    IPAK-4
    NDD04N50Z Power MOSFET 500V 3.4A 2.7 Ohm Single N-Channel DPAK/IPAK DPAK-3
    IPAK-4
    NDD04N60Z Power MOSFET 600V 4.1A 2 Ohm Single N-Channel DPAK/IPAK DPAK-3
    IPAK-4
    NDD05N50Z Power MOSFET 500V 4.7A 1.5 Ohm Single N-Channel DPAK/IPAK DPAK-3
    IPAK-4
    NDF02N60Z Power MOSFET 600V 2.4A 4.8 Ohm Single N-Channel TO-220FP TO-220 FULLPAK-3
    NDF03N60Z Power MOSFET 600V 3A 3.6 Ohm Single N-Channel TO-220FP TO-220 FULLPAK-3
    NDF04N60Z Power MOSFET 600V 4.8A 2 Ohm Single N-Channel TO-220FP TO-220 FULLPAK-3
    NDF04N62Z Power MOSFET 620V 4.1A 2 Ohm Single N-Channel TO220FP TO-220 FULLPAK-3
    NDF05N50Z Power MOSFET 500V 5A 1.5 Ohm Single N-Channel TO-220FP TO-220 FULLPAK-3
    NDF06N60Z Power MOSFET 600V 6A 1.2 Ohm Single N-Channel TO-220FP TO-220 FULLPAK-3
    NDF06N62Z Power MOSFET 620V 3.8A 1.2 Ohm Single N-Channel TO220FP TO-220 FULLPAK-3
    NDF08N50Z Power MOSFET 500V 7.5A 0.850 Ohm Single N-Channel TO-220FP TO-220 FULLPAK-3
    NDF08N60Z Power MOSFET 600V 7.5A 0.95 Ohm Single N-Channel TO-220FP TO-220 FULLPAK-3
    NDF10N60Z Power MOSFET 600V 10A 0.750 Ohm Single N-Channel TO-220FP TO-220 FULLPAK-3
    NDF10N62Z Power MOSFET 620V 5.7A 750 mOhm Single N-Channel TO220FP TO-220 FULLPAK-3
    NDF11N50Z Power MOSFET 500V 10.5A 0.52 Ohm Single N-Channel TO-220FP TO-220 FULLPAK-3
    NMLU1210 Power MOSFET 20V 3.2A  26 mOhm Dual N-Channel Full Bridge Rectifier UDFN UDFN-8
    NT4N03 Power MOSFET 30V 4A 60mOhm Dual N-Channel S0-8 SOIC-8
    NTA4001N Small Signal MOSFET 20V 238mA 1.5 Ohm Single N-Channel SC-75 with ESD Protection SC-75-3
    NTA4151P Small Signal MOSFET 20V 760mA 360 mOhm Single P-Channel SC-75 with ESD Protection SC-75-3
    NTA4153N Small Signal MOSFET 20V 915mA 230 mOhm Single N-Channel SC-75 with ESD Protection SC-75-3
    NTA7002N Small Signal MOSFET 30V 154mA 7 Ohm Single N-Channel SC-75 with ESD Protection SC-75-3
    NTB25P06 Power MOSFET 60V 27.5A 82 mOhm Single P-Channel D2PAK D2PAK-3
    NTB35N15 Power MOSFET 150V 37A 50 mOhm Single N-Channel D2PAK D2PAK-3
    NTB45N06 Power MOSFET 60V 45A 26 mOhm Single N-Channel D2PAK D2PAK-3
    NTB45N06L Power MOSFET 60V 45A 28 mOhm Single N-Channel D2PAK Logic Level D2PAK-3
    NTB5404N Power MOSFET 40V 167A 4.5 mOhm Single N-Channel D2PAK D2PAK-3
    NTB5405N Power MOSFET 40V 116A 5.8 mOhm Single N-Channel D2PAK D2PAK-3
    NTB5426N Power MOSFET 60V 120A 6 mOhm Single N-Channel D2PAK D2PAK-3
    NTB5605P Power MOSFET 60V 18.5A 140 mOhm Single P-Channel D2PAK D2PAK-3
    NTB5860N Power MOSFET 60V 169A 3.0 mOhm Single N-Channel D2PAK D2PAK-3
    NTB5860NL Power MOSFET 60V 169A 3.0 mOhm Single N-Channel D2PAK  Logic Level D2PAK-3
    NTB60N06 Power MOSFET 60V 60A 14 mOhm Single N-Channel D2PAK D2PAK-3
    NTB6410AN Power MOSFET 100V 76A 13 mOhm Single N-Channel D2PAK D2PAK-3
    NTB6412AN Power MOSFET 100V 58A 18.2 mohm Single N-Channel D2PAK D2PAK-3
    NTB6413AN Power MOSFET 100V 42A 28 mohm Single N-Channel D2PAK D2PAK-3
    NTD110N02R Power MOSFET 24V 110A 4.6 mOhm Single N-Channel DPAK DPAK-3
    NTD14N03R Power MOSFET 25V 14A 95 mOhm Single N-Channel DPAK DPAK-3
    NTD18N06L Power MOSFET 60V 18A 65 mOhm Single N-Channel DPAK Logic Level DPAK-3
    NTD20N03L27 Power MOSFET 30V 20A 27 mOhm Single N-Channel DPAK Logic Level DPAK-3
    NTD20N06 Power MOSFET 60V 20A 46 mOhm Single N-Channel DPAK DPAK-3
    NTD20N06L Power MOSFET 60V 20A 48 mOhm Single N-Channel DPAK Logic Level DPAK-3
    NTD20P06L Power MOSFET 60V 15.5A 150 mOhm Single P-Channel DPAK Logic Level DPAK-3
    NTD24N06 Power MOSFET 60V 24A 42 mOhm Single N-Channel DPAK DPAK-3
    NTD24N06L Power MOSFET 60V 24A 45 mOhm Single N-Channel DPAK Logic Level DPAK-3
    NTD25P03L Power MOSFET 30V 25A 72 mOhm Single P-Channel DPAK Logic Level DPAK-3
    NTD2955 Power MOSFET 60V 12A 180 mOhm Single P-Channel DPAK DPAK-3
    IPAK-4
    NTD3055-094 Power MOSFET 60V 12A 94 mOhm Single N-Channel DPAK DPAK-3
    IPAK-4
    NTD3055L104 Power MOSFET 60V 12A 104 mOhm Single N-Channel DPAK Logic Level DPAK-3
    IPAK-4
    NTD3055L170 Power MOSFET 60V 9A 170 mOhm Single N-Channel DPAK Logic Level DPAK-3
    NTD4302 Power MOSFET 30V 18.5A 10 mOhm Single N-Channel DPAK DPAK-3
    NTD4804N Power MOSFET 30V 117A 4 mOhm Single N-Channel DPAK DPAK-3
    NTD4805N Power MOSFET 30V 88A  5 mOhm Single N-Channel DPAK DPAK-3
    IPAK-4
    NTD4806N Power MOSFET 30V 76A 6 mOhm Single N-Channel DPAK DPAK-3
    IPAK-3
    NTD4808N Power MOSFET 30V 63A 8 mOhm Single N-Channel DPAK DPAK-3
    IPAK-4
    NTD4809N Power MOSFET 30V 58A 9 mOhm Single N-Channel DPAK DPAK-3
    IPAK-3
    NTD4809NH Power MOSFET 30V 58A 9 mOhm Single N-Channel DPAK DPAK-3
    NTD4810N Power MOSFET 30V 54A 10 mOhm Single N-Channel DPAK DPAK-3
    NTD4813N Power MOSFET 30V 40A 13 mOhm Single N-Channel DPAK IPAK-3
    NTD4813NH Power MOSFET 30V 40A 13 mOhm Single N-Channel DPAK DPAK-3
    NTD4815N Power MOSFET 30V 35A 15 mOhm Single N-Channel DPAK DPAK-3
    IPAK-3
    NTD4858N Power MOSFET 25V 73A 6.2 mOhm Single N Channel DPAK DPAK-3
    IPAK-3
    NTD4860N Power MOSFET 25V 65A 7.5 mOhm Single N Channel DPAK DPAK-3
    NTD4863N Power MOSFET 25V 49A 10.2 mOhm Single N-Channel DPAK DPAK-3
    NTD4904N Power MOSFET 30V 79A 3.7 mOhm Single N-Channel DPAK DPAK-3
    IPAK-3
    IPAK-4
    NTD4906N Power MOSFET 30V 54A 5.5 mOhm Single N-Channel DPAK DPAK-3
    IPAK-3
    NTD4909N Power MOSFET 30V 41A 8 mOhm Single-N Channel DPAK  DPAK-3
    IPAK-3
    NTD4910N Power MOSFET 30V 37A 9 mOhm Single N-Channel DPAK DPAK-3
    IPAK-4
    NTD4963N Power MOSFET 30V 44A 9.6 mohm Single N Channel DPAK DPAK-3
    IPAK-3
    IPAK-4
    NTD4965N Power MOSFET 30V 68A 4.7mOhm Single N-Channel DPAK DPAK-3
    IPAK-3
    IPAK-4
    NTD4969N Power MOSFET 30V 41A 9mOhm Single N Channel DPAK DPAK-3
    IPAK-3
    IPAK-4
    NTD4970N Power MOSFET 30V 36A 11mOhm Single N-Channel DPAK DPAK-3
    IPAK-3
    IPAK-4
    NTD5406N Power MOSFET 40V 70A 10 mOhm Single N-Channel DPAK DPAK-3
    NTD5407N Power MOSFET 40V 38A 10 mOhm Single N-Channel DPAK DPAK-3
    NTD5414N Power MOSFET 60V 24A 37 mOhm Single N−Channel DPAK DPAK-3
    NTD5802N Power MOSFET 40V 101A 4.4 mOhm Single N-Channel DPAK DPAK-3
    NTD5803N Power MOSFET 40V 75A 7.2 mOhm Single N-Channel DPAK DPAK-3
    NTD5804N Power MOSFET 40V 69A 8.5 mOhm Single N-Channel DPAK DPAK-3
    NTD5805N Power MOSFET 40V 51A 9.5 mOhm Single N-Channel DPAK DPAK-3
    NTD5806N Power MOSFET 40V 33A 19 mOhm Single N-Channel DPAK DPAK-3
    NTD5807N Power MOSFET 40V 23A 31mOhm Single N−Channel DPAK DPAK-3
    NTD5862N Power MOSFET 60V 90A 5.7 mOhm Single N Channel DPAK DPAK-3
    IPAK-4
    NTD5865N Power MOSFET 60V 34A 18 mOhm Single N Channel DPAK DPAK-3
    IPAK-4
    NTD5865NL Power MOSFET 60V 34A 16mOhm Single N-Channel DPAK Logic Level DPAK-3
    IPAK-4
    NTD5867NL Power MOSFET 60V 19A 39mOhm Single N-Channel DPAK Logic Level DPAK-3
    IPAK-4
    NTD6414AN Power MOSFET 100V 32A 37 mohm Single N-Channel DPAK DPAK-3
    NTD6415AN Power MOSFET 100V 23A 55 mohm Single N-Channel DPAK DPAK-3
    IPAK-4
    NTD6415ANL Power MOSFET 100V 23A 56 mohm Single N-Channel DPAK Logic Level DPAK-3
    NTD6416AN Power MOSFET 100V 17A 81 mohm Single N-Channel DPAK DPAK-3
    IPAK-4
    NTD6416ANL Power MOSFET 100V 19A 81 mohm Single N-Channel DPAK Logic Level DPAK-3
    IPAK-4
    NTE4151P Small Signal MOSFET 20V 760mA 360 mOhm Single P-Channel SC-89 with ESD Protection SC-89-3
    NTE4153N Small Signal MOSFET 20V 915mA 230 mOhm Single N-Channel SC-89 with ESD Protection SC-89-3
    NTF2955 Power MOSFET 60V 2.6A 170 mOhm Single P-Channel SOT-223 SOT-223-4 / TO-261-4
    NTF3055-100 Power MOSFET 60V 3A 100 mOhm Single N-Channel SOT-223 SOT-223-4 / TO-261-4
    NTF3055L108 Power MOSFET 60V 3A 120 mOhm Single N-Channel SOT-223 Logic Level SOT-223-4 / TO-261-4
    NTF5P03T3 Power MOSFET 30V 5A 100 mOhm Single P-Channel SOT-223 SOT-223-4 / TO-261-4
    NTF6P02 Power MOSFET 20V 10A 50 mOhm Single P-Channel SOT-223 SOT-223-4 / TO-261-4
    NTGD1100L Small Signal MOSFET 8V 3.3A 55 mOhm Dual P-Channel TSOP6 with Level-Shift SC-74
    NTGD4161P Power MOSFET 30V 2.3A 160 mOhm Dual P-Channel TSOP6 TSOP-6
    NTGD4167C Small Signal MOSFET 30V 2.6A 90 mOhm Complementary TSOP-6 TSOP-6
    NTGS3130N Power MOSFET 20V 5.6A 24 mOhm Single N-Channel TSOP6 TSOP-6
    NTGS3136P Power MOSFET 20V 5.8A 33 mOhm Single P-Channel TSOP-6 TSOP-6
    NTGS3433 Power MOSFET 12V 3.3A 75 mOhm Single P-Channel TSOP-6 TSOP-6
    NTGS3441 Power MOSFET 20V 2.35A 90 mOhm Single P-Channel TSOP-6 TSOP-6
    NTGS3443 Power MOSFET 20V 2A 65 mOhm Single P-Channel TSOP-6 TSOP-6
    NTGS3446 Power MOSFET 20V 5.1A 45 mOhm Single N-Channel TSOP6 TSOP-6
    NTGS3455 Power MOSFET 30V 3.5A 100 mOhm Single P-Channel TSOP-6 TSOP-6
    NTGS4111P Power MOSFET 30V 4.7A 60 mOhm Single P-Channel TSOP6 TSOP-6
    NTGS4141N Power MOSFET 30V 7A 25 mOhm Single N-Channel TSOP6 TSOP-6
    NTGS5120P Power MOSFET 60V 2.9A 111 mOhm Single P-Channel TSOP-6 TSOP-6
    NTHC5513 Power MOSFET 20V 3.9A 80 mOhm Complementary ChipFET ChipFET-8
    NTHD3100C Power MOSFET 20V 3.9A 80 mOhm Complementary ChipFET ChipFET-8
    NTHD3101F Power MOSFET 20V 4.4A 80 mOhm Dual P-Channel ChipFET with Schottky Diode ChipFET-8
    NTHD3102C Power MOSFET 20V 5.5A 45 mOhm Complementary ChipFET ChipFET-8
    NTHD4102P Power MOSFET 20V 4.1A 80 mOhm Dual P-Channel ChipFET ChipFET-8
    NTHD4502N Power MOSFET 30V 3.9A 85 mOhm Dual N-Channel ChipFET ChipFET-8
    NTHD4508N Power MOSFET 20V 4.1A 75 mOhm Dual N-Channel ChipFET ChipFET-8
    NTHD4P02 Power MOSFET 20V 3A 155 mOhm Dual P-Channel ChipFET with Schottky Diode ChipFET-8
    NTHS4101P Power MOSFET 20V 6.7A 34 mOhm Single P-Channel ChipFET ChipFET-8
    NTHS4166N Power MOSFET 30V 8.2A 24 mOhm Single N-Channel ChipFET ChipFET-8
    NTHS5404 Power MOSFET 20V 7.2A 30 mOhm Single N-Channel ChipFET ChipFET-8
    NTHS5441T1 Power MOSFET 20V 5.3A 60 mOhm Single P-Channel ChipFET ChipFET-8
    NTHS5443 Power MOSFET 20V 4.9A 65 mOhm Single P-Channel ChipFET ChipFET-8
    NTJD1155L Small Signal MOSFET 8V 1.3A 175 mOhm Dual  P-Channel SC−88 with Level-Shift SC-88-6 / SC-70-6 / SOT-363-6
    NTJD4001N Small Signal MOSFET 30V 250mA 1.5 Ohm Dual N-Channel SC−88 SC-88-6 / SC-70-6 / SOT-363-6
    NTJD4105C Small Signal MOSFET 20V 775mA 220 mOhm Complementary SC−88 SC-88-6 / SC-70-6 / SOT-363-6
    NTJD4152P Small Signal MOSFET 20V 880mA 215 mOhm Dual P-Channel SC−88 with ESD Protection SC-88-6 / SC-70-6 / SOT-363-6
    NTJD4158C Small Signal MOSFET 30V 880mA 260 mOhm Complementary SC−88 SC-88-6 / SC-70-6 / SOT-363-6
    NTJD4401N Small Signal MOSFET 20V 630mA 375 mOhm Dual N-Channel SC−88 with ESD Protection SC-88-6 / SC-70-6 / SOT-363-6
    NTJD5121N Small Signal MOSFET 60V 295mA 1.6 Ohm Dual N-Channel SC−88 with ESD Protection SC-88-6 / SC-70-6 / SOT-363-6
    NTJS3151P Small Signal MOSFET 12V 3.3A 60 mOhm Single P-Channel SC−88/SC70−6/SOT−363 SC-88-6 / SC-70-6 / SOT-363-6
    NTJS3157N Power MOSFET 20V 4A 60 mOhm Single N-Channel SC−88 SC-88-6 / SC-70-6 / SOT-363-6
    NTJS4151P Power MOSFET 20V 4.2A 60 mOhm Single P-Channel SC−88 SC-88-6 / SC-70-6 / SOT-363-6
    NTJS4405N Small Signal MOSFET 25V 1.2A 350 mOhm Single N-Channel SC−88 SC-88-6 / SC-70-6 / SOT-363-6
    NTK3043N Small Signal MOSFET 20V 285mA 3.4 Ohm Single N-Channel SOT-723 with ESD Protection SOT-723-3
    NTK3134N Small Signal MOSFET 20V 890mA 350 mOhm Single N-Channel SOT-723 with ESD Protection SOT-723-3
    NTK3139P Small Signal MOSFET 20V 780mA 480 mOhm Single P-Channel SOT-723 with ESD Protection SOT-723-3
    NTLGD3502N Power MOSFET 20V 5.8A 60 mOhm Dual N-Channel DFN DFN-6
    NTLGF3402P Power MOSFET 20V 3.9A 140 mOhm Dual P-Channel DFN with Schottky Diode DFN-6
    NTLJD3115P Power MOSFET 20V 3.3A 100 mOhm Dual P-Channel WDFN6 WDFN-6
    NTLJD3119C Power MOSFET 20V 4.6A 65 mOhm Complementary WDFN6 WDFN-6
    NTLJD4116N Power MOSFET 30V 4.6A 70 mOhm Dual N-Channel WDFN6 WDFN-6
    NTLJF3117P Power MOSFET 20V 4.1A 100 mOhm Dual P-Channel WDFN6 with Schottky Diode WDFN-6
    NTLJF4156N Power MOSFET 30V 4A 70 mOhm N-Channel with Schottky Diode in WDFN6 Package WDFN-6
    NTLJS2103P Power MOSFET 12V 7.7A 40 mOhm Single P-Channel WDFN6 WDFN-6
    NTLJS3113P Power MOSFET 20V 7.7A 40 mOhm Single P-Channel WDFN6 WDFN-6
    NTLJS3A18PZ Power MOSFET 20V 8.2A 18 mOhm Single P-Channel WDFN WDFN-6
    NTLLD4901NF Power MOSFET 30V 11A  22 mOhm Dual N−Channel WDFN8 WDFN-8
    NTLUD3A260P Small Signal MOSFET 20V 1.7A  200mOhm Dual P-Channel uDFN  UDFN-6
    NTLUD3A50PZ Power MOSFET 20V 5.6A  50 mOhm Dual P-Channel uDFN UDFN-6
    NTLUF4189NZ Small Signal MOSFET 30V 1.5A 200 mOhm Dual N-Channel UDFN6 with Schottky Diode UDFN-6
    NTLUS3A18PZ Power MOSFET 20V 8.2A 18 mOhm Single P-Channel UDFN6 UDFN-6
    NTLUS3A39PZ Power MOSFET 20V 5.2A 39 mOhm Single P-Channel uDFN UDFN-6
    NTLUS3A40P Small Signal MOSFET 20V 6.4A 29 mOhm Single P-Channel UDFN with ESD Protection UDFN-6
    NTLUS3A90P Small Signal MOSFET 20V 4A 62 mOhm Single P-Channel UDFN with ESD Protection UDFN-6
    NTMD3P03 Power MOSFET 30V 3.05A 85 mOhm Dual P-Channel SO-8 SOIC-8
    NTMD4184PF Power MOSFET 30V 2.3A 165 mOhm Dual P-Channel SO-8 with Schottky Diode SOIC-8
    NTMD4820N Power MOSFET 30V 6.4A 20 mOhm Dual N-Channel SO-8 SOIC-8
    NTMD4840N Power MOSFET 30V 5.5A 24 mOhm Dual N-Channel SO-8 SOIC-8
    NTMD5836NL Power MOSFET 40V 9A 11mOhm Dual N-Channel SO-8 Logic Level SOIC-8
    NTMD5838NL Power MOSFET 40V 8.9A 25 mOhm Dual N−Channel SO−8 SOIC-8
    NTMD6N02 Power MOSFET 20V 6.5A 35 mOhm Dual N-Channel SO-8 SOIC-8
    NTMD6N04R2 Power MOSFET 40V 4.6A 34 mOhm Dual N-Channel SO-8 SOIC-8
    NTMD6P02 Small Signal MOSFET 20V 7.8A 33 mOhm Dual P-Channel SO-8 SOIC-8
    NTMFD4901NF Power MOSFET 30V 18A, 10/3.5 mohm Asymmetrical Dual N Channel SO-8FL SO-8FL Dual / DFN-8
    NTMFD4902NF Power MOSFET 30V 18A 10/6.2mohm Asymmetrical Dual N Channel SO-8FL SO-8FL Dual / DFN-8
    NTMFS4821N Power MOSFET 30V 58.5A 6.95 mOhm Single N-Channel SO-8FL SO-8FL / DFN-5
    NTMFS4823N Power MOSFET 30 V 30 A 10.5 mOhm Single N−Channel SO−8FL SO-8FL / DFN-5
    NTMFS4825NFE Power MOSFET 30V 171A 2mOhm Single N-Channel S-08 Thermally Enhanced with Schottky Diode SO-8FL / DFN-5
    NTMFS4833N Power MOSFET 30V 191A 2 mOhm Single N-Channel SO-8FL SO-8FL / DFN-5
    NTMFS4833NS SENSEFET?  30V 156A  2.2 mOhm Single N-Channel SO-8FL SO-8FL / DFN-8
    NTMFS4834N Power MOSFET 30V 130A 3.5 mOhm Single N-Channel SO-8FL SO-8FL / DFN-5
    NTMFS4835N Power MOSFET 30V 104A 3.5 mOhm Single N-Channel SO-8FL SO-8FL / DFN-5
    NTMFS4841N Power MOSFET 30V 57A 7 mOhm Single N-Channel SO-8FL SO-8FL / DFN-5
    NTMFS4845 Power MOSFET 30V 115A 2.9 mOhm Single N-Channel SO-8FL SO-8FL / DFN-5
    NTMFS4846 Power MOSFET 30V 100A 3.4 mOhm Single N-Channel SO-8FL SO-8FL / DFN-5
    NTMFS4847N Power MOSFET 30V 85A 4.1 mOhm Single N-Channel SO-8FL SO-8FL / DFN-5
    NTMFS4851 Power MOSFET 30V 66A 5.9 mOhm Single N-Channel SO-8FL SO-8FL / DFN-5
    NTMFS4852N Power MOSFET 30V 155A  2.1 mOhm Single N-Channel SO-8FL SO-8FL / DFN-5
    NTMFS4854NS SENSEFET?  25V 149A 2.5 mOhm Single N-Channel  SO-8FL SO-8FL / DFN-8
    NTMFS4897N Power MOSFET 30V 171A  2 mOhm Single N-Channel SO-8FL with Schottky Diode SO-8FL / DFN-5
    NTMFS4898N Power MOSFET 30V 117A 3 mOhm Single N-Channel SO-8FL with Schottky Diode SO-8FL / DFN-5
    NTMFS4899N Power MOSFET 30V 75A 5 mOhm Single N-Channel SO-8FL with Schottky Diode SO-8FL / DFN-5
    NTMFS4921N Power MOSFET 30V 58.5A 6.95 mOhm Single N-Channel SO-8FL SO-8FL / DFN-5
    NTMFS4922NE Power MOSFET 30 V 147 A 2.0 mOhm Single N-Channel Thermally Enhanced SO-8FL   SO-8FL / DFN-5
    NTMFS4923NE Power MOSFET 30V 91A 3.3mOhm Single N-Channel Thermally Enhanced SO-8FL SO-8FL / DFN-5
    NTMFS4925N Power MOSFET 30V 48A 6mOhm Single N-Channel SO-8FL SO-8FL / DFN-5
    NTMFS4925NE Power MOSFET 30V 48A 6.0mOhm Single N-Channel Thermally Enhanced SO-8FL   SO-8FL / DFN-5
    NTMFS4926N Power MOSFET 30V 44A  7 mOhm Single N-Channel SO-8FL SO-8FL / DFN-5
    NTMFS4926NE Power MOSFET 30V 44A 7.0mOhm Single N-Channel Thermally Enhanced SO-8FL   SO-8FL / DFN-5
    NTMFS4927N Power MOSFET 30V 38A 9mOhm Single N-Channel SO-8FL SO-8FL / DFN-5
    NTMFS4931N Power MOSFET 30V 246A 1.1 mOhm Single N-Channel SO-8FL SO-8FL / DFN-5
    NTMFS4933N Power MOSFET 30V 166A 1.2 mOhm Single N-Channel SO-8FL SO-8FL / DFN-5
    NTMFS4934N Power MOSFET 30V 147A 2mOhm Single N-Channel SO-8FL SO-8FL / DFN-5
    NTMFS4935N Power MOSFET 30V 93A 3.2 mOhm Single N-Channel SO-8FL SO-8FL / DFN-5
    NTMFS4936N Power MOSFET 30V 79A 4 mOhm Single N-Channel SO-8FL SO-8FL / DFN-5
    NTMFS4937N Power MOSFET 30V 70A 4.5 mOhm Single N-Channel SO-8FL SO-8FL / DFN-5
    NTMFS4939N Power MOSFET 30V 53A 5.5 mOhm Single N-Channel SO-8FL SO-8FL / DFN-5
    NTMFS4941N Power MOSFET 30V 47A 6.2 mOhm Single N-Channel SO-8FL SO-8FL / DFN-5
    NTMFS4943N Power MOSFET 30V 41A 7.2 mOhm Single N-Channel SO-8FL SO-8FL / DFN-5
    NTMFS4946N Power MOSFET 30V 100A 3.4 mOhm Single N-Channel SO-8FL SO-8FL / DFN-5
    NTMFS4955N Power MOSFET 30V 48A 6 mOhm Single N-Channel SO-8FL SO-8FL / DFN-5
    NTMFS4983NF Power MOSFET 30V 106A 2.1 mOhm Single N-Channel SO-8FL with Schottky Diode   SO-8FL / DFN-5
    NTMFS4985NF Power MOSFET 30V 65A 5 mOhm Single N-Channel SO-8FL with Schottky Diode   SO-8FL / DFN-5
    NTMFS4C05N Power MOSFET 30V 78A 3.4 mOhm Single N-Channel SO-8FL SO-8FL / DFN-5
    NTMFS4C06N Power MOSFET 30V 69A 4 mOhm Single N-Channel S0-8FL SO-8FL / DFN-5
    NTMFS4C08N Power MOSFET 30V 52A 5.8 mOhm Single N-Channel SO-8FL SO-8FL / DFN-5
    NTMFS4C09N Power MOSFET 30V 52A 5.8 mOhm Single N-Channel S0-8FL SO-8FL / DFN-5
    NTMFS4C10N Power MOSFET 30V 46A 6.95 mOhm Single N-Channel SO-8FL SO-8FL / DFN-5
    NTMFS4C13N Power MOSFET 30V 38A 9.1 mOhm Single N-Channel SO-8FL SO-8FL / DFN-5
    NTMFS5830NL Power MOSFET 40V 172A 2.3 mOhm Single N-Channel SO-8FL SO-8FL / DFN-5
    NTMFS5832NL Power MOSFET 40V 110A 4.2mOhm Single N-Channel S0-8 FL Logic Level SO-8FL / DFN-5
    NTMFS5834NL Power MOSFET 40V 74A 9.3mOhm Single N-Channel SO-8FL SO-8FL / DFN-5
    NTMFS5844NL Power MOSFET 60V 60A 12mOhm Single N-Channel SO-8FL Logic Level SO-8FL / DFN-5
    NTMS10P02 Power MOSFET 20V 10A 14 mOhm Single P-Channel SO-8 SOIC-8
    NTMS4177P Power MOSFET 30V 11.4 A 19 mOhm Single P-Channel SO-8 SOIC-8
    NTMS4503N Power MOSFET 28V 14A 7 mOhm Single N-Channel SO-8 SOIC-8
    NTMS4801N Power MOSFET 30V 9.9A 12.5 mOhm Single N-Channel SO-8 SOIC-8
    NTMS4807N Power MOSFET 30V 12.2A 6.1 mOhm Single N-Channel SO-8 SOIC-8
    NTMS4816N Power MOSFET 30V 9A 10 mOhm Single N-Channel SO-8 SOIC-8
    NTMS4916N Power MOSFET 30V 11.4A 9 mOhm Single N-Channel SO-8 SOIC-8
    NTMS4920N Power MOSFET 30V 17A 4.3 mOhm Single N-Channel SO-8 SOIC-8
    NTMS4937N Power MOSFET 30V 13.6A, 6.5 mOhm Single N-Channel SO-8 SOIC-8
    NTMS4939N Power MOSFET 30V 12.5A  8.4 mOhm Single N−Channel SO−8FL SOIC-8
    NTMS5835NL Power MOSFET 40V 12A 10mOhm Single N-Channel SO-8 SOIC-8
    NTMS5838NL Power MOSFET 40V 7.5A 25mOhm Single N-Channel SO-8 SOIC-8
    NTMS5P02 Power MOSFET 20V 5.4A 33 mOhm Single P-Channel SO-8 SOIC-8
    NTMS7N03R2 Power MOSFET 30V 7A  23 mOhm Single N-Channel SO-8 SOIC-8
    NTNS3193NZ Small Signal MOSFET 20V 230 mA 1.4 Ohm Single N−Channel XLLGA3 XLLGA-3
    NTNS3A65PZ Small Signal MOSFET 20V 281 mA 1.6 Ohm Single P−Channel SOT−883 SOT-883
    NTNS3A91PZ Small Signal MOSFET -20V -223mA 1.6 Ohm Single P−Channel XLLGA3 XLLGA-3
    NTNUS3171PZ Small Signal MOSFET 20V 140mA 3.5Ohm Single P-Channel SOT-1123 with ESD SOT-1123-3
    NTP2955 Power MOSFET 60V 12A 196 mOhm Single P-Channel TO-220 TO-220-3
    NTP5404N Power MOSFET 40V 167A, 4.5 mOhm Single N-Channel Power TO-220 TO-220-3
    NTP5860N Power MOSFET 60V 169A 3.0 mOhm Single N-Channel TO-220 TO-220-3
    NTP5860NL Power MOSFET 60V 169A 3 mOhm Single N-Channel TO-220 Logic Level TO-220-3
    NTP5863N Power MOSFET 60V 97A  7.8 mOhm Single N-Channel TO-220 TO-220-3
    NTP5864N Power MOSFET 60V 63A 12.4 mOhm Single N-Channel TO-220 TO-220-3
    NTP6410AN Power MOSFET 100V 76A 13 mOhm Single N-Channel TO-220 TO-220-3
    NTP6411AN Power MOSFET 100V 77A 14 mOhm Single N-Channel TO-220 TO-220-3
    NTP6412AN Power MOSFET 100V  58A 18.2 mOhm Single N-Channel TO-220 TO-220-3
    NTP6413AN Power MOSFET 100V 42A  28 mOhm Single N-Channel TO-220 TO-220-3
    NTR0202PL Small Signal MOSFET 20V 400mA 800 mOhm Single P-Channel SOT-23 Logic Level  SOT-23-3
    NTR1P02 Small Signal MOSFET 20V 1A 180 mOhm Single P-Channel SOT-23 SOT-23-3
    NTR1P02LT1 Small Signal MOSFET 20V 1.3A 220 mOhm Single P-Channel SOT-23 Logic Level  SOT-23-3
    NTR2101P Small Signal MOSFET 8V 3.7A 52 mOhm Single P-Channel SOT-23 SOT-23-3
    NTR4003N Small Signal MOSFET 30V 560 mA 1.5 Ohm Single N-Channel SOT-23 SOT-23-3
    NTR4101 Small Signal MOSFET 20V 3.2A 85 mOhm Single P-Channel SOT-23 SOT-23-3
    NTR4170N Power MOSFET 30V 4A 55 mOhm Single N-Channel SOT-23 SOT-23-3
    NTR4171P Power MOSFET 30V 3.5A 75 mOhm Single P-Channel SOT-23 SOT-23-3
    NTR4502P Power MOSFET 30V 1.95A 200 mOhm Single P-Channel SOT-23 SOT-23-3
    NTR4503N Small Signal MOSFET 30V 2A 140 mOhm Single N-Channel SOT-23 SOT-23-3
    NTS2101P Small Signal MOSFET 8V 1.4A 100 mOhm Single P-Channel SC-70 SC-70-3 / SOT-323-3
    NTS4001N Small Signal MOSFET 30V 270mA 1.5 Ohm Single N-Channel SC-70 SC-70-3 / SOT-323-3
    NTS4101P Small Signal MOSFET 20V 1.37A 120 mOhm Single P-Channel SC-70 SC-70-3 / SOT-323-3
    NTS4173P Small Signal MOSFET 30V 1.3A 150 mOhm Single P-Channel SC-70 SC-70-3 / SOT-323-3
    NTS4409NT1G Small Signal MOSFET 25V 750mA 350 mOhm Single N-Channel SC-70 ESD SC-70-3 / SOT-323-3
    NTTFS3A08PZ Power MOSFET 20V 15A 6.7 mOhm Single P-Channel u8FL u8FL / WDFN-8
    NTTFS4821N Power MOSFET 30V 57A 10.8 mOhm Single N-Channel u8FL u8FL / WDFN-8
    NTTFS4928N Power MOSFET 30V 37A 9 mOhm Single N-Channel u8FL u8FL / WDFN-8
    NTTFS4929N Power MOSFET 30V 34A  11 mOhm Single N Channel u8FL u8FL / WDFN-8
    NTTFS4930N Power MOSFET 30V 23A  23 mOhm Single N Channel u8FL u8FL / WDFN-8
    NTTFS4932N Power MOSFET 30V 79A 4 mOhm Single N-Channel u8FL u8FL / WDFN-8
    NTTFS4937N Power MOSFET 30V 75A  4.5 mOhm Single N-Channel u8FL u8FL / WDFN-8
    NTTFS4939N Power MOSFET 30V 56A 5.5 mOhm Single N-Channel u8FL u8FL / WDFN-8
    NTTFS4941N Power MOSFET 30V 46A 6.2 mOhm Single N-Channel u8FL u8FL / WDFN-8
    NTTFS4985NF Power MOSFET 30V 64A 5.2 mOhm Single N-Channel u8FL with Schottky Diode   u8FL / WDFN-8
    NTTFS4C05N Power MOSFET 30V 75A 3.6 mOhm Single N-Channel u8FL u8FL / WDFN-8
    NTTFS4C10N Power MOSFET 30V 44A 7.4 mOhm Single N-Channel u8FL u8FL / WDFN-8
    NTTFS4C25N Power MOSFET 30V 27A 17 mOhm Single N-Channel u8FL u8FL / WDFN-8
    NTTFS5116PL Power MOSFET 60V 20A 52mOhm Single P-Channel u8FL Logic Level u8FL / WDFN-8
    NTTFS5811NL Power MOSFET 40V 53A 6.4 mOhm Single N-Channel u8FL  u8FL / WDFN-8
    NTTFS5820NL Power MOSFET 60V 37A 11.5 mOhm Single N-Channel u8FL Logic Level u8FL / WDFN-8
    NTTFS5826NL Power MOSFET 60V 20A 24mOhm Single N-Channel u8FL Logic Level u8FL / WDFN-8
    NTUD3169CZ Small Signal MOSFET 20V 280 mA 1.5 Ohm Complementary SOT-963 ESD SOT-963
    NTUD3170NZ Small Signal MOSFET 20V 280 mA 1.5 Ohm Dual N-Channel SOT-963 SOT-963
    NTZD3152P Small Signal MOSFET 20V 430mA 900 mOhm Dual P-Channel SOT-563 ESD SOT-563
    NTZD3154N Small Signal MOSFET 20V 540 mA 550 mOhm Dual N-Channel SOT-563 ESD SOT-563
    NTZD3155C Small Signal MOSFET 20V 540 mA/ -430 mA 400 mOhm Complementary SOT-563 ESD SOT-563
    NTZD5110N Small Signal MOSFET 60V 310 mA 1.6 Ohm Dual N-Channel SOT-563 ESD SOT-563
    NTZS3151P Small Signal MOSFET 20V 950 mA 150 mOhm Single P-Channel SOT-563 SOT-563
    NUS5530MN Integrated Power 20V 3.9A 60 mOhm Dual P-Channel MOSFET DFN with PNP Low VCE Switching Transistor DFN-8
    NVB5860N Power MOSFET 60V 220A 3 mOhm Single N-Channel D2PAK D2PAK-3
    NVB5860NL Power MOSFET 60V 220A 3 mOhm Single N-Channel D2PAK Logic Level D2PAK-3
    NVD5117PL Power MOSFET 60V 61A 16 mOhm Single P−Channel DPAK Logic Level DPAK-3
    NVD5803N Power MOSFET 40V 85A 5.7 mOhm Single N-Channel DPAK DPAK-3
    NVD5862N Power MOSFET 60V 98A 5.7 mOhm Single N-Channel DPAK DPAK-3
    NVD5863NL Power MOSFET 60V 82A 7.1mOhm Single N-Channel DPAK Logic Level DPAK-3
    NVD5865NL Power MOSFET 60V 38A 16 mOhm Single N-Channel DPAK Logic Level DPAK-3
    NVD5867NL Power MOSFET 60V 22A 39 mOhm Single N-Channel DPAK Logic Level DPAK-3
    NVD5890N Power MOSFET 40V 123A 3.7mOhm Single N−Channel DPAK DPAK-3
    NVD5890NL Power MOSFET 40V 123A 3.7mOhm Single N-Channel DPAK Logic Level DPAK-3
    NVD6820NL Preferred Device: Power MOSFET 90V 50A 16.7 mOhm Single N-Channel DPAK  Logic Level DPAK-3
    NVD6824NL Power MOSFET 100V 41A 20 mOhm Single N-Channel DPAK Logic Level DPAK-3
    NVD6828NL Power MOSFET 90V 41A 20 mOhm Single N-Channel DPAK Logic Level DPAK-3
    NVMFD5852NL Power MOSFET 40V 44A  6.9 mOhm Dual N-Channel SO-8FL Logic Level SO-8FL Dual / DFN-8
    NVMFD5877NL Power MOSFET 60V 17A 39 mOhm Dual N-Channel SO-8FL Logic Level SO-8FL Dual / DFN-8
    NVMFS4841N Power MOSFET 30V 89A 7 mOhm Single N-Channel SO-8FL Logic Level SO-8FL / DFN-5
    NVMFS5826NL Power MOSFET 60V 26A 24 mOhm Single N-Channel SO-8FL Logic Level SO-8FL / DFN-5
    NVMFS5830NL Power MOSFET 40V 185A 2.3 mOhm Single N-Channel SO-8FL Logic Level SO-8FL / DFN-5
    NVMFS5832NL Power MOSFET 40V 120A  4.2 mOhm Single N−Channel SO-8FL Logic Level SO-8FL / DFN-5
    NVMFS5834NL Power MOSFET 40V 75 A 9.3 mOhm Single N-Channel SO-8FL Logic Level SO-8FL / DFN-5
    NVMFS5844NL Power MOSFET 60V 61A 12 mOhm Single N-Channel SO-8FL SO-8FL / DFN-5
    NVMFS5885NL Power MOSFET 60V 39A 15 mOhm Single N-Channel  SO-8FL Logic Level SO-8FL / DFN-5
    NVTFS4823N Power MOSFET 30V 30A 10.5 mOhm Single N-Channel u8FL u8FL / WDFN-8
    NVTFS4824N Power MOSFET 30V 49A 4.7 mOhm Single N-Channel u8FL u8FL / WDFN-8
    NVTFS5116PL Power MOSFET 60V 14A 52 mOhm Single P-Channel u8FL Logic Level u8FL / WDFN-8
    NVTFS5124PL Power MOSFET 60V 8A 260 mOhm Single P-Channel u8FL Logic Level u8FL / WDFN-8
    NVTFS5811NL Power MOSFET 40V 40A 6.7 mOhm Single N-Channel u8FL Logic Level u8FL / WDFN-8
    NVTFS5820NL Power MOSFET 60V 29A 11.5 mOhm Single N-Channel  u8FL Logic Level u8FL / WDFN-8
    NVTFS5826NL Power MOSFET 60V 20A 24 mOhm Single N-Channel u8FL Logic Level u8FL / WDFN-8
    SCH1330 Power MOSFET -20V -1.5A 241 mOhm Single P-Channel SCH6
    SCH1331 Power MOSFET -12V -3.0A 84 mOhm Single P-Channel SCH6
    SCH1332 Power MOSFET -20V -2.5A  215m Ohm Single P-Channel SCH6
    SCH1334 Small Signal MOSFET -12V -1.6A 215 mOhm Single P-Channel SCH6
    SCH1335 Small Signal MOSFET -12V -2.5A 112mOhm Single P-Channel SCH6
    SCH1337 Small Signal MOSFET 30V 2.4A 150 mOhm Single P-Channel SCH6
    SCH1430 Small Signal MOSFET 20V 2A 125mOhm Single N-Channel SCH6
    SCH1433 Small Signal MOSFET 20V 3.5A 64 mOhm Single N-Channel SCH6
    SCH1434 Small Signal MOSFET 30V 2A 165mOhm Single N-Channel SCH6
    SCH1435 Small Signal MOSFET 30V 3.0A 89 mOhm Single N-Channel SCH6
    SCH1436 Small Signal MOSFET 30V 1.8A 180mOhm Single N-Channel SCH6
    SCH1439 Power MOSFET 30V 3.5A 72mOhm Single N-Channel SCH6
    SCH2825 Small Signal MOSFET 30V 1.6A 180 mOhm Single N-Channel SCH6 with Schottky
    SFT1341 Power MOSFET -40V -10A 210 mOhm Single P-Channel TP/TP-FA
    SFT1342 Power MOSFET -60V -12A 96 mOhm Single P-Channel TP/TP-FA
    SFT1345 Power MOSFET -100V -11A 275 mohm P-Channel Single TP/TP-FA
    SFT1350 Power MOSFET -40V -19A 59 mOhm Single P-Channel TP/TP-FA
    SFT1423 Power MOSFET 500V 2A 5 Ohm Single N-Channel TP/TP-FA
    SFT1431 Power MOSFET 35V 11A 25 mOhm Single N-Channel TP/TP-FA
    SFT1440 Power MOSFET 600V 1.5A 8.1 Ohm Single N-Channel TP & TP-FA
    SFT1443 Power MOSFET 100V 9A  290 mOhm Single N-Channel TP/TP-FA D2PAK 3-LEAD
    SFT1445 Power MOSFET 100V 17A 111 mOhm Single N-Channel TP/TP-FA
    SFT1446 Power MOSFET 60V 20A 51 mOhm Single N-Channel TP
    SFT1450 Power MOSFET 40V  21A  28 mOhm Single N-Channel TP DPAK / TP-FA
    SMP3003 Power MOSFET -75V -100A  8 m Ohm Pch Single TO-263-2L D2PAK / TO-263-2L
    VEC2415 Small Signal MOSFET 60V 3A 80 mOhm Dual N-Channel VEC8
    VEC2616 Small Signal MOSFET 60V 3A 80 mOhm Complementary VEC8
    VN2222LL Small Signal MOSFET 60V 150mA 7.5 Ohm Single N-Channel TO-92 TO-92
    保护 MOSFET
    保护 MOSFET
    安森美半导体提供自我保护MOSFET,可能包含限流、限温、ESD保护或电流镜。
    保护MOSFET Excel 文档格式选型指南
    NCV8408 Self-Protected Low Side Driver with Temperature and Current Limit DPAK-3
    NCV8461 Self-Protected High Side Driver with Temperature Shutdown and Current Limit SOIC-8
    TND027SW Low Side Power Switch SOIC-8
    9N05A N-Channel, Logic Level, Clamped MOSFET w/ESD Protection DPAK-3
    NA-Bare Die
    MLD1N06CL Single N-Channel Power MOSFET with Voltage Clamp DPAK-3
    NCV8401A Self-Protected Low Side Driver with Temperature and Current Limit DPAK-3
    NCV8402A Self-Protected N-Channel Power MOSFET SOT-223-4 / TO-261-4
    NCV8402AD Dual Self-Protected N-Channel Power MOSFET SOIC-8
    NCV8403A Self-Protected Low Side Driver with Temperature and Current Limit DPAK-3
    NCV8405A Self-Protected Low Side Driver with Temperature and Current Limit DPAK-3
    NCV8406A Self-Protected Low Side Driver DPAK-3
    NCV8440A Self-Protected N-Channel MOSFET SOT-223-4 / TO-261-4
    NCV8450A Self Protected High Side Driver with Temperature and Current Limit SOT-223-4 / TO-261-4
    NCV8452 Self-Protected High Side Driver with Temperature Shutdown and Current Limit SOT-223-4 / TO-261-4
    NCV8460A Self-Protected High Side Driver SOIC-8
    NIMD6001A Dual N-Channel MOSFET Driver with Diagnostic Output SOIC-8
    c LED Shunt POWERMITE-2
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
