龙人旗下深圳市龙芯世纪科技有限公司
  • 数据开关
  • 发布时间:2013/9/9 10:50:58   修改时间:2013/9/9 10:50:58 浏览次数:1656
  • 数据开关
    模拟USB开关 – 高带宽模拟开关 – 总线开关
    安森美半导体提供通用及专用开关,用于USB、PCle、以太网、Display Port、MHL及UART。
    Product Datasheet Compliance Status Description Channels Number of Switches Configuration Icc Max (uA) ron Max (?) VCC Min (V) VCC Max (V) Package Type
    NCN7201 NCN7201/D (271.0kB) Pb-free
    Halide free
    ActiveNEW 2:1 Gigabit Ethernet LAN Switch with Power-down Feature 11 22 11PDT 450 6 3 3.6 WQFN-42
    74FST3257 74FST3257-D (128.0kB) Pb-free
    Halide free
    Active Quad 2:1 Multiplexer/Demultiplexer (Mux/Demux) Bus Switch 4 4 SPDT 3 4 4 5.5 QFN-16
    SOIC-16
    TSSOP-16
    7SB3125 7SB3125/D (141.0kB) Pb-free
    Halide free
    Active 1 Bit Bus Switch 1 1 SPST 2.5 6 4 5.5 SC-88A-5 / SC-70-5 / SOT-323-5
    TSOP-5 / SOT-23-5
    UDFN-6
    ULLGA-6
    7SB3126 7SB3126/D (141.0kB) Pb-free
    Halide free
    Active 1 Bit Bus Switch 1 1 SPST 1 6 4 5.5 SC-88A-5 / SC-70-5 / SOT-323-5
    TSOP-5 / SOT-23-5
    UDFN-6
    ULLGA-6
    7SB3257 7SB3257/D (141.0kB) Pb-free
    Halide free
    Active 1 Bit Mux / Demux Bus Switch 1 1 SPST 1 6 4 5.5 SC-88A-5 / SC-70-5 / SOT-323-5
    TSOP-5 / SOT-23-5
    UDFN-6
    ULLGA-6
    7SB384 7SB384/D (133.0kB) Pb-free
    Halide free
    TSOP-5 / SOT-23-5
    UDFN-6
    ULLGA-6
    7SB385 7SB385/D (133.0kB) Pb-free
    Halide free
    TSOP-5 / SOT-23-5
    UDFN-6
    ULLGA-6
    7WB3125 7WB3125/D (159.0kB) PPAP Capable
    Pb-free
    Halide free
    Active 2 Bit Bus Switch 2 2 SPST 1 6 4 5.5 UDFN-8
    ULLGA-8
    7WB3126 7WB3126/D (159.0kB) PPAP Capable
    Pb-free
    Halide free
    ULLGA-8
    7WB3305 7WB3305/D (159.0kB) PPAP Capable
    Pb-free
    Halide free
    ULLGA-8
    7WB3306 7WB3306/D (140.0kB) PPAP Capable
    Pb-free
    Halide free
    Active 2 Bit Bus Switch 2 2 SPST 1 6 4 5.5 TSSOP-8
    UDFN-8
    ULLGA-8
    7WB383 7WB383/D (163.0kB) Pb-free
    Halide free
    Active 2 Bit Bus Exchange Switch 2 2 SPDT 1 6 4 5.5 UDFN-8
    ULLGA-8
    7WBD3125 7WBD3125/D (163.0kB) Pb-free
    Halide free
    Active 2-Bit Translating Bus Switch 2 2 SPST 1 15 4 5.5 UDFN-8
    ULLGA-8
    UQFN-8
    US8
    7WBD3126 7WBD3126/D (163.0kB) Pb-free
    Halide free
    ULLGA-8
    UQFN-8
    US8
    7WBD3305 7WBD3305/D (163.0kB) Pb-free
    Halide free
    ULLGA-8
    UQFN-8
    US8
    7WBD3306 7WBD3306/D (175.0kB) Pb-free
    Halide free
    Active 2-Bit Translating Bus Switch 2 2 SPST 1 15 4 5.5 TSSOP-8
    UDFN-8
    ULLGA-8
    UQFN-8
    US8
    7WBD383 7WBD383/D (167.0kB) Pb-free
    Halide free
    Active 2-Bit Translating Bus Exchange Switch 2 2 SPDT 1 15 4 5.5 UDFN-8
    ULLGA-8
    UQFN-8
    US8
    NCN1154 NCN1154/D (414.0kB) Pb-free
    Halide free
    Active DP3T Data Switch, USB 2.0 High Speed / Audio, with Negative Swing Capability 2 6 DP3T 35 7.5 2.7 5 UQFN-12
    NCN1188 NCN1188/D (918.0kB) Pb-free
    Halide free
    Active Data Switch, 3:1 High Speed USB Switch with Audio and MHL Capability 2 6 DP3T 35 7.5 2.7 5.5 UQFN-12
    NCN2411 NCN2411/D (309.0kB) Pb-free
    Halide free
    Active 4-Channel Differential 1:2 Mux/Demux Switch for PCI Express Gen2 8 16 8PDT 300 13 1.5 2 WQFN-42
    NCN2612 NCN2612/D (121.0kB) Pb-free
    Halide free
    Active Data Switch, 6-Differential Channel 1:2 Switch for PCIe 2.0 and Display Port 1.1 12 24 12PDT 500 13 3 3.6 WQFN-56
    NCN2612B NCN2612B/D (404.0kB) Pb-free
    Halide free
    Active Data Switch, 6-Differential Channel 1:2 Switch for PCIe 2.0 and Display Port 1.1 12 24 12PDT 350 13 3 3.6 WQFN-56
    NCN3411 NCN3411/D (521.0kB) Pb-free
    Halide free
    Active Data Switch, 4-Channel Differential, 1:2 Mux/Demux, for PCI Express Gen3 8 16 8PDT 300 13 1.5 2 WQFN-42
    NCN3612B NCN3612B/D (625.0kB) Pb-free
    Halide free
    Active Data Switch, 6-Differential Channel 1:2 Switch for PCIe 3.0 and Display Port 1.2 12 24 12PDT 350 13 3 3.6 WQFN-56
    NCN7200 NCN7200/D (118.0kB) Pb-free
    Halide free
    Active Data Switch, Gigabit Ethernet LAN, with 2:1 Mux/ DeMux and Power-down Feature 11 22 11PDT 1500 16 3 3.6 WQFN-42
    NCN9252 NCN9252/D (356.0kB) Pb-free
    Halide free
    Active DP3T Data Switch, USB 2.0 High Speed (480 Mbps), USB/UART/Data Multiplexing 2 6 DP3T 1 6 1.65 4.5 UQFN-12
    NLAS3899 NLAS3899B/D (131.0kB) Pb-free
    Halide free
    Active Analog Switch, Dual DPDT, Low RON, Low Capacitance 4 8 DPDT 2 4 1.65 4.3
    4.4
    QFN-16
    NLAS4717 NLAS4717/D (118.0kB) Pb-free
    Halide free
    Active High Bandwidth USB 1.1 Dual SPDT Analog Switch  2 4 SPDT 1 4.5 1.8 5.5 Flip-Chip-10
    Micro10
    NLAS4717EP NLAS4717EP/D (133.0kB) Pb-free
    Halide free
    WQFN-10
    NLAS7213 NLAS7213/D (547.0kB) Pb-free
    Halide free
    Active DPST Analog Switch for High Speed USB 2.0 2 2 DPST 1 9 1.65 4.5 UQFN-8
    NLAS7222A NLAS7222A/D (199.0kB) Pb-free
    Halide free
    Active USB 2.0 DPDT Analog Switch with Enable 2 4 DPDT 4 9 3 3.6 UQFN-10
    WQFN-10
    NLAS7222B NLAS7222B (171.0kB) Pb-free
    Halide free
    Active USB 2.0, 4.5 V, DPDT Analog Switch with Enable 2 4 DPDT 1 8 1.65 4.5 UQFN-10
    NLAS7222C NLAS7222B (171.0kB) Pb-free
    Halide free
    Active USB 2.0 4.5V DPDT Analog Switch with Enable  and Flow Thru Pinout  2 4 DPDT 1 8 1.65 4.5 UQFN-10
    NLAS7242 NLAS7242/D (666.0kB) Pb-free
    Halide free
    Active High Speed USB 2.0 (480 Mbps) DPDT Analog Switch 2 4 DPDT 1 7.5 1.65 4.5 UQFN-10
    NLAS8252 NLAS8252/D (162.0kB) Pb-free
    Halide free
    Active DP3T Analog Switch for USB/UART/Data Multiplexing 2 6 DP3T 1 6 1.65 4.5 UQFN-12
    NS3L500 NS3L500/D (121.0kB) Pb-free
    Halide free
    Active 3V, 8-Channel, 2:1 Gigabit Ethernet LAN Switch with LED Switch 11 22 11PDT 600 7 3 3.6 WQFN-56
    NS5B1G384 NS5B1G384/D (117.0kB) Pb-free
    Halide free
    Active Single (NC) Normally Closed SPST Analog Switch 1 1 SPST 1 7 2 5.5 SC-88A-5 / SC-70-5 / SOT-323-5
    TSOP-5 / SOT-23-5
    NS5B1G385 NS5B1G385/D (138.0kB) Pb-free
    Halide free
    Active Single (NO) Normally Open SPST Analog Switch 1 1 SPST 1 7 2 5.5 SC-88A-5 / SC-70-5 / SOT-323-5
    TSOP-5 / SOT-23-5
    NS5S1153 NS5S1153/D (201.0kB) Pb-free
    Halide free
    Active DP2T USB 2.0 High Speed / Audio Switch with Negative Swing Capability 2 4 DPDT 35 4.6 2.7 5 UQFN-10
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
