龙人旗下深圳市龙芯世纪科技有限公司
  • 触发器、锁存器及寄存器
  • 发布时间:2013/9/9 10:56:46   修改时间:2013/9/9 10:58:16 浏览次数:2396
  • 触发器、锁存器及寄存器
    DFF - JKFF – 锁存器 – 寄存器 – 移位寄存器
    安森美半导体提供差分触发器(DFF)、锁存器、寄存器及移位寄存器。
    Product Datasheet Status Description Type Bits Input Level Output Level VCC Typ (V) tJitter Typ (ps) tpd Typ (ns) tsu Min (ns) th Min (ns) trec Typ (ns) tR & tF Max (ps) fToggle Typ (MHz) Package Type
    MC100E131 MC10E131/D (129.0kB) Active ECL 4-Bit D Flip-Flop D-Type 4 ECL ECL 5 1 0.5 0.15 0.175 0.4 480 1100 PLCC-28
    MC100E143 MC10E143/D (127.0kB) Active ECL 9-Bit Hold Register Register 9 ECL ECL 5 1 0.8 0.05 0.3 0.9 800   PLCC-28
    MC100E150 MC10E150/D (79.0kB) Active ECL 6-Bit D Latch Latch 6 ECL ECL 5 1 0.8 0.2 0.2 0.75 450 1000 PLCC-28
    MC100E151 MC10E151/D (127.0kB) Active ECL 6-Bit D Flip-Flop Register Register 6 ECL ECL 5 1 0.65 0.15 0.35 0.75 450 1100 PLCC-28
    MC100E175 MC10E175/D (80.0kB) Active ECL 9-Bit Latch With Parity Latch 9 ECL ECL 5 1 0.6 0.275 0.175 0.85 800 1000 PLCC-28
    MC100E241 MC100E241/D (125.0kB) Active 5.0 V ECL 8-Bit Scannable Register Shift Register 8 ECL ECL 5 1 0.75 0.175 0.2 0.9 800   PLCC-28
    MC100E431 MC10E431/D (133.0kB) Active ECL 3-Bit Differential D Flip-Flop D-Type 3 ECL ECL 5 1 0.6 0.2 0.2 0.4 650 1100 PLCC-28
    MC100E451 MC10E451/D (134.0kB) Active 5.0 V ECL 6-Bit Differential Register Register 6 ECL ECL 5 1 0.65 0.15 0.35 0.75 800   PLCC-28
    MC100E452 MC10E452/D (135.0kB) Active 5.0 V ECL 5-Bit Differential Register Register 5 ECL ECL 5 1 0.6 0.175 0.225 0.75 650   PLCC-28
    MC100EL29 MC100EL29/D (116.0kB) Active 5.0 V ECL Dual Differential Clock / Data D Flip-Flop With Set and Reset D-Type 2 ECL ECL 5 1 0.58 0 0.1 0.1 550 1100 SOIC-20W
    LVDS
    MC100EL30 MC100EL30/D (130.0kB) Active ECL Triple D Flip-Flop with Set and Reset D-Type 3 ECL ECL 5 1 0.45 0.15 0.2 0.4 550 1200 SOIC-20W
    MC100EL31 MC10EL31/D (131.0kB) Active ECL D Flip-Flop with Set and Reset D-Type 1 ECL ECL 5 1 0.475 0.15 0.25 0.4 350 2800 SOIC-8
    TSSOP-8
    MC100EL35 MC10EL35/D (134.0kB) Active ECL JK Flip-Flop JK-Type 1 ECL ECL 5 1 0.252 0.15 0.25 0.4 350 2200 DFN-8
    0.525 SOIC-8
      TSSOP-8
    MC100EL51 MC10EL51/D (143.0kB) Active ECL  Differential Clock/Data D Flip-Flop D-Type 1 ECL ECL 5 1 0.475 0.15 0.25 0.4 350 2800 SOIC-8
    TSSOP-8
    MC100EL52 MC10EL52/D (144.0kB) Active ECL  Differential Clock/Data D Flip-Flop D-Type 1 ECL ECL 5 1 0.365 0.125 0.15   350 2800 SOIC-8
    TSSOP-8
    MC100EP131 MC10EP131/D (164.0kB) Active Quad D Flip-Flop with Set, Reset, and Differential Clock D-Type 4 CML ECL 3.3 0.2 0.46 0.12 0.12 0.29 290 3000 LQFP-32
    ECL 5 QFN-32
    MC100EP142 MC10EP142/D (176.0kB) Active ECL 9-Bit Shift Register Shift Register 9 CML ECL 3.3 1 0.675 0.05 0.1 0.8 275 2800 LQFP-32
    ECL 5 QFN-32
    MC100EP29 MC10EP29/D (175.0kB) Active ECL Dual Differential Clock/Data D Flip-Flop With Set and Reset D-Type 2 CML ECL 3.3 0.2 0.42 0.1 0.1 0.15 300 3000 QFN-20
    ECL 5 TSSOP-20
    MC100EP31 MC10EP31/D (139.0kB) Active ECL D Flip-Flop with Set and Reset D-Type 1 CML ECL 3.3 0.2 0.34 0.1 0.15 0.225 200 3000 DFN-8
    ECL 5 SOIC-8
        TSSOP-8
    MC100EP35 MC10EP35/D (137.0kB) Active ECL JK Flip-Flop JK-Type 1 CML ECL 3.3 0.2 0.41 0.15 0.15 0.15 180 3000 DFN-8
    ECL 5 SOIC-8
        TSSOP-8
    MC100EP451 MC10EP451/D (159.0kB) Active 3.3 V / 5.0 V ECL 6-Bit Differential Register with Master Reset Register 6 CML ECL 3.3 0.2 0.45 0.08 0.08 0.25 260 3000 LQFP-32
    ECL 5 QFN-32
    MC100EP51 MC10EP51/D (150.0kB) Active ECL D Flip-Flop with Reset and Differential Clock D-Type 1 CML ECL 3.3 0.2 0.37 0.1 0.1 0.15 180 3000 DFN-8
    ECL 5 SOIC-8
        TSSOP-8
    MC100EP52 MC10EP52/D (152.0kB) Active ECL Differential Clock/Data D Flip-Flop D-Type 1 CML ECL 3.3 0.2 0.33 0.05 0   180 4000 DFN-8
    ECL 5 SOIC-8
        TSSOP-8
    MC100LVEL29 MC100LVEL29/D (133.0kB) Active ECL Dual Differential Clock/Data D Flip-Flop with Set and Reset D-Type 2 ECL ECL 3.3 1 0.58 0 0.1 0.1 550 1100 SOIC-20W
    LVDS
    MC100LVEL30 MC100LVEL30/D (113.0kB) Active ECL Triple D-Type Flip-Flop with Set and Reset D-Type 3 ECL ECL 3.3 1 0.45 0.15 0.2 0.4 550 1200 SOIC-20W
    MC100LVEL31 MC100LVEL31/D (127.0kB) Active ECL D Flip-Flop with Set and Reset D-Type 1 ECL ECL 3.3 1 0.475 0.15 0.25 0.4 320 2900 SOIC-8
    TSSOP-8
    MC100LVEL51 MC100LVEL51/D (128.0kB) Active ECL Differential Clock D Flip-Flop D-Type 1 ECL ECL 3.3 1 0.475 0.15 0.25 0.35 320 2800 DFN-8
    SOIC-8
    TSSOP-8
    MC10E131 MC10E131/D (129.0kB) Active ECL 4-Bit D Flip-Flop D-Type 4 ECL ECL 5 1 0.5 0.15 0.175 0.4 480 1100 PLCC-28
    MC10E141 MC10E141/D (129.0kB) Active ECL 8-Bit Shift Register Shift Register 8 ECL ECL 5 1 0.75 0.175 0.2 0.9 800 700 PLCC-28
    MC10E142 MC10E142/D (150.0kB) Active ECL 9-Bit Shift Register Shift Register 9 ECL ECL 5 1 0.8 0.05 0.3 0.9 800   PLCC-28
    MC10E143 MC10E143/D (127.0kB) Active 5.0 V ECL 9-Bit Hold Register Register 9 ECL ECL 5 1 0.8 0.05 0.3 0.9 800   PLCC-28
    MC10E150 MC10E150/D (79.0kB) Active ECL 6-Bit D Latch Latch 6 ECL ECL -5.2 1 0.8 0.2 0.2 0.75 450 900 PLCC-28
    MC10E151 MC10E151/D (127.0kB) Active ECL 6-Bit D Register Register 6 ECL ECL 5 1 0.65 0.15 0.35 0.75 450 1100 PLCC-28
    MC10E175 MC10E175/D (80.0kB) Active 5.0 V ECL 9-Bit Latch With Parity Latch 9 ECL ECL -5.2 1 0.6 0.275 0.175 0.85 800 1100 PLCC-28
    MC10E431 MC10E431/D (133.0kB) Active ECL 3-Bit Differential Flip-Flop D-Type 3 CML ECL 5 1 0.6 0.2 0.2 0.4 650 1100 PLCC-28
    ECL
    MC10E451 MC10E451/D (134.0kB) Active 5.0 V ECL 6-Bit D Register Differential Data and Clock Register 6 ECL ECL 5 1 0.65 0.15 0.35 0.75 800   PLCC-28
    MC10E452 MC10E452/D (135.0kB) Active 5.0 V ECL 5-Bit Differential Register Register 5 ECL ECL 5 1 0.6 0.175 0.225 0.75 650   PLCC-28
    MC10EL31 MC10EL31/D (131.0kB) Active 5.0 V ECL D Flip-Flop with Set and Reset D-Type 1 ECL ECL 5 1 0.475 0.15 0.25 0.4 350 2800 SOIC-8
    TSSOP-8
    MC10EL35 MC10EL35/D (134.0kB) Active 5.0 V ECL JK Flip-Flop JK-Type 1 ECL ECL 5 1 0.525 0.15 0.25 0.4 350 2200 SOIC-8
    TSSOP-8
    MC10EL51 MC10EL51/D (143.0kB) Active 5.0 V ECL Differential Clock/Data D Flip-Flop D-Type 1 ECL ECL 5 1 0.475 0.15 0.25 0.4 350 2800 SOIC-8
    TSSOP-8
    MC10EL52 MC10EL52/D (144.0kB) Active 5.0 V ECL  Differential Clock/Data D Flip-Flop D-Type 1 ECL ECL 5 1 0.365 0.125 0.15   350 2800 SOIC-8
    TSSOP-8
    MC10EP131 MC10EP131/D (164.0kB) Active 3.3 V / 5.0 V ECL Quad D Flip-Flop with Set, Reset, and Differential Clock D-Type 4 CML ECL 3.3 0.2 0.46 0.12 0.12 0.29 290 3000 LQFP-32
    ECL 5 QFN-32
    MC10EP142 MC10EP142/D (176.0kB) Active 3.3 V / 5.0 V ECL 9-Bit Shift Register Shift Register 9 CML ECL 3.3 1 0.675 0.05 0.1 0.8 275 2800 LQFP-32
    ECL 5 QFN-32
    MC10EP29 MC10EP29/D (175.0kB) Active 3.3 V / 5.0 V ECL Dual Differential Clock/Data D Flip-Flop With Set and Reset D-Type 2 CML ECL 3.3 0.2 0.42 0.1 0.1 0.15 300 3000 QFN-20
    ECL 5 TSSOP-20
    MC10EP31 MC10EP31/D (139.0kB) Active 3.3 V / 5.0 V ECL D Flip-Flop with Set and Reset D-Type 1 CML ECL 3.3 0.2 0.34 0.1 0.15 0.225 200 3000 DFN-8
    ECL 5 SOIC-8
        TSSOP-8
    MC10EP35 MC10EP35/D (137.0kB) Active 3.3 V / 5.0 V ECL JK Flip-Flop JK-Type 1 CML ECL 3.3 0.2 0.41 0.15 0.15 0.15 180 3000 SOIC-8
    ECL 5 TSSOP-8
    MC10EP451 MC10EP451/D (159.0kB) Active 3.3 V / 5.0 V ECL 6-Bit Differential Register with Master Reset Register 6 CML ECL 3.3 0.2 0.45 0.08 0.08 0.25 260 3000 LQFP-32
    ECL 5 QFN-32
    MC10EP51 MC10EP51/D (150.0kB) Active 3.3 V / 5.0 V ECL D Flip-Flop with Reset and Differential Clock D-Type 1 CML ECL 3.3 0.2 0.375 0.1 0.1 0.15 180 3000 DFN-8
    ECL 5 SOIC-8
        TSSOP-8
    MC10EP52 MC10EP52/D (152.0kB) Active 3.3 V / 5.0 V ECL Differential Clock/Data D Flip-Flop D-Type 1 CML ECL 3.3 1 0.33 0.05 0   180 4000 DFN-8
    ECL 5 SOIC-8
        TSSOP-8
    MC10H131 MC10H131/D (153.0kB) Active Dual Type Master-Slave D Flip-Flop D-Type 2 ECL ECL -5.2   1 0.7 0.8   2000 250 PDIP-16
    PLLC-20
    MC10H135 MC10H135/D (154.0kB) Active Dual  Master-Slave JK Flip-Flop JK-Type 2 ECL ECL -5.2   1.5 1.5 1   2200 250 PDIP-16
    PLLC-20
    MC10H141 MC10H141/D (149.0kB) Active 4-Bit Universal Shift Register Shift Register 4 ECL ECL -5.2   1.5 1.5 1   2400 250 PDIP-16
    PLLC-20
    MC10H176 MC10H176/D (153.0kB) Active Hex Master-Slave D Flip-Flop D-Type 6 ECL ECL -5.2   1.7 1.5 0.9   1900 250 PDIP-16
    PLLC-20
    NB4L52 NB4L52/D (143.0kB) Active 2.5 to 5.5 V ECL D Flip-flop w/Differential Reset & Input Termination D-Type 1 CML ECL 2.5 1 0.33 0.1 0.05 0.4 200 4000 QFN-16
    CMOS 3.3
    ECL 5
    LVDS
    NB7V52M NB7V52M/D (151.0kB) Active D Flip Flop, 1.8 V / 2.5 V Differential, with Reset and CML Outputs D-Type 1 CML CML 1.8 0.2 0.2 0.04 0.05   35 10000 QFN-16
    ECL 2.5
    LVDS
    NBSG53A NBSG53A/D (215.0kB) Active 2.5 V / 3.3 V Selectable Differential Clock / Data D Flip-Flop / Clock Divider with Reset and OLS D-Type 1 CML ECL 2.5 0.5 0.215 0.03 0.025 0.009 60 10000 QFN-16
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
