龙人旗下深圳市龙芯世纪科技有限公司
  • Skew管理器 串并转换器 转换器
  • 发布时间:2013/9/9 10:59:55   修改时间:2013/9/9 10:59:55 浏览次数:1750
  • Skew管理器
    可编程延迟线路
    安森美半导体提供用于歪曲率管理的延迟线路。
    Product Compliance Status Description Input Level Output Level VCC Typ (V) fMax Typ (MHz) td(prog) Min (ns) td(prog) Max (ns) td(step) Typ (ps) tJitter Typ (ps) tR & tF Max (ps) Package Type
    NB3L02 Pb-free ActiveNEW 2.8 V, High Precision 1:2 Clock Fanout Buffer      2.8 26         800 WLCSP6 1.17x0.77 (200um bumps)
    Halide free
    MC100E195 Pb-free Active ECL Programmable Delay Chip ECL ECL 5 1000 2.05 2.6 20 5 325 PLCC-28
    Halide free
    MC100E196 Pb-free Active ECL Programmable Delay Chip ECL ECL 5 1000 2.05 2.6 20 5 325 PLCC-28
    Halide free
    MC100EP195 Pb-free Active 3.3 V ECL Programmable Delay Chip CML ECL 3.3 1200 2.2 12.2 10 1 300 LQFP-32
    Halide free ECL QFN-32
    MC100EP195B Pb-free Active 3.3 V ECL Programmable Delay Chip CML ECL 3.3 1200 2.2 12 10 3 300 LQFP-32
      LVDS
    MC100EP196 Pb-free Active 3.3 V ECL Programmable Delay Chip CML ECL 3.3 1200 2.2 12.2 10 3 210 LQFP-32
    Halide free ECL
    MC100EP196B Pb-free Active 3.3 V ECL Programmable Delay Chip with FTUNE CML ECL 3.3 1200 8.95 12.11 11 1.2 165 LQFP-32
      LVDS
    MC10E195 Pb-free Active 5.0 V ECL Programmable Delay Chip ECL ECL 3.3 1000 2.05 2.6 20 5 325 PLCC-28
    Halide free
    MC10E196 Pb-free Active 5.0 V ECL Programmable Delay Chip ECL ECL 3.3 1000 2.05 2.6 20 5 325 PLCC-28
    Halide free
    MC10EP195 Pb-free Active 3.3 V ECL Programmable Delay Chip CML ECL 3.3 1200 2.2 12.2 10 3 300 LQFP-32
    NB6L295 Pb-free Active Dual Channel Programmable Delay Line with LVPECL Output CML ECL 2.5 1500 6.2 6.2 11 3 150 QFN-24
    Halide free ECL 3.3
      LVDS
    NB6L295M Pb-free Active Dual Channel Programmable Delay Line with CML Output CML CML 2.5 1500 6.2 6.2 11 2.4 150 QFN-24
    串并转换器
    串行转换器 – 并行转换器
    安森美半导体提供差分并行至串行及串行至并行转换器。
    Product Datasheet Compliance Status Description Bits Input Level Output Level VCC Typ (V) fdr Typ (Gb/sec) tpd Typ (ns) tsu Min (ns) th Min (ns) tJitter Typ (ps) tR & tF Max (ps) Package Type
    MC100E446 MC10E446/D (147.0kB) Pb-free
    Halide free
    Active 5.0 V ECL 4-Bit Parallel/Serial Converter 4 ECL ECL 5 1.6 1.2 -0.45 0.65 1 350 PLCC-28
    MC100EP445 MC10EP445/D (188.0kB) Pb-free
    Halide free
    Active Serial / Parallel Converter, 3.3 V / 5 V, 8-bit ECL 8 CML
    ECL
    ECL 3.3
    5
    2.5 1.3 -0.4 0.6 0.2 300 LQFP-32
    QFN-32
    MC100EP446 MC10EP446/D (240.0kB) Pb-free
    Halide free
    Active Serial / Parallel Converter, 3.3 V / 5 V, 8-Bit, CMOS / ECL / TTL Data Input 8 CML
    ECL
    ECL 3.3
    5
    3.4 0.8 -0.45 -0.6 0.2 170 LQFP-32
    QFN-32
    MC10E446 MC10E446/D (147.0kB) Pb-free
    Halide free
    Active 5.0 V ECL 4-Bit Parallel/Serial Converter 4 ECL ECL 5 2 1.8 -0.25 0.3 1 350 PLCC-28
    MC10EP445 MC10EP445/D (188.0kB) Pb-free
    Halide free
    Active 3.3 V / 5.0 V ECL 8-Bit Serial/Parallel Converter 8 CML
    ECL
    ECL 3.3
    5
    MC10EP446 MC10EP446/D (240.0kB) Pb-free
    Halide free
    Active 3.3 V / 5.0 V ECL 8-Bit Differential Parallel/Serial Converter 8 CML
    ECL
    ECL 3.3
    5
    QFN-32
    转换器
    逻辑电平转换器
    安森美半导体提供差分逻辑电平转换器,可连接至ECL、PECL、CML、LVDS、HSTL、HCSL、TTL及CMOS器件
    Product Datasheet Compliance Status Description Channels Input Level Output Level VCC Typ (V) fMax Typ (MHz) tpd Typ (ns) tR & tF Max (ps) Package Type
    MC100EL90 MC100EL90/D (111.0kB) Pb-free
    Halide free
    Active Translator, Triple ECL Input to PECL Output 3 ECL ECL 5 650 0.5 500 SOIC-20W
    MC100EL91 MC100EL91/D (132.0kB) Pb-free
    Halide free
    Active Triple LVPECL/PECL Input to -5.0 V ECL Output Translator 3 ECL ECL 5 700 0.67 400 SOIC-20W
    MC100ELT20 MC10ELT20/D (127.0kB) Pb-free
    Halide free
    Active Translator, TTL to Differential PECL  1 TTL ECL 5 100 1.2 1500 SOIC-8
    TSSOP-8
    MC100ELT21 MC10ELT21/D (129.0kB) Pb-free
    Halide free
    Active Translator, Differential PECL to TTL 1 ECL TTL 5 100 3.5 750 SOIC-8
    TSSOP-8
    MC100ELT22 MC10ELT22/D (117.0kB) Pb-free
    Halide free
    Active Translator, Dual TTL to Differential PECL 2 TTL ECL 5 100 1.2 1600 SOIC-8
    TSSOP-8
    MC100ELT23 MC100ELT23/D (144.0kB) Pb-free
    Halide free
    Active Translator, Dual Differential PECL to TTL 2 ECL TTL 5 100 3.5 1600 SOIC-8
    TSSOP-8
    MC100ELT24 MC10ELT24/D (127.0kB) Pb-free
    Halide free
    Active Translator, TTL to Differential ECL  1 TTL ECL 5 400 0.95 1250 DFN-8
    SOIC-8
    TSSOP-8
    MC100ELT25 MC10ELT25/D (131.0kB) Pb-free
    Halide free
    Active Translator, Differential ECL to TTL 1 ECL TTL 5 100 2.6 2300 DFN-8
    SOIC-8
    TSSOP-8
    MC100ELT28 MC10ELT28/D (132.0kB) Pb-free
    Halide free
    Active Translator, TTL to Differential PECL and Differential PECL to TTL 2 ECL
    TTL
    ECL
    TTL
    TSSOP-8
    MC100EP90 MC10EP90/D (136.0kB) Pb-free
    Halide free
    Active Translator, Triple ECL Input to LVPECL / PECL Output 3 ECL ECL 3.3
    5
    3000 0.26 180 TSSOP-20
    MC100EP91 MC100EP91/D (136.0kB) Pb-free
    Halide free
    Active PECL to NECL Translator 3 CML
    CMOS
    ECL
    LVDS
    TTL
    ECL 3.3 2 0.55 150 QFN-24
    SOIC-20W
    MC100EPT20 MC10EPT20/D (126.0kB) Pb-free
    Halide free
    Active Translator, LVTTL / LVCMOS to Differential LVPECL 1 CMOS
    TTL
    ECL 3.3 1000 0.37 180 DFN-8
    SOIC-8
    TSSOP-8
    MC100EPT21 MC100EPT21/D (127.0kB) Pb-free
    Halide free
    Active Translator, Differential LVPECL to LVTTL 1 CML
    ECL
    LVDS
    TTL 3.3 350 1.4 500 DFN-8
    SOIC-8
    TSSOP-8
    MC100EPT22 MC100EPT22/D (327.0kB) Pb-free
    Halide free
    Active Translator, Dual LVTTL / LVCMOS to Differential LVPECL 2 CMOS
    TTL
    ECL 3.3 1100 0.42 220 DFN-8
    SOIC-8
    TSSOP-8
    MC100EPT23 MC100EPT23/D (123.0kB) Pb-free
    Halide free
    Active Translator, Dual Differential LVPECL to LVTTL 2 CML
    ECL
    LVDS
    TTL 3.3 350 1.5 600 DFN-8
    SOIC-8
    TSSOP-8
    MC100EPT24 MC100EPT24/D (127.0kB) Pb-free
    Halide free
    Active Translator, LVTTL / LVCMOS to Differential LVECL 1 CMOS
    TTL
    ECL 3.3 1000 0.53 180 DFN-8
    SOIC-8
    TSSOP-8
    MC100EPT25 MC100EPT25/D (130.0kB) Pb-free
    Halide free
    Active Translator, Differential LVECL / ECL to LVTTL 1 ECL TTL 3.3 275 1.1 1100 DFN-8
    SOIC-8
    TSSOP-8
    MC100EPT26 MC100EPT26/D (157.0kB) Pb-free
    Halide free
    Active Translator, 1:2 Fanout Differential LVPECL / LVDS to LVTTL 1 ECL TTL 3.3 275 1.5 900 DFN-8
    SOIC-8
    TSSOP-8
    MC100EPT622 MC100EPT622/D (131.0kB) Pb-free
    Halide free
    Active Translator, 10-bit LVTTL / LVCMOS to LVPECL 10 CMOS
    TTL
    ECL 3.3 1500 0.45 250 LQFP-32
    QFN-32
    MC100LVEL90 MC100LVEL90/D (112.0kB) Pb-free
    Halide free
    Active Translator, Triple ECL Input to LVPECL Output 3 ECL ECL 3.3 650 0.5 500 SOIC-20W
    MC100LVEL91 MC100LVEL91/D (125.0kB) Pb-free
    Halide free
    Active Translator, Triple LVPECL / PECL Input to ECL Output 3 ECL ECL 3.3
    5
    600 0.62 580 SOIC-20W
    MC100LVEL92 MC100LVEL92/D (129.0kB) Pb-free
    Halide free
    Active Translator, Triple PECL Input to LVPECL Output 3 ECL ECL 3.3 600 0.61 580 SOIC-20W
    MC100LVELT20 MC100LVELT20/D (101.0kB) Pb-free
    Halide free
    Active LVTTL/LVCMOS to Differential LVPECL Translator 1 CMOS
    TTL
    ECL 3.3 1000 0.37 180 SOIC-8
    MC100LVELT22 MC100LVELT22/D (145.0kB) Pb-free
    Halide free
    TTL
    ECL 3.3 2000 0.35 500 DFN-8
    SOIC-8
    TSSOP-8
    MC100LVELT23 MC100LVELT23/D (127.0kB) Pb-free
    Halide free
    Active Translator, Dual Differential LVPECL to LVTTL 2 ECL TTL 3.3 180 1.7 600 DFN-8
    SOIC-8
    TSSOP-8
    MC10ELT20 MC10ELT20/D (127.0kB) Pb-free
    Halide free
    TSSOP-8
    MC10ELT21 MC10ELT21/D (129.0kB) Pb-free
    Halide free
    TSSOP-8
    MC10ELT22 MC10ELT22/D (117.0kB) Pb-free
    Halide free
    TSSOP-8
    MC10ELT24 MC10ELT24/D (127.0kB) Pb-free
    Halide free
    Active TTL to Differential ECL Translator 1 TTL ECL 5 400 0.95 1250 SOIC-8
    TSSOP-8
    MC10ELT25 MC10ELT25/D (131.0kB) Pb-free
    Halide free
    Active Translator, Differential ECL to TTL 1 ECL TTL 5 100 2.6 2300 SOIC-8
    TSSOP-8
    MC10ELT28 MC10ELT28/D (132.0kB) Pb-free
    Halide free
    TTL
    ECL
    TTL
    TSSOP-8
    MC10EP90 MC10EP90/D (136.0kB) Pb-free
    Halide free
    5
    MC10EPT20 MC10EPT20/D (126.0kB) Pb-free
    Halide free
    TTL
    SOIC-8
    TSSOP-8
    MC10H124 MC10H124/D (133.0kB) Pb-free
    Halide free
    Active Quad TTL to ECL Translator 4 TTL ECL 5 50 1.6 1600 PDIP-16
    PLLC-20
    MC10H125 MC10H125/D (156.0kB) Pb-free
    Halide free
    Active Quad ECL to TTL Translator 4 ECL TTL 5 50 1200 PDIP-16
    PLLC-20
    MC10H350 MC10H350/D (106.0kB) Pb-free
    Halide free
    Active PECL to TTL Translator 4 ECL TTL 5 50 3.5 1600 PDIP-16
    PLLC-20
    MC10H351 MC10H351/D (105.0kB) Pb-free
    Halide free
    Active TTL, NMOS to ECL Translator 4 TTL ECL 5 1.3 2000 PLLC-20
    MC10H600 MC10H600/D (110.0kB) Pb-free
    Halide free
    Active 9-Bit TTL-ECL Translator 1 TTL ECL 5 1500 PLCC-28
    MC10H601 MC10H601/D (110.0kB) Pb-free
    Halide free
    Active 9-Bit ECL-TTL Translator 1 ECL TTL 5 3.45 1500
    3000
    PLCC-28
    MC10H602 MC10H602/D (112.0kB) Pb-free
    Halide free
    Active 9-Bit Latch/TTL-ECL Translator 1 TTL ECL 5 1500 PLCC-28
    MC10H604 MC10H604/D (132.0kB) Pb-free
    Halide free
    Active Registered Hex TTL/ECL Translator 6 TTL ECL 5 2000 PLCC-28
    MC10H605 MC10H605/D (137.0kB) Pb-free
    Halide free
    Active REG Hex ECL/TTL Translator 6 ECL TTL 5 5.2 1500 PLCC-28
    NB100ELT23L NB100ELT23L/D (125.0kB) Pb-free
    Halide free
    Active Translator, Dual Differential LVPECL to LVTTL  2 ECL TTL 3.3 275 2.1 1300 SOIC-8
    TSSOP-8
    NB100LVEP91 NB100LVEP91/D (155.0kB) Pb-free
    Halide free
    Active Translator, AnyLevel™ Positive Input to NECL Output Voltage 3 CML
    HSTL
    LVDS
    ECL 2.5
    3.3
    2500 0.43 250 QFN-24
    SOIC-20W
    NLSX4302E NLSX4302E/D (166.0kB) Pb-free
    Halide free
    Active DUAL-SUPPLY LEVEL TRANSLA 2 CMOS CMOS 3.3 25 4 10 UQFN-8
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
