龙人旗下深圳市龙芯世纪科技有限公司
  • 环境光传感器 CMOS图像传感器 接触式图像传感器模块
  • 发布时间:2013/9/9 11:01:15   修改时间:2013/9/9 11:01:15 浏览次数:1984
  • 环境光传感器
    环境光传感器
    安森美半导体提供带暗电流补偿的环境光传感器
    Product Datasheet Compliance Status Description IOTyp  (μA) Output Interface Vin Min (V) Vin Max (V) TA Min (°C) TA Max (°C) Package Type
    NOA1305 NOA1305/D (273.0kB) Pb-free
    Halide free
    Product Preview Ambient Light Sensor I2C 2.4 3.6 -40 85 CUDFN-6
    LA0151CS LA0151CS/D (150.0kB) Pb-free Active Ambient Light Sensor with 2-Stage Gain Switching, Linear Current Output 1.6
    80
    Analog 2.2 5.5 -30 85 ODCSP-4
    LA0152CS LA0152CS/D (236.0kB) Pb-free
    Halide free
    Active Ambient Light Sensor with Standby Function, Linear Current Output 8
    80
    LV0104CS ENA2079/D (500.0kB) Pb-free
    Halide free
    Active Digital Ambient Light Sensor I2C 2.3 3.6 -30 85 ODCSP-4
    LV0111CF LV0111CF/D (179.0kB) Pb-free
    Halide free
    Active Ambient Light Sensor with Standby Function, Logarithmic Current Output 21 Analog 2.3 5.5 -30 85 ODCSP-4J
    NOA1211 NOA1211/D (137.0kB) Pb-free
    Halide free
    Active Ambient Light Sensor with Dark Current Compensation 14 Analog 2 5.5 -40 85 CUDFN-6
    NOA1212 NOA1212/D (147.0kB) Pb-free
    Halide free
    Active Ambient Light Sensor with Dark Current Compensation 64 Analog 2 5.5 -40 85 CUDFN-6
    NOA3301 NOA3301/D (653.0kB) Pb-free
    Halide free
    Active Ambient Light Sensor + Proximity Sensor I2C 2.3 3.6 -40 80 CUDFN-8
    NOA3302 NOA3302/D (317.0kB) Pb-free
    Halide free
    Active Ambient Light Sensor + Proximity Sensor I2C 2.3 3.6 -40 80 CWDFN-8
    CMOS图像传感器
    CMOS图像传感器
    安森美半导体提供CMOS有源像素传感器,用于数码摄影、大区域及超高速传感器、机器视觉、条形码成像及医疗成像。
    Product Datasheet Compliance Status Description Megapixels Frame Rate (fps) Optical Format Shutter Type Pixel Size (μm) Color Package Type
    IBIS4-6600 NOII4SM6600A/D (642.0kB) Pb-free
    Halide free
    Active 6.6 Megapixel CMOS Image Sensor 6.6 5 1 inch Rolling 3.5 x 3.5 Mono LCC-68
    LUPA1300-2 NOIL2SM1300A/D (785.0kB) Pb-free
    Halide free
    Active High Speed CMOS Image Sensor 1.3 500 1 inch Pipelined and Triggered Global 14 x 14 Color
    Mono
    CPGA-168
    LUPA300 NOIL1SM0300A/D (446.0kB) Pb-free
    Halide free
    Active CMOS Image Sensor 0.3 250 1/2 inch Pipelined and Triggered Global 9.9 x 9.9 Color
    Mono
    LCC-48
    NA-Wafer
    LUPA3000 NOIL1SN3000A/D (916.0kB) Pb-free
    Halide free
    Active 485 FPS,13.3 Gb High Speed Image Sensor 3 485 1 inch Pipelined and Triggered Global 8.0 x 8.0 Color
    Mono
    CPGA-369
    LUPA4000 NOIL1SM4000A/D (508.0kB) Pb-free
    Halide free
    Active 4 Megapixel CMOS Image Sensor 4 15 35 mm Pipelined Global 12 x 12 Color
    Mono
    CPGA-127
    STAR1000 NOIS1SM1000A/D (672.0kB) Pb-free
    Halide free
    Active 1 Megapixel Radiation Tolerant CMOS Image Sensor 1 11 1 inch Rolling 15 x 15 Mono JLDCC-84
    STAR250 NOIS1SM0250A/D (458.0kB) Pb-free
    Halide free
    Active 250K Pixel Radiation Tolerant CMOS Image Sensor 0.25 29 1 inch Rolling 25 x 25 Mono JLDCC-84
    NA-Wafer
    VITA1300 NOIV1SN1300A/D (754.0kB) Pb-free
    Halide free
    Active CMOS Image Sensor, Global Shutter, 1.3 Megapixel 1.3 37
    150
    1/2 inch Pipelined Global, Rolling with CDS, LVDS, 10-bit outputs 4.8 x 4.8 Color
    Mono
    LCC-48
    NA-Bare Die
    VITA2000 NOIV1SN2000A/D (802.0kB) Pb-free
    Halide free
    Active CMOS Image Sensor, Global Shutter, 2.3 Megapixel 2 23
    92
    2/3 inch Pipelined Global, Rolling with CDS, LVDS, 10-bit outputs 4.8 x 4.8 Color
    Mono
    LCC-52
    VITA25K NOIV1SN025KA/D (781.0kB) Pb-free
    Halide free
    Active CMOS Image Sensor, Global Shutter, 25 Megapixel 25 53 35 mm Pipelined Global, Rolling with CDS, LVDS, 10-bit outputs 4.5 x 4.5 Color
    Mono
    CPGA-355
    VITA5000 NOIV1SN5000A/D (749.0kB) Pb-free
    Halide free
    Active CMOS Image Sensor, Global Shutter, 5.3 Megapixel 5 75 1 inch Pipelined Global, Rolling with CDS, LVDS, 10-bit outputs 4.8 x 4.8 Color
    Mono
    LCC-68
    接触式图像传感器模块
    接触式图像传感器模块
    安森美半导体提供在紧凑的封装中集成了光源、透镜及图像传感器的接触式图像传感器模块。
    Product Datasheet Compliance Status Description Resolution (dpi) Pixels Scan Length (mm) Line Scanning Speed (μs/line) Output Number of Outputs Light Source Color f Max (MHz) Package Type
    NOM02A4-AG01G NOM02A4-AG01G/D (261.0kB) Pb-free Active Contact Image Sensor Module, 200 dpi, A4 Size, Green LED, 1728 µs/line 200 1728 216 1728 Analog 1 Green 2 Image Sensor Module A4
    NOM02A4-AR03G NOM02A4-AR03G/D (262.0kB) Pb-free Active Contact Image Sensor Module, 200 dpi, A4 Size, Red LED, 346 us/line 200 1728 216 346 Analog 1 Red 5 Image Sensor Module A4
    NOM02A4-MW60G NOM02A4-MW60G/D (889.0kB) Pb-free Active Contact Image Sensor Module, 200dpi, A4 Size, White LED, 90 μs/line 200 1728 216 90 Multiple Analog 4 White 5 Image Sensor Module A4
    NOM02A6-AW49G NOM02A6-AW49G-D (261.0kB) Pb-free Active Contact Image Sensor Module, 200 dpi, A6 Size, White LED, 167us/line 200 832 104 167 Analog 1 White 5 Image Sensor Module
    NOM02B4-DR11G NOM02B4-DR11G/D (274.0kB) Pb-free Active Contact Image Sensor Module, 200 dpi, B4 Size, Red LED, 410us/line 200 2048 256 410 Binary 1 Red 5 Image Sensor Module
    触摸传感器
    触摸传感器
    安森美半导体提供静电电容式触摸传感器。
    Product Datasheet Compliance Status Description Number of Sensing Inputs Number of Sensing Outputs Interface Control Proximity Sensing VDD Min (V) VDD Max (V) IDD Typ (μA) Package Type
    LC717A00AJ ENA2089/D (144.0kB) Pb-free
    Halide free
    Active Capacitance-Digital-Converter IC for Electrostatic Capacitive Touch Sensors 8 8 I2C
    SPI
    Yes 2.6 5.5 320 SSOP-30
    LC717A00AR ENA2048/D (145.0kB) Pb-free
    Halide free
    Active Touch Sensors, Capacitance-Digital- Converter for Electrostatic Capacitive 8 8 I2C
    SPI
    Yes 2.6 5.5 320 VCT-28
    LC717A10AJ ENA2162/D (143.0kB) Pb-free
    Halide free
    Active Capacitance-Digital-Converter IC for Electrostatic Capacitive Touch Sensors 16 I2C
    SPI
    Yes 2.6 5.5 570 SSOP-30
    LC717A10AR ENA2161/D (143.0kB) Pb-free
    Halide free
    SPI
    Yes 2.6 5.5 570 VCT-28
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
