龙人旗下深圳市龙芯世纪科技有限公司
  • 多路转换器
  • 发布时间:2013/9/9 11:04:46   修改时间:2013/9/9 11:04:46 浏览次数:1524
  • 多路转换器
    2:1多工器 - 4:1多工器 - 8:1多工器
    安森美半导体提供多种标准逻辑系列的2:1、4:1及8:1多工器。
    Product Datasheet Compliance Status Description Channels VCC Min (V) VCC Max (V) tpd Max (ns) IO Max (mA) Package Type
    MC74HC238A MC74HC238A/D (136.0kB) Pb-free
    Halide free
    ActiveNEW 1-of-8 Decoder/Demultiplexer 1 2 6 19 5.2 SOIC-16
    TSSOP-16
    MC14028B MC14028B/D (134.0kB) Pb-free
    Halide free
    AEC Qualified
    PPAP Capable
    Active BCD-to-Decimal Decoder 1 3 18 260 2.25 SOIC-16
    MC14512B MC14512B/D (128.0kB) Pb-free
    Halide free
    AEC Qualified
    PPAP Capable
    Active 8-Channel Data Selector 1 3 18 250 2.25 SOIC-16
    MC14514B MC14514B/D (124.0kB) Pb-free
    Halide free
    Active 4-Bit Transparent Latch/4-to-16 Line Decoder 1 3 18 450 2.25 SOIC-24
    MC14515B MC14514B/D (124.0kB) Pb-free
    Halide free
    MC14532B MC14532B/D (134.0kB) Pb-free
    Halide free
    AEC Qualified
    PPAP Capable
    Active 8-Bit Priority Encoder 1 3 18 220 2.25 SOIC-16
    MC14555B MC14555B/D (128.0kB) Pb-free
    Halide free
    AEC Qualified
    PPAP Capable
    Active Dual Binary to 1-of-4 Decoder/Demultiplexer 2 3 18 190 2.25 SOIC-16
    MC14556B MC14555B/D (128.0kB) Pb-free
    Halide free
    AEC Qualified
    PPAP Capable
    MC74AC138 MC74AC138/D (189.0kB) Pb-free
    Halide free
    Active 1-of-8 Decoder/Demultiplexer 1 2 6 9.5 24 SOIC-16
    TSSOP-16
    MC74AC139 MC74AC139/D (182.0kB) Pb-free
    Halide free
    Active Dual 1-of-4 Decoder/Demultiplexer 2 2 6 8.5 24 SOIC-16
    TSSOP-16
    MC74AC157 MC74AC157/D (115.0kB) Pb-free
    Halide free
    Active Quad 2-Input Multiplexer 4 2 6 9 24 SOIC-16
    TSSOP-16
    MC74AC253 MC74AC253/D (182.0kB) Pb-free
    Halide free
    Active Dual 4-Input Multiplexer with 3-State Outputs 2 2 6 11.5 24 SOIC-16
    MC74AC257 MC74AC257/D (181.0kB) Pb-free
    Halide free
    Active Quad 2-Input Multiplexer 3-State Output 4 2 6 7.5 24 SOIC-16
    MC74ACT138 MC74AC138/D (189.0kB) Pb-free
    Halide free
    Active 1-of-8 Decoder/Demultiplexer 1 4.5 5.5 10.5 24 SOIC-16
    TSSOP-16
    MC74ACT139 MC74AC139/D (182.0kB) Pb-free
    Halide free
    Active Dual 1-of-4 Decoder/Demultiplexer 2 4.5 5.5 9.5 24 SOIC-16
    TSSOP-16
    MC74ACT153 MC74AC153/D (180.0kB) Pb-free
    Halide free
    Active Dual 4-Input Multiplexer 2 4.5 5.5 11.5 24 SOIC-16
    MC74ACT157 MC74AC157/D (115.0kB) Pb-free
    Halide free
    Active Quad 2-Input Multiplexer 4 4.5 5.5 9.5 24 SOIC-16
    TSSOP-16
    MC74ACT253 MC74AC253/D (182.0kB) Pb-free
    Halide free
    Active Dual 4-Input Multiplexer with 3-State Outputs 2 4.5 5.5 13 24 SOIC-16
    MC74ACT257 MC74AC257/D (181.0kB) Pb-free
    Halide free
    Active Quad 2-Input Multiplexer with 3-State Output 4 4.5 5.5 10.5 24 SOIC-16
    MC74HC138A MC74HC138A/D (136.0kB) Pb-free
    Halide free
    AEC Qualified
    PPAP Capable
    Active 1-of-8 Decoder/Demultiplexer 1 2 6 19
    27
    4
    5.2
    SOIC-16
    TSSOP-16
    MC74HC139A MC74HC139A/D (139.0kB) Pb-free
    Halide free
    AEC Qualified
    PPAP Capable
    Active Dual 1-of-4 Decoder / Demultiplexer  2 2 6 23 4 SOIC-16
    TSSOP-16
    MC74HC151A MC74HC151A/D (129.0kB) Pb-free
    Halide free
    Active 8-Input Multiplexer 1 2 6 43 5.2 SOIC-16
    TSSOP-16
    MC74HC153A MC74HC153A/D (127.0kB) Pb-free
    Halide free
    Active Dual 4-Input Data Selector/Multiplexer High-Performance Silicon-Gate CMOS 2 2 6 36 5.2 SOIC-16
    TSSOP-16
    MC74HC157A MC74HC157A/D (142.0kB) Pb-free
    Halide free
    AEC Qualified
    PPAP Capable
    Active Data Selector/Multiplexer (Mux), 2-Input Q 4 2 6 21 6 SOIC-16
    TSSOP-16
    MC74HC251A MC74HC251A/D (158.0kB) Pb-free
    Halide free
    Active 8-Input Multiplexer (3-state)  1 2 6 48 5.2 SOIC-16
    TSSOP-16
    MC74HC4067A MC74HC4067A/D (164.0kB) Pb-free
    Halide free
    Active Quad Analog Switch/Multiplexer/Demultiplexer 1 2 6 19 25 SOIC-24
    TSSOP-24
    MC74HCT138A MC74HCT138A/D (157.0kB) Pb-free
    Halide free
    Active 1-of-8 Decoder/Demultiplexer with LSTTL Compatible Inputs 1 4.5 5.5 27 4 SOIC-16
    TSSOP-16
    MC74HCT4051A MC74HCT4051A/D (201.0kB) Pb-free
    Halide free
    Active Analog Multiplexers / Demultiplexers with LSTTL Compatible Inputs 4 2 12 45 25 SOIC-16
    TSSOP-16
    MC74HCT4066A MC74HCT4066A/D (168.0kB) Pb-free
    Halide free
    Active Quad Analog Switch/Multiplexer/Demultiplexer/with LSTTL Compatible Inputs 4 4.5 5.5 10 2 SOIC-14
    TSSOP-14
    MC74HCT4851A MC74HCT4851A/D (160.0kB) Pb-free
    Halide free
    Active Analog Multiplexers/Demultiplexers with Injection Current Effect Control with LSTTL Compatible Inputs 4 2 6 40 0.0001 SOIC-16
    SOIC-16W
    TSSOP-16
    MC74HCT4852A MC74HCT4851A/D (160.0kB) Pb-free
    Halide free
    Active Analog Multiplexers/Demultiplexers with Injection, TTL 8 4.5 5.5 40 0.0001 SOIC-16
    TSSOP-16
    MC74LCX138 MC74LCX138/D (160.0kB) Pb-free
    Halide free
    AEC Qualified
    PPAP Capable
    Active Low Voltage CMOS 3-to-8 Decoder/Demultiplexer 1 2 3.6 6 24 SOIC-16
    TSSOP-16
    MC74LCX139 MC74LCX139/D (156.0kB) Pb-free
    Halide free
    Active Dual Low Voltage CMOS 2-of-4 Decoder/Demultiplexer 2 2 3.6 6.2 24 SOIC-16
    TSSOP-16
    MC74LCX157 MC74LCX157/D (153.0kB) Pb-free
    Halide free
    Active Low Voltage CMOS Quad 2-Input Multiplexer 2 2 3.6 5.8 24 SOIC-16
    TSSOP-16
    MC74LCX158 MC74LCX158/D (154.0kB) Pb-free
    Halide free
    Active Low Voltage Quad 2-Input Multiplexer 4 2 3.6 6.5 24 SOIC-16
    TSSOP-16
    MC74LCX257 MC74LCX257/D (126.0kB) Pb-free
    Halide free
    Active Low Voltage CMOS Quad 2-Input Multiplexer 4 2 3.6 6 24 SOIC-16
    TSSOP-16
    MC74LCX258 MC74LCX258/D (128.0kB) Pb-free
    Halide free
    Active Low Voltage Quad 2-Input Multiplexer with 5V-Tolerant Inputs and Outputs (3-State, Inverting) 4 2 3.6 6.5 24 SOIC-16
    TSSOP-16
    MC74LVX138 MC74LVX138/D (137.0kB) Pb-free
    Halide free
    Active 3-to-8 Line Decoder 1 2 3.6 12.3 4 SOIC-16
    TSSOP-16
    MC74LVX139 MC74LVX139/D (136.0kB) Pb-free
    Halide free
    Active Dual 2-to-4 Decoder/ Demultiplexer 2 2 3.6 13 4 SOIC-16
    TSSOP-16
    MC74LVX157 MC74LVX157/D (131.0kB) Pb-free
    Halide free
    Active Quad 2-Channel Multiplexer (Mux) 4 2 3.6 11.4 4 SOIC-16
    TSSOP-16
    MC74LVX257 MC74LVX257.PDF (138.0kB) Pb-free
    Halide free
    Active Quad 2-Channel Multiplexer with 3-State Outputs 4 2 3.6 12 4 SOIC-16
    TSSOP-16
    MC74LVX4051 MC74LVX4051/D (189.0kB) Pb-free
    Halide free
    Active Analog Multiplexer/Demultiplexer (Mux/Demux) 1 2.5 6 23 4 QFN-16
    SOIC-16
    TSSOP-16
    MC74LVX4052 MC74LVX4052/D (175.0kB) Pb-free
    Halide free
    Active Analog Multiplexer/Demultiplexer (Mux/Demux) 2 2.5 6 23 4 SOIC-16
    TSSOP-16
    MC74LVX4053 MC74LVX4053/D (175.0kB) Pb-free
    Halide free
    Active Analog Multiplexer / Demultiplexer 3 2.5 6 23 4 SOIC-16
    TSSOP-16
    MC74LVXT4051 MC74LVXT4051/D (174.0kB) Pb-free
    Halide free
    Active Analog Multiplexer/Demultiplexer (Mux/Demux) 1 2.5 6 23 4 SOIC-16
    TSSOP-16
    MC74LVXT4052 MC74LVXT4052/D (175.0kB) Pb-free
    Halide free
    TSSOP-16
    MC74LVXT4053 MC74LVXT4053/D (175.0kB) Pb-free
    Halide free
    Active Analog Multiplexer/Demultiplexer (Mux/Demux) 3 2.5 6 23 4 SOIC-16
    TSSOP-16
    MC74VHC138 MC74VHC138/D (131.0kB) Pb-free
    Halide free
    Active 3-to-8 Line Decoder 1 2 5.5 10.1 8 SOIC-16
    TSSOP-16
    MC74VHC139 MC74VHC139/D (129.0kB) Pb-free
    Halide free
    Active Dual 2-to-4 Decoder/Demultiplexer 2 2 5.5 9.2 8 SOIC-16
    TSSOP-16
    MC74VHC157 MC74VHC157/D (121.0kB) Pb-free
    Halide free
    Active 2-Input Data Selector/Multiplexer (Mux) 4 2 5.5 8.4 8 SOIC-16
    TSSOP-16
    MC74VHC257 MC74VHC257/D (141.0kB) Pb-free
    Halide free
    Active Quad 2-Channel Multiplexer with 3-State Outputs 4 2 5.5 7.9 8 SOIC-16
    TSSOP-16
    MC74VHC4052 MC74VHC4051/D (200.0kB) Pb-free
    Halide free
    Active Analog Multiplexer/ Demultiplexer 1 2 6 49 8 SOIC-16
    TSSOP-16
    MC74VHC4053 MC74VHC4051/D (200.0kB) Pb-free
    Halide free
    TSSOP-16
    MC74VHC4316 MC74VHC4316/D (166.0kB) Pb-free
    Halide free
    Active Quad Analog Multiplexer/Demultiplexer (Mux/Demux) 4 2 6 8 SOIC-16
    TSSOP-16
    MC74VHCT138A MC74VHCT138A/D (132.0kB) Pb-free
    Halide free
    Active 3-to-8 Line Decoder 1 3 5.5 11.4 8 SOIC-16
    TSSOP-16
    MC74VHCT139A MC74VHCT139A/D (138.0kB) Pb-free
    Halide free
    Active Dual 2-to-4 Decoder/Demultiplexer 2 4.5 5.5 9.2 8 SOIC-16
    TSSOP-16
    MC74VHCT157A MC74VHCT157A/D (137.0kB) Pb-free
    Halide free
    Active Quad 2-Channel Multiplexer 4 4.5 5.5 8.4 8 TSSOP-16
    NL7SZ18 NL7SZ18/D (122.0kB) Pb-free
    Halide free
    Active 1:2 Digital Demultiplexer Non-Inverting, 3-State 2 1.65 5.5 4 32 SC-88-6 / SC-70-6 / SOT-363-6
    UDFN-6
    NL7SZ19 NL7SZ19/D (90.0kB) Pb-free
    Halide free
    Active 1:2 Digital Multiplexer / Demultiplexer 2 1.65 5.5 4 50 SC-88-6 / SC-70-6 / SOT-363-6
    UDFN-6
    NLAS4053 NLAS4053/D (146.0kB) Pb-free
    Halide free
    Active Analog Multiplexers/Demultiplexers 3 2.5 5.5 40 50 SOIC-16
    TSSOP-16
    NLX1G99 NLX1G99/D (170.0kB) Pb-free
    Halide free
    Active Selectable Function Logic 1 1.65 5.5 6.7 32 ULLGA-8
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
