龙人旗下深圳市龙芯世纪科技有限公司
  • 多频振荡器
  • 发布时间:2013/9/9 11:05:34   修改时间:2013/9/9 11:05:34 浏览次数:1708
  • 多频振荡器
    双单稳多谐振荡器
    安森美半导体提供多种逻辑系列的双单稳多谐振荡器。
    Product Datasheet Compliance Status Description Channels VCC Min (V) VCC Max (V) tpd Max (ns) IO Max (mA) Package Type
    MC14528B MC14528B/D (140.0kB) Pb-free
    Halide free
    AEC Qualified
    PPAP Capable
    Active Dual Monostable Multivibrator 2 3 18 240 2.25 SOIC-16
    MC14538B MC14538B/D (192.0kB) Pb-free
    Halide free
    AEC Qualified
    PPAP Capable
    Active Dual Precision Monostable Multivibrator 2 3 18 300 2.25 SOIC-16
    SOIC-16W
    TSSOP-16
    MC74HC4538A MC74HC4538A/D (192.0kB) Pb-free
    Halide free
    AEC Qualified
    PPAP Capable
    Active Dual Precision Monostable Multivibrator 2 3 6 35 4 SOIC-16
    TSSOP-16
    收发器
    双向收发器
    安森美半导体提供多种标准逻辑系列的双向总线收民器。
    Product Datasheet Compliance Status Description Channels Output VCC Min (V) VCC Max (V) tpd Max (ns) IO Max (mA) Package Type
    FST3125 FST3125/D (118.0kB) Pb-free
    Halide free
    ActiveNEW 4-BIT BUS SWITCH 4 CMOS 4 5.5 0.25 128 SOIC-14
    TSSOP-14
    MC74AC245 MC74AC245/D (112.0kB) Pb-free
    Halide free
    Active Octal Bidirectional Transceiver with 3-State Inputs/Outputs 1 3-State 2 2
    6
    6.5 24 SOIC-20W
    TSSOP-20
    MC74AC646 MC74AC646/D (160.0kB) Pb-free
    Halide free
    Active Octal Bus Transceiver Register with 3-State Outputs (Non-inverting) 8 3-State 2 6 12 24 SOIC-24
    MC74AC652 MC74AC652/D (157.0kB) Pb-free
    Halide free
    MC74ACT245 MC74AC245/D (112.0kB) Pb-free
    Halide free
    Active Octal Bidirectional Transceiver with 3-State Inputs/Outputs 1 3-State 4.5 5.5 8 24 SOIC-20W
    TSSOP-20
    MC74ACT640 MC74ACT640/D (88.0kB) Pb-free
    Halide free
    Active Octal 3-State Inverting Bus Transceiver 1 3-State 4.5 5.5 8 24 SOIC-20W
    MC74ACT646 MC74AC646/D (160.0kB) Pb-free
    Halide free
    Active Octal Bus Transceiver/Register with 3-State Outputs (Non-inverting) 8 3-State 4.5 5.5 14.5 24 SOIC-24
    MC74ACT652 MC74AC652/D (157.0kB) Pb-free
    Halide free
    MC74HC245A MC74HC245A/D (151.0kB) Pb-free
    Halide free
    AEC Qualified
    PPAP Capable
    Active Octal 3-State Non-Inverting Bus/Transceiver 1 3-State 2 6 15 6 SOIC-20W
    TSSOP-20
    MC74HCT245A MC74HCT245A/D (147.0kB) Pb-free
    Halide free
    Active Octal 3-State Non-Inverting Bus Transceiver 1 3-State 4.5 5.5 22 6 SOIC-20W
    TSSOP-20
    MC74LCX16245 MC74LCX16245/D (123.0kB) Pb-free
    Halide free
    Active Low Voltage CMOS 16-Bit Transceiver 8 3-State 2 3.6 5.2 24 TSSOP-48
    MC74LCX245 MC74LCX245/D (140.0kB) Pb-free
    Halide free
    Active Octal Transceiver, CMOS, Low Voltage 1 CMOS 2 3.6 7 24 QFN-20
    SOIC-20W
    TSSOP-20
    MC74LVX245 MC74LVX245/D (136.0kB) Pb-free
    Halide free
    Active Octal Bus Transceiver 1 CMOS 2 3.6 10.1 4 SOIC-20W
    TSSOP-20
    MC74LVX4245 MC74LVX4245/D (132.0kB) Pb-free
    Halide free
    Active Dual Supply Octal Translating Transceiver 8 3-State 2.7 3.6 10 24 SOIC-24
    TSSOP-24
    MC74LVXC3245 MC74LVXC3245/D (131.0kB) Pb-free
    Halide free
    Active Configurable Dual Supply Octal Transceiver 8 3-State 2.3 3.6 9 24 SOIC-24
    TSSOP-24
    MC74VHC245 MC74VHC245/D (131.0kB) Pb-free
    Halide free
    Active Octal Bus Transceiver 1 CMOS 2 5.5 7.5 8 SOIC-20W
    TSSOP-20
    MC74VHCT245A MC74VHCT245A/D (140.0kB) Pb-free
    Halide free
    Active Octal Bus Transceiver 1 CMOS 4.5 5.5 8.7 8 SOIC-20W
    TSSOP-20
    转换器
    逻辑电平转换器
    安森美半导体提供多种标准逻辑系列的逻辑电平转换器。
    Product Datasheet Compliance Status Description Channels Input Level VCC Min (V) VCC Max (V) tpd Max (ns) IO Max (mA) Package Type
    NLSV4T3144 NLSV4T3144 (117.0kB) Pb-free
    Halide free
    ActiveNEW 4-bit configurable dual-supply bus buffer level translator 4 CMOS 0.9 4.5 1.9 50 UQFN-12
    MC14504B MC14504B/D (143.0kB) Pb-free
    Halide free
    AEC Qualified
    PPAP Capable
    Active Hex Level Shifter 1 CMOS
    TTL
    3 18 340 2.25 SOIC-16
    TSSOP-16
    Halide free
    Active Dual Supply Octal Translating Transceiver 8 TTL 2.7 3.6 10 24 SOIC-24
    TSSOP-24
    NLSV1T240 NLSV1T240/D (113.0kB) Pb-free
    Halide free
    Active 1-Bit Dual-Supply Inverting Level Translator 1 CMOS 0.9 4.5 3.3 50 UDFN-6
    NLSV1T244 NLSV1T244/D (113.0kB) Pb-free
    Halide free
    Active 1-Bit Dual-Supply Non-Inverting Level Translator 1 CMOS 0.9 4.5 3.3 50 UDFN-6
    NLSV1T34 NLSV1T34/D (127.0kB) Pb-free
    Halide free
    Active 1-Bit Dual-Supply Non-Inverting Level Translator 1 CMOS 0.9 4.5 3.3 24 SC-88A-5 / SC-70-5 / SOT-323-5
    UDFN-6
    ULLGA-6
    NLSV22T244MUTAG NLSV22T244/D (137.0kB) Pb-free
    Halide free
    Active Dual 2-Bit Dual-Supply Non-Inverting Level Translator 4 CMOS 1.65 3.6 3.3 50 UQFN-12
    NLSV2T240 NLSV2T240/D (114.0kB) Pb-free
    Halide free
    Active 2-Bit Dual-Supply Inverting Level Translator 2 CMOS 0.9 4.5 3.3 50 UDFN-8
    NLSV2T244 NLSV2T244/D (138.0kB) Pb-free
    Halide free
    Active 2-Bit Dual-Supply Non-Inverting Level Translator 2 CMOS 0.9 4.5 3.3 50 Micro8?-8
    SOIC-8
    UDFN-8
    NLSV4T240 NLSV4T240/D (119.0kB) Pb-free
    Halide free
    Active 4-Bit Dual-Supply Inverting Level Translator 4 CMOS 0.9 4.5 3.3 50 UQFN-12
    NLSV4T240E NLSV4T240E/D (155.0kB) Pb-free
    Halide free
    Active 4-Bit Dual-Supply Inverting Level Translator 4 CMOS 0.9 4.5 2.5 24 SOIC-14
    TSSOP-14
    UQFN-12
    NLSV4T244 NLSV4T244/D (142.0kB) Pb-free
    Halide free
    Active 4-Bit Dual-Supply Non-Inverting Level Translator 4 CMOS 0.9 4.5 3.3 50 SOIC-14
    TSSOP-14
    UQFN-12
    NLSV4T244E NLSV4T244E/D (144.0kB) Pb-free
    Halide free
    Active 4-Bit Dual-Supply Non-Inverting Level Translator 4 CMOS 0.9 4.5 2.5 24 SOIC-14
    TSSOP-14
    UQFN-12
    NLSV4T3234 NLSV4T3234/D (72.0kB) Pb-free
    Halide free
    Active 4-Bit Dual Supply Bus Buffer Translator w/ 26 Ohm Output Series Resistor 4 CMOS 0.9 4.5 5.6 50 Flip-Chip CSP-11
    NLSV8T240MUTAG NLSV8T240/D (114.0kB) Pb-free
    Halide free
    Active 8-Bit Dual-Supply Inverting Level Translator 8 CMOS 0.9 4.5 3.3 50 UDFN-20
    NLSV8T244 NLSV8T244/D (144.0kB) Pb-free
    Halide free
    Active 8-Bit Dual-Supply Non-Inverting Level Translator 8 CMOS 0.9 4.5 3.3 50 SOIC-20W
    TSSOP-20
    UDFN-20
    NLSX0102 NLSX0102/D (136.0kB) Pb-free
    Halide free
    PPAP Capable
    Active 2-Bit 20 Mb/s Dual-Supply Level Translator 2 CMOS 1.5 5.5 7.4 1 Flip-Chip-8
    NLSX3012 NLSX3012/D (170.0kB) Pb-free
    Halide free
    Active 2-Bit 100 Mbps Configurable Dual-Supply Level Translator 2 CMOS 1.3 4.5 7.2 0.02 Micro8?-8
    SOIC-8
    UDFN-8
    NLSX3013 NLSX3013/D (148.0kB) Pb-free
    Halide free
    Active 8-Bit 100 Mbps Configurable Dual-Supply Level Translator 8 CMOS 1.3 4.5 6
    6.5
    0.02 Flip-Chip-20
    NLSX3014 NLSX3014/D (134.0kB) Pb-free
    Halide free
    Active 4-Bit 100 Mbps Configurable Dual-Supply Level Translator 4 CMOS 0.9 4.5 6.5 0.02 UQFN-12
    NLSX3018 NLSX3018/D (144.0kB) Pb-free
    Halide free
    Active 8-Bit  100 Mb/s Configurable Dual-Supply Level Translator 8 CMOS 0.9 4.5 6.5 20 SOIC-20W
    TSSOP-20
    UDFN-20
    NLSX3373 NLSX3373/D (118.0kB) Pb-free
    Halide free
    Active 2-Bit 20 Mb/s Dual-Supply Level Translator 2 CMOS 1.2 5.5 30 40 UDFN-8
    NLSX3378 NLSX3378/D (115.0kB) Pb-free
    Halide free
    Active 4-Bit 20 Mbps Dual-Supply Level Translator 4 CMOS 1.2 4.5 15 40 Flip-Chip-12
    NLSX4014 NLSX4014/D (174.0kB) Pb-free
    Halide free
    Active 4-Bit 100 Mbps Configurable Dual-Supply Level Translator 4 CMOS 1.3 4.5 17 0.02 SOIC-14
    TSSOP-14
    UQFN-12
    NLSX4302E NLSX4302E/D (166.0kB) Pb-free
    Halide free
    Active DUAL-SUPPLY LEVEL TRANSLA 2 CMOS 1.5 5.5 8.6 0.02 UQFN-8
    NLSX4373 NLSX4373/D (139.0kB) AEC Qualified
    Pb-free
    Halide free
    Active 2-Bit 20 Mb/s Dual-Supply Level Translator 2 CMOS 1.5 5.5 20 1 Micro8?-8
    SOIC-8
    UDFN-8
    NLSX4378 NLSX4378/D (116.0kB) Pb-free
    Halide free
    Active 4-Bit 24 Mbps Dual-Supply Level Translator 4 CMOS 1.65 5.5 20 1 Flip-Chip-12
    NLSX5002 NLSX5002/D (134.0kB) Pb-free
    Halide free
    Active 2-Bit 100 Mbps Configurable Dual-Supply Level Translator 2 CMOS 0.9 4.5 13 0.02 UQFN-8
    NLSX5011 NLSX5011/D (150.0kB) Pb-free
    Halide free
    Active 1 Bit 100 Mbps Configurable Dual-Supply Level Translator 1 CMOS 0.9 4.5 11 0.02 UDFN-6
    ULLGA-6
    NLSX5012 NLSX5012/D (154.0kB) Pb-free
    Halide free
    Active 2 Bit 140 Mbps Enhanced Dual-Supply Auto Sense Level Translators 2 CMOS 0.9 4.5 11 0.02 Micro8?-8
    SOIC-8
    UDFN-8
    NLSX5014 NLSX5014/D (160.0kB) Pb-free
    Halide free
    Active 4-Bit 100Mb/s Configurable Dual-Supply Level Translator 4 CMOS 0.9 4.5 11 0.02 SOIC-14
    TSSOP-14
    UQFN-12
    PCA9306 PCA9306/D (179.0kB) Pb-free
    Halide free
    Active Dual Bidirectional I<sup>2</sup>C Bus and SMBus Voltage Level Translator 2 CMOS 0 5.5 2 64 TSSOP-8
    UQFN-8
    US8
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
