龙人旗下深圳市龙芯世纪科技有限公司
  • 整流器
  • 发布时间:2013/9/9 11:06:37   修改时间:2013/9/9 11:06:37 浏览次数:1596
  • 整流器
    整流器 (150)
    肖特基二极管 – 肖特基整流器
    安森美半导体提供低损耗、大电流肖特基二极管和整流器。
    肖特基二极管及整流器Excel 文档格式选型指南(150项)
    Product Description Package Type
    NHPV08S600 8A, 600V, Planar Ultrafast TO-220 FULLPAK-2
    TO-220-2
    NHPV15S600 15A 600V Planar UltraFast Power Rectifier TO-220 FULLPAK-2
    TO-220-2
    NTST40100CTG 40A 100V Dual Schottky Power Rectifier D2PAK-3
    I2PAK-3
    TO-220 FULLPAK-3
    TO-220-3
    1N4001 50 V, 1.0 A Standard Rectifier Axial Lead-2
    1N4002 100 V, 1.0 A Standard Rectifier Axial Lead-2
    1N4003 200 V, 1.0 A Standard Rectifier Axial Lead-2
    1N4004 400 V, 1.0 A Standard Rectifier Axial Lead-2
    1N4005 600 V, 1.0 A Standard Rectifier Axial Lead-2
    1N4006 800 V, 1.0 A Standard Rectifier Axial Lead-2
    1N4007 1000 V, 1.0 A Standard Rectifier Axial Lead-2
    1N4933 50 V, 1.0 A Fast Recovery Rectifier Axial Lead-2
    1N4934 100 V, 1.0 A Fast Recovery Rectifier Axial Lead-2
    1N4935 200 V, 1.0 A Fast Recovery Rectifier Axial Lead-2
    1N4936 400 V, 1.0 A Fast Recovery Rectifier Axial Lead-2
    1N4937 600 V, 1.0 A Fast Recovery Rectifier Axial Lead-2
    1N5400 50 V, 3.0 A Standard Recovery Rectifier Axial Lead-2
    1N5401 100 V, 3.0 A Standard Recovery Rectifier Axial Lead-2
    1N5402 200 V, 3.0 A Standard Recovery Rectifier Axial Lead-2
    1N5404 400 V, 3.0 A Standard Recovery Rectifier Axial Lead-2
    1N5406 600 V, 3.0 A Standard Recovery Rectifier Axial Lead-2
    1N5407 800 V, 3.0 A Standard Recovery Rectifier Axial Lead-2
    1N5408 1000 V, 3.0 A Standard Recovery Rectifier Axial Lead-2
    BYV32 200 V, 16 A Ultrafast Rectifier TO-220-3
    BYW29 200 V, 8.0 A Ultrafast Rectifier TO-220-2
    BYW51 200 V, 16 A Ultrafast Rectifier TO-220-3
    BYW80 200 V. 8.0 A Ultrafast Rectifier TO-220-2
    DSM10G 600 V, 1.0 A Power Rectifier
    MBR5H100MFS 5.0 A, 100 V Schottky Diode in SO-8FL SO-8FL / DFN-5
    MBRB40250TG 40A 250V Schottky Power Rectifier D2PAK-3
    MR851 100 V, 3.0 A Fast Recovery Power Rectifier Axial Lead-2
    MR852 200 V, 3.0 A Fast Recovery Power Rectifier Axial Lead-2
    MR854 400 V, 3.0 A Fast Recovery Power Rectifier Axial Lead-2
    MR856 600 V, 3.0 A Fast Recovery Power Rectifier Axial Lead-2
    MRA4003T3 300 V, 1.0 A Standard Recovery Rectifier SMA-2
    MRA4004 400 V, 1.0 A Standard Recovery Rectifier SMA-2
    MRA4005 600 V, 1.0 A Standard Recovery Rectifier SMA-2
    MRA4006 800 V, 1.0 A Standard Recovery Rectifier SMA-2
    MRA4007 1000 V, 1.0 A Standard Recovery Rectifier SMA-2
    MRS1504 400 V, 1.5 A Standard Recovery Rectifier SMB-2
    MSR1560 600 V, 15 A Soft Recovery Rectifier TO-220-2
    MSR860 600 V, 8 A Soft Recovery Rectifier TO-220-2
    MSRD620CT 200 V, 6.0 A Soft Ultrafast Rectifier DPAK-3
    MSRD620CTR 200 V, 6.0 A Reverse Polarity Power Rectifier DPAK-3
    MUR105 50 V, 1.0 A Ultrafast Rectifier Axial Lead-2
    MUR110 100 V, 1.0 A Ultrafast Rectifier Axial Lead-2
    MUR1100E 1000 V, 1.0 A  Ultrafast Rectifier Axial Lead-2
    MUR115 150 V, 1.0 A Ultrafast Rectifier Axial Lead-2
    MUR120 200 V, 1.0 A Ultrafast Rectifier Axial Lead-2
    MUR130 300 V, 1.0 A Ultrafast Rectifier Axial Lead-2
    MUR140 400 V, 1.0 A Ultrafast Rectifier Axial Lead-2
    MUR1520 15 A Ultrafast Rectifier TO-220-2
    MUR1540 400 V, 15 A Ultrafast Rectifier TO-220-2
    MUR1560 600 V, 15 A Ultrafast Rectifier TO-220-2
    MUR160 600 V, 1.0 A Ultrafast Rectifier Axial Lead-2
    MUR1610CT 100 V, 16 A Ultrafast Rectifier TO-220-3
    MUR1615CT 150 V, 16 A Ultrafast Rectifier TO-220-3
    MUR1620CT 200 V, 16 A Common Cathode Ultrafast Rectifier TO-220-3
    MUR1620CTR 200 V, 16 A Common Anode Ultrafast Rectifier D2PAK-3
    TO-220-3
    MUR1640CT 400 V, 16 A Ultrafast Rectifier TO-220-3
    MUR1660CT 600 V, 16 A Ultrafast Rectifier TO-220-3
    MUR180E 800 V, 1.0 A Ultrafast Rectifier Axial Lead-2
    MUR2020R 200 V, 20 A Ultrafast Rectifier TO-220-2
    MUR210 100 V, 2.0 A Ultrafast Rectifier Axial Lead-2
    MUR2100E 1000 V, 2.0 A Ultrafast Rectifier Axial Lead-2
    MUR220 200 V, 2.0 A Ultrafast Rectifier Axial Lead-2
    MUR240 400 V, 2.0 A Ultrafast Rectifier Axial Lead-2
    MUR260 600 V, 2.0 A Ultrafast Rectifier Axial Lead-2
    MUR3020WT 200 V, 30 A Ultrafast Rectifier TO-247-3
    MUR3060WT 600 V, 30 A Ultrafast Rectifier TO-247-3
    MUR405 50 V, 4.0 A Ultrafast Rectifier Axial Lead-2
    MUR410 100 V, 4.0 A Ultrafast Rectifier Axial Lead-2
    MUR4100E 1000 V, 4.0 A Ultrafast Rectifier Axial Lead-2
    MUR415 150 V, 4.0 A Ultrafast Rectifier Axial Lead-2
    MUR420 200 V, 4.0 A Ultrafast Rectifier Axial Lead-2
    MUR440 400 V, 4.0 A Ultrafast Power Rectifier Axial Lead-2
    MUR460 600 V, 4.0 A Ultrafast Rectifier Axial Lead-2
    MUR480E 800 V, 4.0 A Ultrafast Rectifier Axial Lead-2
    MUR550PF 520 V, 5.0 A Ultrafast Power Rectifier for Power Factor Correction Axial Lead-2
    DPAK-3
    TO-220-2
    MUR620CT 200 V, 6.0 A Ultrafast Rectifier TO-220-3
    MUR805 50 V, 8.0 A Ultrafast Rectifier TO-220-2
    MUR810 100 V, 8.0 A Ultrafast Rectifier TO-220-2
    MUR8100E 1000 V, 8.0 A Ultrafast Rectifier TO-220-2
    MUR815 150 V, 8.0 A Ultrafast Rectifier TO-220-2
    MUR820 200 V, 8.0 A Ultrafast Rectifier TO-220-2
    MUR840 400 V, 8.0 A Ultrafast Rectifier TO-220-2
    MUR860 600 V, 8.0 A Ultrafast Rectifier TO-220-2
    MUR880E 800 V, 8.0 A Ultrafast Rectifier TO-220-2
    MURA105 1.0 A Ultrafast Power Rectifier SMA-2
    MURA115 1.0 A Ultrafast Power Rectifier SMA-2
    MURA130 1.0 A Ultrafast Power Rectifier SMA-2
    MURA140 1.0 A Ultrafast Power Rectifier SMA-2
    MURA160 600 V, 1.0 A Ultrafast Power Rectifier SMA-2
    MURA205 Ultrafast Power Rectifier SMA-2
    MURA215T3 Ultrafast Power Rectifier SMA-2
    MURA230T3 300 V, 2.0 A Ultrafast Power Rectifier SMA-2
    MURA240T3 400 V, 2.0 A Ultrafast Power Rectifier SMA-2
    MURA260T3 600 V, 2.0 A Ultrafast Power Rectifier SMA-2
    MURB1620CT 200 V, 16 A Common Cathode Ultrafast Rectifier D2PAK-3
    MURB1660CT 600 V, 16 A Ultrafast Rectifier D2PAK-3
    MURD320 200 V, 3.0 A Ultrafast Rectifier DPAK-3
    MURD330 300 V, 3.0 A Ultrafast Rectifier DPAK-3
    MURD340 3.0 A, 400 V Ultrafast Rectifier DPAK-3
    MURD530 300 V, 5.0 A Ultrafast Rectifier DPAK-3
    MURD620CT 200 V, 6.0 A Ultrafast Rectifier DPAK-3
    MURF1620CT 200 V, 16 A Ultrafast Rectifier TO-220 FULLPAK-3
    MURF1660CT 600 V, 16 A Ultrafast Rectifier TO-220 FULLPAK-3
    MURH840CT 400 V, 8.0 A Ultrafast Rectifier TO-220-3
    MURH860CT 600 V, 8.0 A Ultrafast Rectifier TO-220-3
    MURHB840CT 400 V, 8.0 A Ultrafast Rectifier D2PAK-3
    MURHB860CT 600 V, 8.0 A Ultrafast Rectifier D2PAK-3
    MURHD560 600 V, 5.0 A Ultrafast Rectifier DPAK-3
    MURHD560W1 600 V, 5.0 A Ultrafast Rectifier DPAK-3
    MURHF860CT 600 V, 8.0 A Ultrafast Rectifier TO-220 FULLPAK-3
    MURHS160T3 600 V, 1.0 A Ultrafast Rectifier SMB-2
    MURS105 50 V, 1.0 A Ultrafast Rectifier SMB-2
    MURS110 100 V, 1.0 A Ultrafast Rectifier SMB-2
    MURS115 150 V, 1.0 A Ultrafast Rectifier SMB-2
    MURS120 200 V, 1.0 A Ultrafast Rectifier SMB-2
    MURS140 400 V, 1.0 A Ultrafast Rectifier SMB-2
    MURS160 600 V, 1.0 A Ultrafast Rectifier SMB-2
    MURS205 50 V, 2 A Ultrafast Rectifier SMB-2
    MURS210 100 V, 2.0 A Ultrafast Rectifier SMB-2
    MURS220 200 V, 2.0 A Ultrafast Rectifier SMB-2
    MURS230 300 V, 2.0 A Ultrafast Rectifier SMB-2
    MURS240 400 V, 2.0 A Ultrafast Rectifier SMB-2
    MURS260 600 V, 2.0 A Ultrafast Rectifier SMB-2
    MURS320 200 V, 3.0 A Ultrafast Rectifier SMC-2
    MURS340 400 V, 3.0 A Ultrafast Rectifier SMC-2
    MURS360 600 V, 3.0 A Ultrafast Rectifier SMC-2
    MURS360BT3G 600 V, 3.0 A Ultrafast Rectifier SMB-2
    MURS480E 800 V, 4.0 A Ultrafast Rectifier SMC-2
    NTSJ2080CTG LVFR Dual 20A 80V TO-220 FULLPAK-3
    NTSJ3080CTG Schottky Rectifier LVFR Dual 30A 80V TO-220 FULLPAK-3
    NTSJ30U80CTG LVFR Dual 30A 80V TO-220 FULLPAK-3
    NTST20100CTG 20A 100V Dual Schottky Power Rectifier  D2PAK-3
    I2PAK-3
    TO-220 FULLPAK-3
    TO-220-3
    NTST20120CTG LVFR Dual 20A 120V  D2PAK-3
    I2PAK-3
    TO-220 FULLPAK-3
    TO-220-3
    NTST20U100CTG 20A 100V Dual Schottky Power Rectifier D2PAK-3
    I2PAK-3
    TO-220 FULLPAK-3
    TO-220-3
    NTST30100CTG 30A 100V Dual Schottky Power Rectifier D2PAK-3
    I2PAK-3
    TO-220 FULLPAK-3
    TO-220-3
    NTST30120CTG LVFR Dual 30A 120V  D2PAK-3
    I2PAK-3
    TO-220 FULLPAK-3
    TO-220-3
    NTST30U100CTG 30A 100V Dual Schottky Power Rectifier D2PAK-3
    I2PAK-3
    TO-220 FULLPAK-3
    TO-220-3
    NTST40120CTG 40A 120V Dual Schottky Power Rectifier D2PAK-3
    I2PAK-3
    TO-220 FULLPAK-3
    TO-220-3
    NTSV20100CTG 20A 100V Dual Schottky Power Rectifier TO-220-3
    NTSV20120CTG 20A 120V Dual Schottky Power Rectifier TO-220-3
    NTSV2080CTG 20A 80V Dual Schottky Power Rectifier TO-220-3
    NTSV20U100CTG 20A 100V Dual Schottky Power Rectifier TO-220-3
    NTSV20U80CTG 20A 80V Dual Schottky Power Rectifier TO-220-3
    NTSV30100CTG 30A 100V Dual Schottky Power Rectifier TO-220-3
    NTSV30100SG 30 A, 100 V Very Low Forward Voltage Trench-based Schottky Rectifier TO-220-3
    NTSV30120CTG 30A 120V Dual Schottky Power Rectifier TO-220-3
    NTSV3080CTG 30A 80V Dual Schottky Power Rectifier TO-220-3
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
