Product |
Description |
Package Type |
BAS40L |
40 V Schottky Diode |
SOT-23-3 |
NTST40100CTG |
40 A, 100 V, Dual Schottky Power Rectifier |
D<sup>2</sup>PAK-3 I<sup>2</sup>PAK-3 TO-220 FULLPAK-3 TO-220-3 |
SB07-03P |
Single Schottky Barrier Diode, 30 V, 700 mA |
SOT-89 / PCP-1 |
SB10015M |
Single Schottky Barrier Diode, 15 V, 1 A |
SC-88AFL / MCPH-5 |
SBE001 |
Single Schottky Barrier Diode, 30 V, 2 A |
CPH-6 |
SB05-05P |
Single Schottky Barrier Diode, 50 V, 500 mA |
SOT-89 / PCP-1 |
SB3003CH |
Single Schottky Barrier Diode, 30 V, 3 A |
CPH-6 |
SBE818 |
Dual Schottky Barrier Diode, 30 V, 2 A |
SOT-383FL / EMH-8 |
1N5817 |
20 V, 1.0 A Schottky Rectifier |
Axial Lead-2 |
1N5818 |
30 V, 1.0 A Schottky Rectifier |
Axial Lead-2 |
1N5819 |
40 V, 1.0 A Schottky Rectifier |
Axial Lead-2 |
1N5820 |
20 V, 3.0 A Schottky Rectifier |
Axial Lead-2 |
1N5821 |
30 V, 3.0 A Schottky Rectifier |
Axial Lead-2 |
1N5822 |
40 V, 3.0 A Schottky Rectifier |
Axial Lead-2 |
1SS351 |
Dual Schottky Barrier Diode, 5 V, 30 mA |
SC-59 / CP |
80SQ045N |
45 V, 8.0 A Axial Lead Schottky Rectifier |
Axial Lead-2 |
BAS40-04L |
40 V Schottky Diode, dual, series |
SOT-23-3 |
BAS40-06L |
40 V Dual Common Anode Schottky Diode |
SOT-23-3 |
BAS70-04L |
70 V Schottky Diode, Dual, Series |
SOT-23-3 |
BAS70L |
70 V Schottky Diode |
SOT-23-3 |
BAT54 |
30 V Schottky Diode |
SOD-123 |
BAT54AL |
30 V Dual Common Anode Schottky Diode |
SOT-23-3 |
BAT54AW |
SC-70-3 / SOT-323-3 |
BAT54C |
30 V Dual Common Cathode Schottky Diode |
SOT-23-3 |
BAT54CT |
Common Cathode Schottky Diode, dual, 30 V |
SC-75-3 |
BAT54CW |
BAT54CXV3 |
SC-89-3 |
BAT54H |
SOD-323 |
BAT54L |
SOT-23-3 |
BAT54M3T5G |
Schottky Diode |
SOT-723-3 |
BAT54SL |
30 V Schottky Diode, dual, series |
SOT-23-3 |
BAT54SW |
BAT54W |
BAT54XV2 |
SOD-523-2 |
MBD301 |
Schottky Diode UHF 30 V |
TO-92 |
MBD330DW |
30 V Schottky Diode, dual, isolated |
SC-88-6 / SC-70-6 / SOT-363-6 |
MBD54DW |
Schottky Diode, Dual Isolated |
MBD770DW |
70 V Schottky Diode, dual, isolated |
MBR0520L |
20 V, 0.5 A Schottky Rectifier |
SOD-123 |
MBR0530 |
30 V, 0.5 A Schottky Rectifier |
SOD-123 |
MBR0540 |
40 V, 0.5 A Schottky Rectifier |
SOD-123 |
MBR10100 |
100 V, 10 A Schottky Rectifier |
TO-220-2 |
MBR1035 |
35 V, 10 A Schottky Rectifier |
TO-220-2 |
MBR1045 |
45 V, 10 A Schottky Rectifier |
TO-220-2 |
MBR1060 |
60 V, 10 A Schottky Rectifier |
TO-220-2 |
MBR1080 |
80 V, 10 A Schottky Rectifier |
TO-220-2 |
MBR1090 |
90 V, 10 A Schottky Rectifier |
TO-220-2 |
MBR10L60CTG |
60 V, 10 A L-Series Schottky Rectifier |
TO-220-3 |
MBR1100 |
100 V, 1.0 A Schottky Rectifier |
Axial Lead-2 |
MBR120ESF |
SOD123-2 |
MBR120LSF |
20 V, 1.0 A Low V<sub>F</sub> Schottky Rectifier |
SOD123-2 |
MBR120VLSF |
SOD123-2 |
MBR130 |
SOD-123 |
MBR130LSF |
SOD123-2 |
MBR140SF |
SOD123-2 |
MBR150 |
50 V, 1.0 A Schottky Rectifier |
Axial Lead-2 |
MBR1535CT |
35 V, 15 A Schottky Rectifier |
TO-220-3 |
MBR1545CT |
45 V, 15 A Schottky Rectifier |
TO-220-3 |
MBR160 |
60 V, 1.0 A Schottky Rectifier |
Axial Lead-2 |
MBR16100CT |
100 V, 16 A Schottky Rectifier |
TO-220-3 |
MBR1635 |
35 V, 16 A Schottky Rectifier |
TO-220-2 |
MBR1645 |
45 V, 16 A Schottky Rectifier |
D<sup>2</sup>PAK-3 TO-220-2 |
MBR1H100SF |
100 V, 1.0 A H-Series Schottky Rectifier |
SOD123-2 |
MBR20200CT |
200 V, 20 A Schottky Rectifier |
TO-220-3 |
MBR2030CTL |
30 V, 20 A Schottky Rectifier |
TO-220-3 |
MBR2080CT |
80 V, 20 A Schottky Rectifier |
TO-220-3 |
MBR2090CT |
90 V, 20 A Schottky Rectifier |
TO-220-3 |
MBR20H100CT |
100 V, 20 A H-Series Schottky Rectifier |
D<sup>2</sup>PAK-3 |
MBR20L45 |
45 V, 20 A L-Series Dual Schottky Rectifier |
MBR20L60CTG |
60 V, 20 A L-Series Schottky Rectifier |
TO-220-3 |
MBR230LSFT1G |
30 V, 2.0 A Schottky Rectifier |
SOD123-2 |
MBR2515L |
15 V, 25 A Schottky Rectifier |
TO-220-2 |
MBR2535CT |
35 V, 25 A Schottky Rectifier |
TO-220-3 |
MBR2535CTL |
TO-220-3 |
MBR2545CT |
45 V, 30 A Schottky Rectifier |
TO-220-3 |
MBR2H100SF |
100 V, 2.0 A H-Series Schottky Rectifier |
SOD123-2 |
MBR3045ST |
I<sup>2</sup>PAK-3 TO-220-3 |
MBR3045WT |
45 V, 30 A Schottky Rectifer |
TO-247-3 |
MBR30H100CT |
30 A, 100 V H-Series Schottky Rectifier |
TO-220-3 |
MBR30L45 |
45 V, 30 A L-Series Schottky Rectifier |
TO-220 FULLPAK-3 |
MBR30L60CTG |
60 V, 30 A L-Series Schottky Rectifier |
TO-220-3 |
MBR3100 |
100 V, 3.0 A Schottky Rectifier |
Axial Lead-2 |
MBR340 |
Axial Lead-2 |
MBR350 |
50 V, 3.0 A Schottky Rectifier |
Axial Lead-2 |
MBR360 |
3.0 A, 60 V Schottky Rectifier |
Axial Lead-2 |
MBR4015CTL |
40 A, 15 V Schottky Rectifier |
TO-220-3 |
MBR4015LWT |
TO-247-3 |
MBR40250 |
250 V, 40 A Schottky Rectifier |
TO-220-2 |
MBR40250T |
TO-220-3 |
MBR4045WT |
40 A, 45 V Schottky Rectifier |
TO-247-3 |
MBR40H100WT |
100 V, 40 A H-Series Schottky Rectifier |
TO-247-3 |
MBR40L45 |
45 V, 40 A L-Series Schottky Rectifier |
TO-220-3 |
MBR40L60CTG |
60 V, 40 A L-Series Schottky Rectifier |
TO-220-3 |
MBR41H100CT |
D<sup>2</sup>PAK-3 I<sup>2</sup>PAK-3 TO-220-3 |
MBR5H100MFS |
5.0 A, 100 V, Schottky Diode |
SO-8FL / DFN-5 |
MBR6045WT |
45 V, 60 A Schottky Rectifier |
TO-247-3 |
MBR60H100CT |
100 V, 60 A H-Series Schottky Rectifier |
D<sup>2</sup>PAK-3 TO-220-3 |
MBR60L45 |
45 V, 60 A L-Series Schottky Power Rectifier |
TO-220-3 TO-247-3 |
MBR7030WT |
30 V, 70 A Schottky Rectifier |
TO-247-3 |
MBR735 |
35 V, 7.5 A Schottky Rectifier |
TO-220-2 |
MBR745 |
45 V, 7.5 A Schottky Rectifier |
TO-220-2 |
MBRA120ET3 |
20 V, 1.0 A Low Leakage Schottky Rectifier |
SMA-2 |
MBRA130L |
SMA-2 |
MBRA140 |
SMA-2 |
MBRA160T3 |
SMA-2 |
MBRA1H100 |
SMA-2 |
MBRA210ET3 |
10 V, 2.0 A Low V<sub>F</sub> Schottky Rectifier |
SMA-2 |
MBRA210LT3 |
SMA-2 |
MBRA2H100 |
SMA-2 |
MBRA320T3G |
SMA-2 |
MBRA340 |
SMA-2 |
MBRAF1100 |
1.0 A, 100 V Schottky Rectifier |
SMA FL |
MBRAF1540 |
1.5 A, 40 V Schottky Rectifier |
SMA FL |
MBRAF260 |
60 V, 2.0 A Low V<sub>F</sub> Schottky Rectifier |
SMA FL |
MBRAF2H100 |
2.0 A, 100 V Schottky Rectifier |
SMA FL |
MBRAF3200 |
200 V, 3.0 A Schottky Rectifier |
SMA FL |
MBRAF360 |
3 A, 60 V Schottky Rectifier |
SMA FL |
MBRAF440 |
4.0 A, 40 V Schottky Rectifier |
SMA FL |
MBRB1045 |
D<sup>2</sup>PAK-3 DPAK-3 |
MBRB1545CT |
MBRB20100CT |
100 V, 20 A Schottky Rectifier |
MBRB20200CT |
MBRB2060CT |
60 V, 20 A Schottky Rectifier |
MBRB2515L |
MBRB2535CTL |
MBRB2545CT |
MBRB3030CT |
30 V, 30 A Schottky Rectifier |
MBRB3030CTL |
MBRB30H30CT-1 |
30 V, 30 A H-Series Schottky Rectifier |
MBRB30H60CT-1 |
60 V, 30 A H-Series Schottky Rectifier |
D<sup>2</sup>PAK-3 I<sup>2</sup>PAK-3 |
MBRB40250TG |
40 A, 250 V, Schottky Power Rectifier |
MBRB4030 |
30 V, 40 A Schottky Rectifier |
MBRB8H100T4G |
100 V, 8.0 A Schottky Rectifier |
MBRD1035CTL |
DPAK-3 |
MBRD320 |
DPAK-3 |
MBRD330 |
DPAK-3 |
MBRD340 |
DPAK-3 |
MBRD350 |
DPAK-3 |
MBRD360 |
60 V, 3.0 A Schottky Rectifier |
DPAK-3 |
MBRD5H100T4G |
100 V, 5 A Schottky Rectifier |
DPAK-3 |
MBRD620CT |
20 V, 6.0 A Schottky Rectifier |
DPAK-3 |
MBRD630CT |
30 V, 6.0 A Schottky Rectifier |
DPAK-3 |
MBRD640CT |
40 V, 6.0 A Schottky Rectifier |
DPAK-3 |
MBRD650CT |
50 V, 6.0 A Schottky Rectifier |
DPAK-3 |
MBRD660CT |
60 V, 6.0 A Schottky Rectifier |
DPAK-3 |
MBRD835L |
35 V, 8 A Schottky Rectifier |
DPAK-3 |
MBRF10H150CTG |
150 V, 10 A H-Series Dual Schottky Rectifier |
TO-220 FULLPAK-3 |
MBRF10L60CTG |
60 V, 10A Schottky Rectifier |
TO-220 FULLPAK-3 |
MBRF20100CT |
TO-220 FULLPAK-3 |
MBRF20200CT |
20A 200V Schottky Rectifier |
TO-220 FULLPAK-3 |
MBRF2045CTG |
45 V, 20 A Schottky Rectifier |
TO-220 FULLPAK-3 |
MBRF2060CT |
TO-220 FULLPAK-3 |
MBRF20H150CTG |
150 V, 20 A H-Series Dual Schottky Rectifier |
MBRF20L60CTG |
TO-220 FULLPAK-3 |
MBRF2545CT |
45 V, 25 A Schottky Rectifier |
TO-220 FULLPAK-3 |
MBRF30H100CTG |
100 V, 30 A H series Schottky Rectifier |
TO-220 FULLPAK-3 |
MBRF30H150CTG |
150 V, 30 A H-Series Dual Schottky Rectifier |
MBRF30L60CTG |
60 V, 30 A Schottky Rectifier |
TO-220 FULLPAK-3 |
MBRF40250T |
TO-220 FULLPAK-3 |
MBRM110E |
10 V, 1.0 A Low Leakage Schottky Rectifier |
POWERMITE-2 |
MBRM110L |
10 V, 1.0 A Low V<sub>F</sub> Schottky Rectifier |
POWERMITE-2 |
MBRM120E |
POWERMITE-2 |
MBRM120L |
POWERMITE-2 |
MBRM130L |
30 V, 1.0 A Low V<sub>F</sub> Schottky Rectifier |
POWERMITE-2 |
MBRM140 |
POWERMITE-2 |
MBRM1H100 |
POWERMITE-2 |
MBRM2H100 |
POWERMITE-2 |
MBRS1100 |
SMB-2 |
MBRS120 |
SMB-2 |
MBRS130 |
SMB-2 |
MBRS130L |
SMB-2 |
MBRS140 |
SMB-2 |
MBRS1540 |
40 V, 1.5 A Schottky Rectifier |
SMB-2 |
MBRS190 |
90 V, 1.0 A Schottky Rectifier |
SMB-2 |
MBRS2040L |
40 V, 2.0 A Schottky Rectifier |
SMB-2 |
MBRS230L |
30 V, 2.0 A Low V<sub>F</sub> Schottky Rectifier |
SMB-2 |
MBRS240L |
40 V, 2.0 A Low V<sub>F</sub> Schottky Rectifier |
SMB-2 |
MBRS260T3 |
SMB-2 |
MBRS2H100T3G |
100 V, 2.0 A Schottky Rectifier |
SMB-2 |
MBRS3100T3 |
SMC-2 |
MBRS3200 |
SMB-2 |
MBRS3201 |
200 V, 3 A Schottky Fast Soft-Recovery Power Rectifier |
SMC-2 |
MBRS340 |
SMC-2 |
MBRS360 |
SMB-2 SMC-2 |
MBRS410ET3 |
10 V, 4.0 A Schottky Rectifier |
SMC-2 |
MBRS410LT3 |
SMC-2 |
MBRS4201 |
200 V, 4.0 A Schottky Rectifier |
SMC-2 |
MBRS540 |
40 V, 5.0 A Schottky Rectifier |
SMC-2 |
MMBD101L |
7.0 V Low Noise Schottky Diode |
SOT-23-3 |
MMBD301L |
SOT-23-3 |
MMBD301M3T5G |
Schottky Diode |
SOT-723-3 |
MMBD330 |
MMBD352L |
7.0 V Schottky Diode, dual, series, UHF |
SOT-23-3 |
MMBD352W |
MMBD353L |
7.0 V Schottky Diode, dual, series reverse |
SOT-23-3 |
MMBD354L |
7.0 V Dual Common Cathode Schottky Diode |
SOT-23-3 |
MMBD355L |
7.0 V Dual Common Anode Schottky Diode |
SOT-23-3 |
MMBD452L |
30 V Schottky Diode, dual, series, UHF |
SOT-23-3 |
MMBD701L |
SOT-23-3 |
MMBD717L |
20 V Common Anode Schotty Diode |
MMBD770 |
MMDL101 |
Schottky Diode UHF 7.0 V |
SOD-323 |
MMDL301 |
SOD-323 |
MMDL770 |
Schottky Diode UHF 70 V |
SOD-323 |
MMSD301 |
SOD-123 |
MMSD701 |
SOD-123 |
NRVBA140 |
SMA-2 |
NRVBB1060 |
NRVBD1035CTL |
DPAK-3 |
NSR0130P2 |
30 V, 0.1 A Low IR Schottky Diode |
SOD-923-2 |
NSR0140P2 |
SOD-923-2 |
NSR0170P2 |
70 V, 0.1 A Low IR Schottky Diode |
SOD-923-2 |
NSR01F30NXT5G |
Schottky Diode |
DSN-2 |
NSR01L30NXT5G |
Schottky Diode |
DSN-2 |
NSR0230 |
30 V, 0.2 A Low V<sub>F</sub> Schottky Diode |
SOD-723-2 |
NSR0230P2 |
SOD-923-2 |
NSR0240HT1G |
40 V, 0.25 A Low IR Schottky Diode |
SOD-323 |
NSR0240P2 |
40 V, 0.2 A Low IR Schottky Diode |
SOD-923-2 |
NSR0240V2T1G |
SOD-523-2 |
NSR02F30NXT5G |
Schottky Diode |
DSN-2 |
NSR02L30NXT5G |
Schottky Diode |
DSN-2 |
NSR0320 |
20V 1A low VF SOD-323 Schottky Diode |
SOD-323 |
NSR0320XV6 |
23 V, 1.0 A Low V<sub>F</sub> Schottky Diode |
SOT-563 |
NSR0340HT1G |
40 V, 0.25 A Low V<sub>F</sub> SOD-323 Schottky Diode |
SOD-323 |
NSR0340P2 |
40 V, 0.2 A Low V<sub>F</sub> SOD-923 Schottky Diode |
SOD-923-2 |
NSR0340V2T1G |
40 V, 0.25 A Low V<sub>F</sub> SOD-523 Schottky Diode |
SOD-523-2 |
NSR0520V2T1G |
20 V, 0.5 A Low V<sub>F</sub> Schottky Diode |
SOD-523-2 |
NSR0530P2 |
30 V, 0.5 A Low V<sub>F</sub> Schottky Diode |
SOD-923-2 |
NSR05F20NX |
Schottky Diode |
DSN-2 |
NSR05F30NX |
DSN-2 |
NSR05F40NX |
DSN-2 |
NSR0620P2 |
20 V, 0.5 A Low IR Schottky Diode |
SOD-923-2 |
NSR1020MW2 |
20 V, 1.0 A Low V<sub>F</sub> Schottky Diode |
SOD-323 |
NSR10F20NX |
20 V Schottky Diode |
DSN-2 |
NSR10F30NX |
DSN-2 |
NSR10F40NX |
Schottky Diode |
DSN-2 |
NSR20F20NX |
DSN-2 |
NSR20F30NX |
Schottky Diode |
DSN-2 |
NSRLL30 |
30 V, 200 mA Low V<sub>F</sub> Schottky Diode |
SOD-523-2 |
NTSJ2080CTG |
Low Forward Voltage Rectifier, Dual, 20 A, 80 V |
TO-220 FULLPAK-3 |
NTSJ3080CTG |
Schottky Rectifier, Low Forward Voltage, Dual, 30 A, 80 V |
TO-220 FULLPAK-3 |
NTSJ30U80CTG |
Low Forward Voltage Rectifier, Dual, 30 A, 80 V |
TO-220 FULLPAK-3 |
NTST20100CTG |
20 A, 100 V, Dual Schottky Power Rectifier |
NTST20120CTG |
Low Forward Voltage Rectifier, Dual, 20 A, 120 V |
NTST20U100CTG |
NTST30100CTG |
30 A, 100 V, Dual Schottky Power Rectifier |
NTST30100SG |
30 A, 100 V Very Low Forward Voltage Trench-based Schottky Rectifier |
NTST30120CTG |
30 A, 120 V, Dual Low Forward Voltage Rectifier |
NTST30U100CTG |
NTST40120CTG |
40 A, 120 V, Dual Schottky Power Rectifier |
NTSV20100CTG |
TO-220-3 |
NTSV20120CTG |
20 A, 120 V, Dual Schottky Power Rectifier |
TO-220-3 |
NTSV2080CTG |
20 A, 80 V, Dual Schottky Power Rectifier |
TO-220-3 |
NTSV20U100CTG |
TO-220-3 |
NTSV20U80CTG |
TO-220-3 |
NTSV30100CTG |
TO-220-3 |
NTSV30100SG |
30 A, 100 V, Very Low Forward Voltage Trench-based Schottky Rectifier |
TO-220-3 |
NTSV30120CTG |
30 A, 120 V, Dual Schottky Power Rectifier |
TO-220-3 |
NTSV3080CTG |
30 A, 80 V, Dual Schottky Power Rectifier |
TO-220-3 |
RB520S30 |
SOD-523-2 |
RB521 |
SOD-523-2 |
RB751S40 |
SOD-523-2 |
RB751V40 |
SOD-323 |
SB007-03C |
Single Schottky Barrier Diode, 30 V, 70 mA |
SC-59 / CP |
SB007-03Q |
SC-70FL / MCPH-3 |
SB01-05C |
Single Schottky Barrier Diode, 50 V, 100 mA |
SC-59 / CP |
SB01-05Q |
SC-70FL / MCPH-3 |
SB01-15C |
Single Schottky Barrier Diode, 150 V, 100 mA |
SC-59 / CP |
SB02-09C |
Single Schottky Barrier Diode, 90 V, 200 mA |
SC-59 / CP |
SB05-03C |
Single Schottky Barrier Diode, 30 V, 500 mA |
SC-59 / CP |
SB05-03Q |
SC-70FL / MCPH-3 |
SB05-05C |
SC-59 / CP |
SB05W05C |
Schottky Barrier Diode, 50 V, 500 mA, Dual Cathode Common |
SC-59 / CP |
SB07-03C |
SC-59 / CP |
SB10-05P |
Single Schottky Barrier Diode, 50 V, 1 A |
SOT-89 / PCP-1 |
SB1003M3 |
Single Schottky Barrier Diode, 30 V, 1 A |
SC-70FL / MCPH-3 |
SB20-03P |
SOT-89 / PCP-1 |
SB2003M |
SC-88FL / MCPH-6 |
SB80W06T |
Single Schottky Barrier Diode, 60 V, 8.0 A, Dual Cathode Common |
DPAK / TP-FA |
SB80W10T |
Schottky Barrier Diode, 100 V, 8 A, Dual Cathode Common |
DPAK / TP-FA |
SBE002 |
CPH-6 |
SBE805 |
Dual Schottky Barrier Diode, 30 V, 500 mA |
CPH-5 |
SBE807 |
Dual Schottky Barrier Diode, 30 V, 1 A |
CPH-5 |
SBE808 |
Dual Schottky Barrier Diode, 15 V, 1 A |
SC-88AFL / MCPH-5 |
SBE812 |
Dual Schottky Barrier Diode, 60 V, 1 A |
SOT-28FL / VEC-8 |
SBE813 |
Dual Schottky Barrier Diode, 30 V, 3 A |
SOT-28FL / VEC-8 |
SBS811 |
SOT-28FL / VEC-8 |
SBS817 |
Dual Schottky Barrier Diode, 15 V, 2 A |
SOT-383FL / EMH-8 |
SBS818 |
Dual Schottky Barrier Diode, 30 V, 2.0 A |
SOT-383FL / EMH-8 |
SBS822 |
Dual Schottky Barrier Diode, 20 V, 1 A |
SC-88AFL / MCPH-5 |
SBX201C |
Dual Schottky Barrier Diode, 2 V |
SC-59 / CP |
SOT723 SCHOTTKY |
SOT-723-3 |
SS0503SH |
Single Schottky Barrier Diode, 30 V, 0.5 A |
SC-88FL / MCPH-6 |
SS16 |
SMA-2 |
SS2003M |
SC-88FL / MCPH-6 |
SS24 |
SMB-2 |
SS26 |
60 V, 2.0 A Schottky Rectifier |
SMB-2 |
SS3003CH |
CPH-6 |
