龙人旗下深圳市龙芯世纪科技有限公司
  • 调谐二极管 齐纳二极管
  • 发布时间:2013/9/9 11:08:40   修改时间:2013/9/9 11:08:40 浏览次数:1623
  • 调谐二极管
    频率控制二极管
    安森美半导体提供调谐二极管,用于频率控制和频率调谐电路。(10)
    调谐二极管Excel 文档格式选型指南
    Product Description Package Type
    MMBV105GL Tuning Diode 30 V C3/C25 = 4.0-6.5 SOT-23-3
    MMBV3102L Tuning Diode 30 V C3/C25 = 4.5-4.8 SOT-23-3
    SVC203C Varactor Diode, 16 V, Dual Common-Cathode SC-59 / CP
    SVC230 Varactor Diode, 16 V, Dual SC-59 / CP
    SVC236 Varactor Diode, 16 V, Dual SC-59 / CP
    SVC270 Varactor Diode, 16 V, Dual SC-70FL / MCPH-3
    SVC272 Varactor Diode VR;16V IR;50nA CR;2.3 min Dual MCPH3 SC-70FL / MCPH-3
    SVC276 Varactor Diode, 16 V, Dual SC-70FL / MCPH-3
    SVC704 Varactor Diode, 16 V, Single SC-70FL / MCPH-3
    SVC710 Varactor Diode, 15 V, Single SC-70FL / MCPH-3
    齐纳二极管
    齐纳稳压二极管
    安森美半导体提供齐纳二极管,用于稳压电路。(525)
    齐纳二极管Excel 文档格式选型指南
    Product Description
    1SMA5926B 1.5 Watt SMA Zener Voltage Regulators 11 V
    1SMB5953B 150 V, 3.0 W Zener Diode Voltage Regulator
    MM3Z27V 225 mW 27 V ±5% Zener Diode Voltage Regulator
    MM3Z3V3 225 mW 3.3 V ±5% Zener Diode Voltage Regulator
    MM3Z4V3S 4.3 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    MM3Z7V5S 7.5 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    MM3Z9V1 225 mW 9.1 V ±5% Zener Diode Voltage Regulator
    MMBZ5245E 225 W, 15 V Zener Diode Voltage Regulator
    MMSZ24 500 mW 24 V ±5% Zener Diode Voltage Regulator
    MMSZ4679 2.0 V Low Current Zener Diode Voltage Regulator
    MMSZ4688 4.7 V Low Current Zener Diode Voltage Regulator
    MMSZ4689 5.1 V Low Current Zener Diode Voltage Regulator
    MMSZ4693 7.5 V Zener Diode Voltage Regulator
    MMSZ4694 8.2 V Zener Diode Voltage Regulator
    MMSZ4704 17 V Low Current Zener Diode Voltage Regulator
    MMSZ4711 27 V Low Current Zener Diode Voltage Regulator
    MMSZ52 Zener Diode 500 mW SOD-123
    NZ9F4V3S 4.3 V, 200 mW Zener Diode Voltage Regulator 2% Tolerance
    NZ9F4V7S 4.7 V, 200 mW Zener Diode Voltage Regulator 2% Tolerance
    1N53 5 Watt Surmetic 40 Zener Voltage Regulators
    1N5335B 3.9 V, 5.0 W Zener Diode Voltage Regulator
    1N5913B 3.3 V, 3.0 W Zener Diode Voltage Regulator
    1N5917B 4.7 V, 3.0 W Zener Diode Voltage Regulator
    1N5919B 5.6 V, 3.0 W Zener Diode Voltage Regulator
    1N5920B 6.2 V, 3.0 W Zener Diode Voltage Regulator
    1N5921B 6.8 V, 3.0 W Zener Diode Voltage Regulator
    1N5923B 8.2 V, 3.0 W Zener Diode Voltage Regulator
    1N5924B 9.1 V, 3.0 W Zener Diode Voltage Regulator
    1N5925B 10 V, 3.0 W Zener Diode Voltage Regulator
    1N5927B 12 V, 3.0 W Zener Diode Voltage Regulator
    1N5929B 12 V, 3.0 W Zener Diode Voltage Regulator
    1N5929BRNG ZEN SUR30 REG 3W 15V
    1N5931B 18 V, 3.0 W Zener Diode Voltage Regulator
    1N5932B 20 V, 3.0 W Zener Diode Voltage Regulator
    1N5932BRNG ZEN SUR30 REG 3W 20V
    1N5934B 24 V, 3.0 W Zener Diode Voltage Regulator
    1N5934BRNG ZEN SUR30 REG 3W 24V
    1N5935B 27 V, 3.0 W Zener Diode Voltage Regulator
    1N5937B 33 V, 3.0 W Zener Diode Voltage Regulator
    1N5938B 36 V, 3.0 W Zener Diode Voltage Regulator
    1N5940B 43 V, 3.0 W Zener Diode Voltage Regulator
    1N5941B 47 V, 3.0 W Zener Diode Voltage Regulator
    1N5942B 51 V, 3.0 W Zener Diode Voltage Regulator
    1N5946B 75 V, 3.0 W Zener Diode Voltage Regulator
    1N5948B 91 V, 3.0 W Zener Diode Voltage Regulator
    1N5952B 130 V, 3.0 W Zener Diode Voltage Regulator
    1N5953B 150 V, 3.0 W Zener Diode Voltage Regulator
    1N5955B 180 V, 3.0 W Zener Diode Voltage Regulator
    1N5956B 200 V, 3.0 W Zener Diode Voltage Regulator
    1PMT5920B 6.2 V, 3.2 Watt Zener Diode Voltage Regulator
    1PMT5921B 6.8 V, 3.2 Watt Zener Diode Voltage Regulator
    1PMT5924B  9.1 V, 3.2 Watt Zener Diode Voltage Regulator
    1PMT5927B 12 V, 3.2 Watt Zener Diode Voltage Regulator
    1PMT5929B 15 V, 3.2 Watt Zener Diode Voltage Regulator
    1PMT5933B 22 V, 3.2 Watt Zener Diode Voltage Regulator
    1PMT5935B 27 V, 3.2 Watt Zener Diode Voltage Regulator
    1PMT5941B 47 V, 3.2 Watt Zener Diode Voltage Regulator
    1SMA5913B 3.3 V, 1.5.0 W Zener Diode Voltage Regulator
    1SMA5914B 3.6 V, 1.5.0 W Zener Diode Voltage Regulator
    1SMA5915B 3.9 V, 1.5.0 W Zener Diode Voltage Regulator
    1SMA5916B 4.3 V, 1.5.0 W Zener Diode Voltage Regulator
    1SMA5917B 4.7 V, 1.5.0 W Zener Diode Voltage Regulator
    1SMA5918B 5.1 V, 1.5.0 W Zener Diode Voltage Regulator
    1SMA5919B 5.6 V, 1.5.0 W Zener Diode Voltage Regulator
    1SMA5920B 6.2 V, 1.5.0 W Zener Diode Voltage Regulator
    1SMA5921B 6.8 V, 1.5.0 W Zener Diode Voltage Regulator
    1SMA5922B 7.5 V, 1.5.0 W Zener Diode Voltage Regulator
    1SMA5923B 8.2 V, 1.5.0 W Zener Diode Voltage Regulator
    1SMA5924B 9.1 V, 1.5.0 W Zener Diode Voltage Regulator
    1SMA5925B 10 V, 1.5.0 W Zener Diode Voltage Regulator
    1SMA5927B 12 V, 1.5.0 W Zener Diode Voltage Regulator
    1SMA5928B 13 V, 1.5.0 W Zener Diode Voltage Regulator
    1SMA5929B 15 V, 1.5.0 W Zener Diode Voltage Regulator
    1SMA5930B 16 V, 1.5.0 W Zener Diode Voltage Regulator
    1SMA5931B 18 V, 1.5.0 W Zener Diode Voltage Regulator
    1SMA5932B 20 V, 1.5.0 W Zener Diode Voltage Regulator
    1SMA5933B 22 V, 1.5.0 W Zener Diode Voltage Regulator
    1SMA5934B 24 V, 1.5.0 W Zener Diode Voltage Regulator
    1SMA5935B 27 V, 1.5.0 W Zener Diode Voltage Regulator
    1SMA5936B 30 V, 1.5.0 W Zener Diode Voltage Regulator
    1SMA5937B 33 V, 1.5.0 W Zener Diode Voltage Regulator
    1SMA5938B 36 V, 1.5.0 W Zener Diode Voltage Regulator
    1SMA5939B 39 V, 1.5.0 W Zener Diode Voltage Regulator
    1SMA5940B 43 V, 1.5.0 W Zener Diode Voltage Regulator
    1SMA5941B 47 V, 1.5.0 W Zener Diode Voltage Regulator
    1SMA5942B 51 V, 1.5.0 W Zener Diode Voltage Regulator
    1SMA5943B 56 V, 1.5.0 W Zener Diode Voltage Regulator
    1SMA5945B 68 V, 1.5.0 W Zener Diode Voltage Regulator
    1SMB5913B 3.3 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5914B 3.6 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5915B 3.9 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5916B 4.3 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5917B 4.7 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5918B 5.1 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5919B 5.6 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5920B 6.2 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5921B 6.8 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5922B 7.5 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5923B 8.2 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5924B 9.1 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5925B 10 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5926B 11 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5927B 12 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5928B 13 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5929B 15 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5930B 16 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5931B 18 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5932B 20 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5933B 22 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5934B 24 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5935B 27 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5936B 30 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5937B 33 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5938B 36 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5939B 39 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5940B 43 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5941B 47 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5942B 51 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5943B 56  V, 3.0 W Zener Diode Voltage Regulator
    1SMB5944B 62 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5945B 68 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5946B 75 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5947B 82 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5948B 91 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5949B 100 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5951B 120 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5952B 130 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5954B 160 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5955B 180 V, 3.0 W Zener Diode Voltage Regulator
    1SMB5956B 200 V, 3.0 W Zener Diode Voltage Regulator
    3EZ13D5 13 V, 3.0 W SUR30 Zener Diode Voltage Regulator
    3EZ18D11 18 V, 3.0 W SUR30 Zener Diode Voltage Regulator
    3EZ6.2D5 6.2 V, 3.0 W SUR30 Zener Diode Voltage Regulator
    BZG03C15 600 Watt SMA Energy Rated Zener, 150 V
    BZG03C150 600 Watt SMA Energy Rated Zener, 15 V
    BZX84B12 225 mW 12 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    BZX84B15 225 mW 15 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    BZX84B16 225 mW 16 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    BZX84B18 225 mW 18 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    BZX84B22 225 mW 22 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    BZX84B24 225 mW 24 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    BZX84B5V1 225 mW 5.1 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    BZX84B5V6 22 5 mW 5.6 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    BZX84B6V2 225 mW 6.2 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    BZX84B6V8 225 mW 6.8 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    BZX84B7V5 225 mW 7.5 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    BZX84B8V2 225 mW 8.2 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    BZX84B9V1 225 mW 9.1 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    BZX84C10E Energy Rated Zeners in SOT-23 10V 225 W
    BZX84C10L 225 mW 10 V ±5% Zener Diode Voltage Regulator
    BZX84C11E Energy Rated Zeners in SOT-23 11V 225 W
    BZX84C11L 225 mW 11 V ±5% Zener Diode Voltage Regulator
    BZX84C12E Energy Rated Zeners in SOT-23 12V 225 W
    BZX84C12L 225 mW 12 V ±5% Zener Diode Voltage Regulator
    BZX84C13E Energy Rated Zeners in SOT-23 13V 225 W
    BZX84C13L 225 mW 13 V ±5% Zener Diode Voltage Regulator
    BZX84C15E Energy Rated Zeners in SOT-23 15V 225 W
    BZX84C15L 225 mW 15 V ±5% Zener Diode Voltage Regulator
    BZX84C16E Energy Rated Zeners in SOT-23 16V 225 W
    BZX84C16L 225 mW 16 V ±5% Zener Diode Voltage Regulator
    BZX84C18E Energy Rated Zeners in SOT-23 18V 225 W
    BZX84C18L 225 mW 18 V ±5% Zener Diode Voltage Regulator
    BZX84C20E Energy Rated Zeners in SOT-23 20V 225 W
    BZX84C20L 225 mW 20 V ±5% Zener Diode Voltage Regulator
    BZX84C22E Energy Rated Zeners in SOT-23 22V 225 W
    BZX84C22L 225 mW 22 V ±5% Zener Diode Voltage Regulator
    BZX84C24E Energy Rated Zeners in SOT-23 24V 225 W
    BZX84C24L 225 mW 24 V ±5%Zener Diode Voltage Regulator
    BZX84C27E Energy Rated Zeners in SOT-23 27V 225 W
    BZX84C27L 225 mW 27 V ±5% Zener Diode Voltage Regulator
    BZX84C2V4E Energy Rated Zeners in SOT-23 2.4 V 225 W
    BZX84C2V4L 225 mW 2.4 V ±5% Zener Diode Voltage Regulator
    BZX84C2V7E Energy Rated Zeners in SOT-23 2.7 V 225 W
    BZX84C2V7L 225 mW 2.7 V ±5% Zener Diode Voltage Regulator
    BZX84C30E Energy Rated Zeners in SOT-23 30V 225 W
    BZX84C30L 225 mW 30 V ±5% Zener Diode Voltage Regulator
    BZX84C33E Energy Rated Zeners in SOT-23 33V 225 W
    BZX84C33L 225 mW 33 V ±5% Zener Diode Voltage Regulator
    BZX84C36E Energy Rated Zeners in SOT-23 36V 225 W
    BZX84C36L 225 mW 36 V ±5% Zener Diode Voltage Regulator
    BZX84C39E Energy Rated Zeners in SOT-23 39V 225 W
    BZX84C39L 225 mW 39 V ±5% Zener Diode Voltage Regulator
    BZX84C3V0E Energy Rated Zeners in SOT-23 3.0 V 225 W
    BZX84C3V0L 225 mW 3.0 V ±5% Zener Diode Voltage Regulator
    BZX84C3V3E Energy Rated Zeners in SOT-23 3.3 V 225 W
    BZX84C3V3L 225 mW 3.3 V ±5% Zener Diode Voltage Regulator
    BZX84C3V6E Energy Rated Zeners in SOT-23 3.6 V 225 W
    BZX84C3V6L 225 mW 3.6 V ±5% Zener Diode Voltage Regulator
    BZX84C3V9E Energy Rated Zeners in SOT-23 3.9 V 225 W
    BZX84C3V9L 225 mW 3.9 V ±5% Zener Diode Voltage Regulator
    BZX84C43E Energy Rated Zeners in SOT-23 43 V 225 W
    BZX84C43L 225 mW 43 V ±5% Zener Diode Voltage Regulator
    BZX84C47E Energy Rated Zeners in SOT-23 47 V 225 W
    BZX84C47L 225 mW 47 V ±5% Zener Diode Voltage Regulator
    BZX84C4V3E Energy Rated Zeners in SOT-23 4.3 V 225 W
    BZX84C4V3L 225 mW 4.3 V ±5% Zener Diode Voltage Regulator
    BZX84C4V7E Energy Rated Zeners in SOT-23 4.7 V 225 W
    BZX84C4V7L 225 mW 4.7 V ±5% Zener Diode Voltage Regulator
    BZX84C51E Energy Rated Zeners in SOT-23 51 V 225 W
    BZX84C51L 225 mW 51 V ±5% Zener Diode Voltage Regulator
    BZX84C56E Energy Rated Zeners in SOT-23 56 V 225 W
    BZX84C56L 225 mW 56 V ±5% Zener Diode Voltage Regulator
    BZX84C5V1E 225 W, 5.1 V Zener Diode Voltage Regulator
    BZX84C5V1L 225 mW 5.1 V ±5% Zener Diode Voltage Regulator
    BZX84C5V6E 225 W, 5.6 V Zener Diode Voltage Regulator
    BZX84C5V6L 225 mW 5.6 V ±5% Zener Diode Voltage Regulator
    BZX84C62E Energy Rated Zeners in SOT-23 62 V 225 W
    BZX84C62L 225 mW 62 V ±5% Zener Diode Voltage Regulator
    BZX84C68E Energy Rated Zeners in SOT-23 68 V 225 W
    BZX84C68L 225 mW 68 V ±5% Zener Diode Voltage Regulator
    BZX84C6V2E 225 W, 6.2 V Zener Diode Voltage Regulator
    BZX84C6V2L 225 mW, 6.2 V ±5% Zener Diode Voltage Regulator
    BZX84C6V8E Energy Rated Zeners in SOT-23 6.8 V 225 W
    BZX84C6V8L 225 mW 6.8 V ±5% Zener Diode Voltage Regulator
    BZX84C75E Energy Rated Zeners in SOT-23 75 V 225 W
    BZX84C75L 225 mW 75 V ±5% Zener Diode Voltage Regulator
    BZX84C7V5E Energy Rated Zeners in SOT-23 7.5 V 225 W
    BZX84C7V5L 225 mW 7.5 V ±5% Zener Diode Voltage Regulator
    BZX84C8V2E Energy Rated Zeners in SOT-23 8.2 V 225 W
    BZX84C8V2L 225 mW 8.2 V ±5% Zener Diode Voltage Regulator
    BZX84C9V1E Energy Rated Zeners in SOT-23 9.1 V 225 W
    BZX84C9V1L 225 mW 9.1 V ±5% Zener Diode Voltage Regulator
    DF6A6.8 Quad Diode Array for ESD Protection
    MM3Z10V 200 mW 10 V ±5% Zener Diode Voltage Regulator
    MM3Z10VS 10 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    MM3Z11V 225 mW 11 V ±5% Zener Diode Voltage Regulator
    MM3Z12V 225 mW 12 V ±5% Zener Diode Voltage Regulator
    MM3Z12VS 12 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    MM3Z13V 225 mW 13 V ±5% Zener Diode Voltage Regulator
    MM3Z15V 200 mW 15 V ±5% Zener Diode Voltage Regulator
    MM3Z15VS 15 V Tight Tolerance Zener Diode Voltage Regulator
    MM3Z16V 225 mW 16 V ±5% Zener Diode Voltage Regulator
    MM3Z16VS 16 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    MM3Z18V 200 mW 18 V ±5% Zener Diode Voltage Regulator
    MM3Z18VS 18 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    MM3Z20V 225 mW 20 V ±5% Zener Diode Voltage Regulator
    MM3Z22V 225 mW 22 V ±5%Zener Diode Voltage Regulator
    MM3Z22VS 200 mW 22 V ±2% Zener Diode Voltage Regulator
    MM3Z24V 225 mW 24 V ±5% Zener Diode Voltage Regulator
    MM3Z24VS 225 mW 24 V 2% Zener Diode Voltage Regulator
    MM3Z27VS 200 mW 27 V ±2% Zener Diode Voltage Regulator
    MM3Z2V4 200 mW 2.4 V Standard Tolerace Zener Diode Voltage Regulator
    MM3Z2V7 225 mW 2.7 V ±5% Zener Diode Voltage Regulator
    MM3Z30V 225 mW 30 V ±5% Zener Diode Voltage Regulator
    MM3Z33V 200 mW 33 V Zener Diode Voltage Regulator
    MM3Z33VS 200 mW 33 V ±2% Zener Diode Voltage Regulator
    MM3Z36V 225 mW 36 V ±5% Zener Diode Voltage Regulator
    MM3Z36VS 225 mW 36 V 2% Zener Diode Voltage Regulator
    MM3Z39V 225 mW 39 V ±5% Zener Diode Voltage Regulator
    MM3Z3V0 225 mW 3.0 V ±5% Zener Diode Voltage Regulator
    MM3Z3V3S 3.3 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    MM3Z3V6 225 mW 3.6 V ±5% Zener Diode Voltage Regulator
    MM3Z3V9 225 mW 3.9 V ±5% Zener Diode Voltage Regulator
    MM3Z3V9S 3.9 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    MM3Z43V 200 mW 43 V ±5% Zener Diode Voltage Regulator
    MM3Z4V3 200 mW 4.3 V ±5% Zener Diode Voltage Regulator
    MM3Z4V7 225 mW 4.7 V ±5% Zener Diode Voltage Regulator
    MM3Z4V7S 4.7 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    MM3Z5V1 225 mW 5.1 V ±5% Zener Diode Voltage Regulator
    MM3Z5V1S 5.1 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    MM3Z5V6 225 mW 5.6 V ±5% Zener Diode Voltage Regulator
    MM3Z5V6S 5.6 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    MM3Z6V2 225 mW 6.2 V ±5% Zener Diode Voltage Regulator
    MM3Z6V2S 6.2 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    MM3Z6V8 225 mW 6.8 V ±5% Zener Diode Voltage Regulator
    MM3Z6V8S 6.8 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    MM3Z7V5 225 mW 7.5 V ±5% Zener Diode Voltage Regulator
    MM3Z8V2 225 mW 8.2 V ±5% Zener Diode Voltage Regulator
    MM3Z8V2S 8.2 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    MM3Z9V1S 9.1 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    MM5Z10V 200 mW 10 V ±5% Zener Diode Voltage Regulator
    MM5Z12V 200 mW 12 V ±5% Zener Diode Voltage Regulator
    MM5Z15V 200 mW 15 V ±5% Zener Diode Voltage Regulator
    MM5Z16V 200 mW 16 V ±5% Zener Diode Voltage Regulator
    MM5Z18V 200 mW 18 V ±5% Zener Diode Voltage Regulator
    MM5Z20V 200 mW 20 V ±5% Zener Diode Voltage Regulator
    MM5Z24V 200 mW 24 V ±5% Zener Diode Voltage Regulator
    MM5Z27V 200 mW 27 V ±5% Zener Diode Voltage Regulator
    MM5Z2V4 200 mW 2.4 V Standard Tolerance Zener Diode Voltage Regulator
    MM5Z2V4S 2.4 V Tight Tolerance Zener Diode Voltage Regulator
    MM5Z2V7 200 mW 2.7 V ±5% Zener Diode Voltage Regulator
    MM5Z33V 200 mW 33 V ±5% Zener Diode Voltage Regulator
    MM5Z36V 200 mW 36 V ±5% Zener Diode Voltage Regulator
    MM5Z3V0 200 mW 3.0 V ±5% Zener Diode Voltage Regulator
    MM5Z3V3 200 mW 3.3 V ±5% Zener Diode Voltage Regulator
    MM5Z3V6 200 mW 3.6 V ±5% Zener Diode Voltage Regulator
    MM5Z47V 200 mW 47 V ±5% Zener Diode Voltage Regulator
    MM5Z4V3 200 mW 4.3 V ±5% Zener Diode Voltage Regulator
    MM5Z4V7 200 mW 4.7 V ±5% Zener Diode Voltage Regulator
    MM5Z4V7S 4.7 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    MM5Z5V1 200 mW 5.1 V ±5% Zener Diode Voltage Regulator
    MM5Z5V1S 5.1 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    MM5Z5V6 200 mW 5.6 V ±5% Zener Diode Voltage Regulator
    MM5Z5V6S 5.6 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    MM5Z6V2 200 mW 6.2 V ±5% Zener Diode Voltage Regulator
    MM5Z6V2S 6.2 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    MM5Z6V8 200 mW 6.8 V ±5% Zener Diode Voltage Regulator
    MM5Z6V8S 6.8 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    MM5Z7V5 200 mW 7.5 V ±5% Zener Diode Voltage Regulator
    MM5Z8V2 200 mW 8.2 V ±5% Zener Diode Voltage Regulator
    MM5Z8V2S 8.2 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    MM5Z9V1 200 mW 9.1  V ±5% Zener Diode Voltage Regulator
    MM5Z9V1S 9.1 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    MMBZ15VD 15 V Dual Common Cathode Zener Diode Transient Voltage Suppressor
    MMBZ18V 18 V Dual Common Anode Zener Diode Transient Voltage Suppressor
    MMBZ20V 20 V Dual Common Anode Zener Diode Transient Voltage Suppressor
    MMBZ27V 27 V Dual Common Anode Zener Diode Transient Voltage Suppressor
    MMBZ27VC 27 V Dual Common Cathode Zener Diode Transient Voltage Suppressor
    MMBZ33V 33 V Dual Common Anode Zener Diode Transient Voltage Suppressor
    MMBZ5221B 225 mW 2.4 V ±5% Zener Diode Voltage Regulator
    MMBZ5222B 225 mW 2.5 V ±5% Zener Diode Voltage Regulator
    MMBZ5223B 225 mW 2.7 V ±5% Zener Diode Voltage Regulator
    MMBZ5225B 225 mW 3.0 V ±5% Zener Diode Voltage Regulator
    MMBZ5225BL Zener
    MMBZ5226B 225 mW 3.3 V ±5% Zener Diode Voltage Regulator
    MMBZ5227B 225 mW 3.6 V ±5% Zener Diode Voltage Regulator
    MMBZ5228B 225 mW 3.9 V ±5% Zener Diode Voltage Regulator
    MMBZ5229B 225 mW 4.3 V ±5% Zener Diode Voltage Regulator
    MMBZ5230B 225 mW 4.7 V ±5% Zener Diode Voltage Regulator
    MMBZ5231B 225 mW 5.1 V ±5% Zener Diode Voltage Regulator
    MMBZ5231BL Small Signal 5.1V 5%
    MMBZ5231E 225 W, 5.1 V Zener Diode Voltage Regulator
    MMBZ5232B 225 mW 5.6 V ±5% Zener Diode Voltage Regulator
    MMBZ5233B 225 mW 6.0 V ±5% Zener Diode Voltage Regulator
    MMBZ5234B 225 mW 6.2 V ±5% Zener Diode Voltage Regulator
    MMBZ5235B 225 mW 6.8 V ±5% Zener Diode Voltage Regulator
    MMBZ5236B 225 mW 7.5 V ±5% Zener Diode Voltage Regulator
    MMBZ5237B 225 mW 8.2 V ±5% Zener Diode Voltage Regulator
    MMBZ5238B 225 mW 8.7 V ±5% Zener Diode Voltage Regulator
    MMBZ5239B 225 mW 9.1 V ±5% Zener Diode Voltage Regulator
    MMBZ5239E 225 W, 9.1 V Zener Diode Voltage Regulator
    MMBZ5240B 225 mW 10 V ±5% Zener Diode Voltage Regulator
    MMBZ5240E 225 W Energy Rated Zener 10 V SOT-23
    MMBZ5241B 225 mW 11 V ±5% Zener Diode Voltage Regulator
    MMBZ5242B 225 mW 12 V ±5% Zener Diode Voltage Regulator
    MMBZ5242E 225 W, 12 V Zener Diode Voltage Regulator
    MMBZ5243B 225 mW 13 V ±5% Zener Diode Voltage Regulator
    MMBZ5244B 225 mW 14 V ±5% Zener Diode Voltage Regulator
    MMBZ5245B 225 mW 15 V ±5% Zener Diode Voltage Regulator
    MMBZ5246B 225 mW 16 V ±5% Zener Diode Voltage Regulator
    MMBZ5247B 225 mW 17 V ±5% Zener Diode Voltage Regulator
    MMBZ5248B 225 mW 18 V ±5% Zener Diode Voltage Regulator
    MMBZ5248E 225 W, 18 V Zener Diode Voltage Regulator
    MMBZ5249B 225 mW 19 V ±5% Zener Diode Voltage Regulator
    MMBZ5250B 225 mW 20 V ±5% Zener Diode Voltage Regulator
    MMBZ5250E 225 W Energy Rated Zener 20 V SOT-23
    MMBZ5251B 225 mW 22 V ±5% Zener Diode Voltage Regulator
    MMBZ5252B 225 mW 24 V ±5% Zener Diode Voltage Regulator
    MMBZ5252E 225 W Energy Rated Zener 24 V SOT-23
    MMBZ5253B 225 mW 25 V ±5% Zener Diode Voltage Regulator
    MMBZ5253E 225 W, 25 V Zener Diode Voltage Regulator
    MMBZ5254B 225 mW 27 V ±5% Zener Diode Voltage Regulator
    MMBZ5255B 225 mW 28 V ±5% Zener Diode Voltage Regulator
    MMBZ5256B 225 mW 30 V ±5% Zener Diode Voltage Regulator
    MMBZ5256E 225 W Energy Rated Zener 30 V SOT-23
    MMBZ5257B 225 mW 33 V ±5% Zener Diode Voltage Regulator
    MMBZ5257E 225 W Energy Rated Zener 33 V SOT-23
    MMBZ5258B 225 mW 36 V ±5% Zener Diode Voltage Regulator
    MMBZ5258E 225 W Energy Rated Zener 36 V SOT-23
    MMBZ5259B 225 mW 39 V ±5% Zener Diode Voltage Regulator
    MMBZ5259BL 39V Zener
    MMBZ5260B 225 mW 43 V ±5% Zener Diode Voltage Regulator
    MMBZ5260E 225 W Energy Rated Zener 43 V SOT-23
    MMBZ5261B 225 mW 47 V ±5% Zener Diode Voltage Regulator
    MMBZ5261E 225 W, 47 V Zener Diode Voltage Regulator
    MMBZ5262E 225 W Energy Rated Zener 51 V SOT-23
    MMBZ5263B 225 mW 56 V ±5% Zener Diode Voltage Regulator
    MMBZ5263BL 56V Zener
    MMBZ5263E 225 W Energy Rated Zener 56 V SOT-23
    MMBZ5264B 225 mW 60 V ±5% Zener Diode Voltage Regulator
    MMBZ5268B 225 mW 82 V ±5% Zener Diode Voltage Regulator
    MMBZ5270B 225 mW 91 V ±5% Zener Diode Voltage Regulator
    MMBZ5V6A 5.6 V Dual Common Anode Zener Diode Transient Voltage Suppressor
    MMBZ6V2A 6.2 V Dual Common Anode Zener Diode Transient Voltage Suppressor
    MMBZ6V8A 6.8 V Dual Common Anode Zener Diode Transient Voltage Suppressor
    MMBZ9V1A 9.1 V Dual Common Anode Zener Diode Transient Voltage Suppressor
    MMSZ10 500 mW 10 V ±5% Zener Diode Voltage Regulator
    MMSZ11 500 mW 11 V ±5% Zener Diode Voltage Regulator
    MMSZ12 500 mW 12 V ±5% Zener Diode Voltage Regulator
    MMSZ13 500 mW 13 V ±5% Zener Diode Voltage Regulator
    MMSZ13E 225 W Energy Rated Zener 13 V SOD-123
    MMSZ15 500 mW 15 V ±5% Zener Diode Voltage Regulator
    MMSZ15E 225 W Energy Rated Zener 15 V SOD-123
    MMSZ16 500 mW 16 V ±5% Zener Diode Voltage Regulator
    MMSZ18 500 mW 18 V ±5% Zener Diode Voltage Regulator
    MMSZ18E 18 V, 225 W Zener Diode Voltage Regulator
    MMSZ20 500 mW 20 V ±5% Zener Diode Voltage Regulator
    MMSZ22 500 mW 22 V ±5% Zener Diode Voltage Regulator
    MMSZ27 500 mW 27 V ±5% Zener Diode Voltage Regulator
    MMSZ27E 225 W Energy Rated Zener 27 V SOD-123
    MMSZ2V4 500 mW 2.4 V ±5% Zener Diode Voltage Regulator
    MMSZ2V7 500 mW 2.7 V ±5% Zener Diode Voltage Regulator
    MMSZ2V7E 225 W Energy Rated Zener 2.7 V SOD-123
    MMSZ30 500 mW 30 V ±5% Zener Diode Voltage Regulator
    MMSZ33 500 mW 33 V ±5% Zener Diode Voltage Regulator
    MMSZ33E 225 W Energy Rated Zener 33 V SOD-123
    MMSZ36 500 mW 36 V ±5% Zener Diode Voltage Regulator
    MMSZ39 500 mW 39 V ±5% Zener Diode Voltage Regulator
    MMSZ3V0 500 mW 3.0 V ±5% Zener Diode Voltage Regulator
    MMSZ3V3 500 mW 3.3 V ±5% Zener Diode Voltage Regulator
    MMSZ3V6 500 mW 3.6 V ±5% Zener Diode Voltage Regulator
    MMSZ3V9 500 mW 3.9 V ±5% Zener Diode Voltage Regulator
    MMSZ43 500 mW 43 V ±5% Zener Diode Voltage Regulator
    MMSZ4678 1.8 V Low Current Zener Diode Voltage Regulator
    MMSZ4680 2.2 V Low Current Zener Diode Voltage Regulator
    MMSZ4680E 2.2 V, 225 W Low Current Zener Diode Voltage Regulator
    MMSZ4681 2.4 V Low Current Zener Diode Voltage Regulator
    MMSZ4682 2.7 V Low Current Zener Diode Voltage Regulator
    MMSZ4683 3.0 V Low Current Zener Diode Voltage Regulator
    MMSZ4684 3.3 V Low Current Zener Diode Voltage Regulator
    MMSZ4685 3.6 V Low Current Zener Diode Voltage Regulator
    MMSZ4686 3.9 V Low Current Zener Diode Voltage Regulator
    MMSZ4687 4.3 V Low Current Zener Diode Voltage Regulator
    MMSZ4689E 225 W Energy Rated Low Current Zener 5.1 V SOD-123
    MMSZ4690 5.6 V Low Current Zener Diode Voltage Regulator
    MMSZ4690E 225 W Energy Rated Low Current Zener 5.6 V SOD-123
    MMSZ4691 6.2 V Zener Diode Voltage Regulator
    MMSZ4692 6.8 V Zener Diode Voltage Regulator
    MMSZ4696 9.1 V Zener Diode Voltage Regulator
    MMSZ4697 10 V Zener Diode Voltage Regulator
    MMSZ4698 11 V Zener Diode Voltage Regulator
    MMSZ4699 12 V Zener Diode Voltage Regulator
    MMSZ47 500 mW 47 V ±5% Zener Diode Voltage Regulator
    MMSZ4700 13 V Low Current Zener Diode Voltage Regulator
    MMSZ4701 14 V Low Current Zener Diode Voltage Regulator
    MMSZ4701E 225 W, 14 V Zener Diode Voltage Regulator
    MMSZ4702 15 V Low Current Zener Diode Voltage Regulator
    MMSZ4703 16 V  Low Current Zener Diode Voltage Regulator
    MMSZ4705 18 V Low Current Zener Diode Voltage Regulator
    MMSZ4706 19 V Low Current  Zener Diode Voltage Regulator
    MMSZ4707 20 V Low Current Zener Diode Voltage Regulator
    MMSZ4708 22 V Low Current Zener Diode Voltage Regulator
    MMSZ4709 24 V Low Current Zener Diode Voltage Regulator
    MMSZ4710 25 V Low Current Zener Diode Voltage Regulator
    MMSZ4713 30 V Low Current Zener Diode Voltage Regulator
    MMSZ4714 33 V Low Current Zener Diode Voltage Regulator
    MMSZ4715 33 V Low Current Zener Diode Voltage Regulator
    MMSZ4717 43 V Low Current Zener Diode Voltage Regulator
    MMSZ4V3 500 mW, 4.3 V ±5% Zener Diode Voltage Regulator
    MMSZ4V7 500 mW, 4.7 V ±5% Zener Diode Voltage Regulator
    MMSZ51 500 mW, 51 V ±5% Zener Diode Voltage Regulator
    MMSZ5232E 225 W Energy Rated Zener 5.6 V SOD-123
    MMSZ5235E 225 W, 6.8 V Zener Diode Voltage Regulator
    MMSZ5237E 225 W, 8.2 V Zener Diode Voltage Regulator
    MMSZ5242E 225 W, 12 V Zener Diode Voltage Regulator
    MMSZ5244E 225 W, 14 V Zener Diode Voltage Regulator
    MMSZ5245E 225 W, 15 V Zener Diode Voltage Regulator
    MMSZ5246E 225 W, 16 V Zener Diode Voltage Regulator
    MMSZ5248E 225 W Energy Rated Zener 18 V SOD-123
    MMSZ5250E 225 W, 20 V Zener Diode Voltage Regulator
    MMSZ5251E 225 W, 22 V Zener Diode Voltage Regulator
    MMSZ5252E 225 W, 24 V Zener Diode Voltage Regulator
    MMSZ5253E 225 W Energy Rated Zener 25 V SOD-123
    MMSZ5254E 225 W, 27 V Zener Diode Voltage Regulator
    MMSZ5255E 225 W, 28 V Zener Diode Voltage Regulator
    MMSZ5256E 225 W, 30 V Zener Diode Voltage Regulator
    MMSZ5257E 500 mW, 33 V ±5% Zener Diode Voltage Regulator
    MMSZ5258E 225 W Energy Rated Zener 36 V SOD-123
    MMSZ56 500 mW, 56 V ±5% Zener Diode Voltage Regulator
    MMSZ5V1 500 mW, 5.1 V ±5% Zener Diode Voltage Regulator
    MMSZ5V6 500 mW, 5.6 V ±5% Zener Diode Voltage Regulator
    MMSZ6V2 500 mW, 6.2 V ±5% Zener Diode Voltage Regulator
    MMSZ6V8 500 mW, 6.8 V ±5% Zener Diode Voltage Regulator
    MMSZ7V5 500 mW, 7.5 V ±5% Zener Diode Voltage Regulator
    MMSZ8V2 500 mW, 8.2 V ±5% Zener Diode Voltage Regulator
    MMSZ8V2E 225 W Energy Rated Zener 8.2 V SOD-123
    MMSZ9V1 500 mW, 9.1 V ±5% Zener Diode Voltage Regulator
    MSQA6V1W5 Quad Diode Array for ESD Protection
    NSQA6V8A Low Capacitance Quad Transient Voltage Suppressor Array
    NSZ5V6V2 5.6 V ±2% Tight Tolerance Zener Diode Voltage Regulator
    NZ23C5V6 5.6 V Dual Common Anode Zener Diode Transient Voltage Suppressor
    NZ9F10V 10 V, 200 mW Zener Diode Voltage Regulator 5% Tolerance
    NZ9F10VS 10 V, 200 mW Zener Diode Voltage Regulator 2% Tolerance
    NZ9F11V 11 V, 200 mW Zener Diode Voltage Regulator 5% Tolerance
    NZ9F11VS 11 V, 200 mW Zener Diode Voltage Regulator 2% Tolerance
    NZ9F12V 12 V, 200 mW Zener Diode Voltage Regulator 5% Tolerance
    NZ9F12VS 12 V, 200 mW Zener Diode Voltage Regulator 2% Tolerance
    NZ9F13V 13 V, 200 mW Zener Diode Voltage Regulator 5% Tolerance
    NZ9F13VS 13 V, 200 mW Zener Diode Voltage Regulator 2% Tolerance
    NZ9F15V 15 V, 200 mW Zener Diode Voltage Regulator 5% Tolerance
    NZ9F15VS 15 V, 200 mW Zener Diode Voltage Regulator 2% Tolerance
    NZ9F16V 16 V, 200 mW Zener Diode V,oltage Regulator 5% Tolerance
    NZ9F16VS 16 V, 200 mW Zener Diode V,oltage Regulator 2% Tolerance
    NZ9F18V 18 V, 200 mW Zener Diode V,oltage Regulator 5% Tolerance
    NZ9F18VS 18 V, 200 mW Zener Diode V,oltage Regulator 2% Tolerance
    NZ9F20V 20 V, 200 mW Zener Diode V,oltage Regulator 5% Tolerance
    NZ9F22V 20 V, 200 mW Zener Diode V,oltage Regulator 5% Tolerance
    NZ9F24V 24 V, 200 mW Zener Diode V,oltage Regulator 5% Tolerance
    NZ9F2V4 2.4 V, 200 mW Zener Diode V,oltage Regulator 5% Tolerance
    NZ9F2V4S 2.4 V, 200 mW Zener Diode V,oltage Regulator 2% Tolerance
    NZ9F2V7 2.7 V, 200 mW Zener Diode V,oltage Regulator 5% Tolerance
    NZ9F2V7S 2.7 V, 200 mW Zener Diode V,oltage Regulator 2% Tolerance
    NZ9F3V0 3.0 V, 200 mW Zener Diode V,oltage Regulator 5% Tolerance
    NZ9F3V0S 3.0 V, 200 mW Zener Diode V,oltage Regulator 2% Tolerance
    NZ9F3V3 3.3 V, 200 mW Zener Diode V,oltage Regulator 5% Tolerance
    NZ9F3V3S 3.3 V, 200 mW Zener Diode Voltage Regulator 2% Tolerance
    NZ9F3V6 3.6 V, 200 mW Zener Diode Voltage Regulator 5% Tolerance
    NZ9F3V6S 3.6 V, 200 mW Zener Diode Voltage Regulator 2% Tolerance
    NZ9F3V9 3.9 V, 200 mW Zener Diode Voltage Regulator 5% Tolerance
    NZ9F3V9S 3.9 V, 200 mW Zener Diode Voltage Regulator 2% Tolerance
    NZ9F4V3 4.3 V, 200 mW Zener Diode Voltage Regulator 5% Tolerance
    NZ9F4V7 4.7 V, 200 mW Zener Diode Voltage Regulator 5% Tolerance
    NZ9F5V1 5.1 V, 200 mW Zener Diode Voltage Regulator 5% Tolerance
    NZ9F5V1S 5.1 V, 200 mW Zener Diode Voltage Regulator 2% Tolerance
    NZ9F5V6 5.6 V, 200 mW Zener Diode Voltage Regulator 5% Tolerance
    NZ9F5V6S 5.6 V, 200 mW Zener Diode Voltage Regulator 2% Tolerance
    NZ9F6V2 6.2 V, 200 mW Zener Diode Voltage Regulator 5% Tolerance
    NZ9F6V2S 6.2 V, 200 mW Zener Diode Voltage Regulator 2% Tolerance
    NZ9F6V8 6.8 V, 200 mW Zener Diode Voltage Regulator 5% Tolerance
    NZ9F6V8S 6.8 V, 200 mW Zener Diode Voltage Regulator 2% Tolerance
    NZ9F7V5 7.5 V, 200 mW Zener Diode Voltage Regulator 5% Tolerance
    NZ9F7V5S 7.5 V, 200 mW Zener Diode Voltage Regulator 2% Tolerance
    NZ9F8V2 8.2 V, 200 mW Zener Diode Voltage Regulator 5% Tolerance
    NZ9F8V2S 8.2 V, 200 mW Zener Diode Voltage Regulator 2% Tolerance
    NZ9F9V1 9.1 V, 200 mW Zener Diode Voltage Regulator 5% Tolerance
    NZ9F9V1S 9.1 V, 200 mW Zener Diode Voltage Regulator 2% Tolerance
    NZQA5V6A Low Capacitance Quad Transient Voltage Suppressor Array
    NZQA6V2 Quad Transient Voltage Suppressor Array
    NZQA6V8 Quad Transient Voltage Suppressor Array
    NZQA6V8A Low Capacitance Quad Transient Voltage Suppressor Array
    SMF5.0A 200 Watt SOD-123FL Transient Voltage Suppressors, 5.0 V, Unidirectional
    SMF5920 ZENER REGULATOR 6.2 V
    SZBZX84C3V3LT1 ZEN SOT23 REG .225W
    SZBZX84C7V5 ZEN SOT23 REG .225W
    SZMMSZ52 Zener Diode 500 mW SOD-123
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
