龙人旗下深圳市龙芯世纪科技有限公司
  • ESD保护二极管
  • 发布时间:2013/9/9 11:09:21   修改时间:2013/9/9 11:09:21 浏览次数:2331
  • ESD保护二极管
    静电放电(ESD)保护二极管
    安森美半导体提供专门设计用于提供静电放电(ESD)保护的二极管。
    ESD保护二极管Excel 文档格式选型指南
    Product Description Dir Package Type
    DF6A6.8 Quad Diode Array for ESD Protection Unidirectional SC-88-6 / SC-70-6 / SOT-363-6
    ESD5482 ESD Protection Diode Bidirectional X3DFN-2
    ESD5Z Transient Voltage Suppressor and ESD Protection Diode, SOD-523 Unidirectional SOD-523-2
    ESD9X12S ESD Protection Diode, SOD-923 Unidirectional SOD-923-2
    CM1205 8-Channel ESD Protection Array Unidirectional WLCSP-10
    CM1213 6- and 8-Channel Low Capacitance ESD Protection Arrays Bidirectional Micro8?-8
    MSOP-10
    CM1213A 1-, 2-, and 4-Channel Low Capacitance ESD Protection Arrays Unidirectional MSOP-10
    SC-74
    SC-88-6 / SC-70-6
    SOT-143-4
    SOT-23-3
    CM1213A-04SO 4-Channel Low Capacitance ESD Protection Array Bidirectional SC-74
    CM1214A 1- and 2-Channel PicoGuard? AC Signal ESD Protectors Bidirectional Micro8?-8
    SOT-23-3
    CM1216 6- and 8-Channel Low Capacitance ESD Arrays Unidirectional Micro8?-8
    MSOP-10
    CM1223 2-, 4- and 8-Channel Low Capacitance ESD Protection Arrays with Backdrive Protection Unidirectional SOT-123-4
    SOT-23-8
    CM1224 2- and 4-Channel Low Capacitance ESD Protection Arrays Unidirectional MSOP-10
    SOT-143-4
    SOT-23-6
    CM1230 2-, 4- and 8-Channel Low Capacitance ESD Protection Arrays Unidirectional WLCSP-10
    WLCSP-4
    WLCSP-6
    CM1231-02SO 2-Channel PicoGuard XP? ESD Clamp Protection Array Bidirectional SOT-23-6
    CM1233 PicoGuard XS? ESD Clamp Array For High Speed Data Line Protection Unidirectional WDFN-16
    CM1234 PicoGuard XS? ESD Clamp Array For High Speed Data Line Protection Unidirectional WDFN-16
    CM1235 Small Footprint PicoGuard XS? ESD Clamp Array For High Speed Data Line Protection Unidirectional WDFN-16
    CM1236 PicoGuard XS? ESD Clamp Array For High Speed Data Line Protection Unidirectional WDFN-16
    CM1241 4-Channel Low Capacitance Dual-Voltage ESD Protection Array Unidirectional WDFN-8
    CM1242-07 ESD protection in 0201 outline Bidirectional WLCSP-2
    CM1242-33 ESD protection in 0201 outline Bidirectional WLCSP-2
    CM1248-04QG Low Capacitance ESD Protector Unidirectional UDFN-6
    CM1248-08DE Low Capacitance ESD Protector Unidirectional UDFN-8
    CM1250 4-Channel ESD Protection Array Unidirectional UDFN-6
    CM1263-02SE 2-Channel Low Capacitance ESD Protection Array for High-Speed Serial Interfaces Unidirectional SOT-553
    CM1263-06DE 6-Channel Low Capacitance ESD Protection Array for High-Speed Serial Interfaces Unidirectional UDFN-12
    CM1293A 2- and 4-Channel Low Capacitance ESD Protection Arrays Unidirectional SC-74
    SOT-123-4
    CM1293A-04SO 4-Channel Low Capacitance ESD Protection Array  Unidirectional SC-74
    CM1641 4-Channel Low Capacitance Dual-Voltage ESD Protection Array Unidirectional UDFN-8
    CM2006 VGA Port Companion Circuit for Monitors Unidirectional QSOP-16
    CM2009 VGA Port Companion Circuit Unidirectional QSOP-16
    CM2020-00TR HDMI Transmitter Port Protection and Interface Device Unidirectional TSSOP-38
    CM2020-01TR HDMI Transmitter Port Protection and Interface Device Unidirectional TSSOP-38
    DF3A6.8FU ESD Protection Dual Common Anode Diodes SC-70 Unidirectional SC-70-3 / SOT-323-3
    ESD1014 4-Line Surge Rated Rail-Rail Protector Bidirectional UDFN-10
    ESD11A3.3 3.3 V Mid-Capacitance Transient Voltage Suppressor, SOT-1123 Unidirectional SOT-1123-3
    ESD11A5 5.0 V Mid-Capacitance Transient Voltage Suppressor, SOT-1123 Unidirectional SOT-1123-3
    ESD11B Bidirectional TVS in 0201-CSP Bidirectional DSN-2
    ESD11L Low Capacitance ESD Protection Diode, SOT-1123 Unidirectional SOT-1123-3
    ESD11N5 5.0 V Bi-Directional Transient Voltage Suppressor, DSN Package Bidirectional DSN-2
    ESD4238 8 Channel ESD Protection Unidirectional WDFN-16
    ESD5205 5 LINE LOW CAP ESD PROTECTION SOT-963
    ESD5381 ESD Protection Diode Unidirectional X3DFN-2
    ESD5384 4 Chan ESD Prot Unidirectional WLCSP-9
    ESD5481 ESD Protection Zener in DFN 0201 Package  Bidirectional X3DFN-2
    ESD5484 Transient Voltage Suppressors Bidirectional WLCSP-2
    ESD5B Bi-directional ESD Protection Diodes, SOD-523 Bidirectional SOD-523-2
    ESD6100 PicoGuard? 2 Channel Very Low Capacitance ESD Bidirectional WLCSP-4
    ESD7004 Unidirectional 4 Channel Flow-Through, Low Capacitance ESD Protection Unidirectional UDFN-10
    ESD7008 Low Cap ESD Protection for High Speed Data Bidirectional UDFN-18
    ESD7016 Integrated Low Cap ESD Protection for USB 3.0 Bidirectional UDFN-8
    ESD7104 Bi-directional 4 Channel Flow-Through, Low Capacitance ESD Protection Bidirectional UDFN-10
    ESD7381 LOW CAP UNI-DIRECTIONAL ESD Unidirectional X3DFN-2
    ESD7383 3 Chan ESD Protection Bidirectional WLCSP-4
    ESD7481 LOW CAP BI-DIRECTIONAL ESD PROTECTION Bidirectional X3DFN-2
    ESD7484 4 Chan ESD Protection Bidirectional WLCSP-10
    ESD7554 USB 2.0 ESD, 30V VCC UDFN-8
    ESD7951 Bidirectional Low Capacitance ESD Diode Bidirectional SOD-923-2
    ESD7C Transient Voltage Suppressor and ESD Protection Diode, SOT-723 Unidirectional SOT-723-3
    ESD7L Low Capacitance ESD Protection Diode Unidirectional SOT-723-3
    ESD7M5.0DT5G Low Capacitance ESD Protection Diode, SOT-723 Unidirectional SOT-723-3
    ESD8472 Ultra-Low Capacitance RF ESD Protection Bidirectional X3DFN-2
    ESD9B Bi-Directional ESD Protection Diodes, SOD-923 Bidirectional SOD-923-2
    ESD9C ESD Protection Diodes, SOD-923 Unidirectional SOD-923-2
    ESD9L Low Capacitance ESD Protection; Unidirectional Unidirectional SOD-923-2
    ESD9M Low Capacitance ESD Protection; Unidirectional Unidirectional SOD-923-2
    ESD9P 1.3pF Unidirectional ESD Protection Diode in SOD-923 package Unidirectional SOD-923-2
    ESD9R3 Unidirectional, Low Leakage, Low Capacitance TVS Diode Unidirectional SOD-923-2
    ESD9X3.3S ESD Protection Diode, SOD-923 Unidirectional SOD-923-2
    ESD9X5.0S ESD Protection Diode, SOD-923 Unidirectional SOD-923-2
    ESD9X7.0 ESD Protection Diode, SOD-923 Unidirectional SOD-923-2
    ESDR0502B Dual Line Low Cap ESD Protection SC-75 Unidirectional SC-75-3
    ESDR0502N Ultra-Low Capacitance ESD Protection Array for High Speed Data Lines Unidirectional UDFN-6
    ESDR0524P 4-Line Flow-Through, Low Capacitance ESD Protection Diodes Unidirectional UDFN-10
    FCDN612 1-Channel ESD Protector Unidirectional NA-Wafer
    LC03-6 Low Capacitance Transient Voltage Suppressor for High Speed Data Interfaces Unidirectional SOIC-8
    MG2040 Low Capacitance ESD Protection for High Speed Video Interface Unidirectional UDFN18 5.5x1.5, 0.5P/0.75P
    MMQA12V Quad Transient Voltage Suppressor, Common Anode, SC-59 Unidirectional SC-74
    MMQA15V Quad Transient Voltage Suppressor, Common Anode, SC-59 Unidirectional SC-74
    MMQA18V Quad Transient Voltage Suppressor, Common Anode, SC-59 Unidirectional SC-74
    MMQA20V Quad Transient Voltage Suppressor, Common Anode, SC-59 Unidirectional SC-74
    MMQA22V Quad Transient Voltage Suppressor, Common Anode, SC-59 Unidirectional SC-74
    MMQA24V Quad Transient Voltage Suppressor, Common Anode, SC-59 Unidirectional SC-74
    MMQA27V Quad Transient Voltage Suppressor, Common Anode, SC-59 Unidirectional SC-74
    MMQA33V Quad Transient Voltage Suppressor, Common Anode, SC-59 Unidirectional SC-74
    MMQA5V6T1 Quad Transient Voltage Suppressor, Common Anode, SC-74 Unidirectional SC-74
    MMQA6V2 Quad Transient Voltage Suppressor, Common Anode, SC-59 Unidirectional SC-74
    MMQA6V8 Quad Transient Voltage Suppressor, Common Anode, SC-59 Unidirectional SC-74
    MSQA6V1W5 Quad Diode Array for ESD Protection Unidirectional SC-88A-5 / SC-70-5 / SOT-323-5
    NSQA6V8A Low Capacitance Quad Transient Voltage Suppressor Array Unidirectional SC-88A-5 / SC-70-5 / SOT-323-5
    NUP1105L Single Line CAN/LIN Bus Protector, SOT-23 Bidirectional SOT-23-3
    NUP1301 Single Line ESD Protection Low Capacitance Rail Clamp Bidirectional SOT-23-3
    NUP2105 27 V CAN Bus Protector, SOT-23 Bidirectional SOT-23-3
    NUP2114 2 Channel ESD Protection Array Unidirectional SOT-553
    TSOP-6
    NUP2201 Low Capacitance Diode-Transient Voltage Suppressor Array for High Speed Data Lines Protection Bidirectional TSOP-6
    NUP2202 Low Capacitance Diode-Transient Voltage Suppressor Array for High Speed Data Lines Protection Bidirectional SC-88-6 / SC-70-6 / SOT-363-6
    NUP2301 Low Capacitance Diode Array for ESD Protection in Two Data Lines Bidirectional SC-88-6 / SC-70-6 / SOT-363-6
    NUP3112UPMUTAG Quad Transient Voltage Suppressor Array ESD Protection Diodes with Ultra-Low (0.7 pF) Capacitance Unidirectional UDFN-6
    NUP3115UP 3 x 5.0 V + 1 12V ESD Array for USB 2.0 High Speed, 1.6x1.6 uDFN-6 Bidirectional UDFN-6
    NUP4000 Bi-Directional Transient Voltage Suppressor Array for High Speed Data Line Protection Bidirectional SOIC-8
    NUP4004M5 Bi-Directional Quad Transient Voltage Suppressor Array Bidirectional TSOP-5 / SOT-23-5
    NUP4016 Low Capacitance Diode-Transient Voltage Suppressor Unidirectional SOT-953
    NUP4060AXV6T1G 4-Line Transient Voltage Suppressor Array Unidirectional SOT-563
    NUP4103 Quad Transient Voltage Suppressor Array in 5 Bump Flip Chip Pkg Unidirectional Flip-Chip CSP-5
    NUP4106 4-Channel Transient Voltage Suppressor Protection Array, SO-8 Unidirectional SOIC-8
    NUP4114 Sub-1.0 pF Quad ESD Array Unidirectional SC-88-6 / SC-70-6 / SOT-363-6
    SOT-563
    TSOP-6
    NUP412V Low Capacitance 12 V Quad Array for ESD Protection Unidirectional SOT-953
    NUP4201 Low Capacitance Surface Mount TVS for High Speed Data Interfaces Unidirectional SOIC-8
    NUP4201MR6 Low Capacitance Diode-TVS Array for High Speed Data Lines Unidirectional TSOP-6
    NUP4202W1 Low Capacitance Diode-TVS Array for High Speed Data Lines Bidirectional SC-88-6 / SC-70-6 / SOT-363-6
    NUP4212 Ultra-Low Capacitance ESD Protection  Array Unidirectional UDFN-6
    NUP4301 Low Capacitance Diode Array for ESD Protection in Four Data Lines Bidirectional SC-74
    NUP4302 Schottky Diode Array for Four Data Line ESD Protection Bidirectional TSOP-6
    NUP4304MR6 Low Capacitance Diode Array for ESD Protection in Four Data Lines Bidirectional SC-74
    NUP45V6 Low Capacitance 5.6 V Quad Array for ESD Protection Unidirectional SOT-953
    NUP46V8 Low Capacitance 6.8 V Quad Array for ESD Protection Unidirectional SOT-953
    NUP5120X6 5-Line Transient Voltage Suppressor Array Unidirectional SOT-563
    NUP5150 5-Line Transient Voltage Suppressor Array Unidirectional UDFN-6
    NUP8011 8-Line Ultra-Low Profile ESD Array Unidirectional UDFN-8
    NZL5V6AXV3 ESD Protection Dual Common Anode Diodes Unidirectional SC-89-3
    NZL6V8AXV3 ESD Protection Dual Common Anode Diodes Unidirectional SC-89-3
    NZL7V5AXV3 ESD Protection Dual Common Anode Diodes Unidirectional SC-89-3
    NZQA5V6 Quad Transient Voltage Suppressor Array Unidirectional SOT-553
    NZQA5V6A Low Capacitance Quad Transient Voltage Suppressor Array Unidirectional SOT-553
    NZQA6V2 Quad Transient Voltage Suppressor Array Unidirectional SOT-553
    NZQA6V8 Quad Transient Voltage Suppressor Array Unidirectional SOT-553
    NZQA6V8A Low Capacitance Quad Transient Voltage Suppressor Array Unidirectional SOT-553
    PACDN004 2-Channel ESD Protection Array Unidirectional SOT-143-4
    PACDN006 6-Channel ESD Protection Array Unidirectional Micro8?-8
    PACDN009 5-Channel ESD Protection Array Unidirectional Micro8?-8
    PACDN042 Transient Voltage Suppressor Arrays Unidirectional SOT-23-3
    PACDN1404 4-Channel ESD Protection Array Unidirectional WLCSP-6
    PACDN1408 8-Channel ESD Protection Array Unidirectional WLCSP-10
    PACVGA105 VGA Port Companion Circuit Unidirectional QSOP-16
    PACVGA200 VGA Port Companion Circuit Unidirectional QSOP-24
    PACVGA201 VGA Port Companion Circuit Unidirectional QSOP-16
    SL05 Transient Voltage Suppressor Single Line Low Capacitance, 5.0 V Unidirectional SOT-23-3
    SL12 Transient Voltage Suppressor Single Line Low Capacitance, 12 V Unidirectional SOT-23-3
    SL15 Transient Voltage Suppressor Single Line Low Capacitance, 15 V Unidirectional SOT-23-3
    SL24 Transient Voltage Suppressor Single Line Low Capacitance, 24 V Unidirectional SOT-23-3
    SMDA05CDR2G Bi-directional TVS Array for High Speed Data Line Protection Bidirectional SOIC-8
    SMDA12CDR Bi-directional TVS Array for High Speed Data Line Protection 12V Bidirectional SOIC-8
    SMDA15CDR2G Bi-directional TVS Array for High Speed Data Line Bidirectional SOIC-8
    SMDA24 Bi-Directional Transient Voltage Suppressor Array for High Speed Data Line Protection Bidirectional SOIC-8
    SMF05 200 Watt 6.0 V Transient Voltage Suppressor Quad Array Unidirectional SC-88A-5 / SC-70-5 / SOT-323-5
    SMS05 SC-74 Quad Transient Voltage Suppressor Unidirectional SC-74
    SMS05C 5-Line Transient Voltage Suppressor Array Unidirectional TSOP-6
    SRDA05-4 Low Capacitance Surface Mount Transient Voltage Suppressor for High Speed Data Interfaces Bidirectional SOIC-8
    SRDA3.3-4 Low Capacitance Surface Mount Transient Voltage Suppressor for High Speed Data Interfaces Unidirectional SOIC-8
    UESD3.3D ESD Protection Dual Common Anode Diodes Unidirectional SOT-723-3
    UESD5.0D ESD Protection Dual Common Anode Diodes Unidirectional SOT-723-3
    UESD6.0D ESD Protection Dual Common Anode Diodes Unidirectional SOT-723-3
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
