龙人旗下深圳市龙芯世纪科技有限公司
  • AMS 公司电压检测器
  • 发布时间:2015/4/18 11:03:59   修改时间:2015/4/18 11:03:59 浏览次数:2342
  • AMS23 The AMS23 low power voltage detector provides monitoring of battery, power-supply, and regulated system voltages. A precision voltage reference and comparator monitors the VCC input and compares it with a specified voltage threshold condition. When VCC falls below a specified trip point threshold, the output (OUT) is forced low and remains asserted as long as the VCC input remains below VTH- + hysteresis (VHYST). The AMS23 device is guaranteed to output the correct logic state for VCC down to 0.7V. They are also designed to ignore fast transients on VCC. This small, low power device is ideal for portable applications and is available in space-saving SOT23-5 package.
    AMS23 订购型号
    OUTPUT TYPE3 LEAD SOT-23Operating Temp(°C)
    OPEN DRAINAMS23M1-40 to +85°C
    AMS26 数据手册DataSheet 下载 . pdf
    AMS26 series are voltage detector ICs featuring a high accuracy detector threshold of +/-2.0% and ultra-low supply current. Internal circuit contains a precision voltage reference, a comparator, resistor network, and an output driver. The AMS26 has an NPN open collector output. The detector threshold is set from 1.45V to 4.6V in 0.05V increments and 4.6V to 7.9 in 0.1V increments. Also available from 7.9V to 12V in 170mV increments, thus making it easy to use in a variety of supervisory applications including microprocessor reset circuits, memory battery back-up circuit, battery checker, power failure detector and portable and battery powered electronics. AMS26 is available in TO-92 and the sub-miniature 3-pin SOT-23 surface mount package.
    AMS26 订购型号
    OUTPUT TYPETO-923 LEAD SOT-23Operating Temp(°C)
    OPEN DRAINAMS26N-XAAMS26M-XA-30 to +80°C
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
