龙人旗下深圳市龙芯世纪科技有限公司
  • MicroSystem 混合信号数据转换器
  • 发布时间:2015/5/11 15:31:51   修改时间:2015/5/11 15:31:51 浏览次数:1277
  • MicroSystem 混合信号数据转换器 (25)
    Part NumberStatusAnalog Input BW (MHz)Data-Bus Interface (bits)DAC: Resolution (Bits)DAC: Settling Time (uS)DAC: ChannelsNo. of SuppliesSupply (min) (V)ADC: DNL (max) (+/- LSB)ADC: INL (+/-LSB) (max)Power (typ) (mW)Vref (Int/Ext)ADC: Sampling Rate (KSPS)ADC Resolution (Bits)Diff EndedSingle/Dual Analog SupplyDAC: Output TypeAnalog Voltage AV/DD (min) (V)Supply (max) (V)Input Configuration RangeLogic Voltage DV/DD (min) (V)Analog Voltage AV/DD (max) (V)Logic Voltage DV/DD (max) (V)Power Consumption (typ) (mW)ADC: No. of Input ChannelsADC: ArchitectureADC: ENOB (Bits)ADC: No. Missing Codes (Bits)ADC: INL (+/-%) (max)ADC: Analog InputsADC: Input TypeSE OutputOut of Range IndicatorPower DownFlexible IP RangeMultiplexerGlueless MicroCFlexible Conversion RateInt/Ext RefFIFOParallel InterfaceSerial SPI InterfaceSerial I2C InterfaceInternal Reference BufferUnipolarSE/DIFFDIFFSingle-Ended InputInternal ReferenceBiPolarHW ConfigurablePLLExternal ReferencePGAPin/PackageApprox. Price (US$)Description
    MSC1200Y3ACTIVE0.001Parallel/Serial8 122.712564Int/Ext124Diff/SSingleCurrent2.75.5+/-2.52.75.255.2548Delta-Sigma22240.00158VoltageYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYes48TQFP8.10 | 1ku8051 CPU,具有 8kB 内存、24 位 ADC、电流 DAC 和片上振荡器
    MSC1201Y2ACTIVE0.001Parallel/Serial8 122.712564Int/Ext124Diff/SSingleCurrent2.75.5+/-2.52.75.255.2546Delta-Sigma22240.00156VoltageYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYes36VQFN7.00 | 1ku具有 4kB 内存、24 位 ADC、电流 DAC 和片上振荡器的 8051 CPU
    MSC1201Y3ACTIVE0.001Parallel/Serial8 122.712564Int/Ext124Diff/SSingleCurrent2.75.5+/-2.52.75.255.2546Delta-Sigma22240.00156VoltageYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYes36VQFN7.45 | 1ku具有 8kB 内存、24 位 ADC、电流 DAC 和片上振荡器的 8051 CPU
    MSC1202Y2ACTIVE0.001Parallel/Serial8 122.7114Int/Ext116Diff/SSingleCurrent2.75.5+/-2.52.75.255.2546Delta-Sigma16160.00156VoltageYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYes36VQFN5.75 | 1ku具有 4kB 内存、16 位 ADC、电流 DAC 和片上振荡器的 8051 CPU
    MSC1202Y3ACTIVE0.001Parallel/Serial8 122.7114Int/Ext116Diff/SSingleCurrent2.75.5+/-2.52.75.255.2546Delta-Sigma16160.00156VoltageYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYes36VQFN4.95 | 1ku8051 CPU,具有 8kB 内存、16 位 ADC、电流 DAC 和片上振荡器
    MSC1210Y2ACTIVE0.001Parallel/Serial   22.712564Int/Ext124Diff/SSingle 2.75.5+/-2.52.75.255.2548Delta-Sigma22240.00158VoltageYesYesYesYesYesYesYesYesYesYesYes YesYesYesYesYesYesYesYes YesYes64TQFP11.20 | 1ku具有 8051 微控制器和 4k 闪存的精密模数转换器 (ADC)
    MSC1210Y3ACTIVE0.001Parallel/Serial   22.712564Int/Ext124Diff/SSingle 2.75.5+/-2.52.75.255.2548Delta-Sigma22240.00158VoltageYesYesYesYesYesYesYesYesYesYesYes YesYesYesYesYesYesYesYes YesYes64TQFP9.85 | 1ku具有 8051 微控制器和 8k 闪存的精密模数转换器 (ADC)
    MSC1210Y4ACTIVE0.001Parallel/Serial   22.712564Int/Ext124Diff/SSingle 2.75.5+/-2.52.75.255.2548Delta-Sigma22240.00158VoltageYesYesYesYesYesYesYesYesYesYesYes YesYesYesYesYesYesYesYes YesYes64TQFP10.75 | 1ku具有 8051 微控制器和 16k 闪存的精密模数转换器 (ADC)
    MSC1210Y5ACTIVE0.001Parallel/Serial   22.712564Int/Ext124Diff/SSingle 2.75.5+/-2.52.75.255.2548Delta-Sigma22240.00158VoltageYesYesYesYesYesYesYesYesYesYesYes YesYesYesYesYesYesYesYes YesYes64TQFP12.00 | 1ku具有 8051 微控制器和 32k 闪存的精密模数转换器 (ADC)
    MSC1211Y2ACTIVE0.001Parallel/Serial168422.712564Int/Ext124Diff/SSingleVoltage/Current2.75.5+/-2.52.75.255.2548Delta-Sigma22240.00158VoltageYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYes YesYes64TQFP21.90 | 1ku8051 CPU,具有 4kB 存储器、I2C、24 位 ADC 和四路 16 位 DAC
    MSC1211Y3ACTIVE0.001Parallel/Serial168422.712564Int/Ext124Diff/SSingleVoltage/Current2.75.5+/-2.52.75.255.2548Delta-Sigma22240.00158VoltageYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYes YesYes64TQFP22.45 | 1ku8051 CPU,具有 8kB 存储器、I2C、24 位 ADC 和四路 16 位 DAC
    MSC1211Y4ACTIVE0.001Parallel/Serial168422.712564Int/Ext124Diff/SSingleVoltage/Current2.75.5+/-2.52.75.255.2548Delta-Sigma22240.00158VoltageYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYes YesYes64TQFP24.20 | 1ku8051 CPU,具有 16kB 存储器、I2C、24 位 ADC 和四路 16 位 DAC
    MSC1211Y5ACTIVE0.001Parallel/Serial168422.712564Int/Ext124Diff/SSingleVoltage/Current2.75.5+/-2.52.75.255.2548Delta-Sigma22240.00158VoltageYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYes YesYes64TQFP26.20 | 1ku8051 CPU,具有 32kB 存储器、I2C、24 位 ADC 和四路 16 位 DAC
    MSC1212Y2ACTIVE0.001Parallel/Serial168422.712564Int/Ext124Diff/SSingleVoltage/Current2.75.5+/-2.52.75.255.2548Delta-Sigma22240.00158VoltageYesYesYesYesYesYesYesYesYesYesYes YesYesYesYesYesYesYesYes YesYes64TQFP21.20 | 1ku8051 CPU,具有 4kB 存储器、24 位 ADC 和四路 16 位 DAC
    MSC1212Y3ACTIVE0.001Parallel/Serial168422.712564Int/Ext124Diff/SSingleVoltage/Current2.75.5+/-2.52.75.255.2548Delta-Sigma22240.00158VoltageYesYesYesYesYesYesYesYesYesYesYes YesYesYesYesYesYesYesYes YesYes64TQFP21.95 | 1ku8051 CPU,具有 8kB 存储器、24 位 ADC 和四路 16 位 DAC
    MSC1212Y4ACTIVE0.001Parallel/Serial168422.712564Int/Ext124Diff/SSingleVoltage/Current2.75.5+/-2.52.75.255.2548Delta-Sigma22240.00158VoltageYesYesYesYesYesYesYesYesYesYesYes YesYesYesYesYesYesYesYes YesYes64TQFP23.60 | 1ku8051 CPU,具有 16kB 存储器、24 位 ADC 和四路 16 位 DAC
    MSC1212Y5ACTIVE0.001Parallel/Serial168422.712564Int/Ext124Diff/SSingleVoltage/Current2.75.5+/-2.52.75.255.2548Delta-Sigma22240.00158VoltageYesYesYesYesYesYesYesYesYesYesYes YesYesYesYesYesYesYesYes YesYes64TQFP25.50 | 1ku8051 CPU,具有 32kB 存储器、24 位 ADC 和四路 16 位 DAC
    MSC1213Y2ACTIVE0.001Parallel/Serial168222.712564Int/Ext124Diff/SSingleVoltage/Current2.75.5+/-2.52.75.255.2548Delta-Sigma22240.00158VoltageYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYes YesYes64TQFP15.85 | 1ku具有 8051 微控制器与闪存的精密 A/D & D/A
    MSC1213Y3ACTIVE0.001Parallel/Serial168222.712564Int/Ext124Diff/SSingleVoltage/Current2.75.5+/-2.52.75.255.2548Delta-Sigma22240.00158VoltageYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYes YesYes64TQFP16.50 | 1ku具有 8051 微控制器与闪存的精密 A/D & D/A
    MSC1213Y4ACTIVE0.001Parallel/Serial168222.712564Int/Ext124Diff/SSingleVoltage/Current2.75.5+/-2.52.75.255.2548Delta-Sigma22240.00158VoltageYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYes YesYes64TQFP18.10 | 1ku具有 8051 微控制器与闪存的精密 A/D & D/A
    MSC1213Y5ACTIVE0.001Parallel/Serial168222.712564Int/Ext124Diff/SSingleVoltage/Current2.75.5+/-2.52.75.255.2548Delta-Sigma22240.00158VoltageYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYesYes YesYes64TQFP19.95 | 1ku具有 8051 微控制器与闪存的精密 A/D & D/A
    MSC1214Y2ACTIVE0.001Parallel/Serial168222.712564Int/Ext124Diff/SSingleVoltage/Current2.75.5+/-2.52.75.255.2548Delta-Sigma22240.00158VoltageYesYesYesYesYesYesYesYesYesYesYes YesYesYesYesYesYesYesYes YesYes64TQFP15.20 | 1ku具有 8051 微控制器与闪存的精密 A/D & D/A
    MSC1214Y3ACTIVE0.001Parallel/Serial168222.712564Int/Ext124Diff/SSingleVoltage/Current2.75.5+/-2.52.75.255.2548Delta-Sigma22240.00158VoltageYesYesYesYesYesYesYesYesYesYesYes YesYesYesYesYesYesYesYes YesYes64TQFP15.90 | 1ku具有 8051 微控制器与闪存的精密 A/D & D/A
    MSC1214Y4ACTIVE0.001Parallel/Serial168222.712564Int/Ext124Diff/SSingleVoltage/Current2.75.5+/-2.52.75.255.2548Delta-Sigma22240.00158VoltageYesYesYesYesYesYesYesYesYesYesYes YesYesYesYesYesYesYesYes YesYes64TQFP17.45 | 1ku具有 8051 微控制器与闪存的精密 A/D & D/A
    MSC1214Y5ACTIVE0.001Parallel/Serial168222.712564Int/Ext124Diff/SSingleVoltage/Current2.75.5+/-2.52.75.255.2548Delta-Sigma22240.00158VoltageYesYesYesYesYesYesYesYesYesYesYes YesYesYesYesYesYesYesYes YesYes64TQFP19.35 | 1ku具有 8051 微控制器与闪存的精密 A/D & D/A
    MicroSystem 控制器产品系列是完全集成的混合信号器件系列。此系列产品包括整合了以下组件的 8051 CPU:高分辨率 Δ-Σ 型 ADC、高分辨率 DAC、8 通道多路复用器、烧坏检测、可选缓冲输入、偏移 DAC(数模转换器)、可编程增益放大器 (PGA)、温度传感器、精密电压参考、闪存程序存储器、闪存数据存储器和数据 SRAM。此产品系列的器件的引脚都是兼容的,显著简化了器件迁移过程。
    片上外设包括附加的 32 位累加器、SPI 兼容 FIFO 串行端口、多主控 I2C、双 UART、多个数字输入/输出端口、看门狗定时器、低电压检测、片上加电复位、16 位 PWM、断点、节电复位和 3 个定时器/计数器。
    这些设备接受直接来自变送器的低电平差动信号或单端信号。该 ADC 使用具有可编程采样率的 sinc3 滤波器提供了 24 位分辨率和 24 位非遗漏代码性能。该 ADC 还具有一个可选滤波器,该滤波器允许进行高分辨率单周期转换。微控制器核心与 8051 指令集完全兼容。微控制器核心是经过优化的 8051 核心,在时钟源相同的情况下,此核心的执行速度最高可达标准 8051 核心的 3 倍。因此,有可能以较低的外部时钟频率运行器件并获得相同的性能,而功耗却低于标准 8051 核心。
    此产品系列允许用户对闪存和 SRAM 存储器映射进行独特的配置以满足他们的应用领域需求。使用串行和并行编程方法,可以使用低至 2.7V 的电压对闪存进行编程。闪存寿命是 100k 次擦除/写周期。此外,片上集成了 1,280 字节的 RAM。
    此部件具有独立的模拟和数字电源,它们可以独立地接受从 2.7V 到 +5.5V 的电源。在 +3V 工作时,部件功耗通常低于 4mW。此产品系列采用 TQFP-64 封装。
    此产品系列是为高分辨率测量应用领域设计的,例如智能发送器、工业过程控制、秤重、色谱分析和便携仪表。
    TI 德州仪器数MicroSystem 混合信号数据转换器技术支持
    1. TI 德州仪器仪 MicroSystem 混合信号数据转换器产品选型与价格 . xls
    2. 测量MSC12xx 元件的供应电压和提高起ADC PSRR .PDF
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
