龙人旗下深圳市龙芯世纪科技有限公司
  • 视频放大器、缓冲器和滤波器
  • 发布时间:2015/5/22 14:41:09   修改时间:2015/5/22 14:41:09 浏览次数:2117
  • Video Op-Amps
    Video Filters
    Part#Max Pos SupplySupply CurrentOperating Temp RangeStandardsResolutionVariable Gain2:1 Input MUXUS Price 1000-4999
    ADA4432-1-------$0.45
    ADA4433-13.613.2 mA-40 to +125SD480i2x-$0.85
    ADA4424-65.2593 mA-40 to +85CV1080i--$1.59
    ADA4420-65.2536 mA-RGB---$0.69
    ADA4431-13.64.7 mA-40 to +85SD480i2x-$0.50
    ADA4417-3524 mA-40 to +85RGB1080i2x-$0.80
    ADA4430-161.85 mA-40 to +125SD480i2x-$0.50
    ADA4412-31256 mA-40 to +85RGB1080i2x-$1.61
    ADA4411-31260 mA-40 to +85RGB1080i2xX$1.91
    ADA4410-61292 mA-40 to +85CV1080i2xX$2.52
    Video Buffers
    Part#Small Signal BandwidthVos (typ)Amps per PackageV Span MinV Span MaxSupply CurrentSlew RateVNoiseDensity (typ)Ib (typ)AolWidest Temp Range (°C)US Price 1000-4999
    AD8075550 MHz2.5 mV391130 mA1.35 kV/μs22 nV/rtHz5 μA--40 to +85$2.22
    AD8074600 MHz2.5 mV391130 mA1.6 kV/μs19.5 nV/rtHz5 μA--40 to +85$2.22
    AD8509-20 mV93.36.58.5 mA7 V/μs-50 nA--20 to +85$3.77
    AD8079260 MHz5 mV261211.5 mA800 V/μs2 nV/rtHz3 μA--40 to +85$4.56
    CAT-5 Video Drivers
    Part#-3dB Bandwidth0.1 dB Flatness (MHz)Minimum Gain (Acl)Slew Rate (V/us)DisableMin Pos SupplyMax Pos SupplySupply CurrentFeaturesUS Price 1000-4999
    AD8142285 MHz----4.55.5--$1.65
    AD8141275 MHz--1150 V/μs-4.55.544 mA-$1.65
    AD8124110 MHz----4.55.5132 mA-$5.95
    ADA4311-1310 MHz-51050 V/μs--1211.8 mA-$0.95
    AD8148700 MHz23543000 V/μsX4.55.562.5 mASync on Common Mode$3.13
    AD8147600 MHz23523000 V/μsX4.55.561.5 mASync on Common Mode$3.03
    AD8146700 MHz20023000 V/μsX4.55.561.5 mAAdjustable Output Common Mode Voltage$2.92
    ADA4310-1190 MHz-1820 V/μs-61211.2 mA-$0.90
    AD8133450 MHz5521600 V/μsX2.81126 mA-$2.62
    AD8134450 MHz5521600 V/μsX4.51126.5 mASync-on-CM$2.62
    AD8131400 MHz8522000 V/μs-2.71110.25 mA-$1.82
    CAT-5 Video Receivers
    Part#-3dB Bandwidth0.1 dB Flatness (MHz)Slew Rate (V/us)Minimum Gain (Acl)Min Pos SupplyMax Pos SupplySupply CurrentDisableFeaturesUS Price 1000-4999
    AD8145500 MHz1002100 V/μs14.51148.5 mAXSync-on-CM$3.03
    AD8143260 MHz601000 V/μs14.525.239 mAXSync-on-CM$2.58
    AD8130270 MHz301090 V/μs14.525.210.8 mAX-$1.57
    AD8129200 MHz201060 V/μs104.525.210.8 mAXLow Noise$1.57
    CAT-5 Cable Equalizers
    Part#-3dB Bandwidth0.1 dB Flatness (MHz)Slew Rate (V/us)Minimum Gain (Acl)Max Pos SupplySupply CurrentFeaturesUS Price 1000-4999
    AD8123120 MHz---5.5132 mAUp to 300 m of Cat-5$7.88
    AD8128120 MHz702700 V/μs-5.524 mAUp to 100m of CAT-5$2.62
    Video RF Splitters///
    Part#I/O ConfigurationInputs:Outputs1-dB BandwidthCSOCTBNF (typ)US Price 1000-4999
    ADA4304-4----62-724$1.61
    ADA4304-3---62724$1.00
    ADA4304-2----62-724.6$0.91
    ADA4303-2----62-724.4$0.87
    ADA4302-4Differential1:4--73-664.4-
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
