龙人旗下深圳市龙芯世纪科技有限公司
  • 先进负载开关
  • 发布时间:2015/12/18 14:31:23   修改时间:2015/12/18 14:31:23 浏览次数:2161
  • FPF2195 带可调节限流的全功能负载开关 Integrated Load Switch W/Protection & Adjustable Reverse Current Blocking Commercial -40 to 85 °C 600 to 1000 mA 80mΩVin=3.3V 1.8 5.5 WL-CSP 6L
    FPF2495 IntelliMAX? 具有可调限流控制功能的 28V 过压过流保护负载开关 Integrated Load Switch W/Protection & Adjustable Reverse Current Blocking Commercial -40 to 85 °C 100 to 1500 mA
    2.5 5.5 WL-CSP 9L
    FPF3003 用于双电池便携系统的 IntelliMAX? 全功能输入功率路径管理开关 Integrated Load Switch W/Protection Commercial -40 to 85 °C
    34mΩVin=5.5V 2.3 5.5 WL-CSP 16L
    FAN7093_F085 高电流 PN 半桥驱动器 Protected Smart High Side Switch with Diagnostics Automotive Qualified -40 to 150 °C 39000 to 61000 mA 0.0123Ω, 0.0182Ω 7 18 TO-263 8L (D2PAK)
    FDDS10H04_F085A Smart High-Side Switch Protected Smart High Side Switch with Diagnostics Automotive Qualified -40 to 150 °C 40000 to 120000 mA 0.01Ω 5.5 38 TO-252 5L (DPAK)
    FPF1048 IntelliMAX? 处理3A、控制压摆率负载开关,带真正的防电流倒灌功能。 Integrated Load Switch W/Protection Commercial -40 to 85 °C
    26mΩVin=3.3V 1.5 5.5 WL-CSP 6L
    FDBS09H04_F085A Smart High Side Switch Protected Smart High Side Switch with Diagnostics Automotive Qualified -40 to 150 °C 55000 to 125000 mA 0.009Ω 5.5 38 TO-263 8L (D2PAK)
    FDDS100H06_F085 智能高端开关 Protected Smart High Side Switch with Diagnostics Automotive Qualified -40 to 150 °C 7000 to 19000 mA 0.1Ω 5.5 37 TO-252 5L (DPAK)
    FPF2700 AccuPower? 先进负载管理产品 Integrated Load Switch W/Protection Commercial -40 to 85 °C 400 to 2000 mA 0.114ΩVin=12.0V, 0.114ΩVin=5.0V 2.8 36 MLP 3x3 8L (Power 33),  SO 8L NB
    FPF2701 AccuPower? 先进负载管理产品 Integrated Load Switch W/Protection Commercial -40 to 85 °C 400 to 2000 mA 0.114ΩVin=12.0V, 0.114ΩVin=5.0V 2.8 36 MLP 3x3 8L (Power 33),  SO 8L NB
    FPF2702 AccuPower? 先进负载管理产品 Integrated Load Switch W/Protection Commercial -40 to 85 °C 400 to 2000 mA 0.114ΩVin=12.0V, 0.114ΩVin=5.0V 2.8 36 MLP 3x3 8L (Power 33),  SO 8L NB
    FPF2300 双输出限流开关 Integrated Load Commercial -40 to 85 °C 1100 to 1500 mA 140mΩVin=5.5V 1.8 5.5 SO 8L NB,  MLP 3x3 8L (Power 33)
    FPF2302 双输出限流开关 Integrated Load Commercial -40 to 85 °C 1100 to 1500 mA 140mΩVin=5.5V 1.8 5.5 SO 8L NB,  MLP 3x3 8L (Power 33)
    FPF2303 双输出限流开关 Integrated Load Commercial -40 to 85 °C 1100 to 1500 mA 140mΩVin=5.5V 1.8 5.5 SO 8L NB,  MLP 3x3 8L (Power 33)
    FPF2310 双输出可调限流开关 Integrated Load Commercial -40 to 85 °C 400 to 550 mA 140mΩVin=5.5V 1.8 5.5 MLP 3x3 8L (Power 33)
    FPF2312 双输出可调限流开关 Integrated Load Commercial -40 to 85 °C 400 to 550 mA 140mΩVin=5.5V 1.8 5.5 MLP 3x3 8L (Power 33)
    FPF2313 双输出可调限流开关 Integrated Load Commercial -40 to 85 °C 400 to 550 mA 140mΩVin=5.5V 1.8 5.5 MLP 3x3 8L (Power 33)
    FPF2313L 双输出可调限流开关 Integrated Load Commercial -40 to 85 °C 400 to 550 mA 140mΩVin=5.5V 1.8 5.5 MLP 3x3 8L (Power 33)
    FPF2165R 带可调节限流的全功能负载开关 Integrated Load Switch W/Protection & Adjustable Reverse Current Blocking Commercial -40 to 85 °C 150 to 1500 mA 0.124ΩVin=5.0V, 160mΩVin=3.3V 1.8 5.5 MLP 2x2 6L (MicroFET)
    FPF1017 IntelliMAX? 1V额定高级负载管理产品
    45mΩVin=5.5V -0.3 2 UMLP 2x2 6L
    FPF2024 具有100mA限流值的全功能负载开关 Full Functional Load Switch With 100mA Current Limit Commercial -40 to 85 °C 100 to 200 mA 0.325ΩVin=5.0V, 315mΩVin=5.5V, 360mΩVin=3.3V -0.3 5.5 WL-CSP 6L
    FPF2025 具有100mA限流值的全功能负载开关 Full Functional Load Switch With 100mA Current Limit Commercial -40 to 85 °C 100 to 200 mA 315mΩVin=5.5V, 325mΩVin=3.3V 1.6 5.5 WL-CSP 6L
    FPF2026 具有100mA限流值的全功能负载开关 Full Functional Load Switch With 100mA Current Limit Commercial -40 to 85 °C 100 to 200 mA 0.325ΩVin=5.0V, 315mΩVin=5.5V, 360mΩVin=3.3V 1.8 5.5 WL-CSP 6L
    FPF2027 具有100mA限流值的全功能负载开关 Full Functional Load Switch With 100mA Current Limit Commercial -40 to 85 °C 100 to 200 mA 0.325ΩVin=5.0V, 315mΩVin=5.5V, 360mΩVin=3.3V 1.8 5.5 WL-CSP 6L
    FPF2200 具有500mA高精度限流的集成式负载开关 Integrated Load Switch with High Precision Current Limit Commercial -40 to 85 °C 504 to 557 mA 185mΩVin=5.5V, 210mΩVin=3.3V 1.8 5.5 MLP 2x2 6L (MicroFET)
    FPF2201 具有500mA高精度限流的集成式负载开关 Integrated Load Switch with High Precision Current Limit Commercial -40 to 85 °C 504 to 557 mA 185mΩVin=5.5V, 210mΩVin=3.3V 1.8 5.5 MLP 2x2 6L (MicroFET)
    FPF2202 具有500mA高精度限流的集成式负载开关 Integrated Load Switch with High Precision Current Limit Commercial -40 to 85 °C 504 to 557 mA 185mΩVin=5.5V, 210mΩVin=3.3V 1.8 5.5 MLP 2x2 6L (MicroFET)
    FPF2213 具有可调式精密限流的集成式负载开关 Integrated Load Switch with Adjustable High Precision Curent Limit Commercial -40 to 85 °C 250 to 276 mA 325mΩVin=5.5V, 360mΩVin=3.3V 1.8 5.5 MLP 2x2 6L (MicroFET)
    FPF2214 具有可调式精密限流的集成式负载开关 Integrated Load Switch with Adjustable High Precision Curent Limit Commercial -40 to 85 °C 250 to 276 mA 325mΩVin=5.5V, 360mΩVin=3.3V 1.8 5.5 MLP 2x2 6L (MicroFET)
    FPF2223 具有可调式精密限流的集成式负载开关 Integrated Load Switch with Adjustable High Precision Curent Limit Commercial -40 to 85 °C 627 to 693 mA 165mΩVin=5.5V, 210mΩVin=3.3V 1.8 5.5 MLP 2x2 6L (MicroFET)
    FPF2224 具有可调式精密限流的集成式负载开关 Integrated Load Switch with Adjustable High Precision Curent Limit Commercial -40 to 85 °C 627 to 693 mA 165mΩVin=5.5V, 210mΩVin=3.3V 1.8 5.5 MLP 2x2 6L (MicroFET)
    FPF2225 具有可调式精密限流的集成式负载开关 Integrated Load Switch with Adjustable High Precision Current Limit Commercial -40 to 85 °C 627 to 693 mA 185mΩVin=5.5V, 210mΩVin=3.3V 1.8 5.5 MLP 2x2 6L (MicroFET)
    FPF2215 具有可调式精密限流的集成式负载开关 Integrated Load Switch with Adjustable High Precision Curent Limit Commercial -40 to 85 °C 250 to 276 mA 325mΩVin=5.5V, 360mΩVin=3.3V 1.8 5.5 MLP 2x2 6L (MicroFET)
    FPF1009 IntelliMAX? 高级负载产品
    0.03ΩVin=5.0V, 40mΩVin=3.3V 1.2 5.5 MLP 2x2 6L
    FPF2193 带可调节限流的全功能负载开关 Integrated Load Switch W/Protection & Adjustable Reverse Current Blocking Commercial -40 to 85 °C 600 to 1000 mA 80mΩVin=3.3V 1.8 5.5 WL-CSP 6L
    FPF2194 带可调节限流的全功能负载开关 Integrated Load Switch W/Protection & Adjustable Reverse Current Blocking Commercial -40 to 85 °C
    80mΩVin=5.5V 1.8 5.5 WL-CSP 6L
    FPF2142 提供反向电流阻隔的全功能负载开关 Integrated Load Switch W/Protection & Reverse Blocking Commercial -40 to 85 °C 200 to 400 mA 160mΩVin=5.5V 1.8 5.5 MLP 2x2 6L (MicroFET)
    FPF2143 提供反向电流阻隔的全功能负载开关 Integrated Load Switch W/Protection & Reverse Blocking Commercial -40 to 85 °C 200 to 400 mA 160mΩVin=5.5V 1.8 5.5 MLP 2x2 6L (MicroFET)
    FPF2146 提供反向电流阻隔的全功能负载开关 Integrated Load Switch W/Protection & Reverse Blocking Commercial -40 to 85 °C 400 to 800 mA 160mΩVin=5.5V 1.8 5.5 MLP 2x2 6L (MicroFET)
    FPF2147 提供反向电流阻隔的全功能负载开关 Integrated Load Switch W/Protection & Reverse Blocking Commercial -40 to 85 °C 400 to 800 mA 160mΩVin=3.3V 1.8 5.5 MLP 2x2 6L (MicroFET)
    FPF2163 带可调节限流的全功能负载开关 Integrated Load Switch W/Protection & Adjustable Reverse Current Blocking Commercial -40 to 85 °C 600 to 1000 mA 160mΩVin=3.3V 1.8 5.5 MLP 2x2 6L (MicroFET)
    FPF2164 带可调节限流的全功能负载开关 Integrated Load Switch W/Protection & Adjustable Reverse Current Blocking Commercial -40 to 85 °C 600 to 1000 mA 160mΩVin=3.3V 1.8 5.5 MLP 2x2 6L (MicroFET)
    FPF2165 带可调节限流的全功能负载开关 Integrated Load Switch W/Protection & Adjustable Reverse Current Blocking Commercial -40 to 85 °C 600 to 1000 mA 160mΩVin=3.3V 1.8 5.5 MLP 2x2 6L (MicroFET)
    FPF1006 IntelliMAX? 先进负载管理产品 Output Discharge Function Commercial -40 to 85 °C
    70mΩVin=5.5V, 80mΩVin=3.3V 1.2 5.5 MLP 2x2 6L
    FPF2174 IntelliMAX? 先进负载管理产品 Integrated Load Switch W/Protection & Adjustable Reverse Current Blocking Commercial -40 to 85 °C 200 to 400 mA
    1.8 5.5 MLP 3x3 6L
    FPF2172 IntelliMAX? 先进负载管理产品 Integrated Load Switch W/Protection & Reverse Blocking Commercial -40 to 85 °C 200 to 400 mA
    1.8 5.5 MLP 3x3 6L
    FPF1005 IntelliMAX? 先进负载管理产品 Integrated Load Switch Commercial -40 to 85 °C
    FPF2116 IntelliMAX? 先进负载管理产品 Integrated Load Switch W/Protection & Reverse Blocking Commercial -40 to 85 °C 200 to 400 mA 160mΩVin=3.3V 1.8 5.5 SOT-23 5L
    FPF2123 带可调节限流的全功能负载开关 Integrated Load Switch W/Protection & Adjustable Reverse Current Blocking Commercial -40 to 85 °C 600 to 1000 mA 160mΩVin=3.3V 1.8 5.5 SOT-23 5L
    FPF2124 带可调节限流的全功能负载开关 Integrated Load Switch W/Protection & Adjustable Reverse Current Blocking Commercial -40 to 85 °C 600 to 1000 mA 160mΩVin=3.3V 1.8 5.5 SOT-23 5L
    FPF2125 带可调节限流的全功能负载开关 Integrated Load Switch W/Protection & Adjustable Reverse Current Blocking Commercial -40 to 85 °C 600 to 1000 mA 160mΩVin=3.3V 1.8 5.5 SOT-23 5L
    FPF2108 IntelliMAX ? 先进负载管理产品 Integrated Load Switch W/Protection & Reverse Blocking Commercial -40 to 85 °C 400 to 800 mA 160mΩVin=3.3V 1.8 5.5 SOT-23 5L
    FPF2100 全功能负载开关 Integrated Load Switch W/Protection Commercial -40 to 85 °C 200 to 400 mA 160mΩVin=5.5V 1.8 5.5 SOT-23 5L
    FPF2101 全功能负载开关 Integrated Load Switch W/Protection Commercial -40 to 85 °C 200 to 400 mA 160mΩVin=5.5V 1.8 5.5 SOT-23 5L
    FPF2102 全功能负载开关 Integrated Load Switch W/Protection Commercial -40 to 85 °C 200 to 400 mA 160mΩVin=5.5V 1.8 5.5 SOT-23 5L
    FPF2103 全功能负载开关 Integrated Load Switch W/Protection Commercial -40 to 85 °C 200 to 400 mA 160mΩVin=5.5V 1.8 5.5 SOT-23 5L
    FPF2105 全功能负载开关 Integrated Load Switch W/Protection Commercial -40 to 85 °C 400 to 800 mA 160mΩVin=5.5V 1.8 5.5 SOT-23 5L
    FPF2106 全功能负载开关 Integrated Load Switch W/Protection Commercial -40 to 85 °C 400 to 800 mA 160mΩVin=3.3V 1.8 5.5 SOT-23 5L
    FPF2107 全功能负载开关 Integrated Load Switch W/Protection Commercial -40 to 85 °C 400 to 800 mA 160mΩVin=5.5V 1.8 5.5 SOT-23 5L
    FPF2109 提供反向电流阻隔的全功能负载开关 Integrated Load Switch W/Protection & Reverse Blocking Commercial -40 to 85 °C 200 to 400 mA 160mΩVin=5.5V 1.8 5.5 SOT-23 5L
    FPF2000 全功能负载开关 Integrated Load Switch W/Protection Commercial -40 to 85 °C 50 to 100 mA 80mΩVin=3.3V 1.8 5.5 SC70 5L
    FPF2002 全功能负载开关 Integrated Load Switch W/Protection Commercial -40 to 85 °C 50 to 100 mA 80mΩVin=3.3V 1.8 5.5 SC70 5L
    FPF2003 全功能负载开关 Integrated Load Switch W/Protection Commercial -40 to 85 °C 50 to 100 mA 1mΩVin=5.5V -0.3 5.5 SC70 5L
    FPF2004 全功能负载开关 Integrated Load Switch W/Protection Commercial -40 to 85 °C 100 to 200 mA 80mΩVin=3.3V 1.8 5.5 SC70 5L
    FPF2005 全功能负载开关 Integrated Load Switch W/Protection Commercial -40 to 85 °C 100 to 200 mA 80mΩVin=3.3V 1.8 5.5 SC70 5L
    FPF2006 全功能负载开关 Integrated Load Switch W/Protection Commercial -40 to 85 °C 100 to 200 mA 80mΩVin=3.3V 1.8 5.5 SC70 5L
    FPF2007 全功能负载开关 Integrated Load Switch W/Protection Commercial -40 to 85 °C 100 to 200 mA 1mΩVin=5.5V -0.3 5.5 SC70 5L
    压摆率受控负载开关 (31)
    部件编号 说明 功能 ILIM(最小值) (mA) ILIM(最大值) (mA) RON VIN(最小值) (V) VIN(最大值) (V) 封装
    FPF2411 IntelliMAX? 带压摆率控制和 RCB 功能的额定 6 V/6 A 双向开关 带保护和反相闭锁的集成式负载开关
    2.3 5.5 WL-CSP 12L
    FPF1504 先进负载管理开关 先进负载管理开关
    15mΩ@Vin=3.3V 1 3.6 WL-CSP 4L
    FPF1203L IntelliMAX? Ultra-Small, Slew-Rate-Controlled Load Switch 设备ON
    0.045Ω@Vin=5.5V, 55mΩ@Vin=3.3V 1.2 5.5 WL-CSP 4L
    FPF3040 IntelliMAX? 20 V 额定电压双输入单输出电源选择器开关 带保护集成式负载开关
    4 10.5 WL-CSP 16L
    FPF12045 IntelliMAX? 超小型压摆率控制负荷开关 低导通电阻、压摆率控制负载开关
    FPF1204 IntelliMAX? 超小型压摆率控制负荷开关 设备ON
    FPF1039 低导通电阻、压摆率控制负载开关 低导通电阻、压摆率控制负载开关
    0.02Ω@Vin=5.5V, 24mΩ@Vin=3.3V 1.2 5.5 WL-CSP 6L
    FPF1320 具有精确反向电流阻隔功能的IntelliMAX? 双输入单输出高级功率开关 设备ON
    0.005 50mΩ@Vin=3.3V 1.5 5.5 WL-CSP 6L
    FPF1321 具有精确反向电流阻隔功能的IntelliMAX? 双输入单输出高级功率开关 设备ON 65 Ω芯片负载电阻
    FPF1203 IntelliMAX? 超小型压摆率控制负荷开关 设备ON
    FPF1205 IntelliMAX? 高级负载管理器件 设备ON
    75mΩ@Vin=3.3V 1.2 4 WL-CSP 4L
    FPF1206 IntelliMAX? 高级负载管理器件 设备ON
    FPF1207 IntelliMAX? 高级负载管理器件 设备ON
    50mΩ@Vin=3.3V 1.2 4 WL-CSP 4L
    FPF1208 IntelliMAX? 高级负载管理器件 设备ON
    FPF1038 低导通电阻、压摆率控制负载开关 低导通电阻、压摆率控制负载开关
    FPF1103 高级负载管理开关 先进负载管理开关
    35mΩ@Vin=3.3V 1.2 4 WL-CSP 4L
    FPF1108 高级负载管理开关 先进负载管理开关
    FPF1104 高级负载管理开关 先进负载管理开关
    FPF1107 高级负载管理开关 先进负载管理开关
    FPF1013 IntelliMAX? 1V额定高级负载管理产品 输出放电功能
    27mΩ@Vin=3.3V 0.8 1.8 WL-CSP 6L
    FPF1014 IntelliMAX? 1V额定高级负载管理产品 输出放电功能
    FPF1015 IntelliMAX? 1V额定高级负载管理产品 输出放电功能
    34mΩ@Vin=3.3V 0.8 1.8 UMLP 2x2 6L
    FPF1016 IntelliMAX? 1V额定高级负载管理产品 输出放电功能
    FPF1018 IntelliMAX? 1V额定高级负载管理产品 输出放电功能
    FPF1003A IntelliMAX? 先进负载管理产品 集成式负载开关
    1.2 5.5 WL-CSP 6L
    FPF1008 IntelliMAX? 高级负载产品 输出放电功能
    0.03Ω@Vin=5.5V, 40mΩ@Vin=3.3V 1.2 5.5 MLP 2x2 6L
    FPF1007 IntelliMAX? 高级负载产品 输出放电功能
    FPF1004 IntelliMAX? 先进负载管理产品 输出放电功能
    0.03Ω@Vin=5.5V, 35mΩ@Vin=3.3V 1.2 5.5 WL-CSP 6L
    FPF2110 提供反向电流阻隔的全功能负载开关 带保护和反相闭锁的集成式负载开关 200 400 125mΩ@Vin=3.3V 1.8 5.5 SOT-23 5L
    FPF2104 全功能负载开关 带保护集成式负载开关 200 400 125mΩ@Vin=3.3V 1.8 5.5 SOT-23 5L
    FPF2001 全功能负载开关 带保护集成式负载开关 50 100 700m
龙人旗下深圳市龙芯世纪科技有限公司
联系人:BDTIC
地址:深圳市福田区福虹路世界贸易广场B座12F
邮编:100089
电话:0755-83574969
传真:0755-83778351
公司网址:http://www.BDTIC.com/IC
  • 李小东 在2023/8/23 0:15:00留言
  • 详细留言:了解产品的合作
  • 徐工 在2022/11/23 15:39:00留言
  • 详细留言:ATMEGA32 TWI硬件从机使用。
  • 徐工 在2022/11/21 9:30:00留言
  • 详细留言:ATMEAG32 硬件11C主从通信
  • 于方元 在2021/7/8 19:21:00留言
  • 详细留言:全以太网工控系统开发。
  • 明小姐 在2015/3/26 16:06:00留言
