深圳市德威达科技有限公司
  • SFI系列可视流量指示器
  • 发布时间:2012/9/7 10:27:25   修改时间:2012/9/7 10:27:25 浏览次数:1915
  • 产品名称:  SFI可视流量指示器
    产品型号:  SFI
    可直接观察流体
    应用:冷却系统流量指示、润滑系统、供燃料系统等
    100——
    单窗带叶轮
    300——
    双窗带叶轮
    350——
    双窗无叶轮指示
    360——
    双窗带叶拍
    400——
    管状无叶片指示
    700——
    管状带叶片带内部擦拭器
    选型表:
    100300系列特性
    介质: 兼容液体或气体.
    接液材质: 窗口: 回火玻璃; 本体: 紫铜或316 SS; 密封片: Buna-N, 氟橡胶or PTFE; 指示轮: ABS or 316 SS叶轮(100 and 300), 304 SS or 316 SS挡板(360).
    温度限制: 200°F (93°C).
    压力限制: 125 psig (8.62 bar), 150 psig (10.34 bar) on "MP" Models.
    连接: 螺纹.
    举例 SFI 300 SS 2 G2 SFI-300SS-2-G2 Sight Flow Indicator; double window, temper glass, Viton? gaskets, 316SS body, ABS impeller, 2 inch female NPT connections.
    型号 SFI         Sight flow indicator, tempered glass standard, Buna-N gaskets standard, female NPT connections standard.
    类型   100
    300
    350
    360
          Single window, bronze body, ABS Impeller
    Double window, bronze body, ABS Impeller
    Double window, bronze body, no moving indicator
    Double window, bronze body, 304SS flapper
    本体选项     SS
    MP
        316SS body option for 300, 350, 360
    150 psig maximum pressure option, includes Viton? gaskets
    连接尺寸       1/4
    3/8
    1/2
    3/4
    1
    1-1/4
    1-1/2
    2
      1/4 inch connection size
    3/8 inch connection size
    1/2 inch connection size
    3/4 inch connection size
    1 inch connection size
    1-1/4 inch connection size
    1-1/2 inch connection size
    选项         W2
    G1
    G2
    S2
    S3
    I1
    I2
    I3
    F1
    BSPT
    BSPP
    Plexiglass window
    Teflon? gasket
    Viton? gasket
    316SS Shaft (Not on 350 Model)
    Monel Shaft (Not on 350 Model)
    ABS impeller with bronze bushing (Not on 350, 360)
    316SS impeller (Not on 350, 360)
    No impeller (100 only)
    316SS Flapper (360 only)
    BSPT threads
    BSPP threads
    300F系列特性
    介质: 兼容液体或气体.
    接液材质: 窗口: 回火玻璃; 本体: 碳钢或316 SS; 密封片: Buna-N, 氟橡胶or PTFE; 指示轮: ABS or 316 SS叶轮(360)
    温度限制: 200°F (93°C).
    压力限制: 150 psig (10.34 bar)
    连接: 法兰
    举例 SFI 360FSS 1-1/2 G1 SFI-360FSS-1-1/2-G1 Sight Flow Indicator; double window, tempered glass, Teflon? gasket, 316SS body,304SS flapper, 1-1/2 inch raised face flange connections
    型号 SFI       Sight flow indicator, double window, tempered glass, Buna-N gaskets standard, raised face flange connections
    类型   350FCS
    350FSS
    360FCS
    360FSS
        Carbon steel body, no moving indicator
    316SS body, no moving 316SS indicator
    Carbon steel body, 316SS flapper
    316SS body, 316SS flapper
    连接尺寸     1-1/2
    2
    3
    4
    6
      1-1/2 inch raised face flange connection size
    3 inch raised face flange connection size
    4 inch raised face flange connection size
    6 inch raised face flange connection size
    可选项       G1
    G2
    Teflon? gasket
    Viton? gasket
    400系列特性
    介质: 兼容液体或气体.
    接液材质: 筒子: 回火硼硅酸盐; 本体: 铸铁或316 SS; 密封片:PTFE
    温度限制: 200°F (93°C).
    压力限制:
    50 psig (3.45 bar)
    连接: 螺纹或法兰
    举例 SFI 400 1-1/2 SFI-400SS-1-1/2 Sight Flow Indicator; tube type, borosilicate tube, Teflon? gaskets, 316SS body, 1-1/2 inch female NPT connections
    型号 SFI     Sight flow indicator, tube type, borosilicate tube, Teflon? gaskets
    类型   400CI
    400SS
    400F
      Female NPT connections, cast iron body
    (only for 1 through 2 inch sizes)
    Female NPT connections, 316SS body
    Raised face flange connection, 316SS body
    (only for 1 inch and up sizes)
    尺寸     1/2
    3/4
    1
    1-1/4
    1-1/2
    2
    3
    4
    3 inch connection size
    700系列特性
    介质: 兼容液体或气体.
    接液材质: 筒子: 回火硼硅酸盐; 本体: 黄铜或316 SS; 密封片:氟橡胶; 指示轮: 乙缩醛
    温度限制: 212°F (100°C).
    压力限制:
    230 psig (15.86 bar)
    连接: 螺纹
    举例 SFI 700SS 1-1/2   SFI-700SS-1-1/2 Sight Flow Indicator; tube type with 8 blade Delrin? impeller and integral wipers to clean tube interior, tempered borosilicate tube, Viton? gaskets, 316SS body, 1-1/2 inch female NPT connections
    型号 SFI       Sight flow indicator, tube type with 8 blade Delrin impeller and integral wipers to clean tube interior, tempered borosilicate tube, Viton? gaskets
    类型   700
    700SS
        Brass body
    316SS body
    连接尺寸     1/4
    3/8
    1/2
    3/4
    1
    1-1/4
    1-1/2
      1/4 inch female NPT connection size
    3/8 inch female NPT connection size
    1/2 inch female NPT connection size
    3/4 inch female NPT connection size
    1 inch female NPT connection size
    1-1/4 inch female NPT connection size
    1-1/2 inch female NPT connection size
    可选项       BSPT
    BSPP
    BSPT threads
    BSPP threads
美国德威尔(Dwyer)仪器仪表授权中国代理——深圳市德威达科技有限公司深圳市德威达科技有限公司 (Shenzhen Deweida Technology Co., Ltd.)是从事自动控制系统开发和仪器仪表等机电产品销售的高科技专业公司。 公司人员有着多年的工业自动控制和楼宇自动…  更多>>
深圳市德威达科技有限公司
联系人:刘生
地址:深圳市福田区深南中路南侧南光捷佳大厦2001
邮编:518033
电话:0755-83692627,83692637,83692695
传真:0755-83692660
公司网址:http://www.szdwd.com
  • 韩先生 在2013/5/22 14:48:00留言
  • 详细留言:GFC-1144 供货及附件清单 价格
  • 韩先生 在2013/5/22 14:46:00留言
  • 详细留言:GFC-1144
