产品名称: WD2水泄露开关产品型号: WD2Service: Water.Switch Type: WD2-BP2: Solid state relay; WD2-LP: SPDT relay.Electrical Rating: WD2-BP2: Pilot duty rating max. 250 mA @ 24 VDC; WD2-LP: SPDT 1A @ 24 VAC/DC, 1A @ 120 VAC.Audible Alarm Function on WD2-BP1/WD2-BP2: 10 sec on, 30 sec off.LED Alarm Function on WD2-BP1/WD2-BP2: 10 sec off, 30 sec on.Power Requirements: WD2-BP1/WD2-BP2: 3V lithium battery (approximately 2 years battery life); WD2-LP: 11-27 VAC/DC.Power Consumption: WD2-BP1/WD2-BP2: 0.9 mA steady state non-alarm, 3.0 mA during audible alarm, 2.4 mA during LED illumination; WD-LP: DC 25 mA typical and 75 mA max, AC 30 mA typical and 85 mA max.Electrical Connections: WD2-BP2: Attached 22 AWG, PVC insulated cable (0.8 ft long); WD2-LP: Attached 22 AWG, PVC insulated cable (4.8 ft long).Enclosure: Acrylic, ABS plastic.Temperature Limits: 32 to 122°F (0 to 50°C).Weight: WD2-BP1: 2 oz; WD2-BP2: 3.5 oz; WD2-LP: 4.3 oz
型号 特性 WD2-BP1 Battery powered leak detector. WD2-BP2 Battery powered leak detector with SSR output. WD2-LP Line powered 24 VAC/DC leak detector with relay output
联系人:刘生
地址:深圳市福田区深南中路南侧南光捷佳大厦2001
邮编:518033
电话:0755-83692627,83692637,83692695
传真:0755-83692660
公司网址:http://www.szdwd.com
