产品名称: PMT系列粉尘浓度变送器产品型号: PMT
两线制4-20mA输出
Service: Air and compatible gases, any type particulate conductive or nonconductive.Wetted Materials: 304 SS and PTFE.Air Velocity Range: 300 ft/min and higher.Minimum Detection: Standard: 10.0 pA, Optional: 5.0 pA and 0.5 pA.Temperature Limits: Ambient: -15 to 160°F (-25 to 70°C); Process: Standard: -40 to 250°F (-40 to 120°C); Optional: -40 to 450°F (-40 to 232°C).Pressure Limit: 10 psi (0.69 bar).Power Requirement: 18-28 VDC (24V Nominal).Output Signal: 4-20 mA.Loop Resistance: 300 Ohms maximum.Current Consumption: Powered from 4-20 mA loop.Electrical Consumption: Terminal Block.Process Connection: See Model Chart on Ordering Page.Enclosure Rating: Weatherproof, NEMA 4X (IP 66).Mounting Orientation: Any.Weight: Varies with length of probe and type of mount.Agency Approvals: CE Ordinary locations only, CSA
选型表
1.5" Probe3" Probe5" Probe10" Probe15" Probe20" Probe30" Probe36" Probe
联系人:刘生
地址:深圳市福田区深南中路南侧南光捷佳大厦2001
邮编:518033
电话:0755-83692627,83692637,83692695
传真:0755-83692660
公司网址:http://www.szdwd.com
