深圳市德威达科技有限公司
  • PMS系列粉尘浓度传感器
  • 发布时间:2009/6/5 16:24:01   修改时间:2009/10/27 14:58:40 浏览次数:1990
  • 产品名称:  PMS系列粉尘浓度传感器
    产品型号:  PMS
    和DPM监控仪表配套使用
    Service: Air and compatible gases, any type particulate.
    Wetted Materials: 304SS and PTFE.
    Minimum Detection: 5.0 pA.
    Temperature Limits: Ambient: Maximum -40 to 392°F (-40 to 200°C) (Maximum must be calculated for each application).
    Process: See Model Chart on.
    Pressure Limits: Standard: Full vacuum to 10 psi (0.69 bar); Optional: 100 psi (6.89 bar).
    Output Signal: pA.
    Electrical Connection: Low noise coaxial.
    Process Connection: See Model Chart on.
    Enclosure: Standard: Painted cast aluminum, Weatherproof, NEMA 4X; Optional: Intrinsically Safe, CSA.
    Weight: Varies depending on length of probe and type of mount.
    Agency Approvals: CE, CSA.
    选型表
    Example PMS A1 1 T1 P1 L1.5 PMS-A1P1T1P1-L1.5 Particulate Sensor, weatherproof, NEMA 4X, 1/2" NPT
    connection, 250°F max. temp., 10 psi max. pressure, 1.5" probe.
    Series Designator PMS           PMS Particulate Sensor
    Enclosure Rating   A1
    AHZ1
    Intrinsically Safe, CSA & CE Approvals, Class I, II and III, Divisions I & II, All
    Groups, NEMA 4X (requires sanitary connection or flange mount).
    Process Connection     1
    2
    3
    4
          1/2" NPT
    1.5" Sanitary Connection
    2" 150# ANSI Flange
    2" 150# ANSI Flange with Process Mating Flange and Installation Kit.
    Maximum Process
    Temperature
          T1
    T2
    T3
    T4
        250°F (121°C)
    450°F (232°C)
    800°F (426°C) -requires flange mount
    1200°F (649°C) - requires flange mount
    Maximum Process
    Pressure
            P1
    P2
      10 psi
    100 psi - requires flange mount
    Insertion Length
    (recommended at
    least 1/2 duct diameter)
              L1.5
    L03
    L05
    L10
    L15
    L20
    L30
    L36
    L48
    L60
    L72
    1.5" Probe
    3" Probe
    5" Probe
    10" Probe
    15" Probe
    20" Probe
    30" Probe
    36" Probe
    48" Probe
    60" Probe
    72" Probe
美国德威尔(Dwyer)仪器仪表授权中国代理——深圳市德威达科技有限公司深圳市德威达科技有限公司 (Shenzhen Deweida Technology Co., Ltd.)是从事自动控制系统开发和仪器仪表等机电产品销售的高科技专业公司。 公司人员有着多年的工业自动控制和楼宇自动…  更多>>
深圳市德威达科技有限公司
联系人:刘生
地址:深圳市福田区深南中路南侧南光捷佳大厦2001
邮编:518033
电话:0755-83692627,83692637,83692695
传真:0755-83692660
公司网址:http://www.szdwd.com
  • 韩先生 在2013/5/22 14:48:00留言
  • 详细留言:GFC-1144 供货及附件清单 价格
  • 韩先生 在2013/5/22 14:46:00留言
  • 详细留言:GFC-1144
