深圳市德威达科技有限公司
  • PMT系列粉尘浓度变送器
  • 发布时间:2009/9/17 11:48:38   修改时间:2009/10/27 14:57:28 浏览次数:1340
  • 产品名称:  PMT系列粉尘浓度变送器
    产品型号:  PMT
    两线制4-20mA输出
    粉尘浓度检测仪经过一个固定探头的静电荷感应量测量粉尘粒子浓度。粉尘粒子与探头感应产生静电荷,通过探头进行信号放大并传送进监测控制系统。静电荷的大小与粉尘粒子的流量成正比。本系统的高科技电子线路把这部分电荷转换成为控制信号输出,用于连续记录粉尘粒子的总量或浓度
    Service: Air and compatible gases, any type particulate conductive or nonconductive.
    Wetted Materials: 304 SS and PTFE.
    Air Velocity Range: 300 ft/min and higher.
    Minimum Detection: Standard: 10.0 pA, Optional: 5.0 pA and 0.5 pA.
    Temperature Limits: Ambient: -15 to 160°F (-25 to 70°C); Process: Standard: -40 to 250°F (-40 to 120°C); Optional: -40 to 450°F (-40 to 232°C).
    Pressure Limit: 10 psi (0.69 bar).
    Power Requirement: 18-28 VDC (24V Nominal).
    Output Signal: 4-20 mA.
    Loop Resistance: 300 Ohms maximum.
    Current Consumption: Powered from 4-20 mA loop.
    Electrical Consumption: Terminal Block.
    Process Connection: See Model Chart on .
    Enclosure Rating: Weatherproof, NEMA 4X (IP 66).
    Mounting Orientation: Any.
    Weight: Varies with length of probe and type of mount.
    Agency Approvals: CE Ordinary locations only, CSA
    选型表
    Example
    PMT
    A1
    1
    T1
    P1
    1
    L1.5
    PMT-A11T1P1-L1.5 Particulate Transmitter, ordinary/general purpose locations,
    CE approval, NEMA 4X, CSA, , 1/2" NPT connection, 250°F max. temp., 10 psi
    max. pressure, 10.0-5000 pA, 1.5" probe.
    Series Designator
    PMT
    PMT Particulate Transmitter (1-piece configuration, sensor included in price)
    Enclosure Rating
    A1
    AHZ2
    Ordinary/General Purpose Locations, CE Approval, NEMA 4X, CSA
    Hazardous Location, CSA Approval, Class I, Division II, Groups A-D; Class II,
    Groups F,G
    Process Connection
    1
    2
    3
    4
    1/2" NPT
    1.5" Sanitary Connection
    2" 150# ANSI Flange
    2" 150# ANSI Flange with Process Mating Flange and Installation Kit.
    Maximum Process
    Temperature
    T1
    T2
    250°F (121°C)
    450°F (232°C)
    Maximum Process
    Pressure
    P1
    10 psi
    Range
    1
    2
    3
      10.0-5000 pA
    5.0-5000 pA
    0.5-5000 pA (required for low levels or EPA leak detection)
    Insertion Length
    (recommended at
    least 1/2 duct diameter)
    L1.5
    L03
    L05
    L10
    L15
    L20
    L30
    L36
    1.5" Probe
    3" Probe
    5" Probe
    10" Probe
    15" Probe
    20" Probe
    30" Probe
    36" Probe
美国德威尔(Dwyer)仪器仪表授权中国代理——深圳市德威达科技有限公司深圳市德威达科技有限公司 (Shenzhen Deweida Technology Co., Ltd.)是从事自动控制系统开发和仪器仪表等机电产品销售的高科技专业公司。 公司人员有着多年的工业自动控制和楼宇自动…  更多>>
深圳市德威达科技有限公司
联系人:刘生
地址:深圳市福田区深南中路南侧南光捷佳大厦2001
邮编:518033
电话:0755-83692627,83692637,83692695
传真:0755-83692660
公司网址:http://www.szdwd.com
  • 韩先生 在2013/5/22 14:48:00留言
  • 详细留言:GFC-1144 供货及附件清单 价格
  • 韩先生 在2013/5/22 14:46:00留言
  • 详细留言:GFC-1144
