![](http://www.cechina.cn/UpLoad/CompanyFile/2010/6/12/fd7f7349-4218-4406-b9a9-4f80e4b9d8d0.jpg)
产品名称: DM-1100系列数显压差表
产品型号: DM-1100系列
24V电源或电池供电,LCD液晶显示,八种英制、公制单位可供选择
特性
四个按键操作更简化了压差表的设定和操作。
介质: Air and non-combustible, compatible gases.
接液材质: Consult factory.
外壳: Glass filled plastic.
精度: ±1% F.S. including linearity, hysteresis and repeatability.
温度范围: 0 to 140°F (-18 to 60°C).
稳定性: ±1% F.S. per year.
热效应: ±0.09% F.S./°F (±0.15% F.S./°C).
显示: 4-digit LCD (Digits: 0.60"H x 0.33"W).
显示更新: 0.5 second (damping set to 1).
压力范围: Ranges ≤ 10" w.c. plus all bi-directional ranges = 2 psi; Ranges > 10" w.c. = 11 psi.
电源: 9 to 24 VDC with battery back-up or stand alone battery.
电池: 9V alkaline battery (Duracell? PC 1604 or equivalent). Stand Alone Battery Service Life: 9 months (typical) at ambient temperatures of 32 to 104°F (0 to 40°C) and the Display Update set to 10 minutes. Battery may last up to four times longer when using lithium-based battery.
电流消耗: 10 mA maximum.
电源连接: Removable terminal block for 16 to 26 AWG.
尺寸: 4-3/4" diameter x 2.6" diameter.
接口: 1/8" (3 mm) I.D. tubing.
封装: NEMA 4X
选型表
型号 |
描述 |
DM-1102 |
DigiMag? differential digital pressure gage, range 0-0.25" w.c. |
DM-1103 |
DigiMag? differential digital pressure gage, range 0-0.5" w.c. |
DM-1104 |
DigiMag? differential digital pressure gage, range 0-1" w.c. |
DM-1105 |
DigiMag? differential digital pressure gage, range 0-2" w.c. |
DM-1107 |
DigiMag? differential digital pressure gage, range 0-5" w.c. |
DM-1108 |
DigiMag? differential digital pressure gage, range 0-10" w.c. |
DM-1109 |
DigiMag? differential digital pressure gage, range 0-15" w.c. |
DM-1110 |
DigiMag? differential digital pressure gage, range 0-25" w.c. |
DM-1111 |
DigiMag? differential digital pressure gage, range 0-50" w.c. |
DM-1112 |
DigiMag? differential digital pressure gage, range 0-100" w.c. |
DM-1122 |
DigiMag? differential digital pressure gage, range 0.25-0-0.25" w.c. |
DM-1123 |
DigiMag? differential digital pressure gage, range 0.5-0-0.5" w.c. |
DM-1124 |
DigiMag? differential digital pressure gage, range 1-0-1" w.c. |
DM-1125 |
DigiMag? differential digital pressure gage, range 2-0-2" w.c. |
DM-1127 |
DigiMag? differential digital pressure gage, range 5-0-5" w.c. |
DM-1128 |
DigiMag? differential digital pressure gage, range 10-0-10" w.c. |
附件 |
型号 |
描述 |
A-299 |
Mounting bracket, flush mount Magnehelic? gage in bracket. Bracket is then surface mounted. Steel with gray hammertone epoxy finish. |
A-300 |
Flat aluminum bracket for flush mounting Magnehelic? gage. |
A-310A |
3-way vent valve, plastic, 1/8" NPT to 1/4" metal tubing, 80 psi rating, replaces former Model A-310 (brass). |
A-480 |
Plastic static pressure tip. |
