![](http://www.cechina.cn/UpLoad/CompanyFile/2010/6/12/ea215677-7d2b-4c6e-86c9-124a7950ba15.jpg)
产品名称: BYDS系列风门旁通控制开关
产品型号: BYDS系列
产品介绍:
The Series BYDS Bypass Damper Switch is designed to control motorized bypass dampers. As individual zone dampers open and close, the system static pressure will rise and fall. In order to maintain proper airflow and static pressure through the HVAC system, a bypass system incorporating a floating type motorized damper and a static pressure control should be incorporated. A typical on/off pressure switch cannot operate in this application due to the high cycle rate that would result, eventually causing contact burnout. The BYDS static pressure control is equipped with a solid-state switching and timing circuit to enhance operation and improve long-term reliability in this demanding application.
技术参数:
介质: Air and non-combustible, compatible gases.
材质:Diaphragm Material: silicone; Housing Material: switch body: PA 6.6 and POM; Cover: polystyrene.
温度: Process ambient temperature from -4 to 185°F (-20 to 85°C).
压力: Max. Operating Pressure: 40" w.c. (10 kPa) for all pressure ranges.
开关类型: Single-pole double-throw (SPDT).
额定电气: 1A @ 24 VAC.
电气连接: Screw terminal block. M20 x 1.5 with cable strain relief or 1/2" NPT connection.
过程连接:5/16" (7.94 mm) outside diameter tubing, 1/4" (6.0 mm) inside diameter tubing.
安装方向:Vertically, with pressure connections pointing downwards.
封装:NEMA 13, IP54.
寿命: Over 106 switching operations.
重量:5.6 oz (160 g).
选型表:
型号 |
量程 |
BYDS-01-1 |
range .08-.8" w.c. |
BYDS-04-1 |
range .12-1.6" w.c. |
BYDS-03-1 |
range .2-2" w.c. |
BYDS-05-1 |
range .8-4" w.c. |
BYDS-06-1 |
range 2-10" w.c. |
BYDS-07-1 |
range 4-16" w.c. |
