![](http://www.cechina.cn/UpLoad/CompanyFile/2010/6/12/c883eccb-70ae-40ce-98be-2e5ea7058bce.jpg)
产品名称: 616WL系列压差变送器
产品型号: 616WL系列
产品介绍
The Series 616WL Differential Pressure Transmitter senses very low pressures of air and non-combustible, compatible gases and sends a standard 4-20 mA output signal. All models, including those featuring the 3 digit LCD digital read-out, are factory calibrated to specific ranges as listed in the chart below.
Positive, negative and differential pressures can be measured within a full span accuracy of ±0.50%. This weatherproof unit is enclosed in a polycarbonate case, designed to meet (IP66/NEMA 4X). Internal digital push button zero and span allow for quick and simple field calibration.
技术参数
介质: Air and non-combustible, compatible gases.
材质:Consult factory.
精度:±0.50% F.S., display accuracy ±0.5%.
稳定性:±1% F.S./yr.
温度范围:0 to 140°F (-17.8 to 60°C).
温度补偿范围: 20 to 120°F (-6.67 to 48.9°C).
压力范围:See Catalog page.
热效应:±0.02% F.S./°F (0.036% F.S./°C).
电源: 12-30 VDC (2-wire).
输出信号: 4 to 20 mA.
调零: Digital, Push Button Adj.
环路阻抗: DC; 0-900 ohms maximum.
电流:DC; 38 mA maximum.
电气连接:Screw-type terminal block.
过程连接: Barbed, dual size to fit 1/8" and 3/16" (3.12 and 4.76 mm) I.D. rubber or vinyl tubing.
封装:NEMA 4X (IP66).
安装方向: Vertical, consult factory for other position orientations.
重量: Without LCD 17 oz (482 g); with LCD 18 oz (510 g).
认证:CE.
选型表
EXAMPLE |
616WL |
1 |
AT |
Series 616WL-1-AT Differential Pressure Transmitter, range 0-0.10" w.c., with aluminum tag. |
SERIES |
616WL |
Differential Pressure Transmitter |
RANGE |
1 2 3 4 5 11 12 13 14 15 21 22 23 24 25 31 32 33 34 35 |
0-0.10" w.c. 0-0.25" w.c. 0-0.50" w.c. 0-1.00" w.c. 0-2.50" w.c. 0.10-0-0.10" w.c. 0.25-0-0.25" w.c. 0.50-0-0.50" w.c. 1.00-0-1.00" w.c. 2.50-0-2.50" w.c. 0-30 Pa 0-60 Pa 0-100 Pa 0-125 Pa 0-250 Pa 30-0-30 Pa 60-0-60 Pa 100-0-100 Pa 125-0-125 Pa 250-0-250 Pa |
OPTIONS |
AT LCD NIST PRESETD |
Aluminum Tag Liquid Crystal Display NIST Certificate of Calibration LCD Display Set to 0-100% |
