产品名称: 3200系列防爆压力变送器
产品型号: 3200系列
产品介绍
The Mercoid? Series 3200 Smart Pressure Transmitter is a microprocessor-based high performance transmitter, which has flexible pressure calibration, push button configuration, and programmable using HART? Communication. The Series 3200 is capable of being configured with the zero and span buttons, a field calibrator is not required for configuration. The transmitter software compensates for thermal effects, improving performance. EEPROM stores configuration settings and stores sensor correction coefficients in the event of shutdowns or power loss. The Series 3200 is FM approved for use in hazardous (Classified) locations. The 100:1 rangeability allows the smart transmitter to be configured to fit any application.
技术参数
介质: Compatible gases, steam, liquids or vapors.
材质: 316L SS.
精度: ±0.075% FS (@ 20°C).
可调范围: 100:1 turn down.
稳定性: ±0.125% FSO/yr.
温度: Process: -40 to 248°F (-40 to 120°C); Ambient: Without LCD -40 to 185°F (-40 to 85°C), With LCD -22 to 176°F (-30 to 80°C).
热效应: ±0.125 %span /32°C.
电源: 11.9 to 45 VDC.
输出: 4 to 20 mA / HART? Communication.
响应时间: 0.12 seconds.
缓冲时间: 0.25 to 60 seconds.
环路电阻: Operation: 0-1500 Ohm; HART? Communication: 250-500 Ohm.
连接: Two 1/2" female NPT conduit.
过程连接: 1/2" female NPT.
显示: Optional: 5 digit LCD.
封装: NEMA 4X (IP66) and explosion proof for Class I, Div I Groups A, B, C and D.
重量: 8.6 lb.
认证: FM, CE.
型 号 |
范 围 |
3200G-1-FM-1-1 |
Smart pressure transmitter, range -14.5 to 21 psi. |
3200G-2-FM-1-1 |
Smart pressure transmitter, range -14.5 to 217 psi. |
3200G-3-FM-1-1 |
Smart pressure transmitter, range 0 to 725 psi. |
3200G-4-FM-1-1 |
Smart pressure transmitter, range 0 to 3600 psi. |
备注:可选带-LCD显示
