产品名称: 3100系列防爆压差变送器
产品型号: 3100系列
产品介绍
The Mercoid? Series 3100 Smart Pressure Transmitter is a microprocessor-based high performance transmitter, which has flexible pressure calibration, push button configuration, and programmable using HART? Communication. The Series 3100 is capable of being configured for differential pressure or level applications with the zero and span buttons. A field calibrator is not required for configuration. The transmitter software compensates for thermal effects, improving performance. EEPROM stores configuration settings and stores sensor correction coefficients in the event of shutdowns or power loss. The Series 3100 is FM approved for use in hazardous (classified) locations. The 100:1 rangeability allows the smart transmitter to be configured to fit any application.
技术参数
介质: Compatible gases, steam, liquids or vapors.P/1.
材质: 316L SS.
精度: ±0.075% FS (@ 20°C).
可调范围: 100:1 turn down.
稳定性: ±0.125% FSO/yr.
温度: Process: -40 to 248°F (-40 to 120°C); Ambient (without LCD): -40 to 185°F (-40 to 85°C); Ambient (with LCD): -22 to 176°F (-30 to 80°C).
压力: Max. pressure: Range: -14.5 to 2000 psi; Burst pressure: 10000 psi.
热效应: ±0.125% span/32°C.
电源: 11.9 to 45 VDC.
输出: 4 to 20 mA/HART? Communication.
响应时间: 0.12 seconds.
缓冲时间: 0.25-60 seconds.
环路电阻: Operation: 0 to 1500 Ohm; HART? Communication: 250 to 500 Ohm.
连接: Two 1/2" female NPT conduit.
过程连接: 1/4" female NPT.
显示: Optional 5 digit LCD.
封装: NEMA 4X (IP66) and explosion-proof for Class I, Div I, Groups A, B, C and D.
重量: 8.6 lb.
认证: CE, FM.
型 号 |
规 格 |
3100D-1-FM-1-1 |
Smart differential pressure transmitter, range 0.302-6" w.c. |
3100D-2-FM-1-1 |
Smart differential pressure transmitter, range 0.6-30" w.c. |
3100D-3-FM-1-1 |
Smart differential pressure transmitter, range 1.5-150" w.c. |
3100D-4-FM-1-1 |
Smart differential pressure transmitter, range 7.5-750" w.c. |
3100D-5-FM-1-1 |
Smart differential pressure transmitter, range 1-100 psi. |
3100D-6-FM-1-1 |
Smart differential pressure transmitter, range 3-300 psi. |
3100D-7-FM-1-1 |
Smart differential pressure transmitter, range 10-1000 psi. |
3100D-8-FM-1-1 |
Smart differential pressure transmitter, range 30-3000 psi. |
3100D-9-FM-1-1 |
Smart differential pressure transmitter, range 60-6000 psi. |
备注:可选带-LCD显示
附件:
型号 |
规 格 |
A-630 |
316SS angle bracket with bolts. |
A-631 |
316SS flat bracket with bolts. |
