深圳市德威达科技有限公司
  • Mercoid PG系列差压开关
  • 发布时间:2010/6/12 16:07:01   修改时间:2010/6/12 16:07:01 浏览次数:995
  • 产品名称:  PG系列 气用微压/微差压开关
    产品型号:  PG
    可调可视设定点刻度
    特点:大膜盒,高灵敏度,外部可视刻度可调,快动或水银密封开关,被列入ULFMCSA清单
    介质:空气及相容气体
    可调范围:250-7500Pa 3.5-35 KPa
    工作温度:0-82.2
    额定压力:不能超过最大的可调工作压力范围
    接点容量:SPDT4A/120VAC, 2A/240VAC,SPST6A /120VAC, 3A/240VAC
    安装方式:垂直
    尺寸:177.8X101.6mm
    重量:3.4Kg
    选型表:
    型号 范围 最大死区 开关类型
     PG-153-P1 1-30" water (.25-7.47 kPa) 1.9" w.c. (0.47 kPa) SPDT Mercury
     PG-153-P2 0.5-5 psid (.03-3.45 bar) 0.4 psid (0.38 bar) SPDT Mercury
     PG-3-P1 1-30" water (.25-7.47 kPa) 1.3" w.c. (0.32 kPa) SPST Mercury1
     PG-3-P2 0.5-5 psid (.03-3.45 bar) 0.3 psid (0.21 kPa) SPST Mercury1
     PG-7000-153-P1 1-30" water (.25-7.47 kPa) 4" w.c. (1.0 kPa) SPDT Snap
     PG-7000-153-P2 0.5-5 psid (.03-3.45 bar) .5 psid (.035 bar) SPDT Snap
     PG-7000-153HS-P1 1-30" water (.25-7.47 kPa) 4" w.c. (1.0 kPa) SPDT Hermetically Sealed Silver Snap
     PG-7000-153HG-P1 1-30" water (.25-7.47 kPa) 4" w.c. (1.0 kPa) SPDT Hermetically Sealed Gold Snap
    举例
    PG
    153
    P1 PG-153-P1 (Vacuum) (Pressure) (Differential Pressure) Control, fixed deadband, automatic reset, SPDT mercury switch, adjustable range 1.0-30" w.c. (25-760 bar). UL FM CSA
    结构
    PG
      General purpose enclosure, NEMA-1 (standard) UL FM CSA
    复位操作
    PR
      Manual reset, operates on pressure increase automatically, resets on decrease1 UL FM CSA
     PRL
      Manual reset, operates on pressure decrease automatically, resets on increase1  UL FM CSA
    封装选项
      W
      Weather-resistant enclosure, NEMA-2, 3R   FM CSA
      E
      Explosion-proof enclosure, NEMA-7, 9, Class I, Groups C & D; Class II, Groups E, F & G, includes drain, specify if for pressure, vacuum or differential pressure.
    电路(开关)
    选项
    (For Electrical
    Codes see Chart
    Below)
      SPST mercury switch, elect. code K?, opens on vacuum, pressure or differential pressure increase UL FM CSA
    2P
      SPST mercury switch, elect. code L?, opens on vacuum, pressure or differential pressure increase UL FM CSA
    3
      SPST mercury switch, elect. code K?, closes on vacuum, pressure or differential pressure increase UL FM CSA
    3P
      SPST mercury switch, elect. code L?, closes on vacuum, pressure or differential pressure increase UL FM CSA
    153
      SPDT mercury switch, elect. code M? UL FM CSA
    103
      DPST, two SPST mercury switches, elect. code L?, both close on increase, FM approved, PG, PGW only  UL FM CSA
    105
      DPST, two SPST mercury switches, one elect. code L?, one elect. code N, both open on decrease UL FM CSA
    127
      DPST, two SPST mercury switches, elect. code L?, both open on increase UL FM CSA
    129
      DPST, two SPST mercury switches, one elect. code L?, one elect. code N, both open on increase  UL FM CSA
    158
      SPDT, two SPST mercury switches, one elect. code L? - opens on increase, one elect. code N - closes on increase UL FM CSA
    161
      SPDT, two SPST mercury switches, one elect. code L? - opens on decrease, one elect. code N - closes on decrease UL FM CSA
    156
      SPDT, two SPST mercury switches, elect. code L?, one- opens on increase, one closes on increase UL FM CSA
    804
      DPDT, two SPDT mercury switches, elect. code M?
    (__)
      Other circuits available, consult factory
    7000
    153
      SPDT, snap acting switch, rated 15A at 120 VAC, 8A at 240 VAC, 0.5A at 120 VDC, .25A at 240 VDC (1)
    153HS
      SPDT, Hermetically sealed snap switch, rated 5A at 125/250 VAC, 5A resistive at 30 VDC UL
    153HG
      SPDT, Hermetically sealed gold contact snap switch, rated 1A at 125 VAC, 1A resistive at 30 VDC UL
    7200
    804
      DPDT, two SPDT snap acting switches, rated 5A at 120/240 VAC, 30 VDC resistive (1)
    可调压差范围
    P1
    Adjustable range 1.0-30" w.c. (25-760 bar), maximum sustained pressure 2 psig* (0.14 bar) UL FM CSA
    P2
    Adjustable range 0.5-5 psig (.03-.35 bar), maximum sustained pressure 10 psig* (0.69 bar) UL FM CSA
    * Maximum sustained pressure 15 psig (1.0), maximum surge limit 20 psig (1.4), both ranges when used as single pressure switch with low pressure port vented to atmosphere.
    1   7000-153 and 7200-804 not available with PR or PRL manual reset.
     ? See Electrical Rating Chart Below.
    ELECTRICAL RATINGS - Mercury Switch
    CODE
    RATING AC or DC
    K
    6A at 120 V, 3A at 240 V
    L
    10A at 120 V, 5 A at 240 V
    M
    4A at 120 V, 2A at 240 V
    N
    1A at 120 V, 0.5A at 240 V
美国德威尔(Dwyer)仪器仪表授权中国代理——深圳市德威达科技有限公司深圳市德威达科技有限公司 (Shenzhen Deweida Technology Co., Ltd.)是从事自动控制系统开发和仪器仪表等机电产品销售的高科技专业公司。 公司人员有着多年的工业自动控制和楼宇自动…  更多>>
深圳市德威达科技有限公司
联系人:刘生
地址:深圳市福田区深南中路南侧南光捷佳大厦2001
邮编:518033
电话:0755-83692627,83692637,83692695
传真:0755-83692660
公司网址:http://www.szdwd.com
  • 韩先生 在2013/5/22 14:48:00留言
  • 详细留言:GFC-1144 供货及附件清单 价格
  • 韩先生 在2013/5/22 14:46:00留言
  • 详细留言:GFC-1144
