设定点及死区可视可调,防爆
用途:化工、石油、食品、医药等工业特点:室内外安装、防水防爆设计范围:0.7-10/1.4-17.2/2-34bar等多种规格工作温度:-35-+82°C最大过压:瞬间206bar,过程82.6bar连接:1/4"或1/2"NPT设定:现场可调尺寸:188X101mm重量:1.59Kg
选型表:
举例 SA11 13 E A 4 K 1 SA1113E-A4-K1 Pressure Control; weatherproof, NEMA 4X,explosion-proof NEMA 7&9; aluminum pressure chamber, Buna-N diaphragm and O-ring; 1/4" female NPT process connection; adjustable deadband; automatic reset; SPDT snap acting switch; adjustable range 30-500 psig. 结构 SA11 Series Designator, weatherproof NEMA 4X, explosion-proof NEMA 7&9. 可调范围 11 Adjustable range 10-150 psig (0.7-10 bar) 12 Adjustable range 20-250 psig (1.4-17.2 bar) 13 Adjustable range 30-500 psig (2.0-34.0 bar) 开关(Switch) E Snap action switch rated 15 A @ 125/250/480 VAC, 1/8 HP @ 125 VAC, 1/4 HP @ 250 VAC, 1/2 A @ 125 VDC resistive, 1/4 A @ 250 VDC resistive HS Hermetically sealed snap action switch rated 5 A @ 125/250 VAC, 5 A resistive @ 30 VDC* HG Hermetically sealed snap action switch with gold contacts rated 1 A @ 125 VAC, 1 A resistive @ 30 VDC* 压力腔材质(Wetted) A Aluminum B Brass S 316 SS 膜盒材质(Wetted) 4 Buna-N diaphragm and O-ring 5 Fluorocarbon diaphragm and O-ring 开关类型t (Switch) K SPDT L DPDT (not available with HS or HG switch options) 连接 1 1/4 inch female NPT 2 1/2 inch female NPT 可选项 DRAIN Housing with drain - allows condensate to be drained from inside enclosure (meets NEMA 3R instead of 4X) ATEX ATEX Certified Construction
联系人:刘生
地址:深圳市福田区深南中路南侧南光捷佳大厦2001
邮编:518033
电话:0755-83692627,83692637,83692695
传真:0755-83692660
公司网址:http://www.szdwd.com
